- Question about Bolts for Water Pump for BB's from 68-74 with A/C
- Tri power jet size question
- temp. sending unit
- 70 Big Block Running Warm
- Brake Help!!
- Big Block Exhaust Manifold/Header Recommendations
- AC 134A Conversion
- switching to electric oil gauge on a '72
- T-Top Chrome Trim Removal
- instrument cluster, clock
- Upper Rad hose replacement
- Help with BB cam install
- 2 piece rotors for C3's
- Throw Out Bearing going bad?
- heater control lamp
- Help - Edelbrock- messed with the Idle Mixture screws
- under car heat shields
- upshifting problem th400
- Car wants to die when i put it in gear
- Backfire!!!
- Parking Brake Actuating Lever
- Question about after market parts for a TH350
- 1969 Wiper door issue
- SB/BB swap/ automatic trans issues
- Seat Belt Problem
- 75 leaning to 1 side
- Big block idler pulley
- 1969 Convertible Windshield Washer Problems
- Bubba Once Owned My Corvette
- The C3 market
- ZF6 Install
- 2004R 4th gear problem please help
- [suddenly bad idle] Should an HEI cap arc with a wire disconnected?
- Cold startup issue
- Tach drive question
- Need help no spark
- 1979 vent ?
- OMG :( Engine got loud and vibrates car
- 1979 vent ?
- ATF fluid pushing up out of dipstick tube?
- Basic M/C Questions before installing.
- Cam Identification
- 1975 dash wiring question
- Cam lession #101
- Engine miss
- 77 T-Top center bar water leak
- Fuse Panel
- What happened to my engine???
- 1981 electric fan replacement
- Cutting a hole from passenger into rear jack compartment?
- What HEI for my 1981 vette???
- cluster around gear shifter
- little oil leak
- August Steeroids sale
- Rear Camber Adjustable Strut Rod Question.......
- lift VS duration
- Just repaired AC/Vent/Defrost Switch but no heat?
- Comp Cams CL12-242 and stall?
- L81 main dash wiring harness
- Head, and Head Bolt Installation Problem
- Steering Gear Box Adjustment
- Turn Signal/Hazard Switch and Lights Questions
- Ignitor III point-set replacement?
- Seat Mods on a 1968
- Fan hitting shroud.....WHY?
- 74 Upper and Lower Dash removal help
- Rear Sway Bar Install
- drained battery
- Astro Vent Ball Installation.
- Differential Fluid Change
- anybody in the upstate new york area
- 75 outside door handles not working
- 81 plugs and wires
- Seat swap 80s to a 72 HELP
- Best new transmission for my needs?
- Loose Steering Column
- SEM interior paint closest to Medium Red
- 76 steering colomb coupler
- Plug Wire Routing - Pics?
- A noise from the rear end
- Does Ported Vacuum Work on an Early C3?
- Anyone have experience with a Ram 471 clutch ?
- Rochester linkage questoin
- ceramic coated headers
- when swapping aturbo 350 for a 700 r4
- can i run open headers
- Vacuum Reservoir. Another headlight question
- Dash Removal 81
- C3 Dual Electric fan with A/C - how to control
- Running Dual fans
- How to choose the proper centrifugal advance curve for my engine?
- Rochester Choke help
- Pitman arm help
- power antenna connection
- Spicer U-joints
- T-top striker plate/ roof locating wedge Q's
- Holley Vent Question
- carbs on a b&m 250 blower
- 5 speed Manual who's is best?
- need help with my 350 to a 700r4 swap
- Coil failure symptoms?
- High RPM's on the highway
- NEED HELP Kinda fast 427 BB
- Block Question?
- Tuner in Northern VA?
- Need Mechanical Insight 02 Impala
- How to disconnect and Realign Rag Joint?
- How do you take out the light switch assy?
- C3 seats to C6 seats installtion??
- 700 r4 swap
- 1978 400sbc engine swap????
- Looking for info on casting numbers on exhaust manifolds
- How do you replace the plastic collar on the steering column?
- Moisture in battery box creating bad connections to terminals ?
- Finally back from destruction - 964 rwhp!
- Need a Good Shop in San Antonio
- 1981 corvette radiator removal
- L83 carborated
- Low pick up after 50mph
- 72 chrome T strip and weatherstrip Q's
- Edlebrock carb - car stalls
- OBX Sidemount Header Experiences?
- Advice in choosing cam needed!
- Here is some good info on how to rebuild your iron rearend
- How Much $ to Have Rear Wheel Bearings Done on my '71?
- starting the rebuild...383 on its way
- how to replace door hinge spring?
- which cam
- holley carb id
- hood clearance??
- HELP - TBI not squirting fuel
- Help ID'ing my '81?
- Brake caliper lasted 2 days...aaahhhhh
- Carb gurus, a little advice
- something in the rear end is clunking when i down shift.
- mach 1 performance who has it?
- Shifting Gears 101
- Intake oil leak also be vacuum leak??
- Placing a fuel pump
- 1982 Corvette Engine Problem...
- Tuning Issue Need input and opinions
- Wiper motor stops and starts up again
- 78 front bumper question
- CS144 to replace one wire alternator
- 1979 corvette ignition lock cylinder question
- Anyone have a good '79 engine bay picture?
- water pump gallons
- Spinning window crank
- Trailing Arms - Need advice
- Is the MSD 6AL needed?
- Can anyone give me a measurment?
- '69 Auto X video
- Build your own paint booth- cheap!
- how massive were ...
- HOT fuse in battery box on '82
- 1977 Exhaust Questions
- been driving around on E85 for the past week
- How to Remove '71 Wiper Safety Switch?
- i need help with paint prep!!!!!!
- 1968 Overheating Problem Troubleshooting
- 1980 Horn contact question
- Metal Fan on CS144?
- tachometer '79 vette
- Heads for a zero decked block
- clutch fork clearance to back of bellhousing
- New problem!, blow a fuse when trying to start car
- Serpentine belt installs anyone?
- Lazy eye
- 78 Speedometer Inop
- Finally got my Code 42 fixed
- hydraulic or soilds in 78 L82...
- Tachometer rebuild / test..who does it?
- Tach rebuild & test
- Dewitts twin fans drop my idle 300 rpms!
- Power Steering Cylinder leaking
- Fuel Problem Again, at wits end, HELP!!
- so I broke my 200r4...
- "Seals-it" seals and hiem (rear) Strut rods
- New Owner....Interior, Wheel, A/C Re-do
- how different are 68-69 camaro's vs c3 corvette's brakes
- 72 TCS solenoid mounting question
- Clutch Recomendations
- '74 Corvette Rear End Tear Down (PICS)
- hot air true vents
- Electric Meziere WP over Edelbrock
- Battery box damage
- any opinions on this tire..street avenger gt
- Front caliper wows
- Quality of interior repros
- Front Shock Recommendation for Stock 73 BB
- Holley EFI+555"=Fuel Mileage Testing!
- Does Anyone Have Clips/Videos of Stock C3 Mufflers?
- Front end engineering question
- Brake fluid in a c3 corvette
- Adjustable strut rods or standard: street car???
- speedometer reads too high
- new Rear spindles, are these with in spec or are these junk?
- Need help with front fenders
- Another Wiper Question
- AFRs and center bolt valve covers
- 1982 ac compressor - always on?
- Who makes ?
- Dash speaker hole spacing
- Temperature sending unit.
- Engine hoist
- Brake Clunk
- 1981 emission equipment/computer removal
- TH350 fluid leak question
- Wierd ignition thing
- Differential pattern question (pic)
- Replacing 13 year old tires - What do you think of Toyo R888 235/50/15's?
- Water in gas tank
- Trying to set my total timing
- Ignition resistor block
- How do I remove the steering column?
- 74 rear brake lock up??
- Big Block Fan Shroud
- 1982 Corvette shifts to early
- Help with engine identification, 76 305?
- Overheating sbc radiator seals fixed
- Mystery small block heads
- How Much $ to Rebuild a '71 Small Block 350?
- no responses
- ticking noise in 78 L82
- 1970 lower drivers side dash pad
- Do I need 3 belts on my 76?
- Hydraulic lifter bleed out
- Help with rebuilding th400.
- 71 Power Window Help
- Borg Warner T-10
- Fuel line leaking between fuel pump and carb.Need some help
- Heat/AC/Vent/Defrost Control Vacuum Help Needed
- HELP STILL RUNNNIG ROUGH and some times lack of power
- Power Steering Hose Leaking
- Seat Foams, Replacement Ideas
- Oil guage tubing size
- one problem fixed...now a new one (rear end)
- Power to fuse box?
- Help with Brake light PLEASE!
- 79 power steering pump removal
- Whats the trick?
- Installed New Blower Resistor Still Don't Have Lower Blower Speeds???
- Installed Resistor Stil only High Blower Speed/??
- C3 GM front end part numbers
- Tachomter quit on the way to the cruise-in
- Who here has built a Turbo or Twin Turbo motor for their C3?
- New Motor Won't Crank!!!!!! HELP!!!!!
- BW ST10 synchro question
- best top end mods for gain
- Ground rules needed
