- Performance Suspension Kits?
- Breeding the blakes...
- fuel line question
- C4 suspension C3
- How do I get a a aftermarket head unit out in a 79?
- please help! ac probs
- vacum
- Can't get cold air in ???
- Carburetor Question
- tach and trip meter--related?
- c3 radio repair/replacement
- new engine wiring harness install
- Pcv and Vacuum lines
- Trailing arm bolt solution
- door lock key number
- No Start
- How to test this switch.
- Steeroids Or Vb&p Rack attack?
- Throttle sag when warm and just starting from stop
- wipers are working...thats the problem
- Odd clicking when car is off
- ez-efi vs holley tbi
- need help with front pulleys on engine
- Adding a third electric pusher fan to the condenser, good or bad?
- line lock...
- [B][/B] Head Light switch mystrey
- Gas tank size upgrade for a 77
- Muncie vs Super T10
- F.Gregg headlight install help?
- Snapped my hood release cable
- Engine diesels
- Reading Spark Plugs-Tuning Carb
- Temp Sending Unit Location Ideas
- lost key to locking lug nut, easy way to get off?
- brake lights don't work!
- T-top interior hold strap location
- My Baby got some new shoes!
- new timing chain... seems a bit noisy
- ATF in a Super T-10
- Body Alignmnet
- Another brake bleeding ?
- cam shaft questions, 383
- soda blasting
- Way to check refrigerant?
- Rebuild Question
- Steering Linkage
- Steering is to loose what can I do?
- oil pressure line fittings...?
- Vintage or HotRod air guys I have a question.
- Steering Box Rag Joint Setup??
- Upper radiator hose problem
- 400 SBC Oil Pan Help
- Big Block springs
- Safety pin Diameter for knockoffs???
- rear diff
- replacing starter--wiring help
- Transmission troubles (update)
- 3.55 or 3.70 - Why?
- '81 re-use stock monoleaf, or replace?
- popping in carb.....
- '70 Headhight Switch Vacuum Ports.
- Electric pump in the tank for EFI????
- What horn notes were stock?
- Stereo Speaker Recommendations
- Roll Bar/Cage
- Wiper door stays open
- car won't start
- Adding factory style A/C
- A/C problems
- Where can I buy cloth and leather combo seat covers?
- Ignition Swith Stuck
- Is mine an early or late 1977?
- are eastwood products superior to rust oleum?
- 1977 radiator opinions
- Dyno tuner
- smoking out one side
- Headlight question
- 1to1 rod on mechanical secondary speed demon
- Some '82 questions from a '78 guy
- Transmission removal....seeking advice
- Transmission troubles......(some what long post)
- throttle cable
- 77 auto stock rear ratioo?
- bb intake carb combo for stock hood
- Finding Gear Ratio
- 427 Emblem Template
- 69 Tilt column conversion
- What socket do I need to turn crank?
- 454 spoiler extension
- Zinc In Oil for ZZ3
- DeWitts Question - auto or manual
- New stereo wiring question
- ID my Pumpkin ?
- bbc heads cast# 886781
- The Last Week for Free Seat Cover Shipping!
- another carb issue
- Temp. Gauge Not Working
- coil overs
- Wiper door and grill adjustment
- Pics needed : Sanden 508 comp. on a big block
- Another Overheating Question
- hood clearence
- Front spindel
- Weak Secondary Opening
- Car will not start, at wits end:
- [Pics] After 2 years (and 3 garages) i have a running Corvette!!
- 80 Window gear regulator
- Support bar for front headlights corroded
- Engine ID please (pics)...
- Engine Idle Problem
- renegade intake
- Rear Main Seal 383 stroker
- '71 Wipers died in middle of windshield
- Distributor weights & springs in a '71?
- Power Antenna Info
- U-Joint Sizes on 82??
- Help please
- 18x8 + 255/45-18's, 4" vs. 4.5" bs, Coy's vs. Amer. Eagle ??
- Idler pulley
- A/C fan always on
- A/C evaporator?
- Swapping LS2 into C3 - couple of questions
- 700r4 help!!
- Exhaust heat riser valve
- Holley 4165/6210 Question
- whats your guess on this noise
- 1968 manuel to power brakes
- Finding Top Dead Center
- autometer gauge
- Brake Caliper Question
- painter for 69 vert
- ATF Fluid Type
- 1969 Kick Panel Vent Cables
- Headlight warning switch problems
- CS 144 upgrade wiring diagram
- Shocks
- Rebuilding my stock 350/270HP, suggestions?
- dash out, suggestions
- PBM-Erson cams
- What wire goes were?
- balancing flywheel
- need a turbo HELP
- TACH acting weird
- advance spring selection
- Need help picking topend . . .
- 79 L48/L82 Ignition Timing Specs
- emission delete help
- Rear wheel bearings - almost zero end play
- Fuel tank question?
- Rocker Suggestion For L46?
- Rear pulls to right under acceleration
- Rear Bearing Set-Up?
- Mandrel Exhaust Kits for a C3
- Sending unit wire lead 70
- 1978 L-82: Rough Idle. Timing mark jumping around
- Duntov rear end\suspension parts... any good?
- 1970 Pertronix ignition install
- Power window fuse/breaker
- Gearbox
- 1970 LH mirror mounting screws
- corvette central via ebay.....
- Cat Blood Etched Clearcoat?
- Am I missing something?
- lug nut depth / stocker aluminum wheels thickness and loose wheels..
- 78 Turn signal switch replacement
- Headlight Vacum Lines Help
- T56 Magnum for mechanical clutch-help Tremec vendors
- Air filter power
- Changing strut rods and...
- Dual Electric Fan help.
- Custom headlights, anyone done this?
- K&N Filter for MAF
- Will a Holley 4779 body fit on a 4777 base
- Finally got bad TA out, should I replace the other?
- help!! I CANT SEE! HEADLIGHT GURUS IN HERE!
- Chevy Rod End Cap Question
- Black Goop Holding Wiring?
- Interesting chart shows fuel circuits for carbs
- Speedo Cable Lube Instructions.
- Side Pipe install on a 71
- Front bumper cover
- 1968 courtesy light switch
- Jim Shea: Help!
- Energy Suspension Body Bushings?
- Mystery Button On 76 Vette
- Compression vs Detonation vs Gas
- harmonic balancer
- Where to buy Cast Blast ?
- Head Lights Not Functioning Fully
- E-Bay Headers - 63-82 69 68 67 CHEVY CORVETTE STAINLESS EXHAUST HEADER
- rearwindow defog switch as line lock?
- Supercharger 69 bb vette
- A/C Compressor Question
- Low, Unsteady Vacuum readings
- Headlight doors hitting when opening
- 1978 Gearbox
- Ground question
- MSD wiring question
- Brush on primer
- anyone does work on c3s in portland, OR?
- Need tech help with wheel/tire
- need some advice with brakes
- Shifting Hard is Main Concern
- EFI with stock steel lines?
- Breaks up on HARD acceleration
- BB owners step in here please
- Question about Hot Rod Air or other aftermarket A/C system installs
- Which Rims for an 80
- Wiring Questions
- Mech Fuel Pump
- wiper door help
- Power Window Motor ??
- an idiot ran into me
- TH400 kick down response
- Tachometer Problems! PLEASE HELP!!!!!!!!
- Fuel Guage Sticking
- BB 4SP Header removal
- big block hood latches vs small block hood latches
- radiator question
- Simple changes to L48
- front spring advice
- 1978 L82 running ruff shifting hard after hooking up heat riser
- 79 wont start...
- need new tires
- R4 AC compressor help
- oil pressure transmitter location
- Blinkers Don't Cancel..Do it myself or have it done?
- vats bypass module 64024 help
- dilemna, what do i do with heads
- Brakes Rebuilding Tolerances
- Replacing spindle mount
- What to do with a '74 350
- T&L 383 dyno
- Brake Booster Actuation Rod Length
- Keisler's t45rs installed video
- Big block guys, power steering pulleys?
- '70 Corvette Wiper Problem.
- Charging sytem help
- T-45rs
- What would you do now?
- 1978 Antenna
- MY QJ is leaking gas, is it a simple fix or a major rebuild?
- 77 vette Help! rubbing noise in rear end...
- Shift points for a stock 1971 LT-1
- help with 69 coupe
- I have a 1978 L82 cork or rubber valve cover gaskets
- Do I Need To Prime Oil Pump Before Reinstalling It?
- Adding another fuel supply for N20
- Camshaft Upgrade on ZZ4 engine cost?
