- 78 L48 Ignition timing
- Header wrap and stainless steel?
- dash light question on a 78
- Will my trans roll out from under my car?
- Where do I start my 74 tune up?
- Cruise control ROD....
- sticky rings
- Correct Radiator Cap for a 72 Corvette 454 with air?
- C4 Corvette seats in C3 Corvette?
- Which gauges do you have?
- Brake Master Cylinder not functioning
- How do I get rid of the ecm
- Engine guys...I need piece of mind
- slow power windows
- Headers 70 to 76
- new leak found WTF
- Steering Column Repair
- Changing Gear Lube on C3
- C4 ac blower fan on 71 c3
- 1972 Wiper motor wiring
- A/C help
- Single vs Dual Plane Intake?
- Help with moving the vette
- Thanks to Muskegon and Zip!
- Another rear spring issue!
- Clanking Thumping Bumping... All kinds of great noises, & Solutions!
- jacking up rear
- A/C not cold
- to get the wheels off
- Governor Cover Seal TH350
- Balanced Flywheel???
- 78 L48 carb base gasket
- Yes, another manifold question!
- Fuel pump for engine swap.
- Need help with electrical
- Thrown Rod on 383 Stroker
- Speedometer
- gas smell 1982 vette
- L81 flat or dished piston's
- 200r4 install.... need help
- Fuel Pump
- L88 and HEI won't fit together
- 383 stroker with turbo?
- 73 Temp sender wiring
- Clock Needles
- Another Stuck Hood
- Fuel Gauge Resistance range?? Help Quick!
- Fuel Tank
- Muncie problems
- How to Torque Harmonic Balance to 60 lbs?
- Rear Rotor Runout
- chrome bumper alloy wheels
- Water Temp?
- A couple final Rear End questions.
- Some new guy questions
- floating calipers
- Ac cold air
- Does the air filter pan need heat resistant paint?
- front end height
- Test pipe
- Wiper Just Clicks
- Boby mount shims?
- Thoughts on electric water pumps.......
- Rear Spring Cup Depth?
- Adjusting Valves Feedback
- click click click
- Brake proportioning valve leaking
- Aero Kit
- Tight Lug Nuts Wanted
- 350, 383 stroker, 427 or 454 with a th350?
- 12 Volts for Coil
- 355 400hp 79 Vette How much fun?
- Hood cowl venting
- '73 Rear Brake Caliper Question
- how much a/c compressior oil on a 71 bb
- can this be fixed?
- T top assembly
- Steering adjustment question?
- 1965 C-2 KoC raffle
- Clutch Noise and Throwout bearing
- Parking Brakes
- One for the timing experts...
- Undercar Aerodynamics Question!
- No one sells the cable that connect to power antenna ?
- Transmission???
- painless wiring OR- original style harness?
- Header time to install
- zz383 the dreaded intake question
- Cig lighter
- Holley SA 670 new probs
- POA valve removal
- chambered exhaust
- Lower ball joint
- Anyone know how hard it is to run a new antenna cable ?
- Charging the battery
- Engine Builders Advise Needed
- Which compressor?
- RPM's for a 1977 stock 4 speed
- Bee Jay's lightweight Magnaflow Exhaust
- Got a New Fan Clutch from Ecklers...does this sound like it's working?
- DIN stereo install
- 78 rear window trim removal
- Heavy Cast Iron Steering Support
- Any '82 Collectors Edition owners need paperwork?
- Help! Water temp sender dilemma
- Replace C3 seats
- An 80 L-82 story & ??'s
- Help Installing Dual Exhaust
- C3 clock knob question
- Hot rod power tour
- Dynomax VTs
- electric fan conversion 80'
- Courtesy light delay unit
- 77-79/82 seat swap
- What wires are what on gauges
- New rear end...need speedo help
- Posi?
- Oil pressure guage leeking again...
- Help with TH400 Shift Shaft Seal
- Crush sleeve will not fit the pinion (pics)
- Honey I blew up the Horsepower!
- Rear spoiler warping
- Gears -- 3.08 vs 3.70
- Ball,size
- Anyone able to help speedometer cluster
- shift kit
- how do i attach new velcro strips to the door panels
- 1969 L46 Ignition Resistor Wiring Question
- What is this and where does it go?
- Restoring a 72 LT-1
- 73 power lost
- Windshield washer nozzle location
- headers for ls1 in c3
- rebuild or replace PS valve and cylinder
- Rear Storage Compartment Reassembly
- Anyone know how to take 1980 antenna apart
- LS1 Engine Upgrade for 1975 Corvette
- YOU can NOT solve this problem -80 model
- Throttle Switch??
- Turn signal lever relocation to R/H side ?
- SPARE TIRE LIGHT, how does it turn on?
- No.4 body mount -80 model
- Newbie questions on camber / carpet and seat belts
- c3 expansion valve replacement
- Starter engaged when put in gear
- Bleeding brakes...new lesson learned
- Transmission pan leaking! AGAIN!
- Holley Avenger - Choke Pulloff
- HD Rear Diff. cover?
- Auto tranny acting up 700R4
- thinkn about a 5.3 swap
- Burned valve, or just stuck?
- Street Avenger Carb
- 68 shoulder harness
- Installing Air Cleaner Hood Seal...Help
- 68 brake master cylinder
- Rear Shocks on '77
- 69 Corvette Speaker Upgrade
- Big Block Crank Pulley Bolts
- 69 temp control cable
- 1973 New Wiper Motor Smokes: Help!
- Shifter broken
- A Day at the Track
- 72 Blue Cert Label -Weights
- ammeter reads negative @ idle
- 1968 "CE" engine numbers........
- Need your help - Diagnosis of no fuel?
- Shorted out volt gauge... Help!
- comprehensive GM Iron Vortec Parts List
- Heater hose plumbing
- BFG radial TA 255-60-15 simply unavailable.. Anyone use mickey thompson s/t's?
- Any tips on how to swaped out an auto tranny for a 5 speed manual in a C3
- For those of you with BB alternators snapping bolts..
- Rear Spindle Bearings
- Head Porting
- 75 vette T10 or ST10? close or wide?
- Need R4 AC Compressor expert for BB- Pics
- K-motion K-700 springs with Vortecs?
- Power Steering Control Valve Play
- brake line routing question....
- How many have stroker clearanced their block themselves ?
- Q-jet simple request
- new gauges ? 80' vette
- KHE200 radio power supply question (pic)
- Scrape this off or no?
- Will L98 or C4 LT1 Exh manifolds fit with my Z-Bar?
- Rotor runout how to?
- Oil pan gasket/bolts
- Starting problems
- Hooker Side Exhaust Header Questions??
- spark plug wire question
- aluminum engines/motors
- Anyone use the rear defogger wires as radio antenna with any sucess ?
- cruise control brake switch
- spare tire cover refurb
- Engine Part. What is it?? (pic inside)
- Quadra Jet Color?
- Is my diff housing shot? (pics)
- Ah, man. What the hell?
- Electircal woes
- TH350 transmission kickdown adjustment question
- alternator terminal diagram, help?
- Should I Buy an Aftermarket Front Bumper?
- Is all grease created equal?
- CF Member Golf Tournament...Any Interest??
- Help engine swap
- 383 stroker - parts help!!
- 200r4 or 700r4?
- Clutch and freeze plugs on my '72
- Grinding noise when in reverse
- Steering column/turn signal question
- Is this bellhousing 10.5 or 11 inch?
- SBC 2.45 main journal size?
- Mallory Unilite Help...Pulleezzzeee
- New to Forum-1st question about tires!
- Max Front Caster w/Stock A-Arms?
- Factory Exhaust question
- Differential on 1979. Rebuilt by local shop
- 350 block 10066036, is this a high nickel block?
- Stuck clutch fork
- Pitman arm ?
- 72 upper a arms shafts?
- Engine Builders
- side yokes worn?
- Chassis repair !
- Quadrajet?
- different wiper motor shaft sizes?
- Aftermarket Big block corvette power steering pulley may not be what they seem.
- Failed C3 Hood Latch
- Can I switch my 69 dash to a 68?
- Headlight Vacuum Repair Pics
- valve adjustment
- 82 gearing question
- 80 underhood light ???
- Vette Brakes Offset Trailing Arm
- A little confused, need help please !!!
- Never Gonna Make it in Time (Local Drags)
- Engine Build / New Engine : Options - I just cant wait any longer !
- SBC Trick Flow Heads
- Fuel Injection kit under stock hood?
- wiper / headlight vacum
- Rubber Body Mounts on a 69??
- New to the car and I have some issues
- 75 T-tops on a 78?
- Pics of the $1,800 Stingray....
- Adding a PS Pump to BBC
- Headlights no longer light
- Royal Purple Max Gear, Yea/Nea ?
- Throwout Bearing / Pressure Plate Issue
- Problems starting
