- Compression Check Question
- Borgeson Conversion
- Educated about L-88
- Can transmission side cover assy be removed with tranny in car?
- Headers for Factory Side Exhaust
- changing water pump sides
- C3 removable rear window conversion
- '69 ZL1 Stencil????
- Fly wheel
- installing a return line fitting to the tank questions
- Thank You TimAT -- Rear Main Seal
- 4 Speed Reverse Grind
- 82 EGR question
- Need advice for pulley kit
- Steering Column Drop Question
- A/C Motor
- 81 Comp removal question
- Oil change schedule?
- 1980 Rear window trim question
- 1979 L82 Exhaust
- 68 rear compartments
- 77 tach reads hi
- side pipe question - am i missing somthing?
- 77 fuel gauge and lo fuel light problem
- can any one help with 77 wiper problem?
- Transmission leak
- Ken Harrison Stereos
- Setting My 74 Up for Autocrossing
- New Engine
- Fuel pump
- gear ratio + hp/tq + tires = mpg... what is yours
- 3-4 shifter shaft came out of fork?!
- Camshaft
- oil problem...
- 1978 clock question
- hood pin mounting idea, pics included
- Can I or should I reuse head bolts?
- 69-75 convertible door glass in 68
- F41 rear spring who to buy from
- My Brake Booster OK or Junk??
- exhaust questions
- Edelbrock intakes
- Help with 200-4R front pump installation needed
- pics of my new 3" inch exhaust
- engine guru's. review my timing curve.
- Original dimensions of stock Rally rims?
- Does anyone make tubular LOWER A-Arms?
- Conversion to 1/2" fuel supply line ?
- Understanding spark plug codes.
- 6 LINK setup, lets see your setup.
- Qjet id please.
- transmission fluid leak mystery top engine
- Help car not idleing
- Fully Synthetic Oils ??
- Engine "pops" from left exhaust. Help me troubleshoot please!
- Oil Pressure...What do I believe?
- Won't crank after sitting overnight!!!
- My 72' has a loud clunk in rear when putting in reverse?
- Who sells a new "Fuel Tank Cushion"?
- Replacing Headlight Switch on a 81
- Man it smells in here....
- Help Decode
- fuel pump & regulator
- New strut rods!
- Steering Box Rebuild (link)..
- Why Newer Fuel Sending Units Suck!
- Dome light delay 78
- 1979 outside door handle problem
- 79 dash assembly pics please
- 454 '70 casting number
- LS5 Spark plug wires
- Valve Springs
- shifter knob/boot removal
- Electrical help still needed
- Eaton Detroit 9 leaf rear spring
- Lifter Noise L82 78
- Anyone use this Fan?
- Dash Indicator Lights?
- 12 v Vac Pump
- Anyone else have this radiator fitment problem
- Rear End Woes
- Head Selection
- ? about new remaned carb
- Run On
- Spark Plug Wires By Length
- Jet Performance Q-Jet vs Holley Q-Jet Replacement?
- rear TRW fiberglass spring split. who has a good replacement?
- Seat Belt Buckle 1970
- This is how you install a Line Lock
- Mech Clutch & High Torque / HP engines
- Octane booster?
- Can you replace the face on a 75 Tachometer
- My engine compartment wiring is a mess
- '73 454ci dual exhaust w/ longtubes
- Test VSS?
- Suspension issues
- Gauge lights
- Carb Question
- Another fuel pump/carb problem
- 82 Won't Start
- How would you fix this crack?
- Goodtimes. Need pic of headlight switch.
- Trans leak frome bell housing. Started in this cold damp weather.
- Question on lower ball joints
- Rusty A-pillars
- Welded tranny OK???
- Dash gauges die when headlights are on.....
- Mechanical fuel pumps
- Headlight vacuum question....????
- Vacuum gurus needed
- door ajar and seat belt warning questions....
- it leaks! what size hoses? 80 vette
- PCV Help
- Connecting Rod question
- Another timing post
- Pesky Little Bolt
- Custom made wheels - what tires???
- L-82 camshaft timing question...
- Sidepipes hanging low
- 1971 ls5 vacuum and fuel pump pressure
- Courtesy switch in door jam
- Steering questions.
- Are all C3 frames the same?
- Potential 68 Vert buyer with questions!
- T-top rust (lots of pics)
- Headlight Assembly Interchange
- More C3 Corvette exhaust
- No instrument lights 79
- Timing question - Does this make sense?
- Sticking brake caliper 71 Corvette
- Sticking caliper piston???
- Front Sway Bar Torque
- Battery Gauge
- Need a little wiring help for transplanting a 77 steering column into my 71
- Where to ground a rear mounted amplifier?
- door lock problems need advice (picture)
- Tire Size Questions
- MSD Ignition Install
- will '67 side pipe headers and pipes fit on a '79??
- I need some advice diagnosing my 80 vette.
- expansion tank code ???
- Paging Matt Gruber - Tech Article Info
- Base 350 top end build
- separtating bearing support from TA
- Longer Oil Filter for 427
- Finally got my Vintage Air charged up....Impressions..
- Rear end feels like its shifting side to side.
- niosy rear end
- cruise control not working - answer
- Stock 350/270, Want Dave's Small Body HEI Conversion, Where to Mount External Module?
- Best--Aluminum Rad to use?/ and pre formed vac lines
- Decoding engine blocks What's the "T"
- Drive shaft length? and measurement?
- Wiring question
- Looking at this 454 for my 72. Opinions please...
- Electrical Issue Help Needed
- soeedometer for 76
- Trailing Arm Front Bolt
- GForce/Summit Cross Members
- Engine Bucking when Starting
- question about fixing the headlight vacuum tree
- 78 alarm
- Drive shaft removal '78, 4speed
- Please help me evaluate this 383...
- C3 Corvette exhaust
- Broken reverse lever
- ZF Ind help needed Does anybody know about this trany
- New Ignition?
- **Polished SS 1 7/8" primary SBC header !
- Combo/Price opinion
- Oil Pressure Gauge leak
- Door Handles
- Engine color
- Temp Sensor w/ Aluminum Heads
- drive w/o power steering pump?
- taking frame measurments on c3
- Can you use a header bolt as a ground (earth)?
- exterior door handles
- 78 L48 Plug Wiring Question
- 1975 L82 Headswap
- engine help
- 84 Engine/Tranny in an 82?
- Utilization of stock oil pan for 1969?
- Engine and AC Wiring Harnesses
- building a 383 for 1969 4 speed frame
- 69 BB fan clutch
- Paint color 82 Collectors edition
- My first corvette ,just bought and i need some help with the Quadrajet
- Gauge lights don't work. Please help.
- 68 Hood Surround Problem
- Turbo 350 MX2
- Steering cylinder removal
- Gas odor after running
- 82 will not start/crank
- Speedometer gear color code question.
- battery terminal/cable help and car fire story!
- Headlights stuck up after maintenance
- Dome Light Riddle.
- Stupid?....68-72 Water temp gauge....
- Performance l48
- Need Help, Car has no Electrical Power
- 1969 350/350 v 1970 LT1
- Points conversion rant
- Aluminium Wheels
- 1969 350, harmonic balancer ?
- Mice in my 1969 Corvette
- frame mount bracket for trans
- Turn Signals
- How a Pro sets the timing for optimum performance and mpg
- Paging Willcox
- New front suspension
- machine shop
- Oil Plug Trick
- A.I.R Pump Bracket
- 1980 Wiper Motor Questions (Pics)
- Strut rod...mind of it's own
- Steering Gear Box to have 240º lock-to-lock
- need help with my 77 vette
- O-Ring Style Calipers
- Need Quick Help. Fleixble Steering Coupler Stuck.
- What Intake will clear stock 76 Hood?
- 77 vette
- Shimming the Body - Advice, Tips, or Tricks???
- Adjustable strut rod kit ???
- 72 tilt steering colunm
- 69 Vac Question
- 69 Owners! Headlamp washer check valve question
- Found my noise$$$$
- Lifting Big Block Question
- Tranny Leak
- Flywheel Question
- Vibration at idle through highrer rpm's ???????????
- 1978 L82 Rochester Carb Mixture Screws Please Read
- More '70 questions ......
- Battery relocation
- 1978 bumpers
- loose magnet in transmission
- Help I am choking
- 1975 Medium Saddle Coupes
- 1979 lower radiator hose spring
- Ididit tilt steering column for 68 Vette
- HEI distrib on '69 smallblock
- Exhaust question (with video)
- Mounting pictures needed
- key stuck in ignitionI have a 76 vett
- Just Bought 73 454 with 78k
- Windshield frame
- Spring mount bolt size
- Drive shaft dent
- shark( dolphin ) or auto meter
