View Full Version : C1 & C2 Corvettes
  1. Grill removal 61-62 corvette
  2. 40th Anniversary Snap on Corvette Tool Box
  3. O-ringed thermostat housing?
  4. Holley EFI Install- 555"- Auto Enthusiast Magazine
  5. rear wheel toe-in........degrees vs. inches
  6. Vietnam Veteran Corvettes patches
  7. pad stamp decoder help
  8. 1967 stock suspension wheels and tires
  9. New seat question
  10. 1963
  11. Fan Belt
  12. old parts
  13. Windshield trim clips
  14. Silver engine paint
  15. Folding top fit
  16. door hinge pins worn out
  17. Wilcox convertible tops, opinions please
  18. CARLISLE Gas Caps, Radio Knobs & Lighters
  19. NOW what do I do?
  20. Chevy Dealership in NJ
  21. 1963 horns
  22. 59 hood pins
  23. 65 300HP engine number stamp ?
  24. Gen IV Vintage AC installed--But---
  25. A/C decal
  26. '62 Heater/Console question
  27. 427 vs a new crate 454
  28. Corvette Central Happy Hour
  29. Who's C1-2 disc brake conversion is great?
  30. $600K 1967 Corvette 427 on eBay!
  31. 1960 Roman Red Paint Formula???
  32. To all 65-67 owners with 17" x 7" Cragar 610's
  33. Another shop item...
  34. 62 fatman upright problem
  35. Valve Spring Question
  36. 1965 corvette coupe side grill installation questions
  37. 1965 Steering box
  38. 67 L88. should i buy?
  39. Its Friday:Time for a smile
  40. ut oh...did I do that?
  41. Drag Link Rebuild
  42. 1960 lights- Silly Question
  43. The 61 finally made it
  44. C-1 Spindle support question for Tom
  45. 58-62 Cluster
  46. need pic help...
  47. Pictures Flared Fenders - Let's See Some Flares on these early cars
  48. 1959 283 won't start
  49. Alignment, Trailing Arm,Wheelbase Help Needed
  50. Corvette Restorer Pictures
  51. 461 intake question??
  52. High/low switch cause headlights to stay on ?
  53. Speed Direct 15% off summer sale
  54. Here comes another Sting Ray Registry road trip: The Great River Road
  55. whats it worth
  56. 1000 HP Corvette Street Test from Nelson Racing Engines
  57. Carlisle Questions
  58. Blondes, Need I say more?
  59. Balancer install, preventing engine rotation?
  60. Mid-Year Crisis
  61. 66 captive belt for L79
  62. Installed new carpet
  63. Mike 1958
  64. Water base paint????
  65. Why so many different GM Coil numbers for small blocks??
  66. side pipe heat shield
  67. idle 60 PSI oil gauge reading
  68. chrome manifold
  69. 1966 Corvette Drive Axle U-joint replacement
  70. Prodigy Z06
  71. 57 Cigerette Lighter & Battery
  72. 1957 Trunk - need some pics
  73. Is this a 61 or 62?
  74. 1966 Corvette VIN #6S112014, where are you?
  75. '61 paint blemish
  76. I need 58 trunk pictures.
  77. 1963 shifter install
  78. Cutting white walls or red walls on tires?
  79. Heater Hose Connections/Thermostat
  80. Houston Area Care Detailer
  81. How do I find a reputable mechanic?
  82. Carlisle Space
  83. Headlight stress cracks
  84. Horn Button
  85. 64 Corvette Horn Relay
  86. Correct tach ?
  87. drain holes in hood
  88. C-2 headlights won't shut off
  89. Now Where Does That Clutch Vibration Come From??
  90. Big Block Overheating Issues
  91. Head ID
  92. Spark plug diagnosis
  93. Back on the road
  94. Barn find 62 FI today
  95. Ground Strap on Accelerator
  96. High beam indicator light always on
  97. Painting a C1 with BC/CC to NCRS?
  98. Those who have done the Borgeson Power Steering install on a C2.
  99. Oil Slinger
  100. Carlisle Space
  101. Slow to start
  102. OEM Shocks for 65
  103. need advice/opinion on when to install carpet
  104. defroster/heater knobs
  105. Putting Hurst shifter in my 66' 4-speed. Got question about the backup light switch.
  106. Engine Decode
  107. ****** St Jude Auction #64 Harley Shirts From Oz ******
  108. ~~~ St Jude Auction #63..One More time...Otterbox Defender for Original Ipad~~~
  109. C2 LSx Non-Sidepipe Custom Stainless Headers
  110. Need Electrical Guru's Advice - 67
  111. intake manifold for a 396 65 vette
  112. 62 engine number question
  113. 18 months, just not long enough.
  114. Split window for the.......water?
  115. paint problems
  116. Audio recommendations?
  117. 59 gas gauge irratic
  118. 59 Hardtop fit problem
  119. brake warning light replacement C2
  120. Spark Plug Wires
  121. New member needs help with folding top
  122. How would you do it?
  123. Early 57 2x4's info?
  124. Etown Corvette show and go. New look for my car.
  125. Seat I.D. help
  126. Small / large journal main cap size
  127. rear axle code
  128. Our buddy from down under......video
  129. 67 flexplate still have ??????????????
  130. And I thought It Was Hot Here In North Texas!
  131. Need help finding dealer in Winamac In
  132. High pitch whine
  133. How do you spot a fake trim tag?
  134. 59 rear top latches dont line up
  135. 67 rear window run felt
  136. L79 water pump / alternator bolt colors
  137. looking for info on original Chevrolet ok used car sign
  138. Nashville Blessing
  139. 57 RPO 684 - A Photo history
  140. When did they make the change in63 SWC
  141. 65 HD Suspension
  142. Who Dat Guy?
  143. 2818 Holly float pin
  144. New engine-storage-need advice.
  145. Dealer Info
  146. Best Coolent
  147. wiper arm post color?
  148. Aluminum valve covers
  149. puzzled about engine and trans. alignment
  150. Lo rider Car show shooting in Kent, Wa
  151. Intercooler for a Carb'ed Engine
  152. 2818-1 Rebuilding The Throttle Plate, Help!
  153. another overheat problem with new rebuild- help ?
  154. Sad to say goodbye to my 65 coupe
  155. Correct black??
  156. Removing the Gauge Cluster
  157. How to dull polished aluminum
  158. C1's at 'Cars & Coffee' in Great Falls, VA
  159. 1955 Red Engine Paint Availablity
  160. 61 Horn switch question
  161. What's involved in an LS-1 Engine Swap?
  162. 58 Barnfind body lift ( pictures )
  163. 2012 Woodward Ave Dream Cruise
  164. fuel wash questions
  165. Thermostat Housing Sealer
  166. Looking for help
  167. collapsable steering column
  168. C1 Break noise
  169. Save it or run with it
  170. MOTOR id# help
  171. 1957 on craigslist
  172. LS1/Mechanical Clutch
  173. Gas tank cover question in a 1960 Corvette
  174. '62 parking lamp color?
  175. advice needed
  176. Little 'ol car lot pics......!!!
  177. break in oil
  178. Fulie Perculation Fix by Mercruiser ?
  179. Fuel "Issues"
  180. removable hardtop drip rail sealant
  181. Hello I would like to know what a 1966 fast back would be worth?
  182. Windscreen question
  183. It's after 3am Do you know where your extinguisher is? Or WOW chance of a lifetime!!
  184. Best Radial Red-Line Tire
  185. A little progress on the 66
  186. Spicer Half Shaft Universal Joint Problem
  187. Extra adhesive on new weatherstripping...help
  188. Sting Ray in the United In-flight Magazine
  189. Perfect Corvette weather
  190. who can install glass in my hardtop? Savannah GA
  191. C1 power brakes
  192. Head Date Code
  193. 1964 327 300HP Main Seal question
  194. Clock
  195. 1964 Replacement/Aftermarket Brake Drum Question
  196. 63 steering column shaft sleeve
  197. '64 Daytona Blue - metallic color?
  198. 1967 Auto to Manual conversion
  199. Off to the alignment shop
  200. 1965-66 wheel & tires
  201. Friday Funnies..........
  202. Mid-Years for sale in Carlisle?
  203. Back up light wiring
  204. OT - Atlantis returns home! Videos and Pictures
  205. 66 BB inner fender skirt
  206. ADd power stearing to a 64
  207. Front sway bar 4 '64
  208. Front sway bar 4 '64
  209. Building 36 Chevy's
  210. Who are the best companies to buy from?
  211. 66 327 with hei wont hit a lick
  212. Type of interior paint for a C2
  213. C1 alignment question, max caster?
  214. 1958 Barnfind motor startup ( video link )
  215. 10% discount to forum members
  216. Spark plug wires
  217. 67 327 Wiring is &%$*#
  218. Notched Alum Valve Covers
  219. Another whats it worth?
  220. Carter 3461 Rebuild
  221. 1957 Reproduction EATON Gas Cap
  222. 461 Aluminium Intake question
  223. Head Markings
  224. Car Craft
  225. Question about door lock striker on '56 Vette
  226. So why are the parts so costly?
  227. '61 With a 427 & Trips!
  228. Convertible Top Staples?
  229. Joe Jacobs Chevrolet Wilmette Illinois
  230. Upper C Arm removal ??
  231. 67 E-Brake Console Repair
  232. 1962 Taillight Protector Cone Question
  233. Need opinion on tires/wheels.
  234. Bonding adhesive hazards?
  235. Best 6.70 X 15 tire?
  236. Harmonic Balancer ID Needed
  237. Pics of NCRS Nationals...Novi, MI
  238. 63 finally in paint shop
  239. GM of Canada???
  240. Tail Light Wiring Harness Rear Clips
  241. Cleveland, TN. Need help with theft!!
  242. I needed a tow car.....
  243. The mysterious #8 cylinder malfunction
  244. '63 Muncie Trans Oil Fill Plug Size needed
  245. Door latch repair
  246. Question about 1957 Corvette Rear Wiring...
  247. Had accident with my 60
  248. engine date code
  249. Ballpark value on 63 conv.
  250. Newbie Fastback Convert
