View Full Version : C1 & C2 Corvettes
  1. Frame VIN Stamping Question
  2. Owned this C1 for 17 years yet dont know what I have
  3. aluminum radiator Q
  4. fuseable link
  5. Does anyone know where I can find brake booster mounting brackets?
  6. Has anyone ever broken a SB400 crank? I have, on the 56!!!!!!!!!!!!!
  7. turn signal activiation cam
  8. Where to get 60 moulding pieces?
  9. How to protect new paint job
  10. to devildog
  11. Warm motor starter heat soak?
  12. How well do you know engines by sight?
  13. 59 seat tracks-frozen
  14. condenser looking thing
  15. Cast iron PG leaks
  16. OT-want a Jaguar and 30's Ford education
  17. Speedo issue....
  18. rear brakes 63
  19. 1964 muncie 4 speed
  20. Engine rebuild or just head rebuild
  21. I think I will buy 2 of these
  22. March for Heroes II to support The Military Order of the Purple Heart
  23. Flint vs Tonawanda block ?
  24. hesitiation question
  25. hesitiation question
  26. Insulation opinion needed
  27. **** St Jude Auction #16 Autographed Dan Marino--Path to Glory--HOF Enshrinement
  28. 65 Front Sway Bar Bushing Question
  29. Denver Newbie
  30. head light micro switch, dash coil
  31. Correct Casting #'s for 66 L79 ?
  32. 1966 Radio Delete
  33. 66 F41 427 Front Coil Springs
  34. NW Houston BIOYA competition
  35. First impressions
  36. First drive with the 3.08 and T-10 in the 59 today
  37. A different Grand Sport Paint Scheme
  38. parking light/turn signal harness
  39. Protect-o-Plate Question
  40. 66 replacement carb/ 300hp pg
  41. What plugs after upgraded electronic Dist.
  42. 383 or 454
  43. March Madness Sale - Cooper Corvettes
  44. Combo price for (2) 61's?
  45. L72 427/425 HP clutch disc diameter
  46. 1958 air cleaner
  47. Tremec TKO leaking at Speedo Cable
  48. Exhaust Sitting Low In Crossmember (TKO 500)
  49. Mac ET985 Balance Tester Manual Needed
  50. soft top installation cost??
  51. Inspector/appraiser help
  52. What Happened to the Pictures?
  53. Factory 60 radiator sufficient?
  54. National Corvette Museum Insurance Agency Launches New Site!
  55. took my vette out for a cruise yesterday
  56. 53's ONLY
  57. 67 seat recondition
  58. Videotaping Can Get You In Trouble
  59. is this worth anything
  60. C-1 seat belt attachment method?
  61. worn 4 speed linkage?
  62. 67 Rear Brake Caliper Question
  63. 67 Rear Caliper Question
  64. HFT battery float charger
  65. winter nationals in Orlando
  66. Will this flatten out ?
  67. Indexing spark plugs
  68. 60 Valence removal
  69. 3970010 Block
  70. 1964 convertible frame question
  71. '66 VIN 25840; Anyone know the owner?
  72. Flamethrower Coil
  73. Progress on the 30 year old 66
  74. Brake Caliper Halves Torque
  75. 63 Electrical Issue
  76. Mike Terry's 1954 Corvette
  77. "It's alive!"
  78. Master cylinder date codes
  79. Sidepipe help needed
  80. Quick answer please -- Setting intial timing
  81. Found Source of Afterfire..Now another problem
  82. 1963 AM/FM Delco Radio Volume Control
  83. Softtop Rear Latch Rebuild Question
  84. Winter Ride Portland Headlight
  85. Houston engine builders
  86. Rear Quarter Panels
  87. Grand Sport Replica Decals
  88. Anyone good with Holly carbs
  89. 62 Door post hardware question
  90. Wheel Size for Street Shop Frame with Wilwood Brakes
  91. Oldest Vette for your Year
  92. My Rock Auto MOOG parts experience.
  93. Do Car Makers
  94. Getting tired
  95. fuel filter on a C 1 opinion
  96. 54 Vette rolling home Test posting pic
  97. Why Did I Sell That
  98. Triple black C2 pictures ?
  99. Old car brochures
  100. help with 67 back-up light switch
  101. Softtop Blow out Sale is Back! 1956-1967 and 1968-1975!
  102. Swat meet stuff
  103. Still stuck ignition tumbler
  104. Amp guage Question
  105. Midyear soft top weatherstrip.
  106. C1 versus C2
  107. Pic Needed - Headlight Support Rods
  108. 427 crank shaft
  109. Modified C1 Photo Thread!!!!
  110. Lets try a 53 to 55 photo tread
  111. want to see what I've been up too?
  112. Finally
  113. Finding owner of C2
  114. 66 door handle replacement
  115. C1 console u-nuts
  116. 63 photo thread
  117. 67 photo thread
  118. Navy Wings and more of the story
  119. L79 Distributor
  120. fuel filter mounting bracket stud - L79
  121. Rear Brake Light not working
  122. Stroker longblocks?
  123. John Z, need an opinion on a rearend casting/assembly dates
  124. Help Needed: where to plug PW harness into fuse box?
  125. 1967 Interior/ragtop question
  126. 63 coupe door seal
  127. Paint prep question 58
  128. 383 Stroker Suggestions.....
  129. want to switch from PG to 4spd auto
  130. 59 hardtop trivial persiut question
  131. Pro and Con of lending your car to NCM for year or so?
  132. c2 big tank
  133. Exhaust system questions
  134. SWC rear suspension.
  135. Its Friday:Time for a smile
  136. 1963 Fuel Gauge or Sender Problem
  137. Picture of 1958 brass fitting for filter, please?
  138. Posting pictures
  139. Corvettes on woodward food drive & cruise 2011
  140. 62 clutch fork with a later bellhousing for a muncie
  141. '64 photo thread.
  142. Holley 4160
  143. 1960 Torquoise --what do you think?
  144. 65 Photo Thread
  145. J56 Heavy Duty Brakes
  146. 63 engine codes
  147. Best option for alternator
  148. Project 396: Got color!
  149. Headliner Problem
  150. Do you still look?
  151. Source for 12-13" racing steering wheel for 67?
  152. Vintage Air
  153. Wich of these cars would you buy in addition to your C2?
  154. 63 Muncie, Latter Bellhousing ??
  155. Pilot Bearing 327
  156. Inspection needed Seattle,Wa. area
  157. Looking for C2 knowledge in San Antonio
  158. C2 Fiberglass Tonneau Cover - Ever see one?
  159. Frozen Caliper Bleeders
  160. 61 rear wheel size
  161. '63 to '64 - Why So Many Changes???
  162. taking my 66 body off question
  163. What mods have you done that would make an NCRS judge curl into the fetal position?
  164. 1967 Corvette VIN Numbers.
  165. New member
  166. Who sells a 65 Washer Pump Solenoid
  167. 2x4 clone carbs on ebay
  168. Anyone wonting to save a few $$$$ C1
  169. crack repair for 67 wheel-who is the best
  170. C1 shift nob $$$
  171. Grand Sport Front Suspension
  172. body id plate in cowl area 63 swc?
  173. 66 front coil spring
  174. 1961 Hardtop & Deck Lid
  175. Racetrack door trim
  176. Clutch/Brake Peddle Assembly
  177. Meet Me in St. Louis - Engine stamps
  178. ground straps on accellerator rod big block
  179. Ignition Switch Light
  180. A final word on '56-'62 wiper transmissions
  181. L79- 65 ignition coil
  182. Axle vent difference between posi and non posi ?
  183. 1954 Early Vette Question
  184. Cost of Frame and Suspension Restore
  185. motor mount washer ?
  186. A loan shark has my dream car!
  187. 66 photo thread
  188. Apology
  189. Battery gauge test ???
  190. My 1962 Michigan Barn Find Update
  191. Number of '67's with Tuxedo Black and Saddle interior
  192. Riding with Private Malone, song and video
  193. 62 340 horse pulleys
  194. Rag Joint Replacement
  195. C2 Clock bezel removal
  196. Driver's side headlight is stuck
  197. Need tranny expert advice
  198. Please advise
  199. Aftermarket intake manifolds for a C1 - Fitment for a C1
  200. Since I'm pulling the motor
  201. Just changed my motor mounts...
  202. Birdcage Exam
  203. She Begged Me For a Ride...
  204. 67 Speed Minder Needle Color
  205. kellyw66 please read
  206. Chevrolet windshield washer coordinator
  207. Stan's Headers in a C2?
  208. Uneasy feeling
  209. Does this seller really believe this
  210. 1966 L72 Convertible Restoration
  211. dist rebuild
  212. 65 L79 Prelube & Zero Lash Questions
  213. Rears with lower than 4.11:1 ratio!?
  214. Repro knock-off wheels for 1963.
  215. Vent window frames
  216. Any Miami FL members???
  217. 1962 Production Number
  218. Disc brake upgrade and what about the park brake
  219. A6 A/C compressor oil sheild
  220. NCRS membership?
  221. Clutch_Pressure Plate Asm Orientation to Fly Wheel
  222. Looking for relieable installer of 5 speed in MD
  223. Ncrs
  224. Heater Blower Motor Troubleshooting
  225. engine Id help
  226. 66 alignment
  227. Front clip install photo needed
  228. 63 SWC Question re. felt & vent window rivets
  229. Grand Sport Wheels ?
  230. Web site
  231. Phosphating anyone???
  232. Dropping off heads at machine shop...
  233. Installing stainless trim on my 65 Coupe
  234. convertible windshield stainless trim
  235. Big $$$$ for a real part C1
  236. Increasing rear toe
  237. Finding Non-Ethanol fuel
  238. May 15 1965 f/s not mine
  239. C 1 carbs 2x4
  240. Steering Wheel Close
  241. Opinions on this?
  242. OT Packers Steelers
  243. Wiring meltdown - almost burned the 66 coupe
  244. Quartz clock install
  245. 1961 VIN tag, when placed on column during assembly?
  246. C1 Body Droop Remedy
  247. harmonic balancer spacer 62
  248. Rathmann mid year corvettes
  249. grounding straps
  250. I always wanted a big block mid-year Corvette....
