- Big Block Cylinder Head Advice Needed
- 71 ls-5 heater
- drive train
- need advice for TH350 rebuild
- Number matching water pump?
- Snowman's Bruiser Project Phase Five
- Charcoal canister missing
- Can't Get Rid Of A Soft Brake Pedal
- Rear suspension question
- What is the black canister behind the egg crate grill
- Vortec heads and cam.
- Disributor Rebuild?
- Initial (Base) Timing settings on a '70 LT-1
- Dynoed my 496" today....AGAIN...
- Auto transmission problem
- multiple questions on various issues on the vette
- Name this mystery wire
- Chevy Power Manuals... Does anyone know what
- door Jamb ground?
- Firehawk INDY 500 vs. BFGoodrich Radial T/A
- sealant/cushion agent for stainless mouldings
- I need more low
- what componets will make my crate motor look smog legal?
- 77 Oil pressure sender wire color
- No horn - 79 T&T
- Tach Drive Distributor
- Front tire clearance problem
- cleaning you intake manifold and changing pusher rods and valves
- What is the best way to clean you gas tank?
- 72 turn signals not working
- Where to connect vacuum advance hose?
- OK ..Is one of these YOUR's ???
- Happy holidays from vbp
- BBC Cam Recommendation for a 461
- vacuum system diagram/chart source
- What's the weirdest thing YOU'VE found in your Vette??
- How hard is it to rebuild........
- Could a 72 front bumper be put on a 73
- rims... I want wider/taller... show pics of yours?
- Latches for Removeable Rear Window?
- has anyone put a power chip in there 81???
- Help, Adjusting Headlights
- Suspension Question
- can someone recommend headers 1978
- Holley Carburetor
- dynomax 86008 discontinued?
- Wiper arm cover
- 68 327 fan part #?
- Need wiring Schematics/diagrams in color
- performance help
- yoke play and specs
- brown 78
- 1976 L82 Heads/Cam
- 1976 Blower box issue, passenger compartment heat
- (probably stupid) power booster question
- c3 rear end play and stub shaft sizes
- POLL: Would you recommend a T5 swap?
- Question: Rear spring removal
- zz4crate engine
- 1978 Rear gear Identification question
- LS1 MS4 Install (PICS)
- Carburetor is popping when i rev the engine.
- direct bolt on 5 speed trans?
- WS Wiper Motor Over Ride Switch?
- Need to know the differences between 2 base engines..
- Which radiator cap for my 73 ?
- Cheap parts
- Speed Direct front coil-over announcement
- What are these wires for?
- A-arm securing nuts
- Piston to valve clearance question
- Chambered exhaust with mufflers
- '71 350. Exhaust is Uneven, Even With Heat Riser Removed. Any Ideas?
- Has anyone ever used the POR 15 kit before?
- removing AC from my 76 C3 - help
- Coolent Recovery Tank
- Who rebuilds brake calipers?
- 350c plug
- 71 Transmission Change
- Help me identify these wires
- brake upgrades? bigger is better?
- Key Ignition Switch Removal
- 1971 ls-5 temperature sensors
- 1971 ls-5 unknown vacuum hoses
- Plugs Recommended
- Eliminating Catylitic Converter
- How much horsepower
- Holley carb. problem
- My Damn feet are just too big!
- Radiator core support
- ls5 crankshaft end play
- Retro fitting of brake booster/servo.
- '71 Stroker Motor Oil Pan questions
- Please Help! Ran perfect BEFORE I did work
- Fan clutch minutia, part nos. and specs
- Astro ventilation operation
- [1974] Changed rad, drain problem
- Carb identification
- head choice
- Gen6 BBC oil filter
- Gen6 BBC real seal
- Pertronix Ignitor
- 68 rear end gears
- BB oval port heads
- Re-built T-arms - rubbing sound
- Rear Sway bar measurement??
- Body Repair
- Tranny crossmember
- Quadrajet Jetting Question.
- 200r4 rebuild... did you do yours?
- 1981 Choke Relay Question
- Head mounting question.
- Need help locating date code from BB Heads
- Need pics of Early 76 core support
- 1.6 rocker arms
- lifters ??
- What shocks do you recommend?
- Corvette specific TH350 tail housing?
- Rear brake dragging
- No right turn signal
- buying my first 1980 c3.got a few questions
- Best Service Manuels
- Generator light
- Removing Diff housing
- air control valve hose
- Need the process in how to replace the rear body mount riveted to the body
- 1975 Drivers Door Mechanism replacement
- 77 electronic tach question
- Alum. Res. Tank Dents
- Need a torque value
- Headlight actuator
- MPG Improvement
- Broken Bolts - Vacuum Actuator Relay Valve
- Borla vs Magnaflow?
- Pulling to the left on hard braking?
- Electric Choke vs. Divorced Choke?
- Fuel Line Question
- HEI Control Module Connector
- How come I can't make a double flare for brake lines
- Tach wiring removal
- Compression Check
- Engine break-in w/ceramic-coat headers??'s
- Driver side door won"t open
- Installing Shocks
- Couple of C3 Questions
- huge power steering leak
- Starting procedure after fuel pump replacement
- 1980 vette carb?
- Removeable Rear Window?
- Delay in Headlights Opening - replaced lot of parts already...
- Weld up my 72 frame
- Cruise Transducer
- 1969 small block shifter removal
- Timing
- Do any of yall no what kind of wheels this are.
- TH350C Lockup Switch Info. Needed
- 454 to 496
- side pipes stock?
- alignment recomendations
- heater and a/c removal
- two tone paint question,78 pace car.
- Shark Bite Suspension
- Where can I get a genuine GM tach drive cable?
- side mirror sag
- Another Heater Bypass Question
- oil pan gasket?
- Tach still reads backwards !!
- 6 Speed Automatic Transmission - Am I getting greedy?
- replacing cage nut on #4 body mount
- trailering a body on a dolly
- wheels still turning in neutral - WHY?
- power door lock problem
- Good reputable shops
- anyone using a 7" brake booster.
- correct fan # 72BB
- 69 Rearend ???
- New Motor & Zinc
- alt light tapping morse code
- GM block #'s
- Radiator install help
- Header replacement
- Ball joint opinions
- DeWitt's Aluminum Rad Anti-freeze Suggestions??
- Help im locked out!
- Willcox New Sale! Some new items too!
- Brake Line Help
- Going to sell my race car in pieces including Tom's rear setup etc..
- Need some advice please
- 1981 engine rebuild
- 69 Distributor
- Issues swapping my speedometer
- Tools for packing front wheel bearings
- 8'' bolts
- Otto-r racing seats
- newly rebuilt power steering not working?
- Follow along as we (you lot and me!) try to fix my backfiring engine
- r4 compressor to sanden
- selling environment
- Rochester 4MV rebuild kit
- Rusty Sidepipe Headers..
- T5 in C3
- AutoFab 4 Link Guys.. I need setup help.
- Interior Vinyl Paints??????
- Steering pulsates...left turn only
- Parking Brake issue need some assist
- Porting AFR heads
- AFR195 valve seal replacement
- Chevy 350 auto to manual tranny swap
- Progress on Big Brothers '80
- Please Help Identify Vac Advance Can
- Headlight housings stuck in up position
- Wheel bearing maybe? Help please.
- '71 350. Exhaust Doughnut Gaskets Keep Burning Up, Any Ideas?
- Hp stub axles
- transmission help - please
- WTK: Value of Intake Manifold
- Anybody have a G-Tech? how do you like it?
- Need help finding the right piston for 496 project - using LS 5 heads worked!
- AFR 180 on 383
- Need Brake help
- Seat belt interlock bypass?
- Anyone use johnny joints in place of trailing arm bushing?
- experimented with my demon 750DP and MSD today
- Willcox New Tachometer Help, Removal, Board Install, and Video File!!!
- Protecting bare metal
- Aggravating Glove Box Lock
- Bilstein shock install????
- heater core removal
- Fusible Link Alternative
- one side high
- 69 new radiator, no bottom attachment?
- Anyone hear of this place
- Speedomter quit working, probable cause?
- Booster to MC pushrod length???
- Learning on the fly
- Can someone walk me through changing the A/C Compressor....
- transimission
- 12 / 1975 Build Date -Stingray Question
- 13 digit VIN lookup?
- E Brake Upgrades?
- MSD E-Curve Dist problem?
- wacky tachometer
- seeking brake recommendations
- Starter went south !
- Leaking vapor line on 81 fuel pump
- Looking to change carb
- painting front and rear bumper question?
- Did more diagnostic on that ping
