- Toggle Switch function?
- '72 Noise From Right Rear Wheel
- Brake question
- What in Gods name!?
- so whats my next move
- 1971 Tach Issues
- Spark Plug Reading
- 70 LS5 Static Compression Test
- 1968 stainless trim piece on wiperdoor
- Engine Gurus??
- lost my keys to my 78
- Fan Blower Speed - only High Works
- Tilt/Tele Replacement
- Whats up with my Speedo?
- Wiper motor/washer screws
- 79 Steering Column
- 1980 electrical issues
- (1968) Which 327 do I have ...327 w/300hp or 350hp?
- Paragon in same boat as Ecklers....
- A question for you Resto-Mod guys with LS crate motors
- Removed AIR Pump Belt- Is it ok?
- Here's my Eddy Performer installed...
- Q-jet rebuilder?
- What intake manifold gasket do I need? LT-1 heads on 350
- plastic thing behind steering wheel
- electrical question
- Gaps in my fan shroud (corners).
- Front brakes will not release
- Will M/T ET Street Slicks Grow in Dia?
- Shift linkage, shifter problems, and more
- New front brakes get hot then lock up
- speedometer needle sticks
- Creeking noise when I turn left???? help
- Tire Off Ground Push On Top Of Tire, Tire moves in. Axle Moving In Diff.
- Differential leaking at Yokes
- Parking brake shoe guild plate question
- Eckler's - carpet dilemna~fiasco, whatever...
- Seeking advice on an intake manifold choice for my set-up
- Tachometer operation
- Which Chassis is the Best Performance oriented choice?
- intake gasket and head gasket
- Anyone ever use an Engine Test Stand?
- 2004R trans, B&M 2400 stall, fluid leak.
- starting problem
- 76 4sp shifter problems
- engine suffix code VP or 9VP
- Qjet reinstall
- how high is this imaginary headlite line?
- Mickey Thompson Sportsman S/R Tires
- Labor Day Steeroids sale
- Two hoses not connected
- wiper will not stop
- Using stainless T-top trim from a 68-76 on a 77.
- B&M Megashifter install in my 76
- Help with new cam selection for GMPP ZZ454
- Body Panel Gap Adjustments
- '70 WS wipers
- 2004R transmission, TH350 dipstick
- Backup Light Switch for Hurst Shifter in my 69 4Speed
- Carb float adjustment gaskets?
- Carb needle adjustment gaskets?
- How do you clean a 1976 corvette engine? HELP
- Headers
- Automatic Transmission issues
- Oakbrook IL Corvette Show
- Filling Engine with Antifreeze
- Borgeson install
- Willcox
- interior lights
- L-88 Hood on my '79
- What drop base air cleaner to use with Q-jet??
- Holley 4175
- NEW Power Steering Control Valve Leaking
- brake handle seal replacement
- Ignition shielding support mounting
- 700R4 shift question??
- Ram Jet 350
- BB Water pump
- Do I need to do the 'drill' mod on a Robert Shaw thermostat???
- 79 windshield frame compatibility
- LS1 acquisition questions
- More boring temp gauge stuff.
- What parts required for big block conversion?
- overheating problem in my c3
- Distributor shaft stuck....
- 81 or 82 headers on a earlier vet?
- Motor Running Like Crap
- anyone ever swap a solid diff into your c3?
- Electric Fans/ Taurus Conversion
- What's this plug into?
- 1980 transmission converter?
- Not happy with 79 windshield replacement
- 71 LT1 Vette.How Do I know its a real LT1 car?
- 82 engine pull
- valve cover
- interior bulb upgrades?
- Clicking sound - No start
- Oil and aluminum wheel questions
- 72 Vapor Lock
- Distributor ... Keep or New?
- How do I know if I have this?
- Hood VS. fender lines
- anyone drag race their c3? new here.
- Edelbrock, Holley carb hight???
- is it the capacitor for my turn signal flasher???
- Voltmeter slightly erratic
- Thank you Mr Willcox
- boost gage on c3? pic request
- 70 front end leans, has no support, whats wrong?
- Ultima Starter Wiring Problems
- Distributor rotor hard to turn - rebuild or...
- LED-Tunsignal issues
- Point me in the right direction please
- Where to find an upper alternator bracket?
- 1973 corvette switch on gas petal under the dash
- edelbrock top end kit
- dual snorkel oil vent tube
- converting to sidepipes on my 73
- I've read the brake bleeding sticky, still need input!
- 78 driveshaft question
- 76 stock air cleaner assembly fit on any carb??
- Issue with Rebuilt M21 Muncie 4 Speed
- ls1, A/C, cooling system for my 80?
- 2 parts
- Corvette 'shop' incorrectly oriented my U-joint grease fittings!!!
- Help, What plugs for these heads?
- How to: 1971 Gas pedal installation
- "Budget" 540 Build
- Oil pressure guage
- Capacitor 801249 Question?
- My Lincoln MK8 fan install....
- What a great day...but have a problem.
- Rear spring bolt replacement?
- Need to lower front of 76 about 1 1/2"
- removing key switch
- Motive Power Bleeder not working right...
- 74 vette headers
- Power steering pump or Steering control valve?
- 80 tilt/tele,,,horn
- 1970 Hood Clearance
- Interior fiberglass finishing
- Temp Sender Internal Resistance
- 1111263 ball bearing ti race distributor parts
- 74 vette
- Firewall fiberglass looking bad (pics)
- simple (for someone) rear end question
- Rebuilding question / needle and seat assy
- wiring c3
- wiring c3
- odd thing happened 71 fuel strainer in tank
- Installing a pilot bushing in a '76 4 speed
- Iron Eagles's for my 74' - 180 or 200cc runners...???
- Found leak, not sure how to prevent it
- Need nice distributor ...
- LS 7 Heads
- 80 mod californian, car check engine light comes on
- Only premium gas
- Van Steel coilovers
- Engine dies - fuel or ignition?
- Only difference between an L82 and L48...Engine?
- zestays 79 build thread
- Carpet after removing underseat retractors
- Who has done an LT1/LT4 swap?
- 69 L88 Question
- Putting a 700r4 in my 78
- Replacing distributor
- Looking for "x" Pressureplate-Flywheel
- clutch fan leaking oil
- Typical tach operation ??
- 79 L-48 oil fill cap picture??
- Dead BATTERIES
- DEMON carbs.....aka Barry Grant ........
- Fuel Starvation at high RPM
- Vacuum Hose Routing
- Autocross in Minnesoata September 12th
- 1980 power steering jerk
- Inconsistent Brake Pressure
- QJet idle mixture settings, LS5
- alingment question
- More Temp Gauge Questions
- 1968 Dipstick tub replacement
- engine installed finnaly
- Who posted this C3 cockpit heat problem article
- 72 Corvette 454 Smog pulley question and part wanted
- Vot meter issue
- Question about changing intake manifold
- under hood light
- Changing the oil pan gasket
- 2 problems...
- running rich
- No high Rpms
- Dome Volume stock LT1 Pistons
- Coolant recovery/overflow tank question
- 1981 Bad computer?
- Starting issues
- Radiator Problem
- 71 4spd shifter ball thread size
- tricks for placing mounted seats into buckets
- Fluid level in Master Cylinder
- Victor Junior EFI intake with a 4 barrel TB
- *Need Header Recommendation*
- Offset trailing arms question
- 81 Brakes - Soft Pedal - Suggestions
- Exhaust Install - does this look right? (pic)
- Corvette Badge
- Edelbrock Performer - "stock" install problems, Height, Fuel Line and Choke (pic)
- Filter change..fuel line keeps leaking?
- 79 Corvette / Torque Converter / Shift Issues
- Ever wonder what's in a temp sender ? pic
- oil pan gasket
- AC Restoration / Upgrade ?
- What Other vette rims fit?
- Help headlights wont raise
- those that swapped to TPI
- C3 corvette brakes
- Looking for a tall hood, what's out there
- 71 SB rebuild
- grease for bushing
- strut rod bushing / bolt
- Fancy headlight bulbs Myths and Facts
- L-88 air cleaner base. ????
- trans pan color?
- Lights will not turn off.
- Fuel Filter question (weird part)?
- 68 Wipers Won't Stop
- BB Engine Mount "V" Spacers
- Attempting to remove the trailing arm bolt.
- right rear wheel noise
- Will These Wheels Fit on My 71?
- 10 Spline vs 26 Spline Input
- Riveting experience: Anybody replaced seat bolt or seat belt 'under-body' mounts?
- 1971 LT-1 Performance Question
- Hurst shifter stick question
- Holley 50cc accelerator pump kit
- Radiator Removal
- Aluminum intake manifold install: to use the rubber end gaskets or not????
- intake manifold on 454
- Can't remove rear shock mount.
- Top Dead Center and Ditributor install help!:willy:
- hooker headers
- Harmonic blancer
- Bushing failure after 6 months WTF?
- How much play is too much in the pitman arm?
- '72 ballast resistor, resitance wire or both?
- ****!!! Just Found Out I Need a Rebuild - Experienced Suggestions Needed (newbie)
- boiling power steering
- Restoration shops?
- fenders flares mid américa or ACI!!!!!!
- Should I swap the intake mainfold?
- distributor
