- 78 Choke Plate Not Closing (Q-jet)
- Tech Question of the day!
- Complexity in changing valve size?
- Doors for a 1970
- Rear Hlaf shafts different diameter
- The great RAT transformation begins.....
- how much does a C3 body weigh?
- Do I need new cam bearings?
- Quadrajet # 70-454 4-speed
- how to bleed brakes? HELP!
- Question about Vintage Air vs Hot Rod Air...
- Upgrading cooling system
- Radiator Mounting Brackets
- 1969 Electrical question
- aluminum head gauge issues
- L88 Hood Graft
- Unburnt??
- Willcox New Sale
- Hot Rod Magazine EZEFI instal vids
- 80 corvette transmission
- Body comming off...
- TH350 Fluid Question
- Carb info
- 72 wiper problem
- trailing arm rebuild
- 80 vette trans. & torque converter
- Ethanol and C3 Storage Issues
- differential rebuild links
- Battery Charger Refresh cycle
- C6 Rims on a 1979 C3
- moisture...this can't be good.
- how can i tell my rally wheels are 8*15 or7*15
- How much HP will I get form this setup?
- Mounted seat covers- Any special vendor deals?
- Carburetor idle screw question
- Scatter Shield Question
- hot water diverter valve
- Holes for mounting seat tracks?
- Mounting Seat Brackets to Floor bolt ID
- question....waterpump/fan
- How Can I make My Anti Theft Alarm Activate ?
- TKO-600RR Installed, and it is SWEET!!
- Electrical gremlin
- 70 BB Composite Spring Recommendation
- Bench Testing Wiper Motor 75
- back window leaks
- Tire preservative?
- Intermittent starting problem -- need ideas
- Hydraulic roller lifters for roller block?
- Convertible latch mechanism help please.
- GM truck serpentine belt system
- Has anyone ever put a 68-73 rear clip on a later model
- carb replacement
- Power steering valve
- 383ci, 5.7" or 6" Con Rods???
- Frame disassemble appraisal
- ground wires
- msd weird noise
- Cam choice for a 355ci with iron heads
- Ipsco.org parking brake
- 427 vs 454
- Polarity Check - 71 Stingray?
- 68 Master Cylinder rebuild ?
- Charging question
- Lower shock mount assembly
- Need wire color info to wiper solenoid
- Power Steers only right #II Sucess
- 550# VBP springs question
- fiberglass dash for 3rd gen
- question for the motor heads
- Forged differential side yokes for a -78?
- Bubbles in hood
- Key Switch
- Connecting Rod choice, Help
- Body mount???
- power window is dead / replacing switch in console?
- Big timing mark discrepancy
- indicators not disengaging
- Seat adjuster track mounting question
- New Member
- New cam vs vacume
- head porting
- Blower motor
- tachometer needle fell out
- '72 bezel screws?
- New Fuel Line Installed - Pics!
- 76 auto trans shifter
- now the car wont even start...
- quick question on 71 trailing arms
- looking 4 wiper switch 4 1980 corvette
- Strut Rods
- 73 clip
- Building a 402
- Weird Speedo issue
- DeWitts CF group purchase
- Starter does not fit crate motor-HELP
- Horn Part Identify
- Convert to Electric fan
- Rearend Help with a 76
- bearings
- Stub Axle Side Play Clutch Pack Relationship
- fuel tank
- Clear powdercoating on intake
- No Brakes AT ALL!
- quadrajet dribbling gas
- Saginaw ID help, please.
- Hey Dewitts!
- 200R4 Transmission Questions
- How do You Repair A Drivers Door Rear Mirror?
- wheel sizes for 73 vette.
- Wheel spacers?
- Water in gas?
- Bellhousing ID
- Shifter ID
- Corvette Insurance
- Installing four horns
- anyone using a remote starter solenoid?
- Alignment woes
- 2701 Edelbrock EPS
- will this fit?
- Horn Issue
- anyone have their 78 or 79 up on jack stands?
- Replacing heater hose in 78 Vette
- Seating front wheel bearings.
- #2 pocket sleeve and rocker sleeve
- Seat Adjuster Guide
- How much HP
- rear syspension cross member
- intake gasket heat crossover question
- 77 aim?
- leaning out an 81 rochester
- Rear Astro Ventilation Door Actuator
- Sucking oil from valve cover?
- Aftermarket fuel pump question.
- tranny swap problem
- Holley Vacuum to Mechnical Secondaire
- fasten seat belt light comes on when headlights on
- Leaky windows/top - bring bucket
- TH 350 Seal Leak
- Dome light on an 82
- saginaw transmission work in 81
- Please Post Pics of your TH2004R Crossmember
- Gravity Bleeding- Rear Only?
- Tire to Muffler clearance
- Dow 7 coating for magnesium
- Rear End
- Old vs New Vic Jr. manifold -?
- Hesitation Coming out of the Corners
- Anybody ever dropped a Pontiac V8 in a C3?
- short block vendors?
- 1978 electrical questions
- KHE 300 stereo wattage
- Conservitive Fender Flares
- '72 350 Exhaust Pressure Uneven
- Couple questions
- Looking for interior pictures.
- Chrome Bumper Experts - Anyone Know???
- stainless steel brake and fuel line clips
- Replacing Rubber Bumpers,Any suggestions,
- roller rockers and stock valve covers
- fender flares + Wheel size?
- Installing Pace Car decals ??
- 8-71 Blower on 1969/427 who makes a Radiator that will fit?I
- Head gasket advice
- First time setting timing-questions
- Sealing Airgaps w/Expanding Black Foam ???
- new starter
- Dissaster stroke my 1979
- 1982 CE Fuel Grade Recommendation
- Another engine miss
- 69 Vette dash/column wire harness
- Installing z-bar bracket..
- 68 oil pressure gauge compression fittings
- Why rear bearing spacers?
- Carb Question
- Hi/Lo series switch for radiator fans? 1/4 amps, good flow
- Trailing arm Setup Help
- 72 lifter noise
- How to check a switch using a multimeter and a function matrix?
- Help with Pinion Seal question
- Head cc numbers , what they will do
- Performance/MPG inprovement options for an '81 with CCC
- 327 heads...
- Wire question center guages 68 vert
- help for new cam choice
- [1974] What are these wires for?
- Replace Heater Water Control Valve
- Help needed with dash wiring harness
- still having spark knock issues.
- What does "LS" in Chevy's engine stand for?
- Upgrade AC Condenser
- Big Block half shafts??
- Underhood power source?
- Tri Power Carb Questions on my 496 Build
- Gear Vendors Overdrive Review
- 1974 overheating
- Small block oil pan question?
- Aggressive cam / Lopey Idle & Mechanical Clutch
- Power locks & courtesy lights fuse blows
- Door Lock Actuator
- Shunt Resistor needed for Battery Ammeter
- Rewired Fuel Electric Fuel Pump
- Fast Burn head question
- Carborator
- How much compression
- Master Cylinder Leaking
- 870 cfm fan for interior (took out a/c)
- midrange stumble?
- Rehab needs
- Dual Fans and Original Aluminum Radiator
- BB Intake question & head opinon needed!!!
- 73to 74 frame interchange?
- lt1 (genII) swap into '73, question about accessory drive
- Spark Plug Wires
- 327 to 355 problem
- Fiberglass repair 1980
- mystery brown wire w/6.6 volts car running
- 1969 pic's-recent restoration!
- M-20 Shifter Linkage Trouble??
- Snapped hood release cable need to open hood.
- Replaced wiper door vacuum solenoid and wipers stay on
- dumb question-loose wire in batt compartment
- Alternator Belt - lost - help pse
- 16x8 tt 2s tire size
- 1976 breaks
- Overheating 77
- Breaks.
- Early C3 seat weight and bare frame picture?
- 1962? 327??
- End-play rattle
- first vette
- 77E a/c wiring harness
- Power steering
- Power steering
- Help a brother out, what do I have?
- 68 vert kick panel speaker depth
- Holley 3310-1
- Autocrossers, road racers, street freaks, what are your suspension specs?
- rear diff strenth
- console ground wire 68 vert
- Wheels?
- Headlight switch fire?
- 79 Hood Latch
- Air Cleaner ?
- Intake leak time frame & advice
- Looking for a A/F ratio meter
- Transmission fluid leak.
- OEM QJet Rods and Jets: Where to buy?
- Need to determine if this is an L82
