- New member - question on doors for '69 coupe
- Head Suggestions
- fuel is not getting to carb.
- Rear Strut Problem
- Is standard PCV enough for a blown application?
- PCV or not PCV
- Cold Start Fast Idle Question
- 3 switches at below the steering column on my '74?
- Heater Core brands - which is best?
- Need quick help! '70 Center Grill
- Rebuilding Muncie M20-Help!
- Fan Shroud Door
- 68 vette dies after warming up
- Thinking about adding a complete air suspension
- wiper switch
- Help! replaced all wire harnesses, now car won't start
- yet another brake question (please)
- 1972 454 & LT-1 performance
- major electrical problem
- Dumb question for the nite...
- Kent Moore race bearing installer tool
- Freeze plugs
- dash paint
- 1969 Rochester Quadrajet Carburetor numbers
- Another Brake/Pedal question
- head gasket?
- Pulling to the right when braking
- Funny story
- EGR & EFE Removal? Million Dollar Question!
- I made an aluminum custom center dash (pics)
- Electrical Gremlins
- How will this cam work?
- M21 weight
- Shift console light
- Refreshing top end
- sequence advice
- 69 350/300 hp TH400 AT Timing
- clutch diameter?
- 69 L68 Tri- Power tuning?
- Seat belt repair 1973 Corvette
- RPM gauge diagnose
- changing intake manifold?
- Can Am aluminum blocks
- 1971 Grille moulding
- battery drain 79 vette
- HELP Please before I carburate it!!!
- Willcox Winter Sale! New Sale, New Details, New Items. Plus!!! You still get 10% Off
- lug nut problem
- Opinions on parts pick,top end.
- 72 carb quit will 76 carb work
- 275's on Stock Rims - Anybody have pics?
- Need help with brakes . please
- Weighed my 82
- Car works again despite stupid owner.
- Helicoils in head bolt holes (BBC)
- What size/brand driveshaft ujoint
- Trusted Supplier For 200r4
- Show me your custom center dashes?
- Hooker Header gasket ?
- plug wire routing
- Need a little help to figure out what this tapped hole is for on my 350 cui
- Turn signals not working right
- Rockin' but Rockerless!
- Windsheild Wipers
- 1979 Distributor Inspection – please help
- Almost ready to fire up....(new '78 406 build)(pics)
- Engine anatomy question
- Tire size question
- Shock towers
- manifold\breather?
- cylinder compression
- How to remove rear rotors on an '82?
- I cannot find a rattle that is driving me nuts!
- What is the correct color of an '82 caliper?
- 1968 L79 clutch replacement
- November Steeroids sale
- Does anybody know????
- What headers for L31 vortec heads
- 1974 hood latch cable
- Hate the looks of my self centering T/O bearing. are they ok to use?
- engine light on 81 vette
- 350 to 400 crossmember
- Headlight door adjustment?
- zoom or centerforce clutch?
- Holley Spread Bore 68-72 air cleaners.
- Steering column HELP!!!
- 80-90W Oil GL5 for Differential & 4 Speed Tranny?
- Is play in the steering normal on C3's?
- Need info on 72 Spindle nut?
- Spark Plugs for "281" heads
- Weld in kits 9 in. 4links for C-3's
- 1969 Corvette Air Cleaner
- removal of 78 dash
- What are these parts on an '82 CE?
- 1969 427
- 75-79 Tail lights on an a 81?
- AN Hose and "Gas"
- C3 hub caps
- Power steering cylinder install issue ?
- Tranny swap question
- 327 Will Not Start ??
- Brodix Race rite heads
- LT-1 parts distinguishable from others?
- Patriot Headers on JEGS
- Intercooler Install
- New EFI coming out - won award at SEMA....
- Used Holley carb ID and opinions needed.
- Is an L81 a 4 bolt main block?
- Power steering bleeding.
- Plugging my bypass any risk to consider
- Burned headlight switch
- smog pump removal/
- Power steering capacity ?
- Best Replacement Calipers
- Rear End Question
- brake q's 1972
- R&R of Ignition Switch for '74
- Another clutch issue
- red fluid on rotor = no brakes?
- Winter project #1 - Front suspension & Bumper
- Tire & wheel set up
- Pasting a jpg file
- Dyno Day!
- 3.42 1st gear & 3.08 diff???
- steering change over jeep or Borgenson?
- 1978 rear wheel bearings
- Carb/Idle Issue
- Which engine mount
- which header gasket
- 79 Vette
- Exhaust is one of the winter projects
- 350 SB pan rail question. helicoil.
- Need help identifying rear spring brand and rate
- 81 rear suspension shifted will driving in a turn
- CarbCareUSA recommendations
- Carb E4ME from Advance Auto for an 81
- Need advice for my first engine upgrade
- Engine guys Valve springs question?
- Plugging my Oil Bypass valve
- could this be a bad thermostat?
- REmoving rear cargo shade- 1978
- bad whistle from carb
- 1979 transmission cable bracket
- Complete rookie needs help on engine upgrades
- Carb Tuning with O2 Sensor
- C3 rear tire track
- shaking and sputtering engine
- Analog Voltmeter Gauge Readings
- 69 VERT - How to adj. hood release & conv. top release.
- Which torque wrench?
- Sticky door locks
- 1971 LT1 Header ?
- Thermostat Housing Related Emissions Question
- I guess this is a technical question-Gaskets
- Speedometer driven gear ?'s
- Big Block Oil Level & PCV question
- heater hose with ls1
- Can't extract the key from the ignition...
- Total Cost to Rebuild C3 Front & Rear Suspension When DIY?
- Braided Fuel Line
- My 71 does windows
- Motive Power Bleeder
- Sidepipe question
- blackstone oil lab
- Turbo Hydra-Matic on 1968 big block - painted blue? (pics)
- a funny beginners mistake
- Windshield/Birdcage Rust: Anyone Just Live With it & Enjoy the Car?
- Powder coating control arms WITH Ball Joints
- 1982 Corvette Gages
- Any Forum member can MagnaFlux ?
- Power Window Conversion on '71 Convertible. How Much of a Hassle?
- Oil Burning
- Removing engine driven fan?
- Transmission removal help (Cooling lines)
- Pro's & Con's if I remove the Cat from an 81
- Lightning rods shifter
- Why do I smell gas???
- 1972 Transmission Help, What's this work ticket referencing?
- ez wiring harness
- Window issue
- Build complete - strange vibration at 3000-3500?
- hey guys... 1976 C3 wheel/tire size question
- B&M Megashifter users- Help Please
- Trans depot - Are they for real??
- BB head questions???
- Blower Motor
- Need help with hydraulic clutch
- opinons on brake fluid.
- 81 Trailing Arm
- O ring calipers
- How do I remove knob from wiper switch?
- what 5sp. manual trans came in......
- Do I need a new torque converter w/ my zz4
- My new slightly modified ZZ383!! Long post w/pictures!
- Crossfire Question
- Vette Brakes & Products, Inc,
- Small block stroker or Big block
- Alright guys!!!
- valve train question with pic
- Key won't turn fully off or come out of cylinder - HELP!
- light flasher location?
- Engine Code?
- MSD location
- Front tire started hitting fender on turns...?
- Quier Header/Muffler Exhaust Combo for GM FB385?
- Engine Swap Question
- Bilstein Sport Shocks vs. KYB vs. Delco vs. Monroe
- Patriot Headers/Magnaflow/Dual Exhaust
- Forward Lamp harness install
- New Engine Wire Harness\ Fuseable Link ?
- SS Headers
- Ignition Switch Adjustment?
- Radio Install
- Change STS muffler Tone?
- power antennae
- Cam and Valve Train Change
- Carb Bog
- EDM Solid Lifters Review
- Electrical sytem planning
- rpms at 5 when at 60 mph
- LS3 and tko600
- Engine Wizards...advice needed!
- tbi on 76
- AC Upgrade
- New72
- HI Perf Experts: Most effective ways to manage hot engine&trans temp
- Bowtie overdrives
- Factory Engine Upgrades??
- Leak-down Test
- Reducing engine heat means more horsepower
- Ammeter help
- electric fan switch set up
- ammeter help 70
- Fast idle delete ?
- 454 bbc question
- How much HP difference between single plane and dual plane intake??
- Carb. vacuum hose
- 69 optional hubcaps.......?
- Favorite Corvette Magazine
- PCV to carb hose collapsing
- Convertible smells
- Lifter question
- 3 inch exhaust system
- carb bogs
- Q-Jet vs Edelbrock or Holley???
- Who's crammed a big block into an 80-82?
- Removing door handle emblems
- lowering suspension
- I need Electrical help
- Mid 70's hood on a 71?
