- 42% front and %58 rear weight bias
- Carb Idle Mixture
- 78 pace car seat question (help)
- Right Turn signal indicator in dash not working
- Big Block exhaust
- Starter turning slow
- Head bolt tap size?
- How do I replace the brake booster?
- Need to replace Temp Gauge - 1977 Corvette
- running rich, and have spark knock
- How to adjust auto choke curb idle L82 Quad
- Intake help please
- Side Exhaust Pipes Flange leaking
- Relacing rear window seal
- oil pressure sender location. 79 L82
- brake fliud compatibility
- Keisler Kit: Should I switch to a mechanical clutch? What is involved?
- radio help
- TBI for engine
- 2 ohc (overhead cam)!!!!!
- T top seal question
- '69 L71 435 Tri-Power Question
- Wacky tach when cold
- Grinding Noise Please Help!!!!!!!!!!!!!!!!!!!!!
- Engine Replacement on my '79 Vette
- Decode Engine?
- pistons
- Engine Block Decode
- brake lights
- Pulsating Pedal
- Need Windshield Wiper help 1977
- 78 Steering wheel horn assembly - help please
- 82 running hot, stalling
- '72 hazard light problem
- Part II of Bruiser's 555" build in Corvette Enthusiast is on line now!
- Speedo dead in my '81. Is it electronic or cable driven?
- Got a nuisance oil leak from right rear of cylinder head.
- 72 AC Wiper Problems
- engine rebuild
- VBP upper control arms - loose?
- 73 Power Antenna
- 1972 ac
- Coolant Leak
- '78 Pace Car nose emblem R/I
- Automatic Tranny Pump Seal Replacement Cost
- Power window trouble?
- 70 Speedo Cable Routing
- Broken polly body mount
- Fixing dyed leather seats, now rough feeling
- 1980 heatercore replacement
- Ls2 ls3 ls7 the absolute combat
- mini starter
- Hungry fan eating fan shroud
- How long are 76 rocker panels?
- 78 power lock actuator plug
- Spark plug
- 69 Exhaust
- sunday tinkering questions...wiring, air con, heating and air pump! 79 L82. Pics!!
- What is this part called?
- WATER from the EXHAUST - HELP
- 1971 bb rear composite spring rate?
- Taking car to have top replaced. What should I order from Al Knock?
- Transmission torque converter question
- degreeing the cam and initial timing questions
- New Shocks What works best
- No RPM indication from MSD Distributor
- Constant Pressure on Rear Brakes ??
- Major Oil Consumption
- Ati converter 700r4 3000 with lock up
- Some new stuff...
- Stumbling at idle...
- 78 wiper question
- 1980 L82/Lack of Driving Problems
- Steering problem
- Pre and Post 1986 block
- 73 Frame Replacment
- Dynoed my L48
- change in conventional oils????????
- Gravity Bleeding new system trouble
- Raising Vehicle/Jack stand Question
- Is my battery toast?
- 1970: Possible Bent Lower A-arm
- Front Bumper Just Won't Come Off!!!!
- New fuel pump no gas?
- Turn signals ok, hazards not working
- small hole found in right side of shifter column
- SBC head bolts
- COMP Magnum Roller Tip Rocker Question
- 68 Original Spare
- Starting quirk??
- gear pattern
- Power Steers Only Right
- Good Deal on a 71 t-top?
- Hey DeWitts people... how do I fix this??
- kinda stumped...car wont shut off
- differential opinions
- H E L P w / Compressor / paint etc
- Taking a different tack on flip-up vacuum lights
- LQ4 with super T-10
- need bracket for throttle and kickdown
- Video of my bad idle and stall into drive
- 79 ac??
- Modification frame 76 or 454ci 500hp!!!
- 4x6 Speaker trick?
- 72 headlight problem
- 68 327/350 correct valve cover bolt colors
- muncie problem
- need help with springs
- 79 tach bouncing and showing high revs.
- Brake cleaner... SAFETY CHECK!
- hard wiring gauges
- HELP - New owner - rebuild?
- 10% off your first order*
- 12-bolt-Estrada?
- Vacuum hose question
- Square bore on an EDL 2101
- 10% off a-arms and rear coil-overs, free shipping
- Carb Jetting Quetion
- Running problem with new engine
- Will an Edelbrock Performer Intake and Holly Carb clear the base hood?
- Loose steering column
- Q-Jet to Holley 4160 conversion kit? Q-Jet rebushing
- E85 fuel test on my C3
- Should I go frm B26 to B28 vacuum can?
- Steering columns
- 1976 cooling system troubles
- 79 AC and Heater Core Removal
- What I've been up to this summer (short vid)
- TPI Fuel Line Help Needed
- Lowering 80 with 275/40 18" tires
- Bleeding brakes - no fluid out front
- Suspension rebuild question
- Great QJ rebuild
- fuel vapor canister
- A.I.R. Pump System removal questions.
- disassembling vent control
- cleaning up the underbody of a 69
- Tranny Cooler Location - Additional Heat Problem?
- Engine guru question?
- Is header wrapping worth it?
- Size of bolts to connect MC to Hydroboost?
- Big Block swap ?s.....(yes I've searched for days)
- Just gpt my crossmember dent removal tool...pics inside
- Need help with 1968 steering column issue
- AM/FM CB Antenna issue
- help with radiator swap
- For those with a TKO conversion...
- 68 vert vent hoses to the vent balls
- driver dashpad and light install 68 vert
- Quadrajet Secondary ?
- Motive Brake Bleeder
- Companion flange question
- 427 truck mota ?'s
- Headlight dimmer switch replacement?
- Holley4150...do they have a proper ported vacuum take off port?
- '79 timing adjustment and 'ported take-offs'
- So I took the Vette to the track
- Battery gauge problem
- original 71 bbc rebuild thread.
- Dual Exhaust routing ? pics please
- Beehive springs
- Tail light short
- after market coil spring part #
- Removing A/C from a 1979
- front bumper on 1980 'vette
- is the rear window flat?
- 73 Frame Replacement
- Flat tappet cam break in...
- modif 454ci!!!!!
- Rear End for Drag Racing
- How to straighten radiator fins
- So I pulled the trigger on a Vortecpro 496"
- How do I change the ball joints?
- Any seat question--sorry
- Choosing a Carb?
- Corvette Small Block Power Chart
- ENGINE LS2 VS BIG-BLOCK 454ci
- At my wits end...
- Assembly Diagram for 1974-77 Seat Belt Retractor
- 81 Vette with high oil temp
- Low mileage 76 L-48 questions
- Bog at WOT
- Camber, caster, and toe-n .. what is the best for todays tires?
- Cost of crate engine install
- 'Just purchased '72 need help with ID #'s
- What cam is this???
- fuel pump install
- caliper 0 rings
- Headlight switch and dash light brightness
- Has anybody sprayed their center bezels?
- Redline Question? Where does Engine Power Level Off
- Door panel install
- rear spring
- 1979 brake booster pin.
- Call me a dummy
- conditional title?
- Wilwood 570 brake fluid $5.20 bottle and cases on sale
- How does this combo sound?
- Sticky on vibration
- Comp Cams for my TPI/MAP
- C-6 brake test
- grinding welds
- Poor lil' idle!
- Air cleaner for 77
- Battery Cable questions
- 68 C3 Battery Drain
- Washer Pump System Re-build 1972.Help!
- Weatherstripping HELP!!!!
- Driveline angle? After installing a Tremec.
- Quick Video
- Fouled Plug Prob
- Whats her name?
- motor break in new headers help please
- need brake system help!
- removing parking brake
- my tickers out
- Transmission Shift linkage question
- choke light on at idle
- Muncie expert needed.
- stingray 69
- Solid motor mounts recommendation
- What Billet Brackets will work?
- Steering Box ?'s
- Purpose-Power Steering Pump Belt Guard
- original reproduction plug wires or after market?
- Thinking of crate motor for '80 vette-Opinions
- Headers/manifolds
- Advice on Posi wear
- Brake Hose Copper Washer ?
- Tuning a 383 with a Holley StreetAvenger 670
- brake upgrade for 77 c3
- Can anyone decode the tag on a GM rebuilt 700R4
- hp gain from hi comp pistons
- Old and new catalytic converter
- linear actuator wiring
- If you were to replace your windshield for a 72 Corvette and what to keep it original
- 64cc Cylinder Head Question
- Quartz clock question
- initial vs. total timing
- '76 gauge problems, no power
- Just off the tow truck
- After changing weights & springs
- Vette Experts, What do you think about these upgrades?
- Heat Riser Question
- Brakes messed up - HELP!
- headlight switch question
- 1977 Rear End Crossmember Question
- Is the T56 trans bell housing removeable?
- Correct rear suspension torq spec?
- Neutral Safety Switch
