- 1959 Windshield washer coordinator
- Who sells a good pump and how to install
- Chassis Restoration Package Offered By County Corvette
- Saying thanks to Tom Parsons
- Seat Frame questions
- North Texas
- Flat Tappet Cam
- wheel backspace and rear suspension question
- 62 Play in steering box
- 340 hp intake manifold
- Valve/Rocker failure diagnosis help
- dealer info anybody?
- WCFB Dual Quad Clone Carb Numbers needed
- OT - a prayer for the Carson City shooting victims...
- Aftermarket steering wheel for C-1
- Power steering improvement for 65
- New a/c into old 65
- Removed Alarm, Car Won't start! help please [1963 C2]
- Seat belt retainer (65-early 66) no holes
- Stumped on a vapor lock issue...looking for help
- Stumped over vapor lock issue...looking for advice
- Muncie Rebuild in SOCAL
- Anyone have some advice on converting RPMS to speed?
- Custom muffler costs
- Suggestions for a shop to tune my 67 in San Francisco Bay Area (East bay?)
- Pro Stock Engine Technology
- Gas tank floats
- Water Temp gauge replacement
- Wheel Fitment Issues
- How to turn my engine over manually
- Oh No...now what do I do...door stuck problem
- Rear Diff Fluid
- Torque Thrust D Wheel Fitment
- Z06 brake upgrade installation
- '64 windshield is in!
- '65 - Bad Alternator?
- Labor Day Show
- Seat back won't lock on the '67, help!
- 58 Barnfind quarter panel repair ( more pictures )
- Pics from a neat country car show
- Two Classics, One Car
- 1955 Copper - Mr. September?
- Made some progress this weekend...
- Anyone in Spokane WA. can look at a car?
- powerglide in 67 L79?
- NJ Inspection Sticker (Pic)
- For that classic race Corvette?
- 1960 Resto mod color
- Vapor Lock Cure
- Distributor Vacuum Advance Control
- 1961 front sway bar
- high red line tach
- 327 Edelbrock or demon carb conversion,Do U have Pics?
- We lost betty skelton
- removable crossmember 63-67
- Pure gas.org
- e brake stuck
- Fulie Perc Heat Attack Plan B- SuperCoating
- Wildfire claims 2 Corvette, see how it was handled!
- Time for a New Soft Top
- Nice car but it looks bogus from description.
- 64 C2 completely dead electrically.
- Advice needed TA rebuild in Minneapolis
- Header Question
- 63 headlight switch
- Need to find pictures of a grey/black flared 65-67 Stingray Fastback Coupe...
- Drive Shaft U-Joints Torque?
- C2 - Running a 650 Holley DP with rear draft tube
- Installing one Piece front end on 61 Restomod
- Trans or Clutch Problem?
- ~~~~St Jude Auction #88 "Sweetness" Walter Payton Autographed Wheaties Box Flat ~~~~
- *** St Jude Auction #87 Autographed Hero Cards from St Pete Gran Prix ***
- Local guy wants to trade me this for my coupe.
- 64 Bashing
- C2 Question - Glove Box Install
- 66 Wiper Transmission help needed
- Pro Touring- Road and Track- Grand Sport- B/Production
- L/S break lights just stopped working
- 57: connector with 2 pink wires?
- Oil Fill Tube Cap Question
- How to bench test the washer pump ?
- How to Test a Power Brake Booster
- 67 door panel removal
- How to install center arm rest on 63 vette?
- hood hinges
- 58 Barnfind Driver side quarter panel ( pictures )
- Pics needed please
- Super Quiet Side Pipes
- Rear strut rods -64
- 61 vette glass bowl filer 283 ci 230 hp
- Need some helpful advice on setting timing 60vette
- Repo fuel pumps
- rear exhaust panel plug
- If the Devil drove a sports car . . .
- body plate decoding
- 1958 more leg room needed
- C1 wheel bearings observation.
- 61/62 Show me your fuel lines.
- Info needed please
- 65 Coupe rear vinyl filler
- Too much vacuum?
- Carter Carb Plug Leaking
- What is the difference in NCRS points for paint
- C1: tach drive grease?
- assemble 62 windshield?
- 57 Brake warning switch wiring?
- 67 Muncie Trans = Rear Axle Shaft Seal Replacementment.
- Champion Plug for SBC With 461 Heads
- Reproduction 1962 Rocker Moldings
- 63 Early vettes
- FREE! Someone needs this.
- Need advise on Holly 1901 carb
- 1962 Rocker Moldings Restored
- 53 to 55 pinion seal
- Intake port size
- '67 crossmember modification
- need help locating an original 67 435 air cleaner lid with original 435 decal
- 1961 rear sway bar links
- cleaning up 54 carb lines/fittings
- Dog dish resto..
- Carlisle pics
- 62' Radiator Hose help
- underbody retainer finish
- Went to Carlisle to find a car!
- Thoughts on Factory Radio Delete '67
- 1963 T10 trans ID question - main case
- Hardtop Interior Trim Paint Sheen
- Bloomington Gold Dates in Springfield and Bloomington
- Screw in rocker studs
- bumper chrome on 66
- Oil pump bolt torque?
- 1967 Red on Red 427-435 Coupe E-Bay
- On the road again.
- auto trans swap 200r4 in a 57
- need 62' 340 hp thermostst housing
- DMV call back 3-5 working days
- Photo/poster contest: submit your entry
- B-17 flyover
- What's the $$$ on a 65/6/7 'driver' non-matching #'s car???
- distributor advise
- interior paint
- aluminum intake manifold question
- 3 point belt/shoulder harness
- Booster on Clutch?
- Free Shipping Offer from Corvette Central
- Its Friday:Time for a smile
- Help with headlight motor adjustment 1966
- 1967 427/390 Intake Manifold Questions
- 64 Vert - Manual to Automatic Need Advise Please
- How do I install and use the hoist?
- Wash foam filter in air cleaner?
- A/C wiring in a 66
- Clone vs Orginal
- availability 15 x5.5 rims for a 64
- Timing Light troubles.......
- How to identify which motor was originally equipped?
- Brake Line Routing
- Son has a c5 needs help!
- 63 with right side mirror
- My car is 47 today!
- power glide to 350 or later auto
- Ideas for BB valve cover decals???
- Based on these 65' pics.. what can you tell me?
- A/C vacuum lines in a 66
- How to Connect Dwell Tach Meter
- richmond 5 speed w OD in 59 vette
- 58 Barnfind quarter panel repair ( pictures )
- 1966 Soft Top Weatherstrip Fasteners ?
- Who is going to the SACC Natl convention?
- Valve Cover Decal
- 1966 Convertible Rear Window Straps?
- ### St Jude Auction #84 Don Mattingly autographed photo and commemorative plate ###
- checkboard gas pedal
- C2 Steering Column Install
- C2 Gas Cap Lid Cover Install
- Rear mirror adjustment
- Help for a 64 corvette
- Best torque for my money?
- LS2 vs. LS6 - torque
- 66 Project Car
- Ohio Corvette
- Problems with ethanol fuel article
- seat seperator latch bracket
- Anybody seen one of these.....?
- 64 Transmission leak?
- Need weatherstripping source
- Stayfast Top
- 65 wheel and tire pictures
- Is anyone running 15" wheels on a C1 with C4 suspension?
- Newbie needs help!
- Free beer !
- Anyone installed a POA valve eliminator kit?
- Some Carlisle shots, my favorite C1, blue cars, etc...
- paint and body questioin
- Does anyone make areplacement floorboard for a 61/62?
- HP please on a 327
- C1 owners I'm asking a question
- Any ideas what this patch is all about?
- wood shifter ball
- 65 power antenna
- NCM Insurance or Hagerty
- 54 w/o engine, restore or resto-mod?
- NCM Insurance Agency Launches New Online Services
- '61 rear sway bar
- 1964 vet gas tank fuel sending unit
- 62' Hoses under the hood
- What Color Speedo Gear
- Real Yenko?????
- 58 - Headlight Bucket Question (R1, R2, L1, L2)
- Corvette mechanic needed
- OK, here is what I've chosen so far for my '61 resto project
- 1965 Tires Correct Brand?
- Alternator conversion for 62 vette
- (CRUISE) Saturday Sept. 3rd, Lehigh Valley/Easton, Pa.
- Can't Get Reverse to Work
- 65 Vert windshield is in!
- Location of Oil pan plug for a 62
- Electrical Issue
- rear leaf
- 58 - Original color question
- New 61-62 Seat Cover Installation Video
- CL Search Engines ???
- Carlisle – the good, the bad and the ugly!
- wiring help 65' coupe rear blower switch
- 1965 396 documentation
- RestoMod c2
- Bought the lifetime alignment from Firestone
- 1964 corvette heater core problem
- 1964 corvette electrical problem
- Structural Differences In 56 and 57?
- '61 Drum Brakes Work.....
- Curious
- Rough '64 project vert at Carlisle
- safety locks at Spinners of k/o wheels
- Brake light question
- C1 Rear Wheel Well Repair
- C1 & c2 trailing arm
- Please, please post pics of any C1 Vettes with 17 inch wheels
- Another dash question, with pics!
- Quick Rim Question
- >>> St Jude Auction #83 Autographed Wixom Engine builder poster <<<
- Looking for original owner information
- Removing Oil Filler Tube
- 64 AC dash question
- Coupe Over Door Weatherstrips
- 63 Hood insert painting
- Few Pictures from CMS Autofair this weekend
- steering
- AC not working. Anything I can do to figure it out?
- zz4 crate in a 66 powerglide car - driveline
