- Dyno'd today.....
- Fuel line leaking at carb
- compression
- throttle cable issue
- Best lubricant for speedo cable?
- &%^$# U-Joint Removal and Installation Need Advice
- 75 Regulator location?
- Initial timing for 1968 327 HEI
- Tranny change, cant hang exh with stock hanger. Any creative alternative's ? Thanks
- Rotors!!!!!
- Need a front bumper
- Control module for my TPI/MAP
- vibration. where would you start looking?
- Duralast Water Pump
- Problem Mounting Calipers on VBP offset Trailing Arm
- A/C restoration ... mods?
- Wipers not working on 79 - Help Please
- TH400 shift linkage- will not engage in park.
- Jacking from the diff
- How to set static timing for break-in?
- -72 Front wheels backspace?
- Help With Brake Issue
- LT4 Hot Cam into my Gen I small block. Help!
- MPH prediction
- corvette parts in dallas
- Chassis dyno
- weather stripping question
- Corvette Order Copy!!! = D
- Desktop Dyno
- NO gauge lights?
- Brake Master Cylinder lock nuts
- Power steering - feels heavy
- Power Steering remote reservoir - Pictures Wanted
- Wiring problems - Need help!
- Direct "fit" 5 speed .... which one; ready to pull the trigger!!
- Wacky acting temp. gauge
- 540 Piston help
- Wheel Stud Source...Anybody...Bueller???
- Battery Handle.....
- Willwood Brake Wheel combo HELP???
- What is a Turbo 400 and shifter from my 71 worth?
- Rewiring?
- Tach acting funny
- head question:
- how to test for intake manafold coolent leak
- '68 BigBlock oil pan clearance question
- Eliminating AC compressor
- Leaf spring bolts?
- Excellent paint job!
- Seat back repair
- Brake Lubrication locations on 78-82 Corvette
- Rack-Pinion kit for C3, ANY Comments
- was there ever a high HP c3 that couldn't be cooled?
- Front springs
- #1 Body mount alignment off
- Does anyone happen to have a fan clutch
- Convertible Top Install
- SBC 427 heads & cam choice
- Can someone help me Date these Tri-power carbs please..
- Parking Brake Handle Disassembly
- Size & Width of stock '69-72 seats.....
- Mint green 79?
- turn signal indicator lights
- shakey tac
- Help identifying '74 suspension
- 1968 wiring question
- 74 convertible Top Filler picture plz?
- engine fire 80 vette
- Knock off dynamat opinion?
- Fuel Line Pump To Carb
- Impressed
- Options for 2.5" Mandrel Exhaust Kits
- change em or adjust em
- Telescopic Sun Visor 82 CE
- 81' losing all power then comes back?
- black c3's with black wheels?
- what year c4 blower/wheel for 71
- which is true???
- headlight switch removal
- bezel ground wire 68 vert
- School me please...valance replacement on my '72
- Typical manifold vacuum?
- 68 Wipers not working!
- Changing oil in my '74 today
- speedometer gear for 1980 with 4.10 rear
- Vac Advance ??????
- found this on the web
- Tempature sending unit location
- Brake Cooling Ducts
- Small block Hybrid LS engine.
- Advice on front clip installation
- fuel sending unit question for Wilcox
- Sway Bars
- 73 no power to inst lps fuse
- newbie's holly850 carb has issues, help?
- Blower door open should it be?????
- r-12 needed
- Corvette Bash?
- Steering Wheel Play
- Turn Signals Blinking FAST
- Wow! Steering box adjustment works!
- Small Block Advice Part II
- I bought a 1970 LT-1 (survivor type) Couple Questions: Clutch Brakes Wiper Cover
- Jammed seat belt
- will these tires fit ??
- hot air blows all the time
- Correct Seat Track Mounting Brackets
- ZZ4 TURN KEY ENGINE for a 1970 ?
- Head alignment dowel removal?
- Might be heading to the dyno Saturday. Needs?
- Impala ss vs 76 vete
- How much would you pay.........
- Removed play from Steeroids!
- Advice for a potential C3 owner
- what is the best polish for alum wheels
- Distributor TVS
- overhauling 76 L82 need help
- the best car cover?
- "Matching Numbers" again (yes, I know...)
- 700R4 Exhaust
- 81 computer
- edelbrock shocks-
- a/c blowerelay problum
- Help evaluating this 1971 454 Coupe for 19k
- Trans Throttle/detent cable adjustment
- One head light slow to open?
- Mirror mount on doors
- Need dash indicator light help on my '81
- Hood Adjustment Help
- Air Conditioning Vacuum Shuff Off Valve Help!
- Initial Dyno Results for my 496 Tri Power Build
- Painting a 1980
- Ticking noise from distributor?
- New frame!!!!
- Need headlight wiring help!!!
- Timing for "YOUR" specific Engine
- 79 radio/cassette
- Speed Odometer Question
- 1980 seat questions ?
- Fuel gage bounces
- The most backspacing for my c3
- Spark plugs too lean???????
- Radiator Question
- Stuck in first: 74 L48 4-speed
- Outer rear spring hardware
- on the subject of paint
- Tach went nuts
- Alternator Upgrade?
- Yet another Wiper Door question...
- 73 Vert behind seats pic?
- Radio noise
- Replacement hood sources
- HP from new pulleys?
- Tail Lights out
- Rear end clunking noise
- Exhaust
- can fibreglass experts or enthusiasts please give me their advice.
- reflectix
- Headlight Operation Question
- Brake Bleeding
- Lets see some of your "garage" paint booths
- 1979 and new Rock channel inserts
- Re-using Head/intake gaskets?
- Car will not start 70
- I have to replace my Windshield Header and corner pieces
- 69 washer pump solenoid
- Grey, blue, green wires on guages 68 vert
- 78 Courtesy Lights Out!
- funny story about steering column coupler, please help!!
- Carb adjust mixture and air ound hole with slpot not screws?
- Pulley Geometry
- Show me your Spal Fan Relays
- 454 or 427
- Transformation
- big block 454 vs 427
- Method of Installing an intake with 0 leaks!??!?!?!
- Driveshaft installation in 80 vette
- 68 Interior re-assembly order sequence
- block hugger headers
- Retrofit Hydraulic Roller Lifters And Cam
- Rear end question for GTR or anyone that knows.
- Lowered my '68
- Bullit rims for a C3
- Stumped on what my engine is telling me
- Rough idle....
- Centre instrament cluster
- Gearbox crossmember
- total timing- 68 vette
- Replacing distributor shaft ??
- how to install the door handle
- Do i need to rebuild my Distributor? vid.
- Wire Arcing On My A/C Compressor..Fan Dead Now
- T-tops seems not to fit
- Brake Lines...dang those connections
- 82sidepipes
- 1978 L82 Cloud of blue smoke out right exhaust, smoke out of dash?
- 68 Differential Front Mount ?
- And the next snapped off part is......
- Tail Light / Rear Marker lights not working
- 93 fuel gauge not working
- max valve size on 305
- Mini starter binding
- 4L65E new Goodwrench Brain Gen 1 & 2
- 350 rocker arm adjustment
- max wheel width for 73?
- 81 distributor swap
- heat barrier
- Help with heater.
- Trailing arms- what are the odds?
- Wheel Offset Chart (covers high offset and wide wheels)
- fuse box help please
- R-12 static pressure - related to charge?
- TPI in my 69
- Horn Issues
- Thanks Jim Shea
- RPM intake
- Miss/Stall after warm up
- Performance Chips for an '82
- Q. 1974 Alternator Brace
- Headers 74 Suggestions?
- What all is needed for a TH400 to a 200-R4 tranny swap
- Heads up on Dart BB w/ AFR heads
- Power Steering Bad Shutter / Shaking
- Oil Leaks at Rear of Engine Block
- 69 tank sticker decode
- Dual Spal Fan Wiring
- Spark Plugs
- Broke my steering wheel!
- C3s at Carlisle
- 78 Corvette Chassis Ground locations
- help changing window regulators
- 78 Fuel line changing procedure.
- Nitrous Oxide Install
- what plugs here??
- 383 Build - Help
- Electric Fan Sensor.
- What do I put in my new DeWitts?
- heater/vent/ac blowing still moving while in setting is on OFF
- C3 dimensions from wheel centerlines to body mounts
- crossfire 1982 won't start
- Bilstein shock question
- Posted a craiglist ad looking for welder and I got this
- Removing the Steering wheel and the Column
- Turning on the computer/ startin' the thing.
- Engine Suffix Code help!
- electrical fan
- '76 Door Weather Strip - 180 degrees out ???
- Centre instument cluster
- Will a jackstands & string type front wheel alignment be anywhere close to spec?
