- Diff Rebuild in Texas
- Oil Leak
- Control Arm/A Arm bushing replacement questions
- Happy holidays from vbp!
- Edelbrock 2701 Clearence question 1969 Corvette
- Please help me verify 22" wheel fitment on my 81.(BeeJays Specs)
- jumpy bouncy speedo problem
- 1980 bad running
- 73 big block manifold //
- Holley 4175 Tuning
- corvette shop in central ohio
- Transmission problem TH350
- Summit headers and angle plug heads.
- Polishing decals?
- Drive Shaft Concern
- 69 bulk harness plug behind fuse panel?
- 78 Back up lights
- Gas Cap for 74?
- vapor canister location
- Need advice on brake job
- Is 79 L82 flywheel dual mounting pattern?
- 73 Smoking
- Hp Increase w/Mufflers only?
- Weatherstripping problem
- Starter Connections
- Camshaft Swap for 454's
- FAST EZ EFI el. power
- World products beware
- Another Knock Question
- What is direct timing?
- Misc Questions
- Heater Core Fix
- 350 cam / set up questions
- Winter project: Suspension and brakes
- Gas Tank "Tee" fitting help.
- Installing LT1 into my C3
- Tech Article website
- Drilled & Slotted Rotors....how do you turn them?
- 7 year old calipers, what too do???
- Stutter under normal load only when cold... help?
- 2 inlets for my fuel pump???
- 69 QJet
- 1974 Rad support bushings
- 700R4 from an 88, got an overdrive question
- Can anyone help identifty these Hookers ?
- 79 vette 383 seems slow
- seat frame to floor bolt pattern measurements
- Ignition Problem - Help!
- Installing air pump assembly on a 1979 L82
- 1972 350/200hp w/AT Carb Hose Routing?
- 82 Fuel Pump Wiring
- Valve Covers
- P215/70 or P225/70 redlines?
- installing door glass 69 roadster
- My Heads dont Match
- Need Help Please. QJet Surges on WOT.
- close call with brakes
- leaking coolant
- Gauges stopped working :(
- OOPs
- 81 Instrument Cluster lights
- Anyone install a factory remote keyless entry into a C3?
- Only one point sparking on Mallory Dual Point
- 74 vette oil pan & gasket issue
- HEI Distributor Part Question
- 81 straight tailpipes...any underneath pics?
- engine and ehaust fit
- What casting number should be on power steering pump?
- Flasher/Electrical Problems
- Power Steering Rebuild HELP
- Winter project
- Clutch Kit
- Are You Interested in a "Worthy" Header Bracket
- Dual Clutch - 7 speed
- Door lock problem
- Headlight Door Warning Light
- HEI Distributor Replacement
- Need some help with the final fit of these side pipes
- Trailing arm/Spindle
- Broke Electric Choke wire clip in an 80 - please help
- 1981 rear drum /rotor removal...no rivets?
- Turbo Hood with different intake
- Best Ignition + source for electric fan and choke.
- VBP smart strut problems...
- Vibration from 60 to 70 mph
- Best way to clean Block / Pistons
- Just installed double pumper
- Transmission Fluid
- fuel pump
- Stock air cleaner interferes with Holley fuel line?
- Richmond Gear & Trans Shutdown?
- 1978 Exhaust
- Coil Spring Question
- which holley carb will fit?
- sun visor snapped
- Which Clutch Kit for a 383??
- Suspension bushing question
- What LT Headers fit my C3 with Vortec heads?
- new member
- Shades of Red
- 700r4 trans. owners
- Brake Master Cylinder went south....
- VIN plate rivits for 1980 C3
- 81 Build
- L98 heads
- Gas Tank Rubber Lines
- Got a rocker problem..
- Heater core
- Suspension question
- 7040205 carb
- 82CE replacement A/C compressor
- request from Germany : tele steering column
- Door scoffing the top of the side pipe
- Air Cleaner Question
- Advance timing tools
- Want 5 speed hp trany
- Interior windshield post trim removal
- 1978 windshield wiper wiring question
- Aftermarket wiring
- 1978 SAE Steering???
- hard shift from TH400
- What drop base air cleaner should I use?
- Steering Box Removal?
- new Dart SHP 200 designed for larger fp 1205
- BG Speed demon 650 + spread bore ported vacuum fix!
- ticking noise in tranny
- rear rotor / E-brake stuck
- Holley carbs experts, please chime in -->
- Rec's for c3 mechanic in eugene oregon
- Would leaving the hatch open extend the life of the supports?
- In what order do you bleed the brakes with vacuum?
- Big Block Pulleys
- Parking Brake Console Quality
- Small Block Block Dimensions
- Smog in San Diego
- Small gaugesprinted circuit connectors/terminal block
- Its the journey not the destination
- broken key in ignition cylinder
- steering column interlock lever?
- Anyone recommend a good shop if I decide to send my steering column out for rebuild?
- Setting the idle speed the correct way in a Holley carb.
- Oil Pump
- Jeep steering box & GMC Hydroboost fitting sizes?
- magnaflow mufflers?
- Radiator removel and install
- Engine questions...help please :0)
- I installed solid motor mounts
- Brakes pulling to the left solved!
- Valve spring removal
- Fitment question. 15" oval air cleaner
- Holley tuning/ lean spot off idle slow take off.
- Seeking pics of frame reinforcing
- 1974 Door lock system issue
- Trailing Arm Rebuilding Road Trip to CT.
- What am i missing on these motor mount?
- '71 LR Caliper not releasing?
- Edelbrock Intake
- Hayden thermal fan clutch part number confusion
- How do I know it's an LT-1?
- master cylinder rebuild
- A couple of questions for Restoration Experts
- Radiator Support
- Convertible top stowage?
- Arcing at the plug boots
- 81 Corvette Engine Build
- m21 REBUILD KIT
- Question about where to get parts for a '78 HEI Distributor
- T56 bolted to a 70's LT-1?
- a/c vacum
- jack stands on half shafts 1971
- Two questions about timing and plugs. 71 BB [pics]
- #5 & #8 Spark plug
- Swaybar & shock install question
- Power Steering Valve
- 1980 heater vacumm issues
- I think they will fit?
- Rear caliper won't fit after wheel bearings replaced!
- ac question
- belt routing
- 3" single Magnaflow muffler
- QJet mods needed for ZZ4 motor
- 76 C3 - looking for a 'better than stock' front/rear (matched) sway bar set
- Speaking of guage oil line....
- Oil leak at gauge
- *****10th Annual CF Fundraiser for St. Jude in honor of Evan Thomason****
- head light actuators.......
- The To-Do list is going the wrong way
- 81 rear end
- Dash Wiring 12 volts not right
- C3 Corvette heating up?
- Alignment question
- Is there a difference in length of HD side-shafts and regular?
- Back after an 8 year hiatus........
- Question about side pipes
- 81 engine
- Accelerating Problem
- Rear Wheel Noise - worsens as car is driven
- push loc hose
- Really dumb question, but I need help!
- Voltmeter on 77?
- Can't get the strut rod outer ends into the bearing support.
- Any one see this, driveshaft dyno
- Headlight actuator shaft seal or diaphragm?
- Alternator 1100884 fan
- Rotor Runout check?
- Thoughts on this Alternator Relocator
- Cross fire injection manifold
- Help...76 corvette tach issues
- Right spark plug gap made a big difference
- Power Brake Booster Vacuum Filter
- ***SHOCKS: Bilstein vs QA1 vs ???***
- Ignition Key Problems, calling on Jim Shea
- 1968 convertible top pad-straps?
- Engine Backfire
- S.S. Sleaved Brakes
- '81 wiring / plugs behind passenger seat storage
- Neutral Safety Switch?
- What is this? Something vacuum?
- Wheel and tire size
- Exhaust Manifold heat riser/port iron headers
- connecting battery tender?
- Seat back bumper location HELP
- 1976 Corvette potential trade, what to look for?
- Engine shop
- Just installed headers on y 69, whats left to do?
- Plastic Distributor Shield Attachment
- How hard do I have to beat this thing?
- Will Not Start
- Air Compressor Main Hose for a 69 - 350
- Accelerator Cable Question??????
- wont start/ wiring help
- wanted Base map for L83 Crossfire
- Add RH rear mirror
- 1977 350
- 1977 Corvette Dash Lighting
- Too much play in transmission yoke?
- Door misalignment solution
- more power from my 79?
- Edelbrock Carb (what to do first)
- Cam and Roller Rockers
- Help with 77 AC brackets
- 1980 oil pan shape
- Swapping to a 4L60 - Shift Kit & any upgrades needed?
- Are these clutch fork studs intercahangable or not!!??
- Ford guy needs advice
- 1968 seats explained
- Gas Sender..What Size Screws???
- 1980 rear suspension confusion
- Valve cover trimming methods
