View Full Version : C1 & C2 Corvettes
  1. Coupe Door Glass Removal
  2. repainting c1 rims
  3. DMV problem
  4. "Early or Late '63"
  5. SWC power windows
  6. Should I add electric fans
  7. getting the interior ready for body removal
  8. Power brake conversion
  9. 1966 Dash Knob Restoration
  10. 1959 Resto-Mod Corvette Need Fire Extinguiser Bracket/Mount
  11. Trunk question (Crazy)
  12. 65 396 paint progress
  13. Grand Sport Video's
  14. Grand Sport on Ebay
  15. Darn phone !
  16. Going rate on a '61 Hardtop?
  17. 1954 blue flame engine pain in the
  18. 7 Corvettes Destroyed
  19. E15 Gas
  20. 80 Degrees in Houston...AND LOVING IT!
  21. Steering Column
  22. Problem with my glass
  23. gotten over the BB fever yet????
  24. Anyone using clear floor mats
  25. 62 Differential date question
  26. 67 telescopic steering locking?
  27. AutoPartsDealer.com BUYER BEWARE, STAY AWAY FROM!!!
  28. 1966 Sting Ray Garage Find - need help identifying
  29. Couple color questions
  30. '61 disc brake conversion - parts question
  31. Paint or not to paint fiberglass undercarriage bottom
  32. 1967 help
  33. Determining cars build date/birthdate
  34. 'New Zealand's darkest day': Quake kills dozens
  35. Need To Rebuild or Replace Your OEM Motor?
  36. Need Advice
  37. 63 Gas Tanks
  38. Carb Identification
  39. shimming the pressure plate out from the flywheel
  40. Speaker cloth
  41. 427 vs 454
  42. Oil Pump Bolt
  43. Reinstalling drivetrain in '65 SB
  44. can I use any tach drive distributor?
  45. Anderson Motor Co Marietta Ga: I am looking for original Owner
  46. 62 Fuel gauge
  47. Which Optima Battery to use?
  48. Side Pipe covers
  49. Austin, Texas Area Appraiser?
  50. 59 Valence Panel - what is the factory correct bolt for this location?
  51. Stalling on start
  52. Scary
  53. Holley dates
  54. need pics of a Gray/White 59 vette
  55. 53-55 Corvette design
  56. 64 trailing arms.
  57. Car cover vs Garage
  58. Building a 1111087 Distributor
  59. Shop that knows C1/C2 vettes in Norther Virginia?
  60. Nice Corvette Display
  61. What is going on here?
  62. wiring harness support underneath header bar
  63. radio antenna cable connector
  64. Is it worth trying to find a 3/4" sway bar?
  65. Craigslist Notification site
  66. Ramjet 350 knock sensor clearance, headers
  67. 63 window help
  68. How would you fix this: Fiberglass experts
  69. 66 Heater Core
  70. Steering Column Doc
  71. ~~~~ St Jude Auction #18 Chris Reeve Small Sebenza 21 knife with bloodwood inlays
  72. Need help
  73. painting C2, finally! Bead Blast or soda blast
  74. Location of VIN on frame
  75. OT: Let’s talk about Hip Replacement
  76. Who has had good experience plating KO spinners?
  77. 1966 Brake Light Switch and Bumper Stop Bracket Gone
  78. Gas Prices
  79. Headlight wiring
  80. Need help - male hood lock pin
  81. Livin's 57 Corvette.."First Body Off Restoration Progress Report". PAINTED!!!
  82. '67 SB Coil Springs revisited
  83. c 1 rims
  84. getting to visit family 60 vette after 30 years
  85. 61 radiator support removal
  86. rim colors c1 1961
  87. crossmember measurment
  88. 67 steering shaft
  89. Headlights adjustments...
  90. C1 Tie Rod install
  91. '64 clutch pedal shaft
  92. only on ebay...
  93. Jackfit Sighting Today
  94. 62 Carpet question
  95. Battery power loss
  96. Are Replacement Seat Belts Legal?
  97. Richmond Trans & Rear Gear Ratio
  98. Interchangeable steering parts for 63
  99. 66 L-72 listed on Houston Craigslist, plus 58 2x4 shortblock
  100. 1964 tyre question
  101. 62 exhaust
  102. car quiz
  103. 65 all thread front spring compressor
  104. Quick Steering Adapter
  105. Sunday Funnies...........
  106. changed plugs yesterday
  107. Plug wires w/ 90 degree dist cap terminals
  108. Lower reveal moulding Install
  109. I almost made it.
  110. Fresh L79
  111. Fire Extinguisher?
  112. Windage tray bolts
  113. how many 67 red interiors
  114. 1959 Steering Box
  115. Al Knoch Seat Covers
  116. j56 BRAKES HELP!!!!!!!!!!!!
  117. Shocks -- KYB vs Bilstein
  118. 46th Birthday
  119. 65, Black/black air coupes raise your hands
  120. B/B Hood grill baffel
  121. Non Ethanol fuel
  122. Another project completed.
  123. The Exploding Starter
  124. C2 Unnamed Body Mount Location
  125. lower ball joint install on a 65?
  126. Gas tank removal
  127. Radiator removal 56
  128. Sun Visor falling down gradually.
  129. headlight motor female wire connector
  130. Seat belt safety question....
  131. Is Corvette Specialties doing resto work yet?
  132. more power
  133. Is my upper control arm shaft bent?
  134. Pilot Bushing installation 64 327
  135. lower front valance panel (C2) - blackout?
  136. Delusional or what?
  137. Anyone using the 9" slimline power booster ?
  138. How to tell if car is a real heater delete?
  139. Marlboro Maroon--u like?
  140. Any know a website to find good corvette help
  141. 63 steering box question
  142. Radiator Shroud Bracket Fix??
  143. Picture request..tires on green corvettes
  144. Figured out key tumbler
  145. M20 65 vs. 66?
  146. Will I fit into C2 coupe??
  147. plug wires on runnin bad 327/300
  148. radio speaker paint
  149. Holley 4150?
  150. Do you know of this vette?
  151. Where is Frank ??
  152. Who has the best avatar?
  153. R&R half shafts...what do I need to know?
  154. Tack Drive Distributor?
  155. Can someone identify an engine for me
  156. Friday Funnies
  157. Headlight Support Rods
  158. Christian Corvette Club
  159. Anyone have a knee replacement?
  160. How Do You Tell an original 427 Car?
  161. Pls Identify My C1 Caliper
  162. 67 block date & pad date
  163. Transmission fluid at speedo head?
  164. 67 ps pulley nut
  165. Parking Ticket Please...
  166. 1963 Master Cylinder Question
  167. All American Lifts Closing Mar 1st.
  168. 1965 Glenn green coupe history
  169. Outer Headlight Pivot Questions
  170. Corvette owner history question
  171. 1963 Console-side kick panels
  172. I am looking for information about Newman Differential Housings
  173. looking for 1966 vin#194676s104290 engine block
  174. emergency brake light
  175. Where some of the Corvette and other USA iron ends up
  176. 61 corvette that was for sale for 30 minutes
  177. 66 conv. door adjust
  178. 63 Wont Start
  179. Best ever racing Commercial
  180. Valve cover flaw, can it be removed?????
  181. Original shape of ignition tumbler for a 58
  182. need Help with number on 67 l88 carb metering block stamp
  183. Webber carb rebuild
  184. 1967 shifter throw too far rearward II
  185. Hotel info corvettes on woodward
  186. Wiring Harness Tape
  187. diaphragm pressure plates - straight & bent finger
  188. engine won't idle right
  189. 7" dual power brake booster.
  190. Ebay rip
  191. 327/300hp at, runnin real bad!
  192. I met a serial SWC-killer today...
  193. Exhaust Passages???
  194. Need picture of front spindle/knuckle
  195. Overhauled an A6 Compressor Today
  196. 65 Front Sway Bar Question
  197. Channel Guns & Roses in Slash's 66BB
  198. They need to make one of these for the C2
  199. 427-435HP "Engines" worth
  200. Bobby Alloway @ Cobo Hall, Detroit
  201. Iphone corvette app.
  202. Phone corvette ap
  203. 1967 shifter throw too far rearward
  204. Wtf??
  205. seat belts restored
  206. Knockoffs/rallys
  207. Does your 58-62 clutch fork have a dust boot on it???
  208. Tucson Corvette Specialist - C2?
  209. Circuit breaker size?
  210. New Superformance GS to be in Detroit
  211. head light switch removal
  212. Frame VIN Stamping Question
  213. Owned this C1 for 17 years yet dont know what I have
  214. aluminum radiator Q
  215. fuseable link
  216. Does anyone know where I can find brake booster mounting brackets?
  217. Has anyone ever broken a SB400 crank? I have, on the 56!!!!!!!!!!!!!
  218. turn signal activiation cam
  219. Where to get 60 moulding pieces?
  220. How to protect new paint job
  221. to devildog
  222. Warm motor starter heat soak?
  223. How well do you know engines by sight?
  224. 59 seat tracks-frozen
  225. condenser looking thing
  226. Cast iron PG leaks
  227. OT-want a Jaguar and 30's Ford education
  228. Speedo issue....
  229. rear brakes 63
  230. 1964 muncie 4 speed
  231. Engine rebuild or just head rebuild
  232. I think I will buy 2 of these
  233. March for Heroes II to support The Military Order of the Purple Heart
  234. Flint vs Tonawanda block ?
  235. hesitiation question
  236. hesitiation question
  237. Insulation opinion needed
  238. **** St Jude Auction #16 Autographed Dan Marino--Path to Glory--HOF Enshrinement
  239. 65 Front Sway Bar Bushing Question
  240. Denver Newbie
  241. head light micro switch, dash coil
  242. Correct Casting #'s for 66 L79 ?
  243. 1966 Radio Delete
  244. 66 F41 427 Front Coil Springs
  245. NW Houston BIOYA competition
  246. First impressions
  247. First drive with the 3.08 and T-10 in the 59 today
  248. A different Grand Sport Paint Scheme
  249. parking light/turn signal harness
  250. Protect-o-Plate Question
