- Starter Issues Solved
- 81 Sway bar
- How did or do you solve the the dreaded hot start problem on the 454 Corvettes?
- Rear main seal time
- c3 6 speed shift pattern plate
- Possible 1970 Lt-1 corvette
- Thoughts on the 1050cfm Quickfuel carb?
- 1982 R134 fitting problem
- removing bottom radiator on a 5.3lt motor
- Pitman arm hole size
- What is this??
- Trying to be a good neighbor
- Tach issues
- Vacuum Advance
- 76 with exhaust harmonics (I think?)
- Temp Gauge
- 69-Non A/C problems
- 5 blade vs 7 blade mechanical fan
- 81 Vacuum Storage Tank help
- 1975 Restoration Complete (Pics)
- Door handles suck!!!
- 81 EGR tube routing
- 1971 Corvette Wiring Diagram
- Looking for shop or person in st. louis
- tail lights, dash light and parklights not working.
- Engine surging at WOT when hot....
- Headlight washers working?
- 1984 oxygen sensor
- Head Lamps ?
- A/C info help
- QJet Idle Mixture Screws
- Overflow Tank Water Level
- Door does not open, help???
- Anyone running a GenV or GenVI BB? Oil filter question.
- Bonding fiberglass to metal bracket. Which GLUE ?
- Stock 1969 (#186) heads and roller cam
- Rear Side Yolk Repair ?
- Brake pad trick
- Top end kit
- sort of an LT1 question
- Help removing doors?
- steering/shimmy 1980 coup/ new owner, 3 mos.
- May be a silly question but ??
- How do I install window regulator springs?
- 79 L-82 read end shudder/noise
- Need some info about an old engine
- 1969 L46 Spark Plugs
- What is this box?
- Problem with mark 8 fan!!!
- What temp should a 383 Stroker run at? I idle at 220
- Heater hose routing
- Its time for a new alternator
- 270 cfm vortec heads. How much to ask for them?
- 71 T&T Steering Column Parts & Repair.
- On to the Tie Rods ??
- temps higher with T tops off ?????
- steering play on 80
- which distributer
- Electric Fan Users. Quick Question.
- rear window storage tray pivot bushing
- 1978 Climate Controls
- Brake lights are out- 1982
- "69 wiper motor - Willcox ? "
- replaced the brake hoses and M/C and the brake light is on??
- 1974 Frame Replacement w/ 1975 Frame
- Alloy Wheels Can Be Repaired
- need help on engine choice!
- Finally into the 12's
- Steering control valve
- Coil for CD ignition
- Msd
- Circuit breaker in the starter cuircuit???
- AutoX pictures from Saturday
- Fuel vapor smell
- performance questions about 1980 l82
- best tires for street and racing???
- VBP perf-plus set up question.
- Need Pre-Rebuild Advice
- Where does support rod attach?
- In need of a few mentors
- cracked exhaust manifolds 0n 78 L82
- Headlights stuck up?
- Front wheel bearing torgue?
- 78 L82 Engine Compartment-What is this component?
- TH400 to 200R4 Conv. In Massachusetts
- 1982 Sending Unit- Which Wires Where?
- Inside Lock Adjustment Question - Knob rubbing?
- Oil leaking driving me crazy. Any ideas?
- Let the good times begin. Engine Rebuild
- Intermittent cold from A/C
- what is the correct 2 groove crank pulley for sb 74
- So I put in a new ignition module
- Exhaust tone
- Making a jumper for a bad courtesy light timer in a 78
- Power steering for 75 motor in 74 car.
- What is this leaking?
- 74 all lights flashing?
- 72 Vette: Front Turn/Driving Light Tech
- MT Drags Radials ok on public roads?
- 69 BB Valve Cover Question
- New 383 installed in 72 Vette
- Proportioning valve..
- Alternate Coolong Fan Probs - Have I missed anything?
- Motor Swap - Gauges Problem
- 69 gas tank, 1/2 full..no fuel coming out ??
- Advice needed after rebuild
- Big Block Will Not start
- Bee Jay's RPM Air Gap Mod
- Anyone near Topeka Ks need help with crossfire
- full front suspension kits
- steering column shaft too short
- seat belt conversion and install
- Wiper Door Confused
- Floor Pans
- How do you test a coil
- Electrical Issues
- Paging Lars and other carb experts, Holley 4779 base tune for a 406
- Dart Iron Eagle 180 heads
- Need photos of a Rochester carburetor 7042217 numbers (Not Carter)
- Power to manual steering
- ANTI-THEFT and INDICATORS
- Horn Contact
- blinker and brake light ?
- 1st time at strip--need advise--traction
- Disspell some mysteries of tires
- Test Pipe?
- Differential Identification
- Cruise Control
- New harness missing wire?
- Wheel & Tire Questions
- Tips on putting body back on chassis of 68?
- Rotor Runout/New Rotors
- Ignition Lock & Cylinder Changeout.
- How to Adjust '71 Wiper Door Actuator Rod?
- HEI voltage question.....
- 82 collector crossfire issue w/ fuel pump
- Where to find 12v under hood?
- How universal is a 1968, 1969 front clip
- Front Brake Caliper Removal
- PCV valve is it needed?
- Leather Cover and Carpet
- 77 Body Mount Shimming
- 1972 C3 Engine / Emissions Vacuum Diagram
- 1969: Voltage drop when headlights are turned on
- Any one used champion cooling radiators
- Rear End Vibration Help
- Does anybody want to go to the SEMA show?
- 750 CFM on a 454?
- Alternator Noise/Question
- Help with bushing????
- Replaced my Windshield header and corners
- How Do You Replace A Freeze Out Plug?
- 81 vette starter wiring
- EGR Elimination
- How DO I CLEAN A LINED GAS TANK FROM MY 1981
- 82 Crossfire- Lean?
- Brake Calipers
- 83 A/C Compressor Help Needed
- Any opinions on Stahl Side headers
- 350 engine rebuild help with vortec heads...
- 1969 Vacuum Tank
- Stock tire pressures?
- Ring and Pinion
- AC compressor oil???
- 1981 Corvette L82 or L48 motor
- lets see those badass corvettes out there
- leather Cleaner - Who has the best?
- Anyone have a tachometer to read the AC blower motor RPM?
- Is this a LT1 engine? I have the engine block #
- McLeod RST Twin Clutch Kit: Oustanding Performance and Quality
- ’73 M-20 Muncie wiring question
- Differential help
- Need some help hooking up heater control.
- LT-1 Cam specs
- Sun Visors for my 77 Vette
- How Do You Replace Signal/Wash/Bright Arm
- Will ZIP #SU-130 3" half shafts fit on a 69?
- 1969 BB fan shroud
- Belt order
- racing rear suspension
- MSD Distributor and Tachometer
- vacuum control hoses for 69
- 1969 temperature control cable
- Lars can you help ??
- cam install
- Restomod Planning
- coil resistor wire
- Front End Alignment
- {Pics requested} Stock 70-73 exhaust from differ. to exhaust tips
- Exhaust pipe diameter question- OD or ID
- fuel gauge question
- Short Block Assembly ?
- Lt 1
- 73 Remove Heater Core From Engine Compartment
- Starter Problem(?)
- amp meter
- Vacuum problems
- Ammeter going nuts
- Dimensions of front clip
- Engine Suggestion Help
- 2.5" Rams Horn + alternator
- Engine is out but I want to see my headlights???
- 3rd gear muncie problems
- C3 only rolls when clutch is in, cant move otherwise???
- engine rebuild
- valve cover breathers leaking
- Distributor set up
- Help! C3 Seat Runner Disassembly
- 1500 rpm fast idle!!
- th400 transmission filter
- Clutch Diameter
- My head is about to explode
- Finally got my Ls1 swap on the road
- Deleted
- quadrajet base plate
- Tach drive on distr.
- Temperature Gauge Reading
- Oil Pressure Issue
- 1971 Carburetor Inlet Nut
- carb help
- Big Block Ignition Shield differences
- How to Fix - Dash Plastic?
- help with 700 shift schedule
- steering tightness
- Anyone run catalytic converters on true duals?
- True Dual Exhaust Size - 2 1/2" or 3"
- Fisher Body Service Manual
- electrical issue i can't figure out HELP!!!
- Stock hood with a carbed LS
- Fuel Pump Part Number
- Program for figuring out gear ratios
- What type of ECM do I have
- Big Block heater hose/connections-help (Pics)
- Intake Manifold Recommendations
- distributor
- Hood Pins Anyone?
- Small block without the power steering holes drilled ?
- tips for Power Steering Conversion
- Updating the steering system next...Need your opinions
- water temp too high?
- Anyone have a factory Radio w/CB installed? Looking for advice.
- TH350 Strange Dipstick Leak
- Heater/AC Fan
- Actron Tach/Dwell meter only goes to 2000 rpm
- Auto-X preparation
- New cam and oil change
- 74 vette
- 82 X Fire injectors
- 1980 L82 not running good at idle and off idle
- Intake Manifold twin turbo hood.
