View Full Version : C1 & C2 Corvettes
  1. Alternator conversion for 62 vette
  2. (CRUISE) Saturday Sept. 3rd, Lehigh Valley/Easton, Pa.
  3. Can't Get Reverse to Work
  4. 65 Vert windshield is in!
  5. Location of Oil pan plug for a 62
  6. Electrical Issue
  7. rear leaf
  8. 58 - Original color question
  9. New 61-62 Seat Cover Installation Video
  10. CL Search Engines ???
  11. Carlisle – the good, the bad and the ugly!
  12. wiring help 65' coupe rear blower switch
  13. 1965 396 documentation
  14. RestoMod c2
  15. Bought the lifetime alignment from Firestone
  16. 1964 corvette heater core problem
  17. 1964 corvette electrical problem
  18. Structural Differences In 56 and 57?
  19. '61 Drum Brakes Work.....
  20. Curious
  21. Rough '64 project vert at Carlisle
  22. safety locks at Spinners of k/o wheels
  23. Brake light question
  24. C1 Rear Wheel Well Repair
  25. C1 & c2 trailing arm
  26. Please, please post pics of any C1 Vettes with 17 inch wheels
  27. Another dash question, with pics!
  28. Quick Rim Question
  29. >>> St Jude Auction #83 Autographed Wixom Engine builder poster <<<
  30. Looking for original owner information
  31. Removing Oil Filler Tube
  32. 64 AC dash question
  33. Coupe Over Door Weatherstrips
  34. 63 Hood insert painting
  35. Few Pictures from CMS Autofair this weekend
  36. steering
  37. AC not working. Anything I can do to figure it out?
  38. zz4 crate in a 66 powerglide car - driveline
  39. Yesterday my car sneezed
  40. I need TI help BAD!!!
  41. 1965 Clock Repair
  42. What is stock '61 frame worth in mint condition?
  43. MSD ignition and stock plug wires
  44. 65 327 Plug Wire Replacement
  45. Another HL bucket question
  46. Documentation Question........
  47. Anyone see this 59 Pro-Tour project at Carlisle ths weekend
  48. '65 327/350 carb question
  49. Starter question - Crate motor to old bellhousing
  50. Craigslist searches ????/
  51. Wheel and Tire issues with pictures
  52. Is this engine correct for a 62
  53. Advice on which exhaust system to buy for my '60
  54. Saw Kwiklift in Carlisle
  55. starter solenoid wiring color?
  56. Time to Brag
  57. # 4 body mount reinforcement question
  58. C1 hardtop advice
  59. What do you think of this 57?
  60. Tire Rub
  61. OT - Awesome Preseason
  62. Attended the Carlisle Show on Friday (pics)
  63. Can You Repair A Paint Drip?
  64. 58 Barnfind fiberglass repair #2 ( Pictures )
  65. Compression ratio calculator?
  66. Another question pertaining to when engine pad was stamped
  67. What does a "T" stand for on a 62 motor
  68. Tac Drive Distributor - L79
  69. 60' vette... squeak in rear suspension!
  70. Big thanks to you all
  71. After 33 years
  72. 63 Automatic Neutral Safety Switch
  73. Tremec TKO 600 Trans Fluid Leaking from Vent
  74. Seat Belt Stuck
  75. Water pump blues... Am I in trouble?
  76. Help Needed: 327 RE Engine (340hp, 365hp?)
  77. C1 62' distributor
  78. If you are looking for a C2 Hardtop
  79. C2 mini seat
  80. Jackson Chevy-Westbrook, Maine
  81. 62 hood weatherstrip
  82. clean air tube inside exhaust man. question
  83. Rebuilding a wiper motor on a 59.
  84. Replacing headlight bucket on a 59
  85. Trunk tower rivets
  86. Rivet tool
  87. Enclosed Transport Company
  88. C1 62' Spark Plug Wiring Diagram
  89. Is this for real?
  90. it's friday, time for a smile...vicz
  91. 58 door panel
  92. Any Idea Of The Weight Of...
  93. Currently on Ebay - had to share
  94. 1964 - Help with Stats
  95. crate engine question
  96. Austin upcoming swap meet ???
  97. Comments on Soda Blasting
  98. Picked the wrong line, now I need a new mid-year rear bumper.
  99. Anyone else in Florida on Tuesday have lightening Strike their house??
  100. Need info on 66 jack and handle
  101. Enough HP?
  102. '65 Brake Line Substitute?
  103. Looking for a 66 convt. VIN 194676S122690 in Ohio
  104. 56 air cleaner assembly
  105. soft top label protector
  106. Engine grounds??? how many?
  107. I'm guessing this a C2?
  108. Pretty Neat Site
  109. Big Block Confirmation...
  110. McDorman sells Dealership
  111. Irene and Carlisle, Urgent UPDATE....
  112. Irene and Carlisle...UPDATE
  113. streering damper
  114. ??? About 1960 Corvette
  115. What is a "frame off" restoration?
  116. 58 Barnfind fiberglass repair #2 ( pictures )
  117. L88 Production
  118. Need advise on 54 to 53 conversion project
  119. Waiting to install convertible top
  120. C1 Air Cleaner Assembly
  121. Customized Wall Clocks - now at DD MODS!
  122. Color question.
  123. Corvettes at Carlisle Vendor Spot Available for $100
  124. Source of New Parts for 1960 Powerglide
  125. Source for 1964 NOS body parts
  126. Why so few 57 Corvettes
  127. Very Small Question Distributor SHield Plug
  128. Interesting Info from NC DMV
  129. 55/56 hybrid body
  130. '61 rear leaf springs (again)
  131. Hello Irene, goodnight Carlisle...........
  132. Why DeWitts?
  133. Where can I buy a new AC/Delco USA made standard coil?
  134. Seat mount bolt problem
  135. 65 Muncie 4speed triangular mounting plate
  136. OT New and inproved highway sign.
  137. WTB original 1958 oil dipstick
  138. Need to get a 1965 Tach rebuilt
  139. WCFB ported vacuum connection
  140. 1965 Driver Door will not open
  141. 67 Horn problem
  142. 64 vs 65 trailing arm assembly
  143. Running a wire from Ballast resistor to Starter Solenoid
  144. +++ St Jude Auction #79 Autographed Corvette Racing T-Shirt
  145. Loaded for Carlisle
  146. Acckkk! SMOKE!
  147. 58 starter relay?
  148. Italian, Texas style!! Corvlietti?
  149. Bad 57 Corvette Ignition Switch?
  150. Bad 57 Corvette Ignition Switch?
  151. How do I install 58-62 grab bar end caps?
  152. another overheater.
  153. Jumper Battery recommendations
  154. C2 Fuel additive
  155. Grande Prairie drags and show + shine pics
  156. Identifying correct heat core
  157. 235 engine oil leak?
  158. 1962 master cylinder
  159. I Won...I Won...
  160. Need to borrow a side pipe cover.
  161. Need help to find an oil pan please
  162. XM radio
  163. 66 LIC Coil Springs?
  164. Mid year trip Minn 2 La
  165. 1957Corv, how to wire Switch/Reistor/Coil
  166. Translogic on the Evolution of Chevy's Legendary Small-Block
  167. [OT]That was bloody awesome!
  168. Provette76 check your email.
  169. 63-67 grand sport style spoiler, who makes them
  170. Some History of GM/Chevrolet
  171. 1965 327 4spd car, data plate help, best resources to learn about C2's??......thanks.
  172. Corvettes @ Carlisle Display Cars
  173. Why are C1 and C2 in the same forum No Msg.
  174. Corvette World Tribute Video
  175. Best way to add tunes
  176. Finally did it---5spd is in and
  177. 53 - 55 Side Curtain Help
  178. Shifter T-handle Identification Needed
  179. 62 Front Bearing
  180. ==> The CHUCK CoW Carlisle COUNTDOWN CLOCK - COOL FREE DOWNLOAD <===
  181. Hite's Chapel Car Show Photos August 20
  182. Relationship between oil level and oil pressure
  183. Side pipe value
  184. 3.36 Positrac with Powerglide
  185. C1 Overheating
  186. Early Body Scans.....
  187. What's this Holley 4 BBL?
  188. Casting nunbers needed please!
  189. Manual choke question
  190. C1 Pertronix
  191. Put the FI back on my 1960?
  192. SoCla California Stinrays 11-12 cruse from Cars and coffee
  193. Stop me before I hurt someone (me)
  194. Which one of you bought this?
  195. World Corvette Tribute pics for you C1/C2 guys.
  196. What is the BEST Spray Paint for Brake Drums ?
  197. Car show photos - August 7th
  198. Missing Gas Cap Key
  199. Newbie questions /compare 63 - 67
  200. Custom autosound knob problem
  201. Minden Nevada car show
  202. Body mount kit
  203. Looking For an Inspection in Bellingham, Wa
  204. 67 shifter trim plate removal
  205. 67 L79 alternator belt with ac
  206. Took one of the cars for a drive today, pulled back into garage, won't start. Ideas?
  207. 1964 Front Brake Adjustment
  208. 65 Alternator pulley, is this correct?
  209. Keep an extra Carb
  210. 67 #121783, Your engine block is on Ebay
  211. 63 speaker removal
  212. C1 Trunk Lid Is There A Trick To Make It Stay Up
  213. Solid state voltage regulator
  214. 1st dumb question!
  215. C4 horns
  216. C-2 Ignition Coils
  217. Purge solenoid location
  218. Temp Gauge
  219. 65-66 Steel wheels
  220. Holley 3367 vs. 3605
  221. Nick (SIXTSVN) made famous.
  222. Gas gauge does not work?
  223. coil springs,rear leaf,ride height help
  224. 1966 Big Block Hood
  225. Please decipher/critique this engine stamp
  226. 63 shifter............pros and cons
  227. '59 Barn Find Revisit
  228. What is the BLACK RUBBER CYLINDER on the starter red wire for?
  229. LONG ago ad for a '55
  230. What color?
  231. Stereo in a 65 Convertible
  232. Your thoughts on a 63 SWC please
  233. Locking gas cap story.......
  234. Good Split body F/S
  235. Differential rebuild
  236. Dyno results of new induction set up
  237. 53-62 wheel offset measurements Required Please !!!
  238. Suggest web sites to sell a high end '66
  239. No spark, Car completely crapped out while setting timing.
  240. Cruising the Capital... If you aren't coming to Raleigh tomorrow.. You should be..
  241. Drum brake adjustment?
  242. 63 Resto Mod Update
  243. ****** The "Just J" $5000 St Jude Challenge****$3000 so far!!****
  244. C-2 heater core replacement
  245. New GM vs Old GM Warrnty
  246. Vette prep checklist prior to 200 mile drive?
  247. Did you see the Caddy concept car yet
  248. Pertronix Kit and Coil Question
  249. Help with 64 rear suspension
  250. Full Throttle Corvette Summer Sale Starts Today!
