- quad bolt tightness
- What kind of KEEPERS/LOCKS do I need?
- 68 Trim Plate......?
- Q-j question
- Motor change during overhaul
- Frustrating Diff problem
- Rear Emblem Positioning
- Small Block sat for a year
- restoring the interior of a 79
- How to upgrade to an internally regulated alternator
- Uncommon brake problem !
- 1.6 rocker arms
- Afterfire- Real bad
- 1977 Corvette L48/Auto dyno results
- Aluminum steering knuckles and arms
- pushrods
- Centerforce Dual friction, pivot ball set up?
- Clock Knob - 1969 Corvette
- Anaerobic sealer for trans pan: gasket or no?
- Coil Wire Resister
- 360 Forged Wheels & Kaoss
- fuel guage vs. sending relay
- thm400 occassionally blows fluid out the dipstick/filler
- 79 L-48 Leaking Transmission Lines
- Does anyone know where to get a Delphi Bow Terminal?
- oil flow on 350ci L82 Engine on '74
- Brake Light Staying On
- Auto-4speed conversion & U joints..80 model
- Power steering upgrade
- broken valve spring, recomend a book?
- Red Paint
- How do I move wiper switch guts to new bezel?
- Steering on my 74 is stripped
- Lets talk weather pack connectors.
- Oil Pan Gasket
- HEADLIGHTS - Where to buy replacement lights?
- Vintage vs. Classic auto air
- 81 fan switch observation
- Rear gear ratio
- Detonation on part throttle!
- Won't Fire Up
- Houston body work referral
- Check Engine light and too much advance
- gear splits on 6 speeds
- stupid headlight switch
- Attention....attention...attention. Neutral safety switch alert!!!
- Help Needed--Hydraulic Clutch Install / Brake MC Booster ?
- U joint specs
- Need some help please--new engine
- L88 hood drain holes
- 82 trouble starting
- Anchor bolt tab (guide) needed for parking brakes?
- who make a good 37 degree flare tool?
- Ok electric fan choice question!
- Body Mount #3 and birdcage Question
- How to remove rear speakers on a 1979
- 81 upgrade
- Top End kit and carb
- ready to give up
- Holley idle mixture screws
- Who is running this setup????
- Shifter console question (with pics)
- 82 Vette-What is 2nd and 3rd Gear for on Console
- Holley R-4055A fast idle adj.?
- Need some help with ground wiring - 71
- Speedo cable lube
- smoking between shifts
- oil pan RnR
- Starter!! problems
- Exhaust Clamps
- which alternator is best for me
- Help...Brake Problems.
- How do you size AN fittings and others?
- HELP!! Did I crack my trans?
- Spakr issues have returned...
- Body Mount Question
- need advice top end swap
- Corvette Show Pics
- 76 Tach Pegs at WOT
- How do I find bolt/fastener size from AIM or Shop manual ?
- Can i run a 18 by 10" rim on stock trailing arms
- Stalls under load
- Engine quits then immediately will restart
- rear sway bar rubbing on stock rally wheel
- 200r4 lock up switch help
- '69 350/300 Rear Suspension
- Am I crazy?
- is Van Steel Differential rebuild worth cost?
- Gas tank sending unit
- Ignition switch replacement
- I'm tapping out!!!!! Help.
- PS Control Valve Rebuild....leaking
- Bubble tail light lens
- Costs for replacing clutch in '76 L-48?
- what are my dash lights telling me ?
- C3 blower motor up grade to C4?????
- LS2 swap under way
- Brake help
- Exhaust Cross Member Question
- Headers compatible with factory side exhaust
- first time at track- ran 11s!!!!
- T5 swap : help me find this part
- Tachometer with MSD
- Tech: 72 Wiper Switch & Operations Issue
- 78 interior leak
- triangular air filter
- 78 interior leak
- Hood Louvre relay 81
- Neg. battery cable question
- Header Opinions
- Correct Tripower Intake with given Carb set
- Haven't been here in a while.
- Tripower
- Bolt size for 82 CFI manifold
- Computer removal on an '81???
- battery charge
- Cam choice for AFR 180 heads
- Comp Cam 12-420-8
- Using Lizard Skin for insulating the cabin from the engine bay heat
- Anyone know?
- shifting rpm solution
- Starting to spend my saved $$$ into a auto-to-manual trans. conversion.
- Differential noise
- Using an ohm meter and temperature sending unit
- ZZ4 starter question
- 1973 tilt steering
- When Considering A Coating Or Not..."Headers"
- Price For a Good Set of 2.73 Rear Gears?
- vacuum advance question
- thoughts on differential drain plug
- '76 Shifter Console Trim Plate Wood Insert, Auto w/ac
- 77 Wiring
- More photos of C6 Z06 brakes on 1980 C3
- '67 and '69 BB radiator interchange?
- Engine Wire Harness Question
- trouble shifting..
- School Me A Bit
- Can advance timing and not get det.?
- Battery Hold Down Rivets
- 69 shoulder belt guides - correct screws?
- Recommended Tire Size for my '74 ?
- Brakes pull hard to left
- Tightening PS belt 72
- Holley Street Avenger ULTRA 770 for my 383-500? Any experience?
- What years came with 140mph speedo ?
- Side View Mirrors 76
- Left Front wheel to forward
- Anti Freeze ?
- Replacing 4 speed Rear Seal
- 1968 Seat Spacers?
- exhaust upgrade
- Choppy clunking rear noise
- C6 Z06 brakes on my C3
- need help, please no juice anwhere in car
- 1976 Stingray DIY Project w/ pics
- Transmutation gears calculation
- Vert top not staying latched
- Any known issues using tall valve covers??
- bent / broke push rods
- Courtesy light door switch question
- Painting door of '76
- rear sway bar rubbing wheel
- Vanacor hood or not.....
- Upgrade old Distributor or buy new MSD unit?
- Is this the correct Distributor Cap for 1975 HEi
- 81 electrical help!
- Where is my oil going?
- Starter Question
- Alternatives for 1969 Door Ajar Buzzer
- Choosing Carburetor HELP
- Engine knock
- Squeaking brakes?
- Help on gas tank
- Horn Relay on 1980
- Heater cable adjustment
- 1979 4spd question
- 69 Fuel tank replacement
- Saginaw Steering Pump-68 Vette
- cowl induction
- Ammeter Gauge
- Saginaw Transmission Oil Seal
- Courtesy light question
- Wires, plugs and spark...
- '82 tranny
- 1982 crossfire
- Correct Susp Spring Upgrade
- Which part # is correct for a 73 L-82 4 SPD distributor ?
- Body Off/Mount SRIII Frame Chassis
- 73 distributor..1112130 and 1112159 interchangeable ?
- Strange Starter Noise
- Doug's Sidemount Header Install
- Am i getting ripped off by engine builder
- 69 Hood Latch
- 1969 Engine/Trans rebuild
- Mystery Q-Jet Part
- Engine Harness Wiring Questions
- Need torque value, rear trailing arms
- Kick panel speaker help on a 69 coupe
- Electrical question Fuseable link
- Converter selection help
- While I'm waithing for a part...
- hardtop mounting hardware
- Intake install
- Any "Delphi 600" specialists out there?
- New Radio/Old bezel
- starters
- Hood clearance question?
- Edelbrock Performance Top End Kits-Getting More Horespower
- Rectangle headlight conversion ???
- Headlight "UP" adjustment?
- 79 t-top headliners
- please help with battery drain on 79L82
- 77 uneven from the rear ???
- OK...I'm batting a 1000!! on the neutral safety switch
- Glove Box Lock HELP !!
- Question on brakes
- <::::Electric Fuel Pump Comparison Tests::::>
- 74 crate engine install update
- 71 C3 Power Window Problem
- Turn signal problem on 76
- LS motor swap people
- wilwood d8 calibers
- Trans Tunnel/Underbody Insulation-What's Best?
- dash light bulbs
- 76 Bumpers
- 1970 Steering Box Seal
- Need help with vacuum accessories
- Edelbrock Performance Package Question
- Coated headers?
- Bee Jay's hood lightening mods!
- removing a rear end cover help needed
- LA carb specialist help?
- Wiper assembly picture please
- Oil pressure sending unit
- Crankcase pressure
- Intake Manifold Gasket Metal Tabs
- 1981 Corvette Won't Start - - Help!!
- Window tint,good or bad?
- Muncie M20 - 3rd gear synchro problem.
- B&M QuickSilver ratchet shifter installation
- Oil drain plug, Diff plug, Tanny drain plug
- 1969 350/300 fuel economy/performance
- 1973 front brake calipers
- QuadraJUNK
- Wobbly rear rotor...what's the problem & fix?
- How do I adjust Front Body Photo included
- Engine ID
- How Much Vacuum from Vacuum Check Valve
- LS1/T56 pricing and fitment quesitons
- 1772 big block
