- Can't remove rear shock mount.
- Top Dead Center and Ditributor install help!:willy:
- hooker headers
- Harmonic blancer
- Bushing failure after 6 months WTF?
- How much play is too much in the pitman arm?
- '72 ballast resistor, resitance wire or both?
- ****!!! Just Found Out I Need a Rebuild - Experienced Suggestions Needed (newbie)
- boiling power steering
- Restoration shops?
- fenders flares mid américa or ACI!!!!!!
- Should I swap the intake mainfold?
- distributor
- 1979 C3 heater control vac hose question
- Why is Ecklers HEI tach drive $100 bucks cheaper than Summits???
- Air pulley removal
- Wilcox - 68-77 Headlamp Switch Compare ?
- ? about eckler
- new carb purchase
- Rebuild 327
- 71 Cowl Vent Screen Missing or Didn't Exist
- Thoughts on Extrude Honing an Edelbrock Performer Intake?
- New Viagra TV Car Commercial
- Vibration when pulling out
- C3 Fuel Pump
- well it happened!
- HELP: Need help tracking down vibration
- manual steering box fitment
- Problems when cranking
- DIY Seatback cusion installation Tool w/pictures
- New Wilwood D8 Calipers
- Vacuum connections -17056202 Rochester -76 Vette
- Power Locks in 78 will not work?
- Temperature Gauge Success
- Stainless steel double flare leaks fuel?
- puling sbc out. with or without transmission?
- C3 Power window
- Any recommendations for intak mainfold gasket?
- First attempt joy ride & torque ripped the wheel off I guess
- 1973 corvette not downshifting
- Replacing window regulator rollers
- Steering Box Rebuild Seminar at Carlisle
- Carb rebuild then distributor or vise versa?
- 71 starter wiring- easy question?
- 78 AC belt size???
- Has anybody installed this radio?
- Help with Edelbrock heads
- Should I be worried?
- Stock interior clock compatibility
- Gears in the rear
- Expecting the Worst - cracked block?
- Dyno Tuning where you live?
- Good read in Hot Rod
- thanks
- Missing Aux Fan - How badly do I need it
- cal car killing me
- Another pitman arm question
- '71 LT-1 Distributor position question
- Just noticed my engine has only one engine lift ring...
- New exhaust done .
- Big block rebuild
- Fuel Pump rubber hose routing help (pic)
- starter switch
- 4spd conversion
- Rear Differential Fluid
- Speed Demon carb - I encountered a potential death trap issue
- 69 clock cleaning, adjusting time, bulbs ??
- Interior resto in progress...
- I guess I'm changing manifolds sooner than expected...
- Installing a new master cylinder...Pointers?
- Strut rod support bracket?
- Greasing inner rear wheel bearings
- 1978 Alarm relay draining battery
- Any experiences with McJacks C3 shorty headers???
- How to refinish rear leaf spring.
- How do I install Rear Sway Bar End Link Grommets
- any tricks??
- 78 C3 intake Vacuum switch, how to eliminate?
- New Cam and Overheating Now......
- Wichita Kansas Black Top Nationals
- Brakes get spongy over ~5 days
- how tight trailing arm bolt
- LS1 & T56... websites to check?
- Floorpan seams
- Torque Converter Lock-up manual switch question
- What Shocks Would You Recommend For My 1979 - 90% Street / 10% Road Course Use
- 500 mile oil change
- Torn droplink mount?
- 700R4 tv connection
- Help with Q Jet choke
- Need Brake Help
- Taillight rebuild
- C5 seats in your C3
- Has Anyone Tried Stop Leak In The AC ???
- 69E or 69L How Do I Tell?
- went to easy lube and 24 hours later my engine blew up...
- 69 clock, cleaned
- 400sbc swap questions
- T-Top seals
- High-Flow Air intake systems
- BB Hooker Headers,..close to floorboard
- Super 10 Bolt IRS build up......
- control arm reinstall problem
- front tires...
- Headers for angle plug heads
- hooker side pipes
- Starter shorting?
- exhaust change
- HEADS vs. COMP RATIO
- fuel pump?
- ZZ4 Crate Motor and Keisler 5 Speed Questions
- Service Ramps
- Anybody heard of 'Iron Eagle' heads???
- Door jamb courtesy switch
- Starter solenoid - remote switch
- poly vs hard mounts
- Plug wire replacement on 74' C3...
- 80 Speedometer change
- fuel mileage
- Looking for advice on interior sealer to apply before installing carpet... in
- great but end very very sad
- 81speedo
- Lt4 hot cam valve train noise
- How To Install Astro-Ventilation Door Seal Kit
- All sorts of wheel related questions - 1972
- Those running Lincoln MK8 fans.....what is your temps?
- Edelbrock 60739 Performer RPM runner size?
- Cooling Questions
- 75 3 Speed Tranny Adjustments
- Under Dash Electrical Question
- Fuel Filter Assembly leaks - Replacement?
- A/C hose insulation
- Fuel Line problem, need pics and help!
- Radio Have AM NO FM ??
- Fixing/updating the distributor, parts needed?
- Drag radials, what is gonna break?
- 78 Corvette No Power to AC Clutch
- 1969 Overflow Tank 300hp Only?
- Idol issue
- 1971 CEC Solenoid Wiring
- Cam Help!!!
- C3 Power Steering Conversion Tips please!
- Spark plug heat range issue
- Need plastic housing for brake stop light connector
- 74 big block drivetrain
- Sticking Brake Calipers
- Critique my engine build
- Quadra-bog?
- flex hose on rear caliper,not trailing arm
- Flood
- 79 rear wheel bearing procedure
- Schiefer Revloc clutch
- 1975 Driver Door handle
- Cabin Heat Reduced...somewhat..
- Carpet
- Nitrous & Line Lock Buttons?
- tank leaking at driver side
- Let's see your under car exhaust
- Stumped by timing issue
- green fluid in brake resevoir
- I don't get it, front alignment
- What fer Carbs
- No Fuel!!!!!
- Power Window Rolls Up Very Slow and Stops Halfway
- New Guy
- U Joint options for street use 1350 series
- Carburetor
- Headlights work, high beams do not
- Upper & lower A-arm bushing washer & bolt torque specs
- Brakes
- ls1/trans swap...
- a/c heater control panel
- remote brake servo
- 71 Coil Resister
- 427 SBC: Good Deal?
- needind help with C6 seats into my C3
- Speedo Cable,..One or Two Piece? (1973)
- 72 windshield frame good news
- Cutouts for '74 350 2 1/4" or 2 1/2"
- fiber optics 69
- control arm bushing removal??
- Train sound coming from engine (1982 vette)
- 1.52 Comp cam ULTRA PRO MAGNUM Roller rocker opinions.
- wiring question
- Dead short in cig lighter - alternator?
- door problem
- AC/Heater system diagram
- 76 Vette Setup for Street/Strip
- need advice/ help with changing p/s on 77 vette
- Heater Core Gasket/Sealer?
- question: 69 vette brakes
- Zinc Plate Frame?
- Spin tires??
- BBC Intake Mani Question
- ==> The CHUCK CoW Carlisle COUNTDOWN CLOCK - COOL FREE DOWNLOAD <===
- Found Possible Reason For No Hot Air In Re-Vacuum Hosed C3
- removing a i r pulley install spreader bar
- 383 Stroker In My 75
- New radiator,electric fan,alternator and R 134 conversion.
- Post Ignition Proble 1968 427 Tri Power
- Post Ignition Problem 1968 427 Tri Power
- Looking for somebody in the rochester new york area to check out a car for me
- U-Joints not fitting 100%????????
- Hot, not overheating, but trying to :)
- Custom intake lookin better.
- i need help with rear half shaft u joints
- Headlights HELP PLEASE
- Viper 211HV Keyless Entry - anyone install this?
- L88 Fresh Air Chamber Question...
- Jet hot
- Engine Repainted - Rattle Can & Foil - See photos
- Fuel Gauge Moves A Lot
- Gauges? We don't need no stinking gauges....
- help with 68 vette A/C install Thanks!
- Instead of a rag joint I want a universal?
- What, with all these exhaust threads goin' on:
- l88 flares with 20x10 and 20x12
- Heater Blower will not stop running??
- Power Steering Pump for Hydroboost
- short headers
- Intake Mani. Gasket
- Air Conditioning Question
- Vacuum and fuel pressure Tester
- Engine Won't Shut Down!!!!!
- 68 Vert 427 390hp Expansion Tank
- Get me to the finish line- couple final LS1/2004r swap questions
- Tach question
- 81 vette wipers
- Shield for power steering control valve & stuff
- '72 alarm switch removal???
- Supercharged 1971 - New vette owner
- 82 exhaust manifold repair
- 1981 To CCC or Not CCC
- Rebuild my Edelbrock 1411 carb
- Carpet Install.
- Coolant Expansion Tank
- 82 Brake lights are out
- Wiper problem on 1968
- 4" Sidepipe baffle / insert recommendations
- Flat Battery- courtesy light does not go out ?
- ignition switch or key lock failure
- noise coming from rear end ..
- 1971 convertible hep needed
- Crap, what did I do?!
- Question about Bolts for Water Pump for BB's from 68-74 with A/C
- Tri power jet size question
- temp. sending unit
- 70 Big Block Running Warm
- Brake Help!!
- Big Block Exhaust Manifold/Header Recommendations
