View Full Version : C1 & C2 Corvettes
  1. Vette only night at the Chatterbox in NJ
  2. New VIN Number
  3. C2 Registry
  4. Free Shipping Offer from Corvette Central
  5. On the hunt for my fathers 1965 Coupe
  6. C1 rear springs - rebanding
  7. Clutch cross shaft
  8. C2 Vert Upper reveal molding question
  9. WCFB carb info needed
  10. Painting Quarter Trim Panel??
  11. Hours to remove body C2
  12. tach needle 64
  13. Speaker Paint
  14. 1961 corvette birthday
  15. Rear diff yoke: Is part # GM 9210 same as 1330, 1350 or ...?
  16. Reproduction '67 interior door lock knob question
  17. Help With Vintage Dual Quad Setup
  18. Radio Repair
  19. Rear Bearings
  20. 17X8 wheels on the front with no fender mods
  21. QTP Electric Cutout Full Metal Jacket Protection
  22. Co$t of engine rebuild 1967 327/300
  23. Is this your own "Frankie the Fink"
  24. '67, 327 how best to decifer pad stamp...
  25. Wiring Question - '60 C1
  26. Thinking about painting my 66 myself.
  27. Visiting Conn., and Chasing Classic Cars
  28. Original Dealer Location
  29. Richmond Corvette Roundup show this past weekend..
  30. Willcox Summer Sale Starts Now... 10 Percent Off Entire Site
  31. 58 - Front support painting question
  32. C1 Oil Pump question
  33. ~~~~~ St Jude Auction #48 The Master Blaster ! ~~~~~
  34. E.B. Smith Chevrolet business card
  35. 67 Radio antenna connection ?
  36. I need help!!! Im purchasing a 1960 corvette
  37. The Car is packed and Canada awaits
  38. Long Block Short Block... they say there are no dumb questions here.
  39. 64 on ebay
  40. polish festival /weekend car show event PNC NJ
  41. '60 Rebuild after fire. Resto-mod
  42. Wheel cover restoration
  43. Mid year Power Steering Valve Spring
  44. Rear exhaust panel to body
  45. Windshield gasket replacement - DIY, or?
  46. My Clock Finally Died !!!
  47. Do any of you have personal experience with this guy?
  48. Do I need Rings???
  49. 63 Coupe "Experts" needed
  50. Weekend car show pics
  51. Corvette Colours And Racing Circuits
  52. C2 inspection in Santa Fe NM
  53. My car has been bid up to it's reserve...
  54. Need some ideas on putting ac in my 57 vette
  55. 1957 corvette radiator
  56. 1959 FI Heads
  57. Need a new clutch and pressure plate?
  58. C2 Panel For Aftermarket Gages - Any Interest?
  59. Distributor repair question
  60. How can I find my 58 casting engine numbers?
  61. Cartersville, GA cruise in
  62. 64 headlight up and down problems.
  63. 64 headlight up and down problems.
  64. Corvette News 1953 Corvette Search
  65. Some car show pics from today
  66. can't upload custom avatar
  67. 65 Seat Belt Buckle - Chevy Medallion Orientation
  68. 1957 Powerglide - parts help
  69. 56 heater defroster box...
  70. 65 roadster rear carpet
  71. Will it start? Lost time
  72. (PICS) Downtown Leesburg, VA Car Show...
  73. "Hot Rod Air" Operating Manual C2
  74. Need ideas-converted windshield washer system on my 59
  75. 63 vette engine compartment
  76. Early 64 shift console plate ?
  77. Poor Idle
  78. Power Meet in Sweden 6-4-11 (pics)
  79. Got a Bucket List Item
  80. Side cove trim install question
  81. Hot Rod Power Tour Pics
  82. Yellow side pipes
  83. Cleaning Engine Compartment and Underside
  84. Vette show with CF member
  85. radiator support shimming
  86. Clock
  87. Close up photos of Vent Window and Door needed
  88. Holly carb leaking
  89. Could noise be starter/solenoid?
  90. Sarcastic comments to the other side
  91. Is this a 1969 Corvette part ?
  92. Too Hot to Drive...
  93. CA Black/Yellow license plate restoration
  94. Finally going to have a real garage
  95. 56 heater...
  96. ...............#18's frame updates...........
  97. 66 Rim??
  98. Shocking horn button
  99. OT - Cars and Coffee Houston 6-4-2011
  100. 62 carb fuel line
  101. 1959 transmission removal
  102. 2nd post, AC CAP HELP PLEASE
  103. Ac cap help please
  104. Tremecf trann fit in a 66
  105. seat belt bolt anchor WON'T come out
  106. Drive line vibrations in 1962 fuelie
  107. Drive line vibrations in 1962 fulie
  108. Wrench that came with your 62
  109. OT Steering question
  110. 54 Resto Corvette
  111. Wow, way cool Route 66 site and pics!
  112. 56/57: hood hinges?
  113. Events to find Race Ramps! June 3-4, check 'em out!
  114. 59 Main Wiring Harness Routing Question
  115. 1961 front shocks
  116. Ignition Switch
  117. Radio Help
  118. Gas pedal
  119. Redesigned Vintage Air kit is out.
  120. Hangin' Out
  121. '61 Vette Door Glass Frame?
  122. Quick reminder
  123. DOT 5 fluid swells rubber brake parts?
  124. Battery Acid Boiling
  125. 1955 Corvette #006
  126. More and More Corvette Publications are Going Belly Up
  127. 1963 Corvette seat Belt question
  128. What are these holes for?
  129. Devildog
  130. it's friday time for a smile, wake up vicz
  131. LED problem in the '61
  132. Trim tag delima
  133. Best aftermarket hoods and fit
  134. $100 registration to bid at Bloomington???
  135. RPM and speed calculation
  136. pcv beather leaking oil
  137. Fuel sender 62
  138. New '67 Bolt On Wheel Question?
  139. Which Cover for a C2?
  140. Another Corvette publication bites the dust....
  141. Barn find '65 396/425HP engine
  142. 1957 R & D Barn Find
  143. 1964 Corvette Convertible Fender Louvre HELP
  144. new speaker
  145. Tork-Loc Sliders
  146. C2 Corvette Wilwood disc brake upgrade
  147. Inner and outer heather box questions 64 coupe
  148. How much fat in dealer pricing??
  149. Stingray 65 overheating
  150. John Hinkley-A block casting question for you
  151. Red lines for 17"
  152. Inside rear view mirror wont stay in position..
  153. Looking at '62 - Need some help
  154. Custom fit Dynamat...Removing glue from bottom of floor board..Questions
  155. 62 Fuelie Quit
  156. Holley fuel bowl question (67 350 horse)
  157. Tweaky, wining noise on start up
  158. **** St. Jude Auction #47 Otterbox iPad Defender Series Case***
  159. Water Pump
  160. Looking for Part#/Source for Muncie 17-Tooth Driven Speedo Gear
  161. Distributor Rebuild Question
  162. Custom Cars, Mt. Washington, Ky???
  163. Trouble starting
  164. Anyone ever heard of a replacement clutch linkage kit for C2's?
  165. C1 pressure plate
  166. 2818-1 Alternatives?
  167. Want to install a 360 FI on a 300 hp motor
  168. Electr. tach or Mechan.
  169. First Gen Firebird experts in Iowa/Illinois?
  170. Schwitzer fan clutch
  171. 62 Front emblem
  172. Dan hampton
  173. Chevy Orange
  174. What part is missing on 63E in foto?
  175. Mecum being sued
  176. Fan Clutch: Thermostatic vs Torque limit
  177. Whats this block stamp tell me ?
  178. License Plate Hardware
  179. Need a little help with brake fittings
  180. Car Transporter
  181. tach cable instalation
  182. Will 77-82 steering wheel fit a 65?
  183. Question on fitting doors
  184. What is a " Bird cage"
  185. Cooling System Question
  186. 1960 Brakes "hang".....time for hoses...which vendor?
  187. How tall can you be and fit in a 64 coupe?
  188. Dog leg panel question
  189. Anyone near Portland, Oregon to look at car for me?
  190. Taking apart a 67 seat belt buckle
  191. New performance upgrades to the 67 (lots of pics!!)
  192. 63 bolt-ons/knock offs and disk brakes
  193. Is there anything that is supposed to hold the 58-60 seat bottom cushions on.
  194. Amazing Car History
  195. 3 point belts on a 64
  196. Thanks LARS... wherever you are :>)
  197. 1963 Corvette seat mess.....
  198. Georgia crew...get together?
  199. Anyone know this C1 member?
  200. 62 Steering Gear Lub
  201. >*< St Jude Auction #46 Flying Wild Alaska - Hat signed by pilots >*<
  202. Problems and solutions for my 64 365/327 engine
  203. T-56 6 speed
  204. Pilots - Memorial Day with "FIFI" B-29
  205. Ac sealer
  206. All 66's . . .
  207. What is this?
  208. Radiator flush-out and test
  209. Wounded Warrior Recognition at Cruise-In XII
  210. 5 speed
  211. Convertible lower windshield molding - What makes a 63 different?
  212. Protect-O-Plate for 1966 Corvette
  213. That 70s show 58 corvette
  214. spark plug question
  215. Remove convertible top to protect it?
  216. 56 Corvette Inner fenders - removable?
  217. Headed to the local swap meet in June
  218. Free NOS fuel injection gaskets
  219. first corvette
  220. Can carpet be glued to Dynamat?
  221. Paging Bruce Wayne
  222. Strange noise...
  223. 64 knock off wheels
  224. Electrical Fire- diagnosis help White Plains
  225. Brain fart / won't start
  226. Build Date and Block Stamp Concern
  227. 60 Corvette Battery Change
  228. Goofy headlight problem
  229. Muscle Car Values Still Not Making a Comeback
  230. Brake help?
  231. LED light for signal/park lamp front
  232. coolent flush
  233. Does my '61 most likely have solid lifters, mechanical lifters, or hydraulic lifters?
  234. Memorial day
  235. lower steering shaft bearing
  236. Fastest 1957 Production car
  237. Solid Lifters Adjustment
  238. Question about Pricing & Quality between Eclkers and Corvette Central?
  239. Colour-Question C1 58-60, True facts?
  240. original non dot goldline tire value
  241. 63 327 Starter
  242. Magnesium water pump..................
  243. How much play in fan belt?
  244. Anyway to remove the ignition switch?
  245. door window glass edge chips on 65 coupe
  246. 63 Brake light problem
  247. Nose go's on the 62 gasser
  248. Vette aluminum intake?
  249. 67 Purchase
  250. Side (cove) moldings
