View Full Version : C1 & C2 Corvettes
  1. valvoline
  2. Rear of car skates around
  3. Unplugged drain holes from cowl air vents
  4. updating wheels, any good tires with gold/red stripes?
  5. Generator pulley does not line up
  6. No start - need diagnostic help
  7. E85??
  8. C-1 hood issue
  9. Ceramic Coat Intake Manifold
  10. 62 Windshield wiper
  11. 1960 corvette hardtop receiver
  12. Why? paragon Lower inner a-arm
  13. Restomod Results at Auction
  14. Running on 7 cylinders...
  15. Cured my percolation problem
  16. Primer question...
  17. Are The New GM Bronze Pilot Bushings a '2-Piece Unit'?
  18. clutch push rod bushing
  19. help please! 327-300 PG
  20. Who wants to go for a ride??? !!!
  21. Yet Another Wheel Thread
  22. 65 TI Coil Wiring
  23. Anyone know a trick to remove these "brackets"
  24. 1960 Exhaust
  25. Date Code
  26. Painting Aluminum heads
  27. 4 speed repair--Round #2
  28. Still in Southern Ca.
  29. Failed at second attempt to install Window felt
  30. C2 rear deck lid latch release hardware
  31. Please Help with your opinion
  32. bonding strips
  33. 65 Body Prep Before Drop
  34. Spax Shock Absorbers for 66 SB
  35. Wiper motor removal
  36. VBP Rack Steering-Shimmy
  37. 65 396 Oil Priming
  38. Fuel for a 400HP 1967
  39. Installing new Vintage Air Gen 4 unit
  40. C 1 showing car with hard top vs soft
  41. Auto Enthusaist Magazine- 427Hotrod's 2500 mile road trip saga...
  42. Auto Enthusiast-Shouldn't be Here-Traccdog-VortecPro-Dewitt's
  43. Auto Enthusiast-Shouldn'
  44. Holley float sticking in open position
  45. Special ordered Corvettes
  46. What the heck is this?
  47. Oil Pump Rebuild Kit
  48. valve cover value?
  49. Off Topic --- Fly safely Atlantis!
  50. FRiday humor
  51. 59 dash end caps
  52. Missing front bumpers
  53. FM Radio Tag Attachment
  54. suggestions as to how to keep shiny aluminum valve cover clean and shiny?
  55. C1/C2's in NW Indiana?
  56. 1958 motor rebuild ( pictures )
  57. 66 small block hood
  58. How do you adjust driver's door on 67 Vette
  59. Source for used C1 C2 C3 fiberglass parts
  60. Help identify this part
  61. 1960 - Brake questions
  62. tires
  63. 64 steering arm problem
  64. aluminum valve covers...
  65. Clock- Radio- Speaker
  66. C2 headlight bucket support brackets - painting
  67. Rims and tire size for a 1958
  68. The correct Manifold???
  69. Overheating BB: which radiator cap to use?
  70. Any original car colors without painted coves? colors
  71. I need a real Corvette painter.
  72. New Direct Lift Installed with pics
  73. What's the total CFM of.....
  74. grey mold
  75. coolant additive help
  76. 327/365 ticking
  77. Chrome Sity
  78. I want one of these!!
  79. Thread Got Locked And I Am Very Upset
  80. Real or counterfeit 58-62 part??
  81. 2 post or 4 post lift?
  82. Installing Lower Ignition Shielding on '65 327 250 hp
  83. Another pilot bushing question
  84. 65 front shock bolt size?
  85. Drilling a crank snout with the motor in the car?
  86. Mufflers for my 60' w/383?
  87. Radial Tire Source for my 64
  88. Does anyone have Early 60's Auto Cross Pic's at pleasanton, Ca. Fair grounds?
  89. 67 convertible found
  90. Photobucket Vlog
  91. sun visor help 63
  92. Removing side pipes ?
  93. noise coming from back of car
  94. Loss of Oil Pressure part 2
  95. 56/57 speaker cage value?
  96. Silver 1958 Corvette Restomod at 2011 Bloomington Gold
  97. ? about C1 door panels
  98. 61 front end problems
  99. Fuel safe epoxy
  100. Night Rider
  101. Has anyone polished there Plexi glass !
  102. '62 Speedometer Problem
  103. 62 Lock Cylinder Questions
  104. Speed Direct Shark Bite Suspension ??
  105. Some new/old GS pictures
  106. 63/64 dashes
  107. best color combo?
  108. ? for those with lifts: How did you get it delivered?
  109. Timing Problems
  110. Please help with 64 HP oil pan numbers
  111. 4300 miles, 1 blown fuse and 1 ticket later...
  112. Guys need your opinion on carburetor
  113. What kind of oil filter do you use
  114. C2 inspection Las Vegas NV PLEASE
  115. Who sells a tool to ........
  116. I'm getting a LOT of heat inside my 64 coupe
  117. 1962 inner fender replacement
  118. 1962 paint tech help
  119. wax or polish on older paint
  120. Paging: The Saint
  121. C1 Seat Frame Stuck
  122. how much would you do...?
  123. 12-bolt Tom's Differential Conversion
  124. 1967 M20 Muncie transmission problem
  125. Rim Question
  126. Automatics 1967
  127. Edelbrock carb question
  128. What have you found in your C1 C2
  129. 1963 Corvette Interior rebuild..
  130. Need New Headers
  131. Horn Contact Question
  132. '64 Carpet Jigsaw Puzzle About to Begin
  133. Rear park brake cable boot problem
  134. rear bumpers
  135. borg warner questions Please Help
  136. Toyo Tires?
  137. Got Lucky Yesterday!
  138. Got Lucky Yesterday!
  139. 68 rally wheel on 67?
  140. ~~~~~~~ St Jude Auction #58 ..1 Ticket to NASCAR Lenox 301 at NHMS 7/17***
  141. Part no. for 61 Corvette temp sending unit
  142. C2 outboard window trim
  143. 64 "hard top only" rear deck hardware?
  144. Lost another car guy
  145. Leaky Axle on my ‘57
  146. stingray
  147. Alternators
  148. Installing Custom Auto Radio in 1962
  149. Snotty vette owners
  150. Happy 4th
  151. Help with some measurements "Please"
  152. Carter AFB carb rebuilders
  153. Wobbly balancer, crank and main bearing(s) OK?
  154. Body dolly
  155. AC Delco A212C filter...worth?
  156. Question about transmission installation
  157. Job Number ?
  158. Kind of Surprised
  159. Transporting a Car, Who would you call
  160. Lucky Squirrel
  161. M.A.D. Wiring making me Mad!
  162. Video - Sidepipes in a Midyear Coupe at Speed
  163. Ti ignition help
  164. Big Block PML valve covers.....?
  165. Painting 1958 hub cap spinners
  166. OT- 68 Firebird
  167. America on Wheels Museum cruise to Bethlehem PA Steelstacks
  168. 4th of july car show lakehurst NJ
  169. wheel idenity?
  170. Help with Distributor install please
  171. AFB Carb
  172. Canada Day Cars & Planes
  173. 58 dash harness need help
  174. going to Southern Ca. from
  175. 3:08 to 3:36
  176. Restoring my 60 hard top need input ?
  177. 1958 Shop Manual Recommendations
  178. Fiberglass Bumpers for C2??
  179. Anyone running this exhaust setup?
  180. Muffler question
  181. C1 Door panel S-trim tab repair (with pictures)
  182. WANTED INFO on possible SR2 RACECAR
  183. WANTED INFO on possible SR2 RACECAR
  184. 58 partially painted coves?
  185. '67 327
  186. '67 327
  187. '58 Starter: Top Bolt Removal Misery
  188. 1959 Dual Quad Question
  189. 1957 Progress Pics - Need help with Starter installation
  190. What was my car worth in 1971?
  191. Magnetic Oil Drain Plug Recommendation
  192. some more questions about my BB
  193. 64 Coupe antenna
  194. C1's in the Chicago area?
  195. Fendered 53 Indy race car
  196. OT - Cars and Coffee Houston 7-2-2011
  197. Headman Header Clearance
  198. knock off help
  199. Aluminum repair
  200. How important is this procedure
  201. carb leaking gas
  202. Emblems refurbish
  203. More investigation...
  204. Jonno
  205. Everybody have a ....
  206. Edelbrock 1406 carb?
  207. Dash Lights out in 66
  208. Rear Wheel Lug Removal
  209. 64 fuse issue
  210. What Paint to use?
  211. C2 inspection Los Angeles
  212. 67 parking brake problem
  213. New Autogear Muncie Tail Housings
  214. 1964 Riverside Red Paint Formula
  215. 62 Original Motor?
  216. clutch pilot brng, roller vs bushing
  217. New Corvette Jigsaw Puzzle Is Up --- June Winner Announced!
  218. pilot bearing
  219. Watch the Keen Parts car and save!
  220. Ford vs Chevrolet
  221. Pre Sale Inspection Houston Tx
  222. Free Shipping Offer from Corvette Central
  223. Corvette Forum and Hot August Nights. Reno, Nevada.Get Together.
  224. Split window visibility
  225. Good suggestions for jack?
  226. Its Friday:Time for a smile
  227. 62 steering wheel restoration
  228. 1960 Fuelie Found
  229. kwik lift ques
  230. Ozone Generator for freshening musty interiors?
  231. Set initial timing with car in drive?
  232. Temp gauge still. 65
  233. Hard top for a 60
  234. Vacuum Advance Problem
  235. Last Chance To Enter This Months Jigsaw Puzzle Drawing!
  236. Happy Birthday Corvette! Looking GREAT for 58!
  237. Which bumpers to use?
  238. Clutch Disc/Flywheel Surface Condition Question
  239. I goofed...and need some assistance
  240. flares
  241. 56 clutch pedal rod,,
  242. Idea for Jackfit - or others
  243. Anyone pulling thier C-1 with a Trailex or Featherlite open trailer
  244. Black sting ray painting
  245. This poor old car
  246. Complete Wiring
  247. A few questions and a progress status...
  248. Exhaust Manifold Bolt
  249. 427 into a '66 327 car ?
  250. Engine Oil
