- Cam Swap Valve Setting Question
- 82 corvette brakes, fuse panel, heat, light problems
- NEW! Carbon Fiber Doorsills GM LICENSED
- Installing speed bleeders???
- Help needed cross member mod 350/700R4
- Hot Rod Magazine's 289, 302's, 327, 350's and 351's dyno tests?
- Auto Transmission Tube
- TH350 - how much can it handle?
- Major Issue's Please Help!
- How do I remove washer tank?
- Wiper parts
- wiper problem!
- T-45Rs 5 Speed Install
- Ratio computer on line please
- 1969 Corvette L46 Coil Wiring
- Air Fuel Ratio Gauge Opinion
- intake manifold ? (heat shield)
- What is numbers matching
- Convert power brakes to manual brakes...
- 71 lt-1
- Does this sound right ?
- 1968 steering wheel hub?
- Very pleased with ZIP
- How far back do you have to go for no smog stuff ?
- No Brakes
- Loose steering column - 1976
- Engine Block Paint Color
- Do any different model seat belts fit in the 78-82 C3s?
- Converter recommendation.
- Posi unit slippage.
- Block hugger headers
- Broken Torque converter and axle at same time?
- 75 tack
- 73 350 Vette looking for a stock type Carb
- T56 driveshaft
- another home made Rack and Pinion
- Constant Heat Coming IN Duct to cabin
- turn signals dead
- Plug question for zz4
- heat/ac controler
- Finally got my N2O system installed
- NHRA battery rules for 9.99 and faster
- Seats for 75 vette coupe
- Q-jet books
- Hyd. Roller Upgrade?
- Valve Keeper Wear?
- Q. re 7-mm and 8-mm Spark Plug Wires
- pls decode this..
- LS1 swappers - Radiator hose solutions
- Dragon Fire Dizzy Timing?
- Alternate starter
- Rim code verification
- Technique for removing rear window molding on a 1980
- Problem with Richmond 5SP OD
- '78 Spare Tire Light
- Seems like Bubba has weld my frame (pics)
- paint marks on pressure plate?
- Timing Cover Seal Question
- SBC Flywheel
- "79 Vette No A/C or P/W
- A little off topic question about Daytona spyder converted Corvettes
- electric vacuum pump
- My head is cracked!
- carburetor internal corrosion - fuel?
- 78 radio question
- Anyone deal with these guys -Headers ?
- front end rebuild
- Collapsing the steering shaft?
- A little car porn...
- Replacing 1982 Fuel Pump w/1985
- a bubba moment ????
- Next Step?
- Help identify a engine
- Need rear shocks?
- 74 aim
- Turn Signals keep blowing fuse
- Help Can't open my hood.
- Do I need to have a mini starter with Hooker 2123 Super Comps?
- New Exhaust!! :O)
- Jack question
- Anyone using wisco PT046H3 pistons in their 427?
- 82 rear emblem location
- 5 speed trasmision
- Is there any way to quiet '69 BB side pipe mufflers?
- Brake Rotors
- Steering wheel play. still
- Will this tranny work?
- Inside Mirror w/Map light....fix or replace?
- heater blower
- 1973 Front Bumper
- Wheel Stud Replacement on rear
- Long 27 spline 1310 trans slip yoke for Corvette?
- GTO T56 in a 72
- What about some black corvette pics
- Wonder what my 1/4 time would be...
- Race car pics thread?
- How do you tell if the T/A is an offset one?
- Big block Vintage Air compressor install.....pics..
- Heater vacuum valve.
- broken headlight support blind nut - options?
- Rear end rebuilders?
- •• 2010 Short Block Special ••
- Gage cluster paint?
- fuel delivery
- Replacement headlight switch but no vac ports!?!?!?!
- Intake manifold vacuum with LT4 Hot Cam?
- hood latch
- Vacuum peice on headlight switch bad?
- Explanation of transmission choices!
- Light staying on for parking brake
- New Years Corvette "resolutions"?
- Ragtop weather stripping
- synthetic oil
- No oil filler cap? Add oil how?
- Adj Camber Rods: Hiem joints or Solid rubber ends?
- Oil pump drive connector
- which headers will fit my '80?
- Need Some Pictures
- #2 body mount rot
- Happy New Year
- ebay distributer
- Rack Attack vs. Steeroids.
- Center Gage Cluster Removal
- Well finally got a new job !!
- cast in china
- 79 speedo issue
- Spec. on 350/350 GM style cam
- Help Once Again!!!
- Aftermarket A/C unit blower stopped
- 71 ls-5 radiator
- Camshafts/Intake matching : Engine gurus, please chime in.
- wiring diagrams
- brake Bias vlv - placement?
- What type of GEAR CASE OIL ?
- New Years Day STOCK CAR RACE @ Rockingham NC
- front suspension questions
- Preferred method to ding SS exhaust for clearance
- C3 LS engine and coil relocation
- KYB/composite spring
- Repainting 78 L82 Valve Covers
- Show me you Center Caps
- Pre-lube after rebuild
- In Need of Wiring Help!!!(Big Pics)
- Head comparisons: AFR 195 vs, Dart platinum 215
- Anyone order from Viginia Vettes?
- Cam Choice - Need help
- Broken Speedometer cable
- Thinking about swapping out my old transmission
- Make a more powerful L48!!!!!!
- Addco rear swaybar????
- best results for spark plugs ???
- new flywheel...need to resurface ?
- Ammeter shows ( -14 )
- Sway bar or no sway bar?
- Diff Front Mount, Rubber or Poly?
- suspension kit or shocks only? what would you do?
- Need help with power rack and pinion hoses
- engine choices. Vortec or stock.
- Fresh air vents
- Hydraulic clutch no good for flimsy C3 firewall?
- Which Tire Handles/Rides Better: 225/70 or 255/60?
- M20 to an M22
- Gas tank reinstall ?
- Trim ring clips ?
- Head light actuators
- Speedometer Cable question
- picture rolling chassis
- TH400 Tranny ID Help
- Help from a radiator repair person
- Water pump ports
- carb fuel line diagram?
- Need heat in cabin!
- ??? 95 Vette HD brakes VS. SD brakes???
- Hooker S/C installed -- Issues tho, need help
- Any speedometer-spezialists out there?
- want to hear from folks running solid motor mounts.
- Checking "Run-Out"...
- Transmission support bar and Exhaust
- In search of bent frame options for 70 convertible
- spark plug wire looms
- Rocker Adjustment
- Autocraft Scope?
- New Demon Carb, Car won't start.
- Seat belt restore
- electrical help please pics
- photo of '70 seat belt guides
- 1980 oil filter
- Changing Valve Cover Gaskets on 1982 Corvette
- Speed bleeders...
- Automatic transmission won't shift
- Speedometer Gear Question
- Help Choosing Parts
- Productive Evening in the Garage
- Step by Step - How to replace a bulb in the Speedometer or Techometer
- Shorty Headers SB 69 vette?
- gas tank qasket question
- 82 telescopic steering problems
- Header to pipe gasket question
- to replace or not?
- 1982 corvette crossfire question
- 77 C3 transmission change question
- 1979 Throttle cable.
- distributor problem.
- Turbo 350 Trans question
- Engine guys: Big block cam bearing question.
- Seat stuck - can't tilt forward
- will a 400sbc fit in my 1980?
- 68 Starting Problem
- welch plug question
- Body mounts
- 79 Vette transmission help needed
- Did some timing light testing...
- What is this part?
- odd carb. problem...
- is it dye or paint/
- ZZ4 drain plug
- Installing Hooker headers in a '71 BB
- Low fuel light
- 434 horse power
- Power window assembly rebuild
- Re-painting interior pieces
- Sound deadener...
- flywheel size
- AGR Performance Resto Steering Boxes
- Throttle linkage problem?
- Passenger side door panel
- Pro-Touring C3s?
- Why You Can't Troubleshoot Q-Jets via Forums
- 71 Gas Tank Installation Problem
- Awesome Headlight upgrade - Not HID revisited
- How do you adjust a rochester carb choke?
- Rear Bilstein Sport part #
- Cold idle adjust?
- Hooker install issue
- VBP smart struts
- Advice needed - '69 big block composite rear spring
- '76 V Belt Problem
- Who has done Electric Door openers for a C3
- 68 L89 Berger car value ???
- Cat bypass
- zips suspension kits
- 82 Power Window Help
- Hose size question
- engine ID
- Headlights slow to open & rough idle.
- 76 quadrajet adjustments
- Edelbrock pro flow element replacement?
- Wrong Starter?
- 1968 Wiper Wiring
