- rag joint replacement.
- Check out my car (www.9teen70vette.com)
- Balancing new pistons required?
- TPI conversion question
- 69 Chassis tech and road racing
- Oil Pan sealant
- Radio Antenna Issue
- Pretty lines.....
- 68-72 center console restoration
- Latest update 69 chassis
- Tire questions, need suggestion from tire experts
- blew my power booster? want hydroboost help
- 73 AC wiring help
- 1980 brake light and problem
- 79 freeway overheating
- Rear End Help
- HVAC Control Assembly For '73?
- Catalytic regs in MN
- Broke down and bought electric FP. Rerouted fuel lines. Will this work?
- Installing the '69 AC-Heater Control Assembly
- Fuel line help.
- Aftermarket Stereo install question
- catalytic converter and muffler
- Tilt/ Tele assistance please.
- Coil vaoltag #'s
- Push Button Start - ideas?
- What's Under My Hood ??
- Converting stock TH400 VB to Full Manual....
- 77 corvette frame dimension
- What should oil temp be on
- Anyone running 130+ amp Alternators - Wiring?
- Understanding oil viscosity numbers
- no power
- Photoshop request
- Need your opinion please
- Dose it hurt the value to flair fenders
- Quality Rep
- Corvette Bogging When Accelerating (Any Ideas)
- 350 Starter Defect...BE WARE
- Need help with electrical problem
- horse power, crankshaft vs rear wheel
- LT1 Swap power steering problem
- Secondaries not opening???
- Any one ever use this torch?
- help interpret vacuum readings, please
- Difference between 69 gas cap and 79?
- bonding adhesive
- power steering control valve
- big block missfire
- Fuel tank help.
- found the problem
- Shipping seats
- what is this?
- gas leak question
- Help ... break lights ...
- What is my LS1 C3 worth?
- Surging 82
- Not NCRS - but really cool
- so what u guys think of this wheel....
- Factory Calipers vs aftermarket
- 75 cowl Hood
- Help needed with fender and tail lamp panel replacement
- 78 Carpet Replacement - Any Advice?
- 77 windshield trim
- Upper Radiator Hose
- Help - Is it possible to 'unwarp' a T-Top Headliner?
- c3 bird cage
- Which vacuum port for Dist advance?
- Changing Rockers to rollers
- 1982 Rough Idle
- 1980 air cleaner assembly question
- Relay location?
- Bypass Vapor Canister: How and Why?
- Car is killing me
- Interior refurb complete with pics
- I screwed up!
- Tilt steering electrical open
- Starter Problems help! 168 tooth
- 73 headlight trouble
- 454 bogs at WOT - ???
- Performance SB/BB parts sale.....
- Radiator Lower Water Neck
- New door handle removal problem
- Lower shock mount woes.
- need some info on replaceing rear main
- Air Cleaners under 14 inches
- 90 degree or straight boot wires Need opinions
- Remove Inner Springs for Cam Break-In??
- piston selection help
- E Brakes 1976 Vette Stingray
- Enough panel to fix my vette?
- Differential Fluid Change / 79 Vette
- 1970 Front Bumper Install #2
- calling it quits on betsy
- need help finding a part
- '71 coupe steering issue
- Stering column shop in So Cal
- 10% Ethanol
- BG/Demon 6 shooter sale....
- No power to alternator wire
- How to install L-88 flared fenders
- Correct speedo gear for '71?
- Quick question RE: th400
- Sent an email to Optima Battery regarding 1970 454...
- Power Window Motor wiring Question
- Vortec Kickdown Bracket TH350
- Whine from CS130 alternator with battery disconnected
- any fiberglass experts in here? I need help with a project I am doing.
- Which options do I have with power steering?
- ATTENTION all demon experts
- wiped lobe?
- head light switch removal
- Voltage meter at 16 @ battery draining
- How do you remove the fuel sending unit from a 71?
- '76 Headlight Door Issue
- Jay Leno video on Tremec TKO 5-speed install
- Rear Rotor Stuck 76 Vette
- just bought a C3 with a 400ci HELP!
- Changing lifters
- BB Guys: What Aluminum Water Pump?
- Anyone using a Holley 12-125 electric pump
- Body Mount Torque Question - 1969
- Modify C3 to challange C6 Thread... Did it "disappear" or was moved?
- cam gurus what about the comp cam nostalgia zl1?
- Dynocat oil, advice needed
- Speedometer cable lube
- Which 20 inch rims for a 69 vert - need advice
- The oil fouled, PCV, Valve seat issue Help!
- Solid rollers on a hyd roller cam
- How do I make 325 to 350 Hp with what I have?
- Upgraded to a CS144, now I want to upgrade the wire.
- Tach Fluctuates
- Air Filter Recommendations for Double Snorkle '79 L82
- got it back
- Anyone running a summit carb?
- What 5 speeds bolt in?
- 77 motor swap?
- Anti diesel switch or relay?
- Center Console Wiring nightmare and shorts
- C3 rear end upgrade??
- Cabin Heat
- 80 corvette shift kit installation
- Switch on steering column
- Performance Plus or TKO600, help me spend my money!!
- Has anybody tried a 6 speed transmission swap for 79 Vette?
- Help with Carb Tuning??
- Transmission cable on an '80 vette
- I need someone to take me under their wing on this..
- 73 Clutch adjustments
- What's a set of '82 original tires worth - never used.
- Got a knot in my gut today *&%^*Rocker Arm!
- Fabricating a Bracket, What Steel do I use?
- Parts for Cruise Control Transducer
- convo pros or drag wheels
- Need Tire Suggestions.
- oh god......how many times have you said that.
- What programmable fan controllers are you using and what do you recommend?
- Vacuum Line ID
- Black Wire Identification
- Corvette Body Mounts ???
- break caliper question
- '71 Dieseling- need higher octane?
- Correct '71 M21 speedo gear?
- Late C3 Fuse Box Internals
- Well don't think it is vapor lock. Fuel pump?
- the best tire for stock 15" rims: Avon cr6zz
- Stumped on an 81 popping under acceleration
- hose routing
- Autofab 4-link 9" start (weight and pics)
- Tach Running Erratic !!
- IS THIS TO BIG FOR HER (cam size)
- A/C blower motor!
- Adjustable strut rods?
- Wiring Questions (MSD box and Spal Fans)
- How Much Oil is needed for a new engine?
- Oil pump - conflicting opinions
- C3 Rear Brake Bleeding
- Fast burn GM heads
- 1981 Rear Gears
- Looking for car cover recommendations
- Carburetor problem in 4th round of Corvette Challenge today
- 81 Wire problem leads to no power locks
- 68-82 Headlamp and Wiper Vacuum Schematics Free
- Starter Question
- Rear suspension, poly or rubber?
- transistor ignition(K66) install positon '69
- T top differences question
- "73 vette with a 350 crate motor problems
- AC and headers
- I'm Buying a New Alum Radiator But Need Help
- 2 piece timing cover?
- gear ratio?
- front coil spring instalation question
- New Ceramic Coated Header Discoloration
- supercharger and fuel injection 79 Corvette
- Stock air cleaner for '78 L82, black or chrome lid?
- 1977 wiring issue
- Rear Squat Help
- C3 safety
- Removing Trailing Arms??
- Who has the Dragvette 6 link?
- What's involved in re-connecting the Fuel Vapor Canister
- 1977 Corvette Engine Replacement
- Should I get a bigger cam for my bbc
- wiper actuator seal replacement
- replacement radio
- rear spindle setup question
- 1974 Headlight Knob and Post
- Engine began running rough
- engine diagnosis 101
- ''81 Vette parts experts needed! WTH is this thing?
- largest wheel/tire combo on a C3
- Slight ticking sound from rear-U joint or wheel bearing?
- weight difference between BB and SB
- Seating rings
- car's rear pulls left on accel???
- Stupid Universal Joints...Or at least the clips
- Saw this in CHP and looked online....Are they really thaat easy?
- '75 headlight warning buzzer
- Speed Demon Air Bleeds
- how do i get 12 volts
- running hot
- Can 69 headlight switch be purchased local
- Brakes and Cragers
- Solenoid for a '72 QJet
- Oil pump issues
- Here's one for the Experts
- new brake line fittings leak
- find a stroker
- Submitted for your approval, 69 Headlamp Vacuum hose route
- Best Headers for 1980
- BB 2 groove billet waterpump pulley any useing one??
- Electrical short Advice- Dash Amp Gauge question Too
- Electrical short Advice- Dash Amp question gauge too
- C3 brake pads changing
- Another carburetor question
- '71 ignition switch not locking and smoking
- Do they make a billet 2 grove W.P. Pulley??
- '71 rag joint part #
- After market engine dipstick
- Steering Wheel change to later year steering column
- U-joint C-Frame press tool experience?
- Help with carb fitting...
- Simple fuel filter change turned ugly
- roller rockers
- seat change from 77 to ?
- Timing Chain Cover
- C3 questions from a C1 guy
