View Full Version : C1 & C2 Corvettes
  1. c2 fusable link
  2. Devildog/Subfixer - Dart SHP 400: EA Pro v3.5 Simulations
  3. Reuse axle U bolts on my '62?
  4. Wheel Static Collector
  5. 3 Day Master Blaster Memorial Day Blast Off $299 Delivered w/ FREE wall mount
  6. My old '67 pictures
  7. 58 - Soft top support plate mounting plate bolts question
  8. 1964 horns
  9. C1 Dash pad in process
  10. Engine code question
  11. Musclecarcity pics
  12. clutch engages just off floorboard
  13. Best way to polish the window moldings on a coupe?
  14. Anybody Have 1973/74 Distributor Specs?
  15. Water Pump Replacement
  16. Can Anyone Recommend someone to inspect a C2 in Pensacola, Fl.?
  17. Cragar 390c Street Pro Wheels
  18. Long weekend FUNNIES...............
  19. Choke question
  20. Whistle
  21. Early Stolen Corvettes
  22. What theft protection do you have on your C1
  23. Hagerty Operation Ignite! Youth Reporter Contest
  24. Auto Enthusiast Magazine- D.U.I-HEI testing!
  25. 1963 SWC what are these numbers?
  26. NCM Car Insurance
  27. Crown Gear and pinion
  28. Sometimes a black cloud has a silver lining
  29. Making no more 55 shielding
  30. 58-62 Heater Cover / kick panel hardware question
  31. Head light bucket rotation- Urgh
  32. Considering a classic Corvette
  33. Solenoid issue?
  34. 64 Corvette Identification Verification
  35. Need help with casting number.
  36. Changing Choke Thermostat from thermal to electric
  37. Tires for the 1963-4 Grand Sports w/ 15 inch wheels
  38. Air Shocks on a C-1?
  39. Where to buy pedal assy bolts?
  40. Buying from Out of State
  41. 65 Vert - Weatherstrip and Window Channels
  42. '65 Pulls to Right During Hard Acceleration
  43. C1 Brake Problem
  44. Are there any project cars left and are they for sale?
  45. Paint/sealer for exhaust manifolds
  46. Big block expert advice anyone??
  47. brake hose replacement?
  48. C2 backup lights... what parts are needed?
  49. c1 hid headlights
  50. c1 hid headlights
  51. Any Value to a 66 OEM radio non working?
  52. I mounted up 225x70x15 tires on my new CA Bolt-on Knock-offs
  53. 283 engine measurements.
  54. ~*~*~ St Jude Auction #45 Kindle DX E-Book Reader w/accessories ~*~*~
  55. Any American Car, Any Year Brochures
  56. Texas '55-'57 Chevy Convention - Tri Five Vettes too!
  57. 60 speedometer plastic gear
  58. 62 Fuel pump 4656
  59. 67 400 air coupe at Mecum Indy
  60. Engine stand
  61. Removal of the wiper motor on a 63 corvette
  62. 58 on BJ
  63. Question on Lectric Limited spark plug wires
  64. Plastic Tack Strips
  65. Your going to love this
  66. OC Hot Rod Pics
  67. 1967 Newbie
  68. the best state to won and drive a early corvette
  69. Front spindles and drums ?
  70. What is the quater size hole in the firewall?
  71. Value of 57 4 spd tail shaft?
  72. Mecum impressions
  73. C1 & C-2 'S in Old Alabama Video
  74. Strange Problem - 1965
  75. Axle french lock mess-up
  76. Need drivers side 64-67 headlight bucket
  77. 1960 stalling
  78. Post a pic of yourself, let's put faces with names!
  79. Door weatherstrip installation?
  80. 1963 Door Weatherstrip/Rubber Install
  81. Head Light motor, limit switch, or dash switch?
  82. C1 in Regina SK
  83. headlight switch in a 67
  84. iginition switch removal for 63/C2
  85. 1968 AG rims on my 63 split window??
  86. National Insurance Crime Bureau
  87. 67 bolt on restoration
  88. Need to know, where these screws go on hard top
  89. Measurement needed '60
  90. Crankcase ventilation question
  91. 67 brake pedal return spring / does this look right?
  92. Joplin, MO tornado
  93. New Silver Pearl paintjob
  94. Does this sound like a scam??
  95. Filing the Top of the Non-PB MC Just Got Easier
  96. Hard Hot Starting
  97. New 65 roadster owner from colorado who will need lots of help !
  98. C2 Top Install Video
  99. ~~~ St Jude Auction #43 Piloti Driving Shoes ~~~
  100. Molding your own carpet
  101. Searching for Jack Jones.................
  102. Some pics from the Wildwood NJ NCRS Regional
  103. Romeo engineering
  104. 1959 fuel line to fuel pump question
  105. Carpet install question - '66 coupe
  106. Wrong PS pump or is it something else?
  107. heads 62/63 896 vs 291
  108. I need help with values on stolen parts
  109. Half shafts to Spindle on a 66
  110. Selling your Corvette to ProTeam Corvette
  111. Body Trim tag ?????
  112. Restomods at Mecum auction
  113. Cup Holder for C2
  114. Selling to ProTeamCorvette
  115. 67 tranny reverse switch
  116. Old Oval Track pictures......cool!
  117. 1963 Steering Column Issue
  118. appraisal for restomod?
  119. C-2 Baseline 60-0 Brake testing Prior to Wilwood upgrade
  120. Cops and Rodders Car Show Pic
  121. Vin plate ?????
  122. 53 # 285
  123. Pennant Blue '54 Primer??
  124. Adding on "Add-on" pulley
  125. Life is good
  126. '61 Hood Removal & Replacement
  127. Electrical experts...need some suggestions...
  128. Removing rust stains from body?
  129. c1 1961 corvettes and luggage rack on trunk
  130. Do I need this rotor plate?
  131. 1966 Tele Conversion OOpps!
  132. 56 speaker grill...
  133. Beautiful Day to Work on the Vette
  134. 1963 Headlamp motor stopped
  135. 283 Starter ?
  136. No title, what do you do?
  137. Continuation of "Best of Both Worlds" Side Exhaust & Undercar Exhaust
  138. changing rear end pumpkin
  139. C2 Racing
  140. C1 Wiper conversion best kit?
  141. 1953 #274 Mecum Auction Today
  142. 16 Spline slip yoke too long for BW T10
  143. "Corvettes Are Back!"...Dana Mecum
  144. quick ride
  145. 65 carpet replacement
  146. Foggy rear window
  147. uncles old 53 search
  148. all vette car show south NJ 5 22 11
  149. 1957 Barn find
  150. United Kingdom - Windshield Washer Issue!
  151. What part is this?
  152. installing side pipes on a 65 non side pipe car
  153. Non steady timing indication.
  154. 1955 owners Trivia
  155. Ignition shielding for 1960 Vette
  156. From shell oil
  157. points car or perfect car?
  158. car transporting
  159. All corvette car show tomorrow pnw (anacortes, wa)
  160. What should I do about my radio?
  161. Cost of A/C?
  162. Friday funnies
  163. Hot Rod ?
  164. '63 Booster Question
  165. 1966 corvette flywheel
  166. How Do I Peen Over A Rivet
  167. Getting new wheels
  168. Ethonal in gas?
  169. Rechroming C1 parts
  170. 67 435 head plugs
  171. Grand Sport Corvette = Good Medicine
  172. Anyone know if corvette central is offering free shipping on memorial day ?
  173. Jack Deck board stickers..Underneath..Confusion
  174. [PHOTO REQUEST] 1958 accelerator spring?
  175. Supplier For Correct Weatherstrip C-1 ?
  176. 63 radio question
  177. Pulley alignment
  178. 1966 seat upolstering video
  179. 62 corvette pukes out radiator fluid when shutting off
  180. White 65 survivor on ebay SD
  181. What's this hole for?
  182. How to store caster kit for 4 post lift
  183. Installing 59 Complete wiring harness - Fuse Box Question
  184. Hard top, headliner install, questio.
  185. 59 water pump problem
  186. locking an open rearend
  187. Tighten alternator pulley bolt
  188. c2 steering box bushing removal?
  189. 65 Corvette Comes Back Home
  190. t56 in 56
  191. Need Help w/ TI trouble shoot 67BB Please!
  192. What is the earliest 1967?
  193. E brake cable nylon guide on T arm?
  194. Just Bought a 61 vette want to get it restored
  195. '68 Jaguar wreck in Orange County
  196. New pic,s
  197. new pic,s
  198. 65 Nassau Blue Repaint
  199. Thanks to a couple of CF members
  200. Engine casting dates to assembly date
  201. What do C2 radiator pins sit into?
  202. Is This Good/Bad for GM
  203. 62 Restomod Order
  204. L78 Cam Specs.
  205. 1967 327/350 hp not starting, loss of juice
  206. Bumper shims
  207. 67 "barn find" older
  208. What is this C1 auction part ?
  209. On 63 SWC what parts are unique and valuable to check for?
  210. Corvettes at Carlisle Giveaway '91 Corvette ZR-1
  211. New Trailing Arms Installed on my '65 - Pics
  212. Pan Choices for a 383?
  213. Related Post:"400ci in a C2 dyno results"
  214. Contemplating purchase of '63 FI Roadster project car
  215. Diamondback 215-70-15s
  216. power windows for 56'
  217. No service for you!
  218. adding speakers in C!
  219. Carter AFB 3721 rebuild....which kit?
  220. C2 picture
  221. Changing A/C compressor seal w/o removing compressor
  222. 61 Frame Value
  223. Disney first ever car show in Orlando
  224. Lamps behind ignition switch & lighter??
  225. 66 Differential u-joint bolts
  226. Set my expectations please - Original Low Mile Motor
  227. 1967 hard top restoration
  228. Politics as we know it!!
  229. fan clutch
  230. lift question?
  231. WANTED K19 Carb Photo
  232. Best way to clean white door panels?
  233. c3 coupe question
  234. Rick Springfield DUI charges driving his 1963 Split Window Coupe
  235. Thinking of adding power steering
  236. 58-60 vette tail pipe retainers....problem
  237. 55 for sale in Spain
  238. How many key locks on a C2?
  239. Brake Problem
  240. 63 SWC Interior colors
  241. 1963 SWC antenna hole size
  242. Another New 64 member
  243. vin
  244. *~* St Jude Auction #41 Mac Book Pro *~*
  245. Unrestored 53 on ebay. #201
  246. What are these wires?
  247. Discount
  248. Altenator on a 62?
  249. No Smoke, Sparks or Fire...
  250. wcfb choke...
