- Headlight Dimmer Switch ???
- Merry Christmas
- Vacuum advance is retarding my timing?
- Steering Play Diagnosis- need Help
- 68 wiper motor washer pump
- T-top weatherstripping & resto
- C3 Age Data Compiled
- where to start,dipstick blowback
- Trying to identify distributor
- Building an LT1 clone?
- Installing the rubber fuel lines to gas tank on a '76 question!
- Just bought a 77 vette!
- Early release of GMPP 2010 Catalog
- anybody know anything about the racing history of this C3?
- 69 wiper door relay
- Cruise timing- how do you guys set it for best mpg?
- rear end rebuild
- blower issues
- External fuel pump recommendation
- Lm7 pics
- Crane Vac. can
- help with headlights
- ZZ430 idle speed
- best make of rear bearings & u joints????
- steering column lower lever - advice needed
- Will these wheels work? help quick! deal in process
- 200-4R Transmission Lines
- Flywheel bolts
- anyone riding on mickey thompson sportsman S/T radials.
- Need 1982 Engine pictures
- Automatic Shifter Problems
- 15 x 10 wheels on rear - what backspacing?
- Adapting Veglia Oil Pressure Guage to 78 Vette
- Anyone with 288AR cam, have a sound clip?
- Update: Valvetrain and Lash Caps
- To Foose Nitrous 5 or not
- Need some vacuum troubleshooting. headlights pop up when engine is started.
- TO replace or not replace (heater core)
- 69 style side exhaust my way -lots of pics
- Windshield Wiper hits bottom of windshield
- motor build
- 1972 washer pump barrel or blade terminals?
- New PS Ram question
- Alternator lights!!! I'm going crazy
- flywheel help
- long vs. short water pump
- small block oil pan test
- whine/whistle 377ci
- what are these elec parts & connectors?
- Sidepipes(noise)
- Engine number
- who offers a 6 speed shift plate in early C3 design ?
- GOOD machine shop in Elizabethtown, PA?
- Seatbelt override switch PLEASE HELP!
- 77 C3 rear carrier assy question
- The LT1 going in the 68
- C3 Front Signal Problem
- Tips Removing fan, belts and pulley
- Replace stock composite spring?
- Muffler options for '81 ?????
- 68 BB radiator
- Need pics of 1970 wiper door assembly on car
- Engine in death throes?
- Anyone have a picture showing behind the front grills?
- Need Help with Mini-Starter Wiring - with pics
- How do you reomve the glass from a 76 rear view mirror?
- 68 Wiper Motor Replacement
- Windshield Wiper Tach Solenoid Foam Thing
- Pre-77 Hood on a 78+ .. I have both!
- 71 Vette - no "high" on blower fan issues
- Headlight Actuator
- 5.3l ls
- Overheating problem - 81 vette
- horn relay wiring help needed
- 5.3l lsx
- automatic 350s vs std 350s??
- high compression in one cylinder?
- Upper Radiator Hose
- Best option to purchase 4:11 ring and pinion?
- New exhaust pics/vid...
- Fast help needed!! Will these fit??
- Does '74 454 Like to Rev?
- Choosing a dual exhaust system??
- T-56 into an 80 Vette
- 71 ls5 fuel pressure
- Which Felpro Intake gaskets do I need for my ZZ4?
- Side marker
- Leaf Spring - Fiberglass
- 68 vs 69 steering column
- grant steering wheel experts drop in
- repairing Vinyl rips and cracks
- different styles of 5.7 exhaust manifolds?
- How much power will an '81 rear hold?
- BB rocker arm ratios
- Flared 69 or no...?
- Opinions on stamp pad
- drivers side mirror removal
- where to buy seat covers & contact info to W.Knoch, pls
- Dynamat - yay or nay?
- Van Steel December Deals
- 1.098 60', 4.96 lifting at 133
- How do i remove the speedo to cxhange a bulb?
- vaccum advance question
- ttt
- shutter/stalling?
- O2 Sensor Question
- Halogen H4 Healight Conversions for C3
- replacement carb suggestions
- Rear wheel alignment and bearings
- Removable rear window conversion
- 300hp-350hp 82?
- I need help on changing my 1970 interior lights (bulb replacement) .
- Headlight go up but no lights?
- 6L80 anyone seen this transmission, how big, is it possible?
- Bee Jay's LT4 Hot Cam Hydraulic Roller Conversion
- Chrome Hooker Sidepipes--any fans?
- Intermittant Wiper Control
- Turbo 350 Transmission question
- more power... what needs to be beefed up?
- q-jet fuel problem
- Need Dick and Jane instruction
- Carburetor spacer it's a real improvement ?
- Any one use the Innovate LC-1 for tuning?
- Engine temps...
- C3 Pedal assemblies
- Muncie speedo gear removal
- Win ALDL
- AC Question
- Color Code for my 75'
- build date to vin number
- Front suspension rebuild
- What Antifreeze???
- 76 rad wanted
- Piston manuf.????#7028P????
- Steering play and control valve leak
- Has anyone got a solution for dealing with this crusty wiper stuff?
- 73 Vette Tuning, DFW area, please help!
- Ammeter Battery Gauge repair advice
- Fuel Sump Ideas EFI
- Has anyone istalled an AC Delete Cover?
- Top End Rebuild
- Borgeson steering box dimensions?
- No heater hose connections on a supercharger intake manifold?
- Retrofitting Jag rear suspension?????
- 69-75 horn and steering wheel help
- Help with starting
- 1979 engine removal
- Another question about 18s
- Ideal EFI Fuel Lines
- headlight woes
- Halotron Fire Extinguisher
- Question about tightening suspension components
- Any good factory Chevy cast iron BBC Big Port heads out there?
- 82 Vette Tilt and Telescopic Question Please Help
- Trailing Arm Questions
- Manual to Power brakes
- RPM AirGap on a 73 L48?
- Cabin Prepping Before Carpet Installation
- Hardtop glass date codes '68-'72
- Summit 600CFM Carb for C3?
- Wiper Door Question
- crate engine question.
- Are 76 and 78 door internals different??
- How to disconnect speedometer cable
- rag joint tolorence
- dash wire harness
- getting the correct colors on the quad jet
- frontend fiberglass repair info?
- Spark Plugs
- Valve train experts
- Interior Paint
- 70 Auto trans X member
- M/C leak.
- what steering coupler?
- Help With Temperature Cable
- Reed solid roller cams?
- Battery drain
- Rear diff ratio and actual rear wheel horsepower.
- R-12 Freon or R-134
- torque converter
- ZN1 trailer package
- 79 oil pressure guage
- Brake Bleeding Problem
- Carpet Set
- General ride/suspension or Koni shock question
- Use of oil deflectors on SB rocker arms
- Vinyl or leather?
- PCV valve,can I remove?
- What are these three knobs under the dash?
- Hei power
- Paint line on underside of hood / 71 vette
- Decking - how much?
- 76 stingray updates
- trailing arm rebuilder in mn.
- How to find the vacuum leaks, and test system
- Noisy T-Tops on my 75
- How to Replace a 77 Washer Pump?
- Where can I get a 1981 Vette Shop Manual on CD/DVD?
- Lights don't close together.
- Vacuum Lines Disconnected
- AIR (smog) diverter valve question
- Over my head looking for reliable mechanic
- Side pipe mufflers for 68
- Need some ZZ4 input...
- 76 corvette ignition sheilding
- Wiper varrible speed issue
- Power Steering
- 71 Vette wiper door issues
- best/easiest 1973 front bumper to buy?
- Valve Covers
- Leaking heater core
- Can you convert a 1976 to a 69/70 nose and rear?
- SBC 400 question, IN NEED OF A MOTORHEAD :)
- Correct frame splice area?
- Pressure plate wear...ok to reuse, or replace?
- Need advise radiator leak
- Wiper motor/relay solution '78 PC
- RPM will not go down when I hook the vacuum advance!
- Converting to Fast Ez efi
- '79 Front Clip fit '80 Corvette?
- Seals
- End Of the Year Sale-First Items
- Replacement of Radiator Hoses
- Headlight not locking into full open
- Sending Unit Wiring Issues on 1979
- Tighten up telescoptic steering ??
- Which Cables
- Points ignition question
- 81 project on hold
- 1970 Engine ID Code question
- Wheel and tire combos
- Electrical problem: taillights on only with door open?
- Hot Rod says a carb will usually make more HP than EFI
- Can't find a 1970 Chevrolet Corvette Service & Overhaul Manual
- Removing headlights as one piece
- moderator needed to help out with a basher
- Interior Panel repair and paint
- 650 or 750
- Bowtie Phase 2s,or Brodix IK 180s?????
- lifter tapping :-(
- Speedo needle bouncing
- 1977 C3 steel rally wheels color
- Rear Spring Help
- Piston and Rod recommendations Please (small block)
- Vacuum reserve tank & vacuum
- What does this switch do....
- changing the heater core
- Mn-brent ls1-4l60e swap
- Can remove ignition key in gear
- Who has replaced headlight actuator seals?
