View Full Version : C1 & C2 Corvettes
  1. Pauly want to fly here is 1 for U
  2. Low mileage mid-years
  3. Question about "Seat belt buckles for a 66"
  4. fuel line replacement
  5. Turn Signal Activation help
  6. IPG gasket
  7. mid year roll overs
  8. 67 391 heads/on 454 block?
  9. oil pan removal on 67' w/power steering
  10. Loose Mirror
  11. Lower springs for the front of a '56 ???
  12. 1961 Corvette Clutch Height Help
  13. 1962 Starter questions
  14. Level of difficulty to recover a midyear soft top?
  15. Holley-how to fix stripped threads
  16. what brand to buy for front wheel bearings and seals for a 65?
  17. Distributor Cap ID
  18. Route 66
  19. 65 bb
  20. Electrical connector post
  21. C1/1960 Hardtop Restoration
  22. 1958 Could use votes for car of the month on Cool Rides Online
  23. 66 427 oil pan question
  24. Upholstery Shop in North Carolia
  25. Smoking ballast resistor
  26. I finished putting in an aftermarket wiper kit
  27. C2s and the Texas Mile.... Anybody do it?
  28. Ebay selling percentage
  29. 63 340hp rebuild
  30. Hard top rear window refurb cleaning
  31. Transmission ID
  32. 1968/1969 Dealer #218, Zone 10
  33. Package tray divider, welded?
  34. 1965 327 Flywheel
  35. Restored Cluster and Clock arrived today
  36. Electric fan on battery or starter?
  37. 1961 Corvette Heater Core Bypass
  38. C1 converible top straps
  39. Speedometer lag
  40. Ride Height.
  41. Sunshine State Solid Axle Event
  42. Lost power, rough run
  43. HotRodAir Conditioning
  44. Idle to stall.
  45. Electrical Problems - I Can See A Whif Of Smoke!
  46. 66 red line tires ???
  47. Good day for a ride
  48. OK - Follow-Up on the Alternator Thread - U Joints
  49. Headlight Motor Armature bushing
  50. '56 body on a '59 frame
  51. Arizona tax on old Vettes?
  52. 66 427 Engine Pictures
  53. Best brand of bearings for R&R?
  54. trailing arms, bairs / van steele
  55. C1 or C2 wing nut original??
  56. Kool April Nights
  57. 67 BB Evaporator mounting bolts
  58. blue side wall
  59. ANyone have time to Inspect a C2 in Mankota, MN ???
  60. New Distributor Install - 65 L79
  61. c 1 2x4 and intake troubles
  62. Close call with one of my worst fears
  63. C2 Restoration guides
  64. interior question for a 65
  65. Spark plug wire orientation #2 & #4 wires
  66. L79 advance curve problem
  67. 58-62 Corvette restomod A/C vent ideas/pix
  68. do soft tops shrink if not used?
  69. headlights flicker - turn lamps flicker in response??
  70. Two non related questions/observations on my 59
  71. Question about Differentials in a Grand Sport
  72. My '64 is 47 today!
  73. Parking lamps
  74. Wet Alternator Question
  75. C2 vs C3 Handling
  76. Trick Flow Heads - Damper Spring Failure
  77. spaed connectors
  78. Battery for 67 factory air
  79. Question for Tom Parsons
  80. Rear leaf springs for 62
  81. Anybody bought these?
  82. ralley wheel code
  83. Opinions Welcome: 63 Vert Resto Mods
  84. flywheel help
  85. '63-'64 front emblem placement
  86. Have Ebay rates gone up?
  87. Lash hot vs cold?
  88. Recommend header gasket
  89. Big Block in a C1 information
  90. Heater Hose Bracket on A/C Compressor
  91. 64 first drive after frame off. Pics
  92. Opinions on This C2 For Sale
  93. need pic. of 65 fuel line.
  94. Beware of Timken Wheel Bearing Seals
  95. Orange County, CA recommendation for Corvette mechanic
  96. 1966 corvette rear exhaust tail panel
  97. L-79 Head specs
  98. 44 yrs 19 days it is born again!
  99. D&M Restorations in SC
  100. Side pipe restoration
  101. This is very Sad...
  102. Bb question
  103. 53-55 Headlight screens
  104. 1961 PG to Manual 3-speed How To?
  105. exhaust manifolds
  106. 30-30 CR too low?
  107. '61 Parking Light Pigtail Socket Install
  108. Whereabouts of my '59??
  109. CA...Cost just might go up on new cars
  110. Master Brake Cylinder Bleeding, Again
  111. 62 dash/brake light problem
  112. Am I crazy for even thinking about this
  113. " it's friday, time for a smile"-vicz
  114. Hoping everyone is Ok in Hawaii after Tsunami
  115. 1954 ORIGINAL WHEEL / Track
  116. Classic (pre-1970) drag races Navasota TX
  117. 63 vert
  118. 1958 Tire board need measurement for the hand cut out.
  119. Need help with vibration
  120. My '66
  121. Coupe Carpet Question
  122. Not sure if this wheel/tire combo will fit
  123. 65 365hp hard to start
  124. vette pack sidepipe mufflers
  125. Corvettes at Myrtle Beach
  126. rewiring my 61
  127. C1 steering box questions.
  128. pulling steering wheel hub
  129. pictures
  130. Not a C2 but when this happens
  131. Demon Tri power
  132. Recommendations for clock repair
  133. 66 door lock install
  134. Wiring mess
  135. Polly or Rubber ?
  136. 1965 Vette Coupe Restomod build: Phase 5 – Body Mods to Fit SRIII Frame
  137. Great article on 57 Sebring
  138. 2x4 idle mixture settings
  139. How do you handle test drives?
  140. 1966 427/390 Chassis Dyno results
  141. tach cable-1967
  142. Power Valve Adjustment - 67
  143. 1962 back yard find
  144. 1966 L79 Valve Covers
  145. front/rear springs
  146. photos?
  147. Opinions on this C2 for Sale
  148. 283 Oil Pressure
  149. c2 tailpipe position question??
  150. If You Want $130,000 for Your Car, Shouldn't You Be Able to Afford a Decent Camera?
  151. U joint lubing
  152. Web site help
  153. 65 fuel line?
  154. Would you drive your vette in the snow?
  155. Pee Wee Wallace passes at age 79
  156. Solid or Hydraulic?
  157. 67 roadster door
  158. OT: When racing was dangerous... really dangerous
  159. Anyone around Houston area that would sell,rent, let me borrow a body dolly.
  160. Drivetrain durability
  161. conical vs shank lug wheels
  162. Getting orginal owner info
  163. anyone have/used the HFT boroscope
  164. Wiper motor and Painless wiper switch??
  165. Durability Plus Engines
  166. >>>> St Jude Auction #23 STOP!!! Rotors and Pads Winners choice C2-C6 <<<<
  167. 67 Differential Question
  168. Dyno Video
  169. She's 46 Years Old Today!! How About That!
  170. Welcome to is it savable... the next contestant BUMPERS
  171. '66 steel wheel
  172. Choosing the right gear for a 1964 Grand Sport
  173. TI Distributor
  174. 63-64 master cylinder question ???
  175. C1 rear disc Brake Kit supplier?
  176. '65 Corvette/Holiday Inn/Cigarette
  177. Exhaust Maniford # what it fit?
  178. Looking for someone in Lahabra Calif.
  179. 1961 Wiper Coordinator question
  180. Engine Codes
  181. '61 FI Total Timing Specs
  182. 67 Front to Rear Brake line
  183. Ballast Resistor Ignition Circuit Article
  184. Good source for aftermarket parts
  185. Power window motor parts
  186. 67 BB--Scared???
  187. Power Door locks
  188. 67 Tank Sticker ?
  189. O-rings for caliper piston seals - how does this work?
  190. C1 capacitor question
  191. C2 Headlamp Problem
  192. Need front C2 turn signal connectors w/pigtail
  193. Anybody had dealings with Ididit steering Columns
  194. 62 striker plate????
  195. 67 tank sticker wrong numbers
  196. Quick (dumb?) question about repro knock-offs...
  197. St Jude Auction # 22 Yellow Yellow Yellow GREEN!
  198. Corvette Appreciation Day
  199. Insurance - Different Twist - What about Kids?
  200. World of Wheels/Chevy Vette Fest pics
  201. Stock looking non-stock engine pictures
  202. 67 tank sticker zone
  203. Correct fuel line from Carb to fuel pump
  204. Anyone near ATTLEBORO, MA who can look at a C2 for me?
  205. Two 63 Corvettes At Ohio Estate Auction Tuesday
  206. 2011 Corvettes on Woodward Bloomfield Hills, Michigan UPDATE
  207. Finned valve cover seam
  208. Vent Window frame for '65
  209. 62 door weatherstrip installation: Any tips?
  210. Engine number Help!
  211. Bonding front end
  212. What most resembles the 327 - 350HP HT engine
  213. garage empty?
  214. Help in contacting someone
  215. Opinions needed! Brake rebuild on a 1967 327
  216. Train load of C-2'S
  217. The battle of Man vs Bumper
  218. Chambered Under Car Exhaust
  219. Original finish question.
  220. "GLS" on 65 rear spring?
  221. 67 seat belt mounting bolt
  222. Rear tail lights problems!
  223. Help with identifying electrical connectors.
  224. Finishing Cluster Rebuild
  225. Anybody Know Why?
  226. Block drain plugs
  227. mid year (63) seat belt mounts
  228. Anatomy of a C2 Covertible Dck Lid Lock
  229. kick panel and windlace area
  230. Plug Wire Question
  231. What year differentials fit in a 65
  232. T-10 swap
  233. Question on roller cam and thrust button
  234. A Few Vettes - AutoRama in Utah 2011
  235. 58 Barn Find Sold Saturday
  236. Dot 5, Silicone
  237. Project purchase
  238. Steering column color
  239. Replacement windows
  240. 1958 garage find
  241. Bonneville speedsters at Pebble Beach....
  242. 65 Glass dates
  243. SS Caliper Rebuid - O Ring Conversion
  244. 60 fuel pump gasket leak ?
  245. 65 fuel line?
  246. Crate engine deal
  247. Is this a good transmission for a conversion?
  248. E Brake Alarm Light Question
  249. valve covers
  250. Removing casing from generator.
