View Full Version : C1 & C2 Corvettes
  1. 1960 generator
  2. Hood Release cable
  3. 1966 Valve Cover Indentation Start and End date
  4. Carb ID.
  5. C1 and C2 Owners in the Southbay of LA
  6. Speedo cable removal from trans / best tool
  7. instrument light shields 64
  8. 62, 340 hp, intake & carb question
  9. We lost a friend Steve Kosch 4440Stevevette
  10. end links
  11. Headlight bucket alingment and no blower motor questions
  12. What lube to use on a 65 steering box rebuild?
  13. Spark Plug Analysis
  14. Keeping critters away from your car in the winter
  15. 67 hardtop vinyl or painted Thoughts
  16. Front Power Disc Brakes
  17. Heater Core Water Shutoff
  18. Shameless car show ad
  19. Help! Mini-starter &TI wiring!
  20. 13.07 @ 104.82
  21. I need help buying a '62!
  22. Found this Picturesque spot in the mountains on the way to show
  23. Some random pics from MA Funfest today:
  24. 1x4 or 2x4 WCFB power vs fuel consumption questions
  25. She Comes Home Monday...
  26. Can anyone identify this rally wheel
  27. 1960 PG Tranny Question
  28. 1963 Steering wheel
  29. need help mating richmond 5 speed to 4.8l LS1
  30. Paragon's Open House/Lunch Pictures
  31. step up transformer for garage
  32. C1 Soft Top Fasteners
  33. What's casting number for 1962 rear end
  34. 62 Front Brake "Upgrade" back to Stock - Success
  35. Who Can Restore This
  36. 54 Vette on eBay
  37. Cleaning Knock Offs
  38. Corvette buckle model year?
  39. 1963 Restomod HOODS??
  40. interesting '67
  41. Headlight door switch repair help
  42. 54 Corvette sales
  43. Instrument cluster mystery item?
  44. what are "unrestored" 58's worth these days?
  45. If you have an ipad
  46. How to repair a flooded Stingray coupe?
  47. '61 racer
  48. Chevrolet Hall of Fame Museum 2 HUGE events!!
  49. grabbing feeling in rear
  50. C1 side engine mount
  51. Cruise Control Unit The leg you save may be yours
  52. OT..P-51 crashes into stands at Reno airshow
  53. BB Intake manifold Height
  54. O.T. Bad news from Reno
  55. Show us your LS engine in your C2
  56. '58 in Washington state
  57. Share The Hobby
  58. O/T SEMA invite
  59. C1 Help with electrical issue ? Lights
  60. New Article about the Corvette powered British made Gordon-Keeble GT
  61. rugby world cup - nz
  62. 63 Frame stencil question
  63. Has anyone replaced their concrete garage floor?
  64. C2 vent window pivet question
  65. rear leaf spring improvement for C2?
  66. Question on exhaust donut sleeve
  67. FYI How to search all of Craigslist at once
  68. AFter 25 years time to replace some parts!!
  69. Instrument Cluster capacitors missing
  70. Underdash Sound Deadener
  71. Yenco Corvette?
  72. Sequoia/Kings Canyon Fall Corvette Tour
  73. A little trip down memory lane
  74. Mid America Funfest
  75. exhaust pipe clearance
  76. 61 Door Post weatherstrip clips.
  77. Does anyone have any empty valve cover boxes?
  78. Its Friday:Time for a smile
  79. Gas in Carb vacuum line???
  80. 67 AC compressor
  81. Where can I purchase standard v-belts?
  82. Settle an argument guys........
  83. American Racing Torque Thrust D 15X8"
  84. What's it worth?
  85. 62 Vette
  86. LS6 conversion - fuel pump question
  87. 1959 Power Train - Identification
  88. 1965 idler pulley
  89. 1965 power brake question
  90. stripped threads top of float bowl
  91. Gorilla spring
  92. 67 427/390 Oil Pan Part #
  93. hardtop rear window cleaner or polish?
  94. Anyone else attending Petit Le Mans 2011?
  95. 3.36 to 3.70 swap today
  96. 64 Body Off
  97. knock off Q
  98. 1936 footage of car assembly line
  99. Ideal Classic Cars Sarasota,Fl.
  100. zz4 crate PVC in a 66
  101. need help with stamp pad
  102. Exploded veiw of my 67 Split window
  103. Painted the hubcaps
  104. 57 at local pawn shop
  105. Question on LS3 with Automatic conversion
  106. 58 -Looking for picture of fiberglass headlight area
  107. How do you install a fuel strainer on a 62 unit
  108. Tach sender? Picture link
  109. Old tach sender?
  110. Firewall Insulation
  111. ~~St Jude Auction #97 Autographed Matt Kenseth Hat and RickyRudd Diecast w/Jack Roush
  112. New Radio for my '62
  113. Fresh air Inlet Hose '61
  114. How to post a picture
  115. Replacing Carburetor on my 62
  116. C1 Leaf Springs
  117. Corvette Central - check order status
  118. How much should I pay for a 67 coupe 350 hp
  119. 54 conv. top bows question
  120. 1964-66 parking brake cable on a 63
  121. Removal of Silicone
  122. Brake lines for 1961 Vette?
  123. Trailing arm shim that hold in place and keeps the shims from falling off the car
  124. 2 electrical questions
  125. Date codes on original Kelsey Hayes
  126. overheating 427/400
  127. Chevrolet's Mouse that Roared
  128. Transporting a car from Canada to U.S.A
  129. 62 radio removal
  130. Which year C2 to buy?
  131. Picture needed
  132. 59 -60 New Voltage Regulator stops charging when warm
  133. '56 glove box lock
  134. Assembly stamping engine
  135. ZZ4 Heads
  136. How do you take apart a 67 seat sliding track
  137. kbb.com Celebrates Chevrolet's 100th Anniversary; Names Top 10 Chevys of All Time
  138. Orientation of Heat Riser Valve on 66 Big Block??
  139. Undercoating?
  140. Hot and steamy Florida garage.
  141. Pulley and Water pump info
  142. Heater Duct Door
  143. CAM-2 engine oil
  144. Heater Housing Repair Help
  145. Heater Resistor
  146. 65 L79 fittings question
  147. 65 BB Hood GM or??
  148. Original AC 4656 or Not?
  149. O/T Say a few prayers
  150. Problem with 1957 windshield wipers
  151. 1959 Tachometer Removal
  152. '63 Headlights
  153. 4 speed conversion value
  154. The richmond 5 speed OD
  155. T10 shifter repair and maintain 63 swc early
  156. Muncie Question
  157. Mistery strap in left reat quarter
  158. 5 speed or 6 speed for C2
  159. LS1 or LS6 with stock 65 radiator
  160. Rack and Pinion
  161. 58 -Easiest way to remove doors?
  162. C1 door mech rebuild
  163. Wont turn over
  164. 63 SWC starting to run hot
  165. Would you leave your car alone
  166. Specific installation info needed for '62 valve covers
  167. Water pump identifcation
  168. Trim tag location
  169. 1964 differential vin number
  170. C2 - Chubb Rub
  171. HEADLIGHTS won't FLIP OVER
  172. C2 - Heater wire connections
  173. 65 Coupe prior owner info wanted, Tenn
  174. Back from LS Fest, did anyone else go??
  175. '57 trunk mat questions
  176. door latch lock mechanism - new
  177. Question...58 rear bumper bracket
  178. C2 Window Crank Knobs - Removal Question
  179. Adjusting Clutch fan?
  180. 62 Blower Motor
  181. Delay wipers
  182. Fuel Pump for 1961 Vette 270 hp 2X4
  183. 64 Corvette Temp sender... how to check
  184. How to achieve factory black finish on coil springs
  185. What is this exhaust date
  186. So you think you drive your car a lot.
  187. Corvettes & Classics car show Oct.1
  188. Need help here guys did a search no help
  189. New 468 in and running........!
  190. Install Oil Fill Tube
  191. *#*# St Jude Auction #95 Case of AMSOIL 5W30 *#*#
  192. correct air compressor size
  193. Does anyone know what GM 3987265 fits?
  194. instruments and wiring harness
  195. How to check if temp sender is working?
  196. Stripped out door sill screws
  197. Electrical guru's needed.
  198. '60 Powerglide Weeping Through Gaskets
  199. Return To Idle Problem
  200. 1.50 exhaust valve?? WTF, over!
  201. Stewart Warner Tachometer Question
  202. New turbo?
  203. Generators and VR's I love them
  204. Vent windows
  205. 9/11 Remembered
  206. Heads 8782461
  207. 63 parking brake help needed
  208. non PB master cyl for 59 restomod
  209. What are Your thoughts?
  210. 53esque vette
  211. Silver 58 Restomod with LS7 at Bloomington
  212. Corvettes and the flooding
  213. Another dash light thread *** HELP***
  214. Brake fluid?
  215. 67 Super rod SRIII
  216. I went to National Corvette Muesum Today
  217. ~~~~~ St Jude Auction #94 Time to clean up...Detailing Supplies~~~~~
  218. New Seat Covers Who to use ?
  219. Difference in 1963 tank emblem and lid
  220. 67 Resto Rod
  221. Western turbine wheels
  222. Where can I find these?
  223. Phenolic spacer
  224. Headers for LS7 in C2 chassis w/ muncie
  225. 62 door lock not working, maybe
  226. Hub caps on 53
  227. AFB Choke body piston
  228. Can a 40482 fuel pump be rebuilt?
  229. C2 Spare Tire Carrier
  230. 1961
  231. Who remembers or took part in the Stars and Stripes across America Tour
  232. 53-54 carb pics
  233. 1snake you all right?
  234. Question on value if parts.
  235. Holley Carburetor ID
  236. Casting date on a 3 speed transmission
  237. Pics of my new setup
  238. Another plug question, Resistor or not
  239. "pinning "knockoff wheels...
  240. AC44 or AC45
  241. ZZ4 Block ID
  242. 1966 front brake crossover brake line
  243. C1 Owner in Biloxi, MS??
  244. Vettes on the Square
  245. Reproduction headlight bezels for 1960
  246. it's friday, time for a smile-vicz
  247. I wonder how correct it is?
  248. AC 4656 Fuel Pump-Restamp?
  249. heater/Blower box
  250. 65 L79 Carburetor studs
