- HELP! Corvette needs some love!
- Old school look (dual quads) with LS engine
- Setting solid lifter lash on a cold engine
- Huge shoutout to PlasticMan!
- GM's Dr. Jamie Meyer on the '63 Sting Ray
- 15" Steering Wheel Question
- MP Brakes front disc upgrade
- One Friday Funny
- 62' power steering
- 62' steering wheel
- Aftermarket radio with USB
- Thanks for the help
- @@@ St Jude Auction #76 Case of Royal Purple and a K&N Filter @@@
- Has anyone bought carpet from Stock Interiors.Com
- Water pump questions?
- Help !!! Electrical Short
- C2 "Most over used terms in the hobby"
- 59 -60 Voltage Regulator Information Needed
- Discovered an easy trick for setting perfect gaps...
- 1960 front sags a bit
- Best Time for Annual Oil Change?
- C1 hardtops interchangeable?
- Is it hot yet
- Original owners ?
- C2 5-speed frame alteration
- Fan clutch
- 1964 327 300 hp valve cover clearance issue
- Any way to avoid Carlisle traffic?
- test
- Help with inspection in Marco Island, FL
- question on 66 seat covers
- 1960 running Chassis Complete
- How Do You Clean Original Knock Off Wheels?
- Bolt kits
- Nice cruise night in NJ
- Re-wire the 64....yikes!!
- Zinc additive replacement for motor oil
- Corvette Spectacular
- Thinking of selling my '60
- Opinions on this 66 Coupe?
- Corvettes at NASCAR Watkins Glen
- OT- stolen Hurst/Olds man needs help
- Horn Relay
- Changing the luggage compartment courtesy light to LED
- 63 Horn Button Assembly
- roadside flat tire..........what would you do?
- Fiberglass repairs
- 58 silver blue floor mats
- 62 door glass question
- Posting pictures test
- Rivet question
- Oil recommendations
- Classic car insurance
- ZZ4 valve adjustment
- 55 plug wires suck
- 58 fiberglass repair ( picture link )
- New big block comes home......
- Anyone attending the 2012 SACC Natls in AZ?
- Fiberglass repair help
- 67 Ignition Shield Question
- Carlisle help?
- Are you buying a Corvette at Carlisle? Come see us for your insurance needs!
- Is my ballast resistor bad or going bad???
- Where's the build sheet in a '65
- hey flyboys
- 65 L79 question
- Need advice on restoring 63
- 64 Barn Find/Worth?
- Dewitts Radiator
- 62 Brake Fluid type
- 63 Barn Find
- Clever People - How Do I Do This??
- Old polishing cloth from GM 100 bucks??
- Early 283 intake manifold heat riser holes
- 64 gauge question
- Big City Corvette
- C-1 Brakelight
- How many hours should it take to rewire a C1?
- What would cause my idle to drop, Im clueless
- Carlisle forum member locations.
- So I stepped over to the C6 general discussion...
- Clippinger Chevrolet Rally Club Members..
- Carlisle Count Down is on
- T.I. or Pertronics?
- video, c-6 flips at 230 mph
- '59 Non RPO Rear Brake Anchor Pins Adjustable ??
- C2 Dx Car beat two C3 Cars at Daytona 1968
- Another tank sheet/engine question
- Best Convertible Top Manufacturer?
- Lawrence Kreutzer?
- How can you tell if a car is a real big block?
- big brake package deal
- Another "Big Red Wire" question...
- Anyone in Wash, know this car?
- windshield wiper problem
- C2:Rag Joint
- One PITA out of the way
- C2:Steering & Clutch Linkage(Maybe only 63-64)
- Metal in the Oil Pan - Bugger It!
- Loose side mirror - rookie repair?
- Rear squeek going over bumps?
- I would love to see some C-1's and C-2's at our upcoming show:
- Late 64 cooling system label
- Tach dies when head lights are turned on?
- Crossover
- 62 axle bearing retainer plate question
- 1967 Production Numbers
- Borgeson Problem, looking for recommendations
- Block Numbers on a 66
- Pre-winter project.
- dual-9” diaphragm brake booster ??
- Damaged 1957 Wonderbar Radio speaker transformer
- Another 53 Lives
- Anyone ever attempted this?
- 1964 327 300HP to a 427 BiG Block
- 1963 Corvette Engine change
- 62' w/ZZ4
- What are these heads?
- Nees a car look at in Bell Vernon Pa. can you help?
- Tachometer reading problems-59"
- Free Diamond Wipes
- My car is all original....Ahhh yeah right..
- Problems w/repro '57 Fan Shroud
- Automatic Transmission Question
- 4:56 pumpkin...
- Help With C2 Part ID
- Carb, timing or both? 1960
- Rear draft tube removal / PCV conversion
- '55 - '58 Water Pump Heater Hose Ftg Part Number ?
- Republic of Texas Vette owners plates
- 67 SB327 with Big Block hood?
- 1961 use these days
- 67 coupe inspection
- Battery Boil Over
- 63-67 A/C R-12 Flow - Please Critique
- Wacky Wipers
- C2 Headlight Assembly Question
- Vette Education...
- Federal Express problems
- back up switch
- Deeper into Storage
- Replacement cam for 340 hp
- 63 split window
- Headlights
- 67 water pump nipple / bypass
- buying safely in the US?
- Can existing seat covers be reused if replacing cushions on 66 C2
- CF Members and HAN Get Together. Picture Heavy.
- A great man has left us
- Timing Help,Please
- OT Anyone close to Port Jefferson NY
- BIG Wiring Harness Problem(s).... LL... What now ????
- hot air tube on a 327
- Heat shields needed
- Fuel Pressure Gauge Recommendation
- Anyone know anything about either of these 69 Z/28?
- leaf spring rates c-1
- L79 timing question
- NCRS Judging Question
- Transmission fluid
- Route 66 Car Cruise
- Brake sqeak?
- Engine Pad Vin Stamp Help
- 65 Red interior Krylon #
- Broken down, strongest part of oil pan?
- Researching: Early 1963 Sand Cast F.I. Units
- Tank sheet question
- C2 Hood Hinge Mod?
- Headlight screws needed 1962
- ****St Jude Auction #71 Adam's Judges Detail Kit ****
- RE-Closed RPO 640 Thread
- Engine misses and on acceleration
- HL-69 lifters
- What happens when you add too much oil?
- Anyone around North Atlanta Saturday
- 65 vert value
- 63 windshield wiper motor
- California 67' A.I.R.
- new knock off wheel adapter with older knockoff wheels
- Body shop in Bay City Michigan
- Friday Funnies..........all weekend!
- brake conversion
- Join us on Facebook
- DeWitt Radiator at Carlisle
- '65 396 Dyno-Tune
- 65 Red Seat Belts: Any good repros?
- Floor mats Standrd 1965
- ZO6 Brake Backing Plate
- 56 hood pop ups & male latches....
- pre lead east car show on farm NJ area
- 53/89 corvettes won in a drawing years back
- try this again Carlisle spot
- 65 Tele horn button
- silicone VS standerd brake fluid
- Original Teakwood Steering Wheel?
- question tire wheel??
- Shifter, right or wrong?
- Free Carlisle car corral spot read fine print
- Question: To completely rewire or not
- another delay
- Free Shipping Offer from Corvette Central
- HELP: where is the A-C highpressure port for service?
- Dewitts Radiator Problem
- Panama City
- Looking for the perfect Grand Sport Steering Wheel
- RE-Closed RPO 684 Thread
- "bolt on" T-56 for C2?
- Hot August Nights - Reno
- 53 wheel covers
- [PICS] Part 4 NE Dragway Vintage Racing
- 62 Owner in Rauma, Finland?
- [Pics] Part 3, NE Dragway, Vintage Racing
- Brake calipers
- Anyone have personal experience with 56-7 repo exhaust chrome
- Progress on 67 Vert...
- Vent window spacer
- Gassers!
- Corvette Show Cars in a Series
- Homecoming or completing the circle
- [PICS} MORE NE Dragway Vintage Racing
- tire recommendations for my 62
- Hydraulic clutch problem....
- 67 Front Spindle color.
- Need help choosing headlights for the 58
- testing
- For the first time since 1974.......
- ~~ St Jude Auction #70..Custom handmade fixed blade knife~~~
- *** St Jude Auction #69...Time to get lubed up! Case of Royal Purple and K&N filter
- Mystery bracket???
- Code AI
- 1961 Tail Light Connector Splice?
- Turn signal failure
- '65 Rear Wheel Squeak
- Need brake help, 63 drums click/popping
- c2 a/c duct driver side
- Tach and Speedo Dash Hole Size
- [pics] Drag Racing 1972 New England Dragway
- It's alive
- free Car corral spot read fine print
- VetteStock at Bogey's August 13
- Painting midyear coupe
- 283 identification
- ready to take a sledge hammer to a 1959 283
- Rear Valance/Rear Bumpers
- 64 lower rear valence
- Adding headers, expected HP gain?
- TORIN two post lift...
- Tire size recomendation for fit and look on the car...
- 1966 L79 pick-apart
- 1966 l72 verification
