- park brake pad install, need help
- A Heads-Up ; this procedure may save you from pulling your carb for cleaning
- 82 CFI engine Removal-Need Checklist Help
- Why do people go the route of cutting springs vs. vbp monospring conversion?
- shift boot
- Suggestions for C3
- 350 to 327 engine swap
- Body Weight
- Rear Speakers
- Frame Identification,,Help!
- [1974] windshield washer pump woes, part 2
- Best 18 inch tire size for 73 coupe
- Edelbrock performer
- What is the best Cleaner for soaking Carb parts in ?
- Emblem removal
- Your thoughts?
- Help with Center Bezel warning lights
- Aftermarket chrome corner moldings, how do they fit?
- One for the engine guys!
- torker 2 sbc manifold ports
- tires just dry rotted, Need tires now!
- door skin help
- Lead Additive 1970 LT-1
- assembly manual paper vs cd
- Electric fan question
- Headlight Maintenance Switch??
- 72 wheel tire combo questions 20"
- Front sway bar sizes?
- has any body ran performer rpm intake on l48
- 71 headlight issues?
- Half Shaft Question
- Double the HP over the winter - transmission?
- No fuel getting into carb
- flat spotted rally wheel, is it possible to repair?
- Courtesy Light Bulb Socket
- tach and speedometer cable routing
- mechanic shop staten island
- 1968 Front Turn Signal Socket Rebuild?
- Electical Problem??
- Caliper Pistons
- Opinions on steel vs composite springs....
- '76 Fuel Gauge (high ohms, low reading)
- 77 vette handeling REAL bad.
- Help Needed in Phoenix area
- C5 brakes
- speedometer/tach bulb sockets
- Anyone in RI CT or MA
- Help Please...Need Pics of Windshield Corner/Top reveal Moldings
- M-21 1st and 2nd Gear Down Shift Issue?
- Oil Sending unit Install Question
- building 383 stroker
- driver side dash install 68 vert
- Paint job
- Good shop in Vegas for a 68 tri-power?
- Not so common starter ?
- Master cylinder issue?
- Question 1968 rear control arm play
- Recommendations for cam choice, 427
- classic insurance
- Need help starting car
- Cummins Engine shop, any experiences?
- 1976 L-48 Head flow
- 79 alluminum wheels
- headlight switch vacuum leak
- 1970 Alarm problems
- 1.7 sbc rockers
- jim shea steering column again
- This weekend in a 505 hp 2009 ZO-6
- Help please to identify these parts!!
- 81 AC bracket
- exhuast questions
- coolant leak hiding from me
- another brake pressure problem
- Rochester qjet identification
- More Cooling on Track
- A/C never worked where do I start
- Aftermarket Pulley Alignment
- Drilling the shim holes ?
- Engine Builder/machine shop in DFW, TX area?
- 1969 L88 camshaft
- Have you ever gone after an incompetent shop?
- New diff for my '69
- Looking for a mechanic in Fredericksburg, Virginia
- Supercharger on a 502 big block - Yikes, Questions Please!!!
- Anyone have an old jensen cassette player, can't set clock
- Missing teeth
- carb sizing help
- Front end sits high after rebuild...advice?
- 72 front support rod question
- Oil Sending Unit Change Out Tips Please.....
- 70 T&T ignition lock problems
- Engine break in no exhaust
- Front Suspension rebuild question
- Clutch inspection cover - bolt size?
- High idle - no kick down
- 1976 corvette advise on what to look for on purchase
- Oil Pressure Anamoly ???
- Wheel-Studs and Spacer Question?
- EFE Thermal Vacuum Switch Finally Works
- Where is the Fuel / Gas Filter on a 70 LT-1?
- Wiring harness replacement
- Thinking about adding a blower...need help?
- 82 Starter Problem
- rear wheel hop
- well here it is
- Holley 650
- U-Joint Caps Stuck
- Temp Sensor not working
- Just rebuilt my heads
- Still trouble with the new 383
- I need some help to diagnose engines "ticking" noise.
- Wiped lobes
- Engine build, Pully alignment issue
- Intake manifold gasket question
- Syracuse NY tuning
- Please help me before I torch my Shark!
- Hopefully my last Spal Fan wiring question
- Is modern synthetic oil OK for our old Vettes?
- Front Suspension Rebuild
- Resin Mix Ratio?
- M14 bolt to verify TDC
- What's the best way to tackle a short With Common Tools?
- Bouncing fuel gauge fixed
- Any Tricks on Water Pump Install?
- Phoenix brake tool
- Trailing arms turned into while I`m at it.Pixs
- Anyone using Dakota Digital gauges, tach and speedo?
- Clicking trying to start after dying, any suggestions?
- Allen's 69 Side Exhaust
- Help with exhaust manifolds
- Brake Line Distribution Block / Switch
- Front clip problem
- power steering just quit...
- Calling all 77 owners: Need pic from AIM
- Colour wiring diagram?
- Jim shea 68 vette steering column lowering
- Interior Panel Repair
- Delphi 600 Series Steering Box
- Power Steering Control Valve Help
- Prepping/painting slots in 82 aluminum wheels
- New SHP short block
- headlight/temp gauge problem
- seat back release latch
- Jack Point on an 81
- 76 oil pressure sending unit
- How To : Valve stem seals replacement... PICTURES
- pcv help please
- Anyone had a new balancer seal leak?
- Supersoft weatherstripping
- Pinion Nut??
- door sill plate screws rusted or stripped
- Nose support rod on 69
- rocker panel questions
- Radio fuse blows ever 5 min!
- Which rods for L98 heads with screw in studs?
- stripping powder coating
- WET VETTE.......Yeah Baby Yeah!!!!
- exhaust system question
- Transmission leaking
- tilt front end with electric head lights?
- Emergency Hood Cable
- Speeddirect Clutch Linkgae - Install pics and a few critiques
- Which jets
- more l-88 questions
- Problems with 79 speedometer
- TPI Help
- which differential for 5OOhp
- Dana 44
- 76 windshield removal
- Torq-Thrust D Again
- Still Stumbling..
- Transmission cooling line splice
- C3 Wheel bolt pattern
- Tranny radiator location?????
- 6 or 12V
- two grounds on 68 speedometer, why and where
- Convertible top\frame rehab.
- Rear bump stop clearance
- cost for 5 speed transmission
- led tail lights
- Windshield washer system on 69 Corvette
- reproduction fan belts
- headlight switch knob removal
- 82 consol plate wont fit!!!
- 68 vert Headlamp switch nut
- Decking questions
- JEGS timing cover questions
- 1980 auto driveshaft/ 2 different joints
- ***Motor Rebuild Tips***
- Removing hood insulation on 76?
- QJet Issues? What's Wrong With This Picture...
- Napa Temp Switch
- fitting 5" BS wheels on rear?
- Steering pulls after being worked on.
- body back on 4in. to tall
- Have you found your transmission VIN?
- piston to bore clearance spec......
- Alarm Idea??
- Electric power steering questions
- Seat Belt Warning Buzzer Going Off
- Fasten Seatbelt Light
- How to get rid of speaker noise
- Brakes-All is well
- Upper Radiator Hose Replacement for Idiots - 78
- Transmission ?
- Front brake rotors and hubs, great info here.
- pulled the plugs this evening... something doesnt look right
- 1978 windshield washer motor
- Can you check my 383ci shopping list, please
- need help deciphering these wires (1980)
- Connecting e-brake cable
- Acceleration difference with diff ratio's?
- duel quad demons?????
- Very Mild 270hp 350 Performance Improvements: 1.6-ratio rockers
- what is the cause of cam "lope"
- Parking Brake Seal
- Washer pump - does it need to be primed?
- vacuum system
- 1982 TBI rough idle wont run
- 42% front and %58 rear weight bias
- Carb Idle Mixture
- 78 pace car seat question (help)
- Right Turn signal indicator in dash not working
- Big Block exhaust
- Starter turning slow
- Head bolt tap size?
- How do I replace the brake booster?
- Need to replace Temp Gauge - 1977 Corvette
- running rich, and have spark knock
- How to adjust auto choke curb idle L82 Quad
- Intake help please
- Side Exhaust Pipes Flange leaking
- Relacing rear window seal
- oil pressure sender location. 79 L82
- brake fliud compatibility
- Keisler Kit: Should I switch to a mechanical clutch? What is involved?
- radio help
- TBI for engine
- 2 ohc (overhead cam)!!!!!
- T top seal question
- '69 L71 435 Tri-Power Question
- Wacky tach when cold
- Grinding Noise Please Help!!!!!!!!!!!!!!!!!!!!!
- Engine Replacement on my '79 Vette
- Decode Engine?
- pistons
- Engine Block Decode
- brake lights
- Pulsating Pedal
- Need Windshield Wiper help 1977
