- hazard switch
- how important is rotor in trailing arm rebuild
- Start issue...neutral safety? Ignition?
- Stall Converter Question
- 1977 Backfiring constantly...
- Holley Carb - daily Driver recommendation
- Paint prep. for cast vent grates
- remove the thick bonding stuff off console?
- please help with timing issue
- 1980 Driveshaft
- arm rest ?
- Radiator Mounting
- Steering damper- clue me in
- H.D. Bilsteins
- Harbor Freight transmission jack.
- Drag times after tranny swap?
- Speed and RPM
- Will the 420lb monospring be too hard?
- electric corvette project (not mine)
- Opinions on tranny swaps.....
- current capacity for wires in our car
- Early C3 Radiator question, recore? New? Clean?
- best flowing header back exhaust, 69 427
- Roll bar?
- Timing Question
- '73 SB Cooling System Question
- 350 cold air intake?
- 77 Rear Brake Line Question
- Seat Belts
- Door Striker Question
- Guess my compression...
- taking out a/c.
- just one brake (RR) overheating
- It's Raining Parts
- 1968 Passengers side mirror
- 76 4sp, close ratio or wide ratio???
- windshield washer wont stop
- Too Much Oil Question
- 1980 heater core replacement
- where to find a A/C shop
- Summit fuel pump question
- Using original radio plug for aftermarket radio
- Feedback on different front spring rates
- Slight "sputter"
- moving the jetting from a carb to another...Lars,427hotrod...
- T-Top gap ?
- Electrical problem!!!!!
- caliper bleeding
- C5 wheels
- what needs to be changed to make a rubber bumper frame fit a chrome bumper car?
- putting in my horn
- Turn signal short?!?
- Header wrap
- 79 Dipstick specs?
- going drag racing
- Overly Rich Idle (Lars?)
- 1980 Drive Shaft Yoke Identification
- Don't kill me....I did SEARCH but.....Lincoln fan wiring harnesses(prebuilt)?
- Looking for advice on top end engine changes
- broken t handle and still go into reverse?
- Does anybody have pics of rool cage in 69
- Replacing Rad what additional parts
- Newbie Question!
- dash pad tabs?
- Diff Drain Plug Kit from Corvette Central ?
- Valve geometry, valve rotation??
- parking brake help
- Advice on unscrewing stuck tie rods...
- steering wheel removal, turn indicator switch
- Mysterious Wiper Issues
- Trick Flow or Brodix?
- 18" Drag radials
- Restoring seat belts
- Dumb ? of the week, Torque Converter
- Tuneup Messup
- Copper Crush Washers on Front Rubber Brake Hoses
- help with heater box
- Holley Power Valve
- Somebody ask me the question about head flow and HP.
- Roller lifter questions OEM vs Retro
- 76 Stingray getting a 02 motor
- Brown smoke?
- Post Radiator Upgrade - Big Gap
- Figured out my oveheating problem.
- ammeter operation 1968
- Keep my C4 or get a C3
- New Battery
- 1969 fuel filter
- Top End Rebuild
- Searching for Norval's Hub-o-Matic Tool
- Timing light battery cables not long enough
- Pilot bushing clearance spec?
- intake surgery
- 1972 Temp Gauge Help
- How does the actuator rod stay connected to heatriser valve
- For those of you that think they can set the spark plug gap wherever they want
- Muffler shops?
- Instrument panel Gauge question
- BB water pump pulley replacement.
- Corvette Hangout in Opa Locka Florida
- What Am I missing Here? C3 1981
- 8-10 OHM Speakers?
- 1994 SBC 350 engine block questions
- What type of fiberglass is the firewall on my 77?
- Automatic Not Shifting Properly
- 68 frame repair vs value
- Timing Woes
- Front Spindle/Caliper Assembly Question
- Install my own weatherstripping?
- 2004r pressure test
- New parking brake idea!!
- Electric choke
- Need Picture of EGR Valve Vacuum Connection
- ? re Power Brake Booster Check Valve
- Is an XR286R a big cam for street?
- which wire
- question about different types of LTs
- Vintage Air-kits come with compressor?
- Help or tips needed for new center console install
- Pertronix issue or ?
- New rad help
- Motor build
- Still having overheating issues (vortec swap guys help!)
- Made a mistake
- Holley floats
- T-350 question
- hvac vacuum
- Q-Jet over loading
- Want to convert from auto to 4 speed
- Big Block running poor
- New seat tricks? HELP
- Trailing arm installation complete, rear end alignment question
- Optional - FE7 Suspension
- Wheel adapters for C5 Z06 rims
- bumper install help
- Courtesy light switches C3.
- 3 inch exhaust
- wiper door again
- Rally Wheels
- Fan Clutch question..
- Whats this number mean?
- 71 Vacuum Tank
- Bee Jay's Interior
- 1970 with TI Ignition
- Where this green wire should be connected?
- 1975 Front Suspension Questions
- 79 vette heater box
- Now what can it be?????
- Is there a left and right seat?
- Electrical Headlight converison - anyone recognize this kit?
- Att Kiwi's
- Need a Measurment (Floor pans)
- Loose battery
- I swapped from Flowmaster to Magnaflow, Soundfiles included!
- 82 Transmission problem
- What is the weight of a bare BB block?
- My first post
- Lsi water pump.
- Vacuum at Idle
- Which power steering pump with Hydroboost and Steeroids?
- AC Delco Morraine Brakes question...
- Stiff Shifting 4-speed
- Best option for vortec heads
- WOW - I'm back - T5 Tranny ??
- Update on ticking noise! I'm getting closer
- Rust under interior panels?
- 496 build part 2!!
- sticky clutch pedal
- Fluid Leak @ '79 Steering Rack
- What is this and is it in correctly?
- Adjustable Vacuum Advance
- Radiator/shroud Seals.
- Chasis dynoed my car today.....
- Trick to getting the valve springs off?
- Carb help
- hazards not working
- 1972 engine compartment
- Riddle me this
- Peeling the Onion
- Headlights wont pop up: Believe its faulty Switch
- Wheel will not come off !?!
- Rear Shocks - expect to cut off the bolt?
- Headlight Help
- How do you adjust the steering box ?
- u-joint installation in haft shaft question
- Anyone using Mallory E-Fire Dizzy?
- help how do i get the crome windshild molding off on my 71
- Trans cooler lines for the 700R4 conversion
- Help with trouble shooting vacuum system
- 81 Fuse Box Diagram
- Latest Gremlin - Brights flash on/off with turn signal
- Pulling right getting worse
- Front calipers leaking
- TH400 no movement - initial thoughts
- choke
- wiring gas tank sending unit
- Ignition Module
- Taking away belts to increase performance?
- Battery Cable
- 77 Corvette - New Rotors will not go on Help
- windshield wipers won't stop, only one speed
- Seat Belt Warning Button: Retainer?
- how to do brake's cooling ducts?any pics?
- wiper door.
- Header Install Tips??
- Spark plugs C-3 Choices
- Help identify wire - Green/Black next to Compressor
- Need some help with new wheel choices
- Electronic Ignition vs Distributor
- Interior fan, i can hear it, barely feel it
- changing rear end fluid
- 77 Corvette Parking Brake Assembly - Upper and Lower Springs
- Ram Horn Manifolds vs. Headers
- Edelbrock Carb and no choke???
- Uh oh, starter connection problem
- 1971 Windshield Shading
- Help with 68 fan shroud bracket
- BB Oval port intake for L88 hood and air box
- Pre-Ignition condition
- Alternator position question.
- Need to change Power Steering Valve
- Wheel Lugs
- Ticking noise that won't go away, any input?
- 82 wiring issue
- Son of a...what the he!! is wrong with these brakes!!
- Small hole in radiator, how to repair?
- Power steering pulley came loose
- Forum search fixes signals blown fuses
- side pipes question
- Gymkana suspension vs Rally sport package
- Headers - Flowtech or Hedman ??
- TH400 Low Gear Planetary Set
- Altinator Issue
- water temp guage quit working
- Looking for someone local to help recharge AC
- 1977 Brake Caliper Tools?
- 1971 LT1 Hydraulic Cam
- grille installation on a '76
- A/C ?s
- Willcox Summer Sale Starts Today!
- I did something stupid..need the trick
- Thermostat or NO Thermostat?
- New Engine Questions
- CAI Cold Air Intake done...
- Parking light bulb replacement.
- looking for specs of different stock motors
