- Rocker studs turn-now what?
- Tjsiii - l48
- C3 Pace Car Article on Line
- Building a 383 stroker
- Fuel Leak Question
- Which Stroke...3.875, 4" or ?????
- where dimmer rod need to be connected???
- Removing leafs to lower rear
- Hyoercoil Composite Spring
- what to wash and wax / polish my new c3 with
- 81 vette mods to be done..
- Can my 2bolt stock block handle 500-530 hp?
- engine swap
- 74 seat belt is fine, but won't retract...
- wiper solenoid question
- Probe pistons...go with them or not
- l48 engine
- What kind of motor oil should I use?
- firewall insulation best way
- Engine Guru's - LT-1 Heads
- hoodpins
- Header Gasket Install
- oil system question
- help with interior restoration
- Mix ATF and PS fluid?
- Converter or carb: engine dies at moderate throttle
- which oil
- Courtsey light grounding issue (I think!)
- ZL-1 engine vs LS 3
- Antifreeze Leak Around Front Intake Manifold Bolt! Help!
- Gauge Question on '73
- Keisler Tranny
- Air cleaner size to fit.
- cam break in
- Would like side exhaust but which to buy?
- Reverse lockout question
- Rag Joint ---> U-Joint
- Open headers for a week
- Very simple qusetion wrench question
- A little More guidance on seat belts..please?
- 79 Corvette Help Please
- Anyone knows the ID of the stock BB manifolds ?
- power window motor help!
- Receiver Drier rebuild procedure
- Serpentine power steering pulley help please
- Is this a factory body seam?
- kickdown switch broke
- Bent half shaft yoke
- radio restoration
- 76 Horn Question
- Rebuild Quadrajet
- Z068 deconstruction complete
- Getting a 2004R
- 1981 air dam install pic's/diagram
- BBC Fits under Small block hood!!! (lots of pics)!!!
- rochester tuning help
- lower alternator bracket
- Locking In Header Studs
- 383 vs 350?
- Vacuum advance or not
- 71 coil wiring
- Rear end recommendations
- Brake Pedal Goes To The Floor.....
- 1969 Shoulder Harness Retractor
- Cruise control doesn't work!!!
- Is the cam gone?
- Steering Problem Please Help
- Tremec & crossmember ??'s
- Borgeson power steering conversion?
- no shop press needed
- My 68 Air Cleaner
- Wheeler Engines
- New AFR 195's and comp cam
- Engine decisions..383?...406?...ZZ454?...NONE of the above!
- Original gas tank??
- big inch small block builder please!!!
- New master cylinder won't pump
- Crazy Big Block questions
- Does it really even matter????
- '69 steering column
- Quadrajet Accelerator pump issue
- New transmission
- LS6 454 Exhaust system
- Engine code 4bolt or 2bolt
- Wiper motor ID help
- Geasing Rear Spindle Bearings
- STS Baffles vs others?
- 68-72 hoods???
- Anti-freeze leak
- Anti-freeze leak
- Hollly jet sizes
- HMSA racing this weekend @ Thunder Hill, CA
- 2.5" dual exhaust 1980.... suggestions?
- Need Recommendations for a Timing Set..
- HEI Wiring: Pink wire optimal?
- 383 stroker
- New Guy - LQ9/4L80 swap help
- Rear Composite Spring Cushion
- 1973 heads appear different?
- Sand blasting frame on
- Tri Power
- Space between wheel and e-brake cable
- Rag Joint Question
- Anyone using one of these oil drain valves?
- 77 L82 cam specs/head specs
- C3 Article on Line
- Rear Defroster connection
- Top End build advice 350
- Willcox Side Pipe Kit - comments?
- Spark Plug Wires
- ballast resistor?
- C5 calipers on stock C3 rotors?
- sparkplug problem
- L48... Power Boost?
- My extreme noob questions.
- 82 Electric Locks
- Issue with speedometer gears 700R4
- headers
- Heavy duty rearend
- 383 oil pan ??
- Head Light Doors
- 73 Horn Button
- alternator wires
- Chicago Alignment shop needed
- Steering Column
- front coil spring height?
- New Transmission
- Vacuum Tank Replacement
- LF South Jersey Cruise Nights
- rear spring
- A/C upgrade
- Th350 vs Th400 power difference
- Fast burn heads and timing
- Motor guys...383-do these parts support the hp/tq numbers?
- '71 ignition switch?
- Vette won't start
- Rear wheel bearing question
- Plug gap
- Push-on fuel fittings are a major PITA!
- 73 suspension parts paint colors
- Steering Coupler Replacement
- 81 corvette L82 EME carb
- What is this little transmission plug???
- 1976 Side yoke replacement
- Vacuum-Related
- 5.3 swap question
- pushing coolant need help
- 77 vette windshield leak
- What do I have???
- new engine for my 79
- Starting/electronics problem
- High rise manifold hood clearence
- RPM maxes at 3200 on highway but 5200 in N
- 540Teardown Part II
- After sand blasting random parts best way to paint?
- BB Harmonic Balancer issues and more......
- Vaccuumless wiper door question
- '69 power steering pump
- Parking brake adjustment
- Swapping Euro light back to Originals - help!
- key in fender
- Can firing order be changed
- Exhaust?
- '73 454 quadrajet or EFI?
- cleaning up alum intake?
- Strange problem with TH400 kickdown
- Engine ID help please.
- Air filter
- Rivets & riveter for A/C box & body
- Bonding an L88 Hood Scoop on a STOCK hood......
- power window rebuild help
- 81 Hooker Headers Fitment
- Rear Monoleaf
- '70 LT-1 w/ PS - Windage Tray or Oil Pan Issue
- small block to big block swap
- 1/2 rebuilt fuel sending unit pic
- c3 tach filter
- t 56 6 speed
- Radiator Support Upper Brackets
- How to align hood with fender?
- Look guys - only two like this in existence!
- seat rebuild......need help
- What have I done? :willy:
- 1974 Heater Box
- C3 LS1 & T-56 Frame Up Project
- Horsepower?
- How to fix the lights in the dash
- 700R4 lock up, Why
- 81 center console removal
- 79 Vett, NEED HELP ASAP!
- Help with 75 dual retractable seat belt placement
- Timing hash marks with no numbers...?degrees
- Brake booster help
- Electrical Problem
- VBP spring mounting bolts too short?
- Power Steering Cylinder/Ram - Re-build??
- no reverse
- Differential Cushion
- 81 CC carb issue?
- Torque spec
- Brake pedal height adjustment?
- Power brake question
- Finally, I ran my car at the strip...
- Cobfree
- Steeroids ?: what is the diff b/w 67-79 kit and 80-82 kit
- Fuel vapor canister
- 81 question/problem
- Exhaust Coating by Electro Tech?
- Flywheel Selection--Aluminum or Steel?
- Question for LM 1 Users
- power steering pump fittings
- c3 power steering box, rebuilt and types??
- Does this Spedo Cable look right?
- C3 to C4 Blower Motor Conversion
- Carb spacer/heat barrier ??
- '69 Horn Alarm Relay
- Starter issue Part 2
- converting 350 side exhaust to 427 help
- header gasket?
- Press Release MTI Racing Machine Shop
- Differential crossmember removal
- Muskegon Brake Superkit?
- Tips for replacing tach cable?
- cam break-in, EOS, BRAD PENN
- BB guys, what is your oil pressure at operating temp?
- Sidepipe sound
- help for l82 hp
- help with wilcox bumpers 75 vette
- Swapped my 200-4R speedo gears today!!
- tranny front seal
- tach fix or aftermarket tach
- Header coating follow up
- 68 trailing arms
- Angle plug header clearance
- 3/4 cam????
- Pertronix new III series conversion kit 71181
- Routing of dash wiring harness and cables
- 3way Vacuum Fitting hits rear of Edelbrock Air Gap Manifold
- unknown wire
- will it fit?
- Fuse Question
- 1977 Stock Starter on SBC 400?
- remove body in sections?
- Air line to tranny
- Carb and linkage pics
- Assembly manual......for engine
- 1968 Weird Electrical Draw
- 81 c3 hvac under dash vac hose diagram
- Swap to ZZ4 or something else
