View Full Version : C1 & C2 Corvettes
  1. 58/59 dash & upper door panel help!
  2. Taillight question
  3. Air gap Intake
  4. 454 head gaskets
  5. Parking Light Troubles
  6. Waking up from winter
  7. power antenna in 67?
  8. Where NOT to install Dynamat?
  9. Used power steering hoses
  10. Should I use these heads?
  11. 63/C2 Headlights won't work
  12. 1966 headliner color
  13. Bellhousing clutch question
  14. To the engineer charged with the responsibility of
  15. Rear end/differential ?'s
  16. OT, Civil war phot album
  17. 1966 Shifter Boot
  18. where my car came from
  19. question on heater hose replacement - '59
  20. Am I installing this correctly?
  21. Modifying Stock Tank for Injection
  22. Proud new owner
  23. Pedal assembly in a 66 auto
  24. Best 215x70x15 street radial?
  25. Brake Rotors and Pads
  26. Drag racing 1958 Detroit Nationals
  27. Can the entire vent window/side window assembly be rotated
  28. washer pump wiring harness ?
  29. Auto trans vs. 44 spd.
  30. Rear Grounding Point
  31. Ralley Wheels
  32. Tightening up my C2
  33. 67 Aluminum wheel starburst cap
  34. I'm looking for an oil fill tube w/PCV
  35. What are the most valuable C1s?
  36. Is my C2 a early or late manufactured car?
  37. Engine question C2
  38. No Tail & Stop Lights Yes Turn Sig. 62?
  39. What do you think of this block for my December 5`th built 64 coupe
  40. side pipe replacement
  41. 1966 date for early/late difference of A/C condenser upper inlet tube
  42. Buyin' rear end
  43. Differential cross member on a 66
  44. c2 outside window trim chromed or SS
  45. Correct sheen for rims
  46. Hanging Doors HELP
  47. Rebuild c2 headlight motors
  48. 1960 Vette front suspension rebuild problem
  49. Gear ratio change
  50. Will be in Myrtle Beach this weekend.
  51. 63 SWC Interior
  52. *** St Jude Auction #32 Autographed Corvette Racing T-Shirt ****
  53. Spal 16" electric fan swap opinions please
  54. Might be joining the mid-year club, need the new member kit...
  55. 16 vs 24 degrees Centrifugal Advance Range?
  56. Drive Shaft Markings/Finish
  57. 61 shifter plate
  58. '64-'67 console
  59. Tampa HOOTERS April 13th cruise in gathering 6pm-10pm
  60. Question for #'s matching 63 and 64 solid lifter cars
  61. wire connectors
  62. I need help clock removal
  63. new paint on 67
  64. divine spray 9
  65. Corvette Collection
  66. ballast resistor 67'
  67. Engine Stamp Dates
  68. C6 dual mode exhaust retrofit
  69. 67 tranny reverse switch
  70. mid year radiator support lower brackets
  71. muncie input shaft bearing
  72. Door Weatherstriping
  73. What's best to clean/ lube distributor parts?
  74. >>>> St Jude Auction #31 FORCE-CDI-IGNITION-BOX-2-STAGE-MULTI-SPARK-RL-2 <<<<
  75. WCFB Carb Adjust
  76. wonderbar radio
  77. '66 maroon color
  78. 1956 Vs. 1959 Headroom And Steering Column Differences
  79. C1 Brake Booster?
  80. FREE C2 dolly
  81. Temp sender torque in iron manifold?
  82. Pro Team E-bay sale items
  83. Muncie Side Cover Difference?
  84. Midyear hardtop assembly questions ????????
  85. What After market Stereo?
  86. Roadtrip!
  87. Need some opinions
  88. Barrett Jackson Saturday Pics
  89. Seat cover recomendations
  90. Stripping old paint from fiberglass Corvette
  91. Too nice today, had to cruise
  92. Maryland Corvette Spec....anybody know...
  93. Changing the G-90 Gas Filter..63 340 HP....
  94. Powerglide #'s
  95. 327/300 fuel pump pumping air
  96. Anyone have side pipes on thier 1958-1962?
  97. How high should my ceiling be for a lift
  98. Muncie Yoke Wear.
  99. What's a m20 worth?
  100. Chassis Lube problem
  101. No dash lights
  102. Tornado Protection Question
  103. Older car racing?
  104. Cruising
  105. Are all hard top carts similar?
  106. Birthday
  107. Looking for aftermarket FI air-cleaner
  108. build date question
  109. Got the car out today
  110. Corvette on Castle
  111. Undercarriage advise
  112. accept a friend ???
  113. Would you trade your C2 for a C6 Z06?
  114. B/j 66 omg
  115. Blue 65 on Memorial drive @ Sheperd about 5pm
  116. 67 Speedminder needs a new pointer !!
  117. One Thousand Miles and Going Strong...
  118. fuse/wire size for horn relay ?
  119. Need help with 67 clutch bracket ball?
  120. '65 327 w/Solids...The Beginning of The Best of Both Worlds
  121. Added a racing harness bar to my 67 roadster
  122. Road & Track June 1954
  123. Lower seat clip install - '66
  124. Vent window gasket on 67 convertible
  125. U joints
  126. Opinion needed
  127. Does anyone here use a Hein Werner floor jack?
  128. Opinions on My Side Pipe Plan ?...Best of Both Worlds
  129. Installing Repro KO wheels
  130. 66 Conv vent window regulator
  131. Is it the timeless design effect...?
  132. 65-66 Non-Power Brakes MC Gasket Cap
  133. For Those Who Think Flares Kill The Price
  134. Price check...'66 Coupe
  135. summer sun on seat in vert
  136. 1960 speedometer cable
  137. running a engine on a test stand voltage question
  138. Should a New Block be 'Seasoned'?
  139. C1 prices look encouraging at Barrett-Jackson
  140. White wall size for 61 ?
  141. Brake squeek
  142. How often do you wash your car with soap and water?
  143. Corvette Teak steering wheel
  144. 1967 Door Latch Mechanism
  145. Found that spare (T155/90-D16) I needed....
  146. Speedo help
  147. Best Place to for Reproduction Seat Belts
  148. L79 Machined Alt Pulley Weight?
  149. Barrett Jackson Pics
  150. 66 Posi Problem
  151. Has anyone tried the Dynomax VT mufflers?
  152. Friday funnies
  153. Corvette Forum Youtube Channel up and running!
  154. paragon lower windshield trim clips 65
  155. Car origin
  156. Screwed up! No oil pressure on start-up!!!
  157. From show car to driver
  158. 64 clock access
  159. Barrett Jackson
  160. Speedo problem
  161. If your looking for-
  162. Harmonic Balancer
  163. 61 Instrument cluster removal
  164. A question about tires...really old tires?
  165. Corvette Metel Emblem Signs!
  166. GM being sold to Chinese
  167. More wiring help needed on a 66
  168. Seatbelt solutions
  169. front nose mask
  170. Neutral Start Switch-62
  171. carb
  172. 63 center caps for 2-bar knock off
  173. CRAZY Dash panel lights blinking!
  174. Importing Car From Canada To US
  175. Fiberglass leaf in a 66
  176. 1970 Wiper Door Issues
  177. Transport recommendations please
  178. anyone have problems with Willcox C1 seat upholstery?
  179. Its in the details....
  180. Camshaft selection final update!
  181. glass date coding templates
  182. Generator question
  183. '59 To '56 C1 Parts Compatibility?
  184. bent exhaust valves on startup 327
  185. C1 PG owners
  186. Which side pipes to buy for a '65 SB
  187. Should I just get used to this?
  188. New pics and vids
  189. Car Birthday
  190. Vacuum Advance
  191. C1 seat belts
  192. New addition: '65 Fuelie Convertible
  193. Wiring Identification Help
  194. OMG- Keisler RS600 zero availablity- other options?
  195. Steel vs. Nylon shifter bushings in a '66
  196. C2 Windshield post bonding strip?
  197. Which way is up?
  198. Need help C1 read spring installation
  199. C1 Hardtop installed...most attractive color combo ??
  200. '64 Seats / seat tracks
  201. Need Advice About Rebuilding A Fuel Pump '66 327/350
  202. Anyone Seen Anything Like This??
  203. Hardtop Molding
  204. Front Spindle arm mount bolts
  205. '65 Air Vent control loacations
  206. keys for a 66
  207. 67 tranny reverse switch
  208. 1960 'vette renovation!
  209. Saw the 64 resto-mod in Dupont Registry today
  210. A/C in a 66
  211. 10 percent annual Federal tax on your collector car?
  212. 1971 LT-1 What is my axle ratio?
  213. Windshield replacement article c2
  214. Coupe rear window channel.
  215. RT. Wiper transmission on a 65 coupe
  216. A dream, true, Chip & Lance Miller, Corvettes of Carlisle, 50th anniv, 1st vette win
  217. Engine Paints
  218. need advice on C2's
  219. engine mounting question
  220. C1 master cylinder numbers ?
  221. 60 Corvette - Which way do seat belts go?
  222. ? about in line fuse
  223. C1 Automatic transmission conversion
  224. engine paint
  225. Leaking Heater Control Valve
  226. Help with tuning
  227. 63-67 Hard top rear window gasket question
  228. fuel regulator suggestions
  229. Hurst Comp + adjustment in a '66
  230. OT- Forum display issue - Firefox
  231. Fuel Pump rebuild help please
  232. replacement exhaust
  233. John Neas is taking 4 early Vettes to Joplin NCRS Regional
  234. Barrett Jackson
  235. The ultimate C1 fixer upper
  236. Vacuum Secondary Spring on a 66 L79?
  237. Dual points in 61?
  238. Shirts and hats for St. Judes
  239. ammeter harness continuity
  240. my 66 needs a ride
  241. Response on 65 Ad
  242. The 1958 Experience: A Purist's View
  243. Stock wheel for '63 Roadster
  244. Need wheel help for a Fathers Day present
  245. AIH Chrome, Dubuque Iowa?
  246. HEI Distributor Recommendations
  247. Should I rebuild a used power steering pump and cylinder
  248. Wooden gear shift knob
  249. "Battery Brain" remote battery disconnect with low-voltage auto-disconnect
  250. C1 rear crossmember replacement
