View Full Version : C1 & C2 Corvettes
  1. Diffence between original and repro yellow radio card for 67 vette
  2. How Does A New Member Of CF Add An Attachment
  3. FS Body Cart/Corvette Attachment
  4. C2 Battery Cable Clips with A/C
  5. Charlotte Goodguys show
  6. Value added by awards?
  7. lights dimming
  8. ANOTHER Corvette magazine failure?
  9. Tubbing '62 convertible
  10. Two fuelers for the fuelie lovers, one is a fake, for those who care.
  11. Connecting heater hoses on C-1 ??????
  12. Is it just me or is this a decent deal?
  13. '66 brake caliper casting #s
  14. How many of you.........?
  15. 3 spd or 4 spd in your C2
  16. Two classics, both fun to ride.......!
  17. Behind glove box
  18. Luggage stop / Drive shaft tunnel picture
  19. Production numbers by exterior color
  20. Daily Beast on Chevrolet
  21. Fuse Box - Bulkhead Coonector Pin Cleaning Question
  22. found a cool old gas station
  23. Sandblasting the 54
  24. Sandblasting the 54
  25. look here and maybe get a 65 427 for 27.5K
  26. Acceleration hesitation.....
  27. The Dummy Is Stumped--64 center console install with power windows
  28. Clean Air Tube
  29. C1/C2 at Car Show in Padova/Italy
  30. 63 SWC Assembly
  31. Market values for 1962 vette
  32. 63 Powerglide sprung a tiny leak
  33. Chrome plater
  34. Quality of reproduction turn siganl switch
  35. spot a bad birdcage without removing parts?
  36. AM Radio Sucks!
  37. Interior Kit Recommendations Not AK
  38. Head lights flash and motor surges ?
  39. evaporator box
  40. What is a jumper wire ?
  41. JR Motorsports Fall Car Show Fan Favorite
  42. All afternoon to change a bulb
  43. All afternoon to change a bulb
  44. 63 Convertible survivor
  45. Remains of a 56, what is it worth
  46. To modify or not to modify 1963 SWC
  47. Grandsport info?
  48. Accelerometer (G Meter) needed for midyear Corvette racecar.
  49. 65 pedal support studs
  50. Early 65 parking brake cable grommet
  51. 65 steering wheel
  52. Just wanted to know...
  53. 65 Clutch rod
  54. SWC radio
  55. 67 Parking Brake
  56. More 65 brake pedal assy
  57. Original 67 head rest seats
  58. 65 brake pedal assy
  59. tach cable for 64
  60. C2 headlight roll switch connector
  61. T-10 trans dates
  62. A New Corvette Owner
  63. Which C1 would you buy?
  64. 100 years of Chevrolet racing.......
  65. 1961 Engine Rebuild Pictures
  66. "Pulling The String" on a ZZ4
  67. Barrett-Jackson Scottsdale Trip Planning Help needed
  68. 58 grill area
  69. dang!...........can't believe I did this
  70. Petronix or Lectric Limited. Poll
  71. Help 2004 Crate LS1 Long Block ??
  72. Gonna be More OLD mustangs on the road.
  73. Holy moly~check these out
  74. Who knows Edelbrock AFB's?
  75. 67 Birdcage to Frame Ground Question
  76. 365hp valve spring?
  77. Free Shipping Offer from Corvette Central
  78. Phenolic spacer - is this the right one?
  79. C1 non R&P power steering
  80. mild cam in a L76 365hp?
  81. I Need info from Miami FL. Can you help
  82. Distributor Advance Spring Choices
  83. Ride height
  84. It's Friday....Lets play How many things are wrong with this picture?
  85. ST-12 '53-'62 Service Guide
  86. Its Friday:Time for a smile
  87. 67 427 confirmation
  88. exaust manifolds
  89. These new fangled locks suck
  90. exaust manifold
  91. Frame Shop in CT
  92. Clutch pedal fixed
  93. 65 gas pedal lever removal
  94. Need a pigtail
  95. $25 MIB on Race Ramps!
  96. 65 gas pedal
  97. 65' 327 Compression irregularities
  98. Single Post Lift
  99. Obsessive pre-drive routines
  100. C1 power steering
  101. '60 sending unit
  102. 1963-1967 article on gas line replacement
  103. A word of caution
  104. exhaust leak and valve cover leak
  105. Sand blast nozzles
  106. Price Advice Western Wheel Knockoffs
  107. Water pump pulley
  108. cam degrees make sense?
  109. 66 427 plug wires
  110. Source for windshield wiper motor repair---help the dummy
  111. 62 shocks
  112. clutch return spring 59 corvette
  113. Is this license plate frame anything special??
  114. Fuel additives????
  115. My new toy
  116. Piston to wall clearness
  117. Shop Compressor Recommendations
  118. Reproduction water pumps
  119. 90 degree elbow?
  120. Z06 Factory Tour
  121. 65 parking brake paint or no paint
  122. Think I just avoided a disaster
  123. What is the correct number for a 1962 starter
  124. 68 tach ID....?
  125. Modifying my garage floor
  126. re-placing anti-squeak pads for gas tank
  127. How to track down previous owners on pre 81 vehicles?
  128. Help identifying distributors?
  129. Axles
  130. C1 leaf spring arch specifications
  131. Restamps and NCRS
  132. Happy Birthday - October 26, 1966
  133. eckler one pc. nose
  134. Hood release handle
  135. Any experience with RM or Mecum auctions?
  136. 1961 Idle Question
  137. dealer number in 1966
  138. NJ/NY members here
  139. bouthie
  140. Ever consider trading cars ? website to check out- www.tradinpinks.com
  141. No brake lights
  142. Eclkler Shoulder belt kit
  143. Small Block Clutch Parts
  144. Al Knoch..Is it me or what? gotta vent
  145. DO you put sealant on head bolt threads
  146. speedo cable color
  147. Used Oil?
  148. 53-62 Brake Master Cylinder
  149. Does anyone make a custom front grill for the C2?
  150. 2 questions - intake, temp guage
  151. SB Tri-Power update. PICS
  152. Interesting Chevrolet Article
  153. L79 Standard flywheel tooth count
  154. It was for medicinal purposes
  155. MTI Racing in GA feedback....
  156. Who makes the best repro knockoff style wheel?
  157. Bump
  158. Marker light pigtail and other misc...
  159. Opinions wanted
  160. Seat repair
  161. Charging system
  162. problems when I turn left?
  163. steel wheels
  164. Test for '63 Temp Guage
  165. steering column help
  166. distributor bottom thrust plate?
  167. Brake Job....?
  168. Big inches for resto rods
  169. Rear End Advice Needed.
  170. new member question
  171. What method do you ue to lift V8 engine from car
  172. C2 Content: Then & Now | 100 Years of Chevrolet | Chevy Centennial
  173. Rear harness,socket bulb problem
  174. New 63 Roadster
  175. Exhaust recommendations for '65?
  176. Paint a 1960
  177. Corvettes on eBay: a $400K 1954 Corvette Nomad Recreation
  178. Question about parts dealer
  179. Replacing Coupe Window Felts
  180. Wheel Valve Stems for a 66
  181. Russo & Steele Scottsdale 2012
  182. Not fair
  183. 300 HP Valve Covers 1962, steel or alum
  184. Restoring 65 hubcaps
  185. Birthday
  186. Power Windows in the '61
  187. Advice on the 62 Corvette 340 HP manifold
  188. Plexiglass lenses (64 resto mod)
  189. Ls 3 in a swc
  190. engine seems to shutter while idling and under power
  191. Why can't they make it easier?
  192. Lydia, My Wide Body 64 Coupe will be making her debut at 2011 SEMA show Nov 1 - 4.
  193. Cast iron PG for C1
  194. finished the spindles and backplates
  195. New shoes for the old vette...
  196. Cool website to check out
  197. Who sells rebuilt master cylinders for 58-62
  198. Temperature guage not working on '63
  199. 67 Wiring Question
  200. My mini "barn find"
  201. C2 rear suspension geometry questions ..
  202. 62 Manual and Knock off
  203. 65 instrument light bulbs
  204. '66 gas tank removal
  205. Is canister style oil cansiter suppose to use filter o-ring?
  206. C2 with a Gear Vendors OD
  207. Capacitor plug in problem
  208. DIY aerial video of your Corvette
  209. Signet Red & Roman Red
  210. Looking for my dads old 67 l88 from Cleveland, Oh
  211. Can not remove KO wheels
  212. They get better with age.
  213. My 65 383 stroker is running very rich, need help.
  214. Cascade Green Corvettes 56-57 and 60??
  215. ah crap!
  216. 64 Power window question
  217. 66, 427/390 motor mounts
  218. VIN number on frame under body, why
  219. Carter Carb rebuilds
  220. Guldstrand suspension style .....?? OLD
  221. Grand Sport I.D. (Slash) Marks on the Fenders
  222. Dual Quad Hole Repair Advice
  223. trip odometer bracket
  224. Caroll Shelby and Zora
  225. Frank.
  226. 67 435 vers 67 435
  227. L76 - 326 water pump
  228. Steering column escutcheon removal
  229. 1963 steering column escutcheon removal
  230. Ecklers Removable Hardtop
  231. EFI Dual plane intake NA?
  232. Casting Date for cast iron case t10
  233. Frank.
  234. Spare tire for C1 will not let board fit flush
  235. Diff oil
  236. Clutch problem solved
  237. 61 Offset wheel/tire setup
  238. Roll bar for the 62 gasser.
  239. 67 Battery Gauge Capacitor
  240. metallic exhaust tune
  241. Couple of Drag racing videos from LS Fest
  242. Battery dies!! HELP PLEASE!
  243. What is an Open Rear End with Posi Guts Worth??
  244. Ft valance pic
  245. speedometer "bounce"?
  246. C2 emblem for floor decal
  247. 65 pedal assy rebuild
  248. 66 427 power steering adjustment for belt
  249. LS1-2-3 Guys, Where did you get your engine?
  250. Horn Relay Question
