- Ididit tilt steering column for 68 Vette
- HEI distrib on '69 smallblock
- Exhaust question (with video)
- Mounting pictures needed
- key stuck in ignitionI have a 76 vett
- Just Bought 73 454 with 78k
- Windshield frame
- Spring mount bolt size
- Drive shaft dent
- shark( dolphin ) or auto meter
- Changed from the Q-Jet
- Radio Speakers
- Power Locks
- need advise on uneven rear suspension
- Front brake leak at crushed washer
- Parking brake problems
- help.. wiring for 70 amp delco.
- Pic's of Speed Directs new springs for front QA-1 Semi coil overs
- Broken outside mirror bolt
- 68 ignition lock help needed
- 71 bb distributor worth repairing?
- To Gel Coat or to not Gel Coat
- i know its been asked a hundred times...
- changing oil pan gasket-muffler Y pipe in the way?
- Borgueson Install
- bezel refinishing
- Are these cracks common and how do you get rid of them?
- 77 C3 w/700R4 TV cable adjust.
- ls1/t56 six speed in a 79 vette
- Help me choose a piston
- Manual steering move to inner position on steering knuckel
- LS1 in my 75 vette...need help from those who have done the swap
- Viper Tires
- 76 Stereo question
- Turn signal lever removal q.
- Advice for an agressive street setup. (engine/susp.)
- Update on squeak and tire lean
- Deck lid weather stripping..
- Disassembling a '77 Steering Column
- Broken exhaust bolt advice?
- Anyone ever restored an air cleaner?
- Steering Gear box removal.
- Power steering centering setup question
- Digital Torque Adapters
- New member greetings from eastern NC
- Couple of headlight operation questions.
- Installing a 200-4R into my '71 - questions on wiring
- 71 ls5 fan shroud extension questions
- Planning to upgrade carb and intake - please share suggestions
- side window mechanism repair
- TBI Swap question
- Stage 8 Header Bolts on Hookers
- C 3 headlight problems... help please
- Vacuum Lines to 79 Carburetor
- Diff to rr crossmember torque specs???
- making the change
- Radiator and radiator support options for 69-72 Help
- Replacing tach cable
- differential fluid change
- Got t-top weatherstripping, no metal strip?
- Where to purchase 69 rear spindles?
- Painting A C3
- 76 Belts
- why does it keep throwing power S. belts!?
- Heater core for 74 W A/C
- Rebuilding a Holley
- A/C vacuum help!
- ehaust choice
- Best 502 crate engine for the money
- Rear Sway Bar Installation
- 502 head bolts
- No Heat-Changed the rear vacuum control on back of heat/AC control but still can't g
- Auto to manual swap pedal ideas.
- Power Steering Pump
- Tweak my Timing please!
- 700r4 cable deflecting at trans pan going into park
- 77 Corvette Speedo, Odometer, Tach Problems
- starter? help!
- 1980 Corvette - WIW?
- 68 Headlight doors eary vs late
- Which spark plug should I use?
- Alternator problem ?
- Windshield Removal
- Speedway Shaft Rockers Question
- For those who have switched to FI.
- Header bolt came out!
- Oil filter adapter leaking. Which one WONT!?!?!
- Weatherstrip suppliers...
- Rear Pass tire leans in
- A good A/C man on Long Island?
- 79 Corvette Brake Light Issues
- Water Pump swap
- Stall problem
- how do I fix this.... t-tops?
- Has anyone put a C5 radiatior in a C3?
- Oil Pan gasket ?
- Spicers U-Joints
- Head gasket for 502
- BB radiator for 75
- serpentine for zz454
- axel stubs
- Engine pull?
- S2000 seats in a c3?
- Pround owner of a 74 vett.
- Mechanical fuel pump for 383 ?
- new motor from machine shop
- transmission cooler question
- Aftermarket timing cover.NO TIMING MARKS!!
- Ac fitting
- Which Suspension Stake kit???
- Converting to Power Windows....Tweeters in Door Panels???
- Where to buy tubing and heim joints
- Is this the way it is supposed to be?
- Is this legal?
- Jim Shea – power steering pump questions
- pic of 71bb timing tab?
- Shocks etc. advice please
- Please evaluate my birdcage / frame rust
- Ran into problems installing seats today, need help
- Carburetor swap
- Brake line question
- Jet differences
- Spare tire size ?
- another Qjet rebuild question
- Rewiring 1970 wiper motor
- Chrome water pump
- Has anyone converted from r-12 to R134?
- looking for 67 restoration service
- c5 seats
- Need brake caliper info
- Clutch pedal linkage retainer
- HELP identify part 1981
- Engine Harness Wire Location
- reverse flow radiator???
- Trans crossmember
- I sure wouldn't want to do this!!!
- What radiator are you using with your electric fans?
- Kudos to Lars
- Ultra Street Avenger - Anyone got one?
- Hesperia/Apple Valley Alinement
- Motor Trend Oct 69, ZL1 Vette drag test....PICS
- Bore size of LS1 clutch master cylinder
- 350/350 cam recommendations
- lets talk dyno's
- What's wrong with this picture???
- Diagonaising radiator fan clutch problem.
- vacuum advance cold start experiment
- BBC Cam Recommendation
- 10 point cage finished finally
- New stereo and amp insullation:
- 1971 Roadster Windshield Trim Removal
- Comp Cams...Why are we down on them?
- Posting some pics of the paint
- Lower A Arm--Driver's side ?
- 400 block vs 350 ? Questions......
- Looking for advice on new headers
- Help with Backup Light issue on my 1980
- Looking for a good diff rebuilder in So. CA
- Tire Sizes
- Links to tips in the sticky about not working...
- How do i check my headlight switch
- lt1 or not??
- To Send Or Not To Send?
- TPI Conversion query....what HAVE I done?
- Rear sway bar
- Window drops???
- kick down cable
- Help with HEI wires for 71BB
- 142/144 Weiand Supercharger what carb? (anyone running a quadrajet)
- Help with date code on starter
- transmission slow to shift & steering adjustment
- Hooker S/C header resolved
- Steering Column Questions
- guys that have rack/pinion step in
- Body knock noise
- Which Valve cover gasket & how to install??
- L88 hood
- Is the a seal around outside handles?
- bushings
- Quadrajet choke
- Head Bolts is Grade 8 ok?
- overdrive trans, direct replacement for muncie
- carb questions again
- Custom audio in your C3
- "While I'm in there.." dash removed
- Pics Z068
- What is the switch in the center storage box for?
- Trim Tool
- Alloy wheels for c3????
- E-Brake Handle
- Anybody use this company for wheels?
- Key Buzzer Switch
- c6 seats in c3 car
- Newer year AC compressor on a '74 ?
- billet serpentine conversion - alternator question
- Electric Fuel Pump
- What can i try to get the Brake Booster to work again ?
- Auto to manual conversion
- Question about Wiring Diagrams
- Cold air intake... anyone use one of these that has a picture??
- guessing valve adjustment ?????????
- Any vette ?s answered here.....
- Ping at 1500rpm only is driving me insane
- 81 oil dipstick
- New starter will not shim
- 1980 Fuse Box Question
- How do you determine engine temp using an IR thermometer?
- Performer RPM
- Headlights going up and down finaly!!!!
- Rear lamp refurb ?
- Lights go up, only one goes down on 77
- The joys of 5 speed OD and a 4.11 rear end
- LS1 swappers Throttle cable
- Corvette Central Carburetors?
- '70 Locking Storage Compartment
- Wheel bearing question
- Horn won't stop blaring!
- 2004R Swap
- Wiper adjustment
- Swapping in a new door... mirror doesn't fit?
- Jeg's vs Summit
- Any possible way Gen IV Big Block heads will fit a Gen V?
- What part?
- Reverse lockout T56
- Too Good a Deal ???
- 1979 upgrades NEED HELP
- Fuel line
- where to buy best quality weatherstrpi kits?
- How do I transfer door panel hardware?
- Need some help with blower set up
- Bending air lines
- vacuum leak, can't find... trans makes it???
- Tach Problem Resurrected
- How Do You Remove Shoulder Harness
- Points out - HEI in ?
- Reduced heat in cabin by 90%
- "Correct" Water pump for 1971 LS 5
- Swap a 200-4R in for a THM350
- Removing exterior door handle
- Camshaft and lifter change 1976C3
- Brake Lights not working
- Big block conversion
- Where are the hazards?
- 68 z06
- 72 454 what cam shaft to use?
- A/C wiring questions
- 82 Power Steering Ram Assembly
- Fiero Seat Bracket Measurements
- noisy 4 speed trans
- Frame Steel Question
