- Holley carb list #
- Wiggly Rear End
- Installing fixed headlights, what to do with vacuum lines
- Holley 6210 carb and PB connection ...
- 82 spark plugs & wires HELP!!!
- '81 Electric Fan Switch Meltdown
- Quadrajet Vacuum connections
- Tailpipe Hangar pics?
- Carb Sticking on high idle!
- Roll Control Install Assistance
- Broken Rear Main Cap!
- Block #'s: 3970010 / VO426tBC
- What seatbelts and shoulder belts to use with C5 seats?
- Bigblock engine guys: Ring gap recommendations?
- C3 Restoration in Brazil
- Correcting a Speedometer
- ugh...steering problems.....
- What headsto use
- Tires for 68
- source for RH outside mirror w/convex glass?
- Fixed the faulty brakes on my 74 Stingray
- Decal location
- Carburetor recommendation for a ZZ4 on a 72?
- Screw(s) for Fender Louvers???
- 79 L-82 exhaust?
- Thanks for the help. (engine cutting out)
- Bearing Wear
- Bearing Wear
- 68 vette build sheet location
- Summit 1104 to much cam for an L48?
- new suspension question
- Centerforce DF & Hays flywheel combo questions
- Stuck exhaust valve, maybe more. Need help analyzing cylinders
- Need some input from ls1 guys
- Rochester Carburetor Idle Issue
- Length of POSTIVE battery cable?
- Tach stopped working (yes I used the search function first)
- Head id numbers
- kickdown still not working
- wiring gurus i need your help!!!!!!
- where do I stick this thing?
- dash cover?
- hypercoil fiberglass rear spring?
- different sort of hot start problem.
- Sidepipes for a 75 corvette
- Transmission/Differential question
- I am needing molydisulfide base lube?
- Rear main / headers
- L88 hood
- ammeter problem
- What can I use from a 2004 Vette??
- Soft top attachment bolts , what size ?
- Where do I even start on this? Wiper door
- relay rod
- Interior Paint
- L98
- Inner Fender Splash Shield
- Oil Additives
- power steering pumps
- Distributor Wrench...& Timing
- I AM the ultimate bubba (help me)
- Steering & Brake Troubleshooting?
- Distributor Cap Question
- Steering shaft's plastic shear pins
- Z068 Rear Suspension complete photo
- Know of a good brake booster rebuilder?
- 81 CEL Light? Stays on, in the off position
- Removing Trans slip yoke seal
- Rochester Accelerator Hook Up.
- New ignition sys.
- Borgeson Gear Box
- l48 engine rebuild
- Good tremec installation thread?
- Need part number/source for bigblock dowels
- couple questions
- Latest on 0 oil pressure and synthetic oil.
- Any here with real wide rally`s?
- Engine Help. More powa... what next?
- New engine hesitation - Carb Setup?
- Any measurable decrease in water temp by removing the license plate?
- Delco radio/speaker ohms
- Corvette V12?
- Hot Start Problem with '72 350
- Power steering problem.
- vetteman81
- Center gauges - ground??
- 81 Ecm and wire harness
- heater controls vacuum source
- oil leak
- Tie Rod Sleeves
- Standard Motor Inc. Parts
- Telescopic column
- Idle Air Control Valves-82 Vette
- Purchase advice needed please....72 BB
- 78 carb adjusting tool
- Best way to remove engine from 81
- 81 cruise controll electrical testing
- Body Mount Brackets
- Unraveling the Mystery Motor.. 283 Heads?? Question on Valve seals
- Quadrajet Accelerator Pump Volume
- Dash Lights and Gauges
- 1982 Vette -Mass Air Flow Sensor
- That Noise!
- speedo lights
- Getting bumpers chromed
- Intake Manifold Bolt Length? 1974
- screw, part # 343001, what size?
- Best way to drain/add differential fluid
- Sooty Exhaust
- Tuning suspension and ride height insight please, for a novice
- Vented Gas Cap
- More Power Please!!!!!!
- holley street dominator single plane intake
- L-82 heads to replace L-48 heads?
- TH350 Selector Shaft Seal replacement with trans pan removed?
- 81 Cruise control vacume routing
- Firewall Wiring Mystery bundle ??
- What causes PS ram to break?
- Need pics of 69 convertible Rear carpet
- N2O on stock Eng.
- Cleaning rock hard carbon off pulled engine valves. What's the best method?
- Edelbrock
- Voltage on Temp. Gauge Signal Wire?
- c5 chrome thinspoke wheel pics
- Holley 4160 TV & throttle cable setup
- AFR intake, head bolt recommendations??
- Help with steering pump flows, Jim Shea
- Instrument bulbs question
- cam change for 82
- Which header?Dart Pro1,Angle Plug,Steeroiods and Manual
- rear diff bust @ on 4am test drive
- low rev tachometer
- rochester carb float seting.
- Please help Factor 69 side exhaust
- Strickly Corvettes Show
- Cam spec ?
- Transplanting used cam into a different block?
- Steering question
- Jetting a Holley- reading plugs
- Which suspension bolts need to be of a higher grade?
- Horn Problem
- Where's Matt Gruber ?
- Homemade Wheel Cleaner for Polished Aluminum Wheels?
- Remove Inner Wheel Bearing Race
- 81 performance gear ratio
- Just Fitted a MSD Shift Light
- Which HEI Tach Drive Distributor is best?
- Side yoke or bearings?
- steering columm
- Guys, I mentioned this before on my C3 Brake issues
- '71/350: How to Remove Vacuum Canister?
- Another Slip-yoke Question ?
- CF dual friction question
- Catalytic Converter Heat Shield Removal
- Anyone install a Keisler T45 in a 78 -82
- How to by-pass wiper arm vacuum control valve
- P02 wheel cover restoration questions???
- Cabin heat
- 80 model rear spring in/lb rating?
- •► ► TOTALLY FREE DRIVETRAIN INSPECTION - at Corvettes of Westchester - FREE ◄ ◄•
- Help! Will these springs work with new cam and stock L48 heads?
- front-end bolts need welding before alignment???
- wiper switch
- 1982 - Fuel Pump Replacement
- Odd Noise or Is It?
- Advise on a Cam and Head swap 72' 350
- Intaker bolts
- Engine removal today
- Torque Converter
- the engine still wont rev past 4500 RPM!!
- Loud scraping sound from RR Wheel Somewhat long thread
- wiper issues
- Help with seat belt warning light
- Oil pressure drops from 50 to 0 when warm!!!!
- let the work begin.
- How to diagnose hot starting issue?
- Suggestions
- No spark
- Anyone bead blast an alternator?
- 1982-Location of Map Sensor
- Q-jet help
- Oil pump replace
- Temp Guage ?
- Need Help Looking at C3 in Norfolk Virginia
- Power Steering took a dump
- Upgrading my 75 vett
- Vibration, from bad wheel bearing?
- Exhaust gaskets
- vintage air pulley alignment
- Guesstimate needed
- What goes away with header install?
- 74 vette
- carb. rebuild help
- Oil pressure always 40ish?
- 71 LT1 Authenticity
- Slip fit rear bearings teardown and analysis
- vacuum canister leak--repair/replace?
- grease fitting or non grease fitting u-joints.....that is the question
- Chambered exhaust
- Wheel Adapters/Lug Nut Torque Specs.
- 74 corvette
- Oil consumption...
- Vacuum Tank Color?
- differential?
- 491 Camel Hump heads
- Numbers apparantly match, but the dates?
- Completely electrially dead '76 ...fixed, 19 bucks!
- New Rotors Available - Slotted, Dimpled & E-Coated
- Cam question
- Would these Rims fit my '76 ?
- Looking to put vortecs on stock 76
- 1982 starter/selonoid
- 1982 MAP Sensor
- Reputation/ Following
- Birdcage Rust Opinion Needed
- 68 posi rear differential fluids
- 85 with LT1, was this converted?
- Looking for LT-1 oil pump pickup tube
- 80 model coil spring change-out HELP!
- Help me troubleshoot my vacuum system
- Gas Mileage
- tach jumping
- Question about strut rods
- elec.cooling fan ?
- Converting manual to power brakes in a 69
- E Brake Bracket & Cable Relo- ?
- GM Tech 1
- Anyone have 18" Team III's LT III Wheels ?
- Are these tires street legal
- 71 ls-5 radiator shroud questions
- elec. probem
- Rocker Channel Removal
- Under Seat Insulation
- 1980 Rear Main Seal
- Headlights don't go up but do go down on 82
- Holley 650 CFM Four Barrel Street Carburetor
- Which Aluminum Radiator?
- Manifold for a Holley spreadbore
- Mcleod M800 trans
- Horn rebuild kit
- ls5 carb help
- What is this wire for ?
- L88 aftermarket hood for a 69
- Vapor Canister Fuel Leak
- seat belt buzzer 1982
- Pre-ignition/hesitation
- Installing new 383 in my 81
- Do I need valve cover drippers?
- Help with rim problem and lug nuts needed
