- paint
- exhaust
- '82 Vette. Rubber Fuel Lines Leaking!!!
- Bought a Tilt/Tele Column, No Keys, How do I remove Ignition Cylinder?
- 71 BB 4spd pulling the motor ?
- What I'm doing today. timing, oil leaks, pcv,etc
- Q-jet Secondaries don't open w/ light foot
- problem with an innova timing light
- What next?
- Torque Converter Question
- Second guessing cam change
- Tachometer - When did electronic begin
- Willcox New Sale Started!
- 2 inch drop and big brake kit
- Carburator, did corvette ever use a dual feed line stock?
- Not exactly 'Vette related - Looking for thread adatper? Do they make such a thing?
- Dropping in Big Block - Attach Tranny or no?
- The Battlefield Corvtte Club meet at Dave's house to take the body off of his 1968 Co
- Trailing arm shims
- Courtesy lamp help
- What is a 454 small block????
- wiper door solenoid valve/override switch hose?
- Choke Pipe Function On Q-Jet ?
- Fuel line help
- vette stalls when hot - electrical/ignition
- '72 Expansion Tank?
- Installing Rear Shocks to lower Mount- Pics
- Big Block Water Pump Problems
- Relay in center console of 72
- Is anything easy on these C3's ???
- 5 or 6 qts w/filter and oil change ?
- starter not engaging
- headlights issue
- car stalls when hot and only at a stop or low rpms....why?
- just found out i dont have a pace car
- Dynomax Ceramic Coated Headers
- Differential seal question
- Aftermarket intake interferes w/ valve covers
- Probably my winter project
- Drivers Door VIN Sticker Reatachment
- The best mod ever
- Exhaust Fumes
- E-85 Gasoline Experience C3
- Side pipes for 74 Vette
- C3 differential gear ratio
- Lower shock mount question, can this be right?
- fuel inj vs carb...swap
- HELP ! Cant get M21 Trans. out of neutral into gear ; car sat for 3 months.
- Infrared Temp Guns
- ne one do aftermarket air in 78-82?
- 1968 4 Speed Shifter
- Brake Pressure Gone!
- loose mirror
- help with dynomax muffler for 79 L82
- fuel pump pushrod
- What is the correct ignition coil for a 72 Corvette 454 with points?
- 1974 water pump Long Short?
- Detachable Hood Hinges-MidAmerica ?
- Holley carb power source
- Fan Blade from shroud Measurement?
- Holley secondary vaccum control question.
- plz help me.....
- Edelbrock kits
- headlamps inoperative
- Remove and adhere carpet from storage bin doors
- French locks or lock washers?
- Wilcox Help!
- pic of fan shroud and fan for a 74 ?
- Uh oh....Clutch peddal woes...
- Oil? is it any good?
- Ceramic coating break in question???
- 10% off Steeroids sale
- 1976 L-48 Exhaust Question
- A/C Compressor Noise
- Q-jet secondary
- Z bar ball stud bracket for LS motor...etc??
- 10% ethanol hurt original fuel lines?
- Radiator Cleaner Flush
- Torque converter
- carb leak
- Where is the electrical socket located for the rpm gauge?
- 1977 Trailing Arms
- To PCV or not to PCV - revisited
- vette brakes (1981)
- Tie rod to spindle ?
- Tilt tele c ring
- converter and cruise control
- Adjustable Strut Rod Install-82- need advice
- No power to ac/heater blower
- My power cb/radio antenna now works
- Quadrajet Gurus- Please help!
- Valve Cover Bolt:
- Running Hot Cooling 1974
- What weight motor oil can I get away with?
- alternator
- EGR with aftermarket intake
- Fan Clutch
- Please Id this cap/screw/bolts ??
- Oil Leak Under Right Fender, Thin Oil
- Replacing a torque converter
- Need some help getting my brake lines off...
- yet another jetting question
- Crane Cams is back!
- Jealousy
- goQuality Corvetee: low-speed grind/clunk noise from rear? Need advice.
- Half shaft question
- Rear Body to High
- Can I get some help from some Holley Carb guys
- AC compressor replaced - Will not take freon
- Does the fan shroud need to go in from top or bottom
- Question for holley throttle lever
- temperture gauge
- Installing new bumper covers
- how can I test a starter
- Replacing #4 body mount
- How long can I run open headers?
- will it fit?
- 71 Corvette TCS HELP!
- Problems trying to keep L82 valve covers leak free
- Brake question.....NOT bleeding!!!!
- Quick question for the painters
- Firewall removal-mininum effort
- Body Restoration
- TCC fuse ??
- More camber needed? (autoX)
- Brake bad inner coating
- Rear control arm bushings???
- Waterpump Gasket Questions.
- What Paint $$$$$$$?
- Overheating
- paint code
- Uneven Hooker Sidepipes
- high rise intake
- VPB adjustable strut rods and thread locking
- F body rims on a 77?
- Radiator change 74' SB
- G-tech meter?
- tach with Edelbrock pro flow fuel injection
- How many C3ers got laid off?
- G-tech meter?
- 17" Front and 18" Rear Foose Nitrous Legends on 69 Vert with stock TA's
- Another tire rub
- Marine carb
- I can't believe it, carb dead again
- Blade-style battery disconnect switch safety?
- Engine Experts, need input: LT1 Heads?
- Excessive neg camber and no more adjustment!!!
- Steering Locks up, need help!
- transmission id
- Yikes!!! Smoke and flames, what's happening?
- One Eye Open, 68 Headlight Doors
- stupid question
- Body Mounts Replacement
- Water Pump Noise
- Final details - need help
- BBC Oil Pan Help!
- 4 barrel
- dieeerential carrier cushions
- Another rear seal!!!!
- Got my car back
- Grease tach cable
- 1980 autofab 4 link install (weight difference and pics)
- differential change out
- My Harmonic Balancer Was Shot !
- Proform Roller Rockers
- Request: Pics of Sealed Radiator Support
- Mandrel bent custom duel for $425 Good?
- 74 vert Dash speakers, speedo cable, tach cable and radio replacement next week
- Shock Absorbers for my c3
- Replaced AC Control & Air Flow won't change
- Selling my '72
- 73 Power Steering Problem
- 1991 vette Serp Belt system
- What is it?
- Thinking of redoing trailing arms.... a couple questions...
- 305cid Block
- Transistor Ignition Woes
- Vbp's cool sale
- Key won't turn in the ignition
- tbi/tpi kits?
- Sluggish Acceleration & Stalling Issue
- cleaning piston ring lands
- checking rpm with multimeter?
- Bowtie Overdrives order issue
- L-88 trivia + big blocks too
- 383 spark plug gap
- side pipes
- Power steering
- Radiator/Shroud/Fan Question
- Hollysprings, MS 4.50 class
- Successful Engine Work Planning
- 15 degree vacuum advance can
- 78 in-line blower fuse location?
- 1976 rear bumper cover
- '73 rear quarter different than '72?????????
- 1976 L82 Specs
- 1979 Conversion to electric windows?
- TPI knock sensor relocation?
- torq-converter help
- 76 Quadrajet
- Fuel pump causing flooding?
- bogging
- Cover plate for 69 Corvette
- Fuel Pressure
- Best MSD timing curve for the 383
- Alternator Relocation to lower passenger
- door locks ?
- Please Help - Why did I blow the p/s high pressure line???
- How many turns vacuum advance? -'71
- Cs alternator help
- Holley Street Avenger 670 Bog
- Hood Mods? I may have over did it with the engine (see pics)...
- Wiper motor or switch
- Is anyone using an LH8 pan?
- TPI fuel injection
- Kill switch on ignition- '71
- 255/70 on 8 inch Rallys?
- Secondaries not opening with a slow foot
- Replacing swingarm bolts on 79
- steering column parts help
- Ignition Cylinder Help Needed
- Help identify the year of these seats
- Turbo 400 to overdrive trans swap
- 69 350 350HP valve covers
- Testing Coolant Temp Sensor
- Custom Auto Sounds...mp3's skipping
- Fuel pump dead ?
- Are front rotor and hub one piece?
- Headlight Troubleshooting
- How to replace the covers for the door hinge on a 68
- TCC problem
- pulls to left
- Car stumbles under load.
- LS1 Fuel system
- Anyone have exhaust pics?
- Lower Coolant Hose Spring
- Starter Question
- This is how you install a Line Lock
- a/c problum
- Installing Autometer gauges........
- p/s and alternator bracket pics
- wheel size
- front coil springs, which way?
- Dumb Fuel Pump Relay Question
- CFI to carb progress again.
- Stalling issue w/ 1973 454 4spd
- Electric fan connection question
- Lyndale Blue
- Rag joint proper install ?
