- Anyone know of a 4-wheel alignment shop in Los Angeles/Long Beach?
- To those
- R4 Compressor clutch clearance???
- Exhaust cut-outs
- Trans AM GTA wheels
- Head Gasket Problems??
- Modify those spiral baffels
- Backfire thru Exhaust
- rear exhaust panel filler easy fix
- Removing the stock BB fuel pump with the engine in, is it possible?
- 69 BB cooling issue with reverse pump
- clay molds
- lower console removal
- 72 front rotor removal
- '81 help questions on instrumentation
- rear ride height -one side higher than the other?
- Plus size BBC experts, please step inside. . .
- Window & door problems on a 75
- tork converter question 1980
- Who makes complete C3 exhaust systems?
- Fiber Optic Repair ??
- broken door latch
- GM performance parts TPI fuel injection for small block 350
- muncie transmission
- NCCO all vette show
- Anyone have any experience with the stainless 4" sidepipe/header kit on ebay?
- No brake ljghts
- Seattle area Muncie rebuilder?
- rochester 4MV carbrator settings
- Darn Headman Elites
- Help needed with the wiring to the shifter (TH 400 in a 73)
- Run Out on C3 Rotors
- mid mount?
- Front brake line positioning
- lt1 92 conversion coolant/flow/radiator question
- best years c-3
- Elle88 Build thread
- Fixed alternator,now New problem.
- I need steering column HELP!
- 81 with Code 44, Little Help Please
- Fiberglass Repair on Fender Gutter
- 1978 L82 Is the lower radiator house suppose to have a spring inside?
- Trailing Arm Bushing?
- Targa Top on a C3?
- 78 temp gauge
- Free Shipping on ProCharger Systems at EPP
- Camber adjustment help needed.
- C3 Brakes - Help
- '69 Big Block Headers
- Its hot!need a/c
- VSS (128K) for Muncie or ROD6??????
- Outline request
- Bolt On Horsepower
- running 205 today water temp air temp 92 95
- Running 205 derees today water temp air temp 92 to 95
- 1981 Hooker Side Pipe & O2 Bung Help
- Running about 205 today 90 to 95 derees out
- New Guy with a question
- Tips to safely remove front springs
- headlights and turn signals
- 78 Upper Vent Air Flow Help
- differential shimming
- confused
- Help needed with govenor calibration
- Rear differential temp
- Differential help needed
- AC system
- Tri-power manifold height '67 vs '68/69
- 283 Aluminum Valve clearance on '72 LT1
- car quit running please read
- Alternator? Still can't start...
- '79 Door handle sags a bit.....?
- Problem setting timing in my car.
- Today's wheel fitment question
- 81 carb/computer problems ???
- Slow Progress Update
- 75 temp sender & wire
- wich axle ratio i have?
- New cam and headlights wont come up?
- Coolant Leak
- Whats this part and where does it go?
- Seatbelt "pg12177-1" Model#100b-w?
- Air filter too tall for hood; don't want to buy a new hood!
- Casting number help please
- Advice on header selection
- Hooker Side Pipe Improvements
- fuel line issues-anyone else?
- Bottom air spoiler attachment
- heat shield
- Which rear spring?????
- L88 Hood Scope
- Grease for the rear end 1978 Corvette, need to be changed?
- Fuel Pump not the problem Reman carb, stuck float the problem
- How long does your fuel hose last? (FP to filter)
- Here's a good one
- Steering pulling left
- Dana 44 help
- 1973 Corvette fuel filter
- torqe converter question
- 509 Becomes 540 Questions
- '81 guages gone crazy! WTH????
- Engine experts please chime in.
- Seriously considering removal of side pipes!! :-(
- Innovate LM-2 “basic” group purchase
- Owe JCL an Apology - BBC Power Back
- Exhaust manifold Fit
- is what this guy says true or BS
- C3 vette question
- Upper Radiator hose for 71 BB? Anywhere to buy outside of Vette Vendors?
- I need fuel line HELP!!!!!!!
- Trouble Shoot Temp Gauge & Tach 75 vert
- 700R4 swap
- Insurance FYI -Read This
- Fun
- A/C not working
- 4 bolt main
- Got caught in the rain and . . . .
- Ramps to work under C3?
- Shopping at NCRS
- Need advice on a good carburetor and intake
- Build Sheet Found
- 700-R4 crossmember with a TKO-600?
- Where does the black gnd alternator wire go ?
- Has anyone installed a fuel pump 1978 L82?
- 79 Drivers door handle linkage not connected.
- Batwing Xmbr Bushing Install ?
- Got my Art Carr 700R4 in today!
- Car Won't Start, plus its yelling at me..
- SS versus OE fuel lines
- Aftermarket Radio Help
- A/C Duct on driver side 1970
- Exhaust Pipe Mounting
- Frame mounts
- Overheat -- again...any help?
- Bleeding brakes with vacuum pump
- '74 350 L82 Small block
- High idle trouble after cleaning Q-Jet carb
- Timing or Carb Issue
- Exhaust heat sheilds
- Pro Top Line = comp cams = RHS
- Where can I get a build sheet on original copy of invoice
- How to remove body mounts C3?
- rear tail-light sockets?
- Wheel Bearings, Are There any USAs left?
- mod to stop low vent air flow? can't find it
- Vibration in steering... HELP!
- Custom Exhaust/Auto Transmission Question
- mystery hose??
- Brake question...
- 69-71 frame
- 78 Carpet Replacement - Glue Where?
- 1970 4 speed lock out cable help
- 383 stroker
- New Owner Questions-HELP 81
- 81 pinion seal leak
- 700r4 governor cover leaks
- several problems...one solution?
- Starter Nose
- 78 Corvette newbie owner, tech help
- power steering
- Sbc 350
- Trying to find stock looking fuel filter
- Bumper repaint - what to pay
- 1971 / 1972 350Cu Engine
- 1980 Fuse question
- Anyone ever cut their hood and add one of these before?
- how to remove paint specs
- 80 rearend issues
- engine change
- Oil change interval
- Need Help Indentifying Engine Block
- Air Switching Relay
- Does anyone know if this is a 1980 stock color choice?
- 82 Corvette. Help Starting after 18 years of sitting.
- Changing my air cleaner
- Headers and sidepipes to go
- Please tell me this isnt a Coffee Can?
- Still having charging problems
- Stroker rotating assembly
- 79 L82 cam choices
- Alternator whine thru speakers
- Rear End Rebuild-Almost completed- Pics
- Towing vette- trailer vs. dolly
- J56 Caliper brackets
- C3 wider wheels and tires.
- Correct Carb for 1970 LS7 454 motor
- Help make decision
- Need help finding these retaining clips--- sorry if this is against forum rules...
- L48? L82?
- rear bumber emblem
- rear sway bar (not there)
- Where's the HP???
- Seat Belt Warning Light ('69)
- cutting coil springs...uh-oh...cut too much???
- does tunnel insulation cause rust?
- 1 Wire Alternator
- Effect of Advancing or Retarding Cam?
- 200 4r swap universal question
- Exhaust clamps
- Modern master cylinder
- Rear end clunk
- Brake bias ratio
- Rear brake shield
- Interesting Brake light Idea
- need torque values for 2 spots
- Power steering..massive leak!!
- Updates to my Carpet Install for my 78
- rear end assembly 1980
- Has Anyone Ever Dyed Their Rugs ?
- Need 4spd decoded
- A/C Barely Does Anything
- motor mounts
- Need help with brakes
- 79 Engine pics, whats good, whats missing?
- Tank sheet
- Help, Deck lid won't close
- Door: What are these holes for?
- 1982 vac leak of course.
- Gas smell
- Corvette central dual exhaust.
- ac evaporator
- Fuel gage
- A/C Pressure
- So I got my yearone motor in
- Edelbrock 1406 & PCV question
- Question about overheating in a 383 Stroker upgrade
- Cooling questions
- angle plug heads on a 82?
- Headlight washers
- 1972 Corvette Leaf Spring
- Front bumper cover
- T-Top Lock and Rod Adjustment ?
- 1968 327 , Carburetor question
- 82 keeps running with the key off
- Bad Propotioning Valve, Brake Line, or ?
- Looking for someone to redo headers
- Car won't start
- polly body mount install.
- Hooker side pipes with EFI
- Power Antena
- Corvette caliper bleeders is there a torque spec in inch pounds?
- need help
- need interior picture asap!!
- Charging Problem
- rag joint to steering column
- paint
- exhaust
- '82 Vette. Rubber Fuel Lines Leaking!!!
- Bought a Tilt/Tele Column, No Keys, How do I remove Ignition Cylinder?
