- sb dewiits and bb
- 1978 A/C control head help
- Antenna and ground plate question
- Door ajar switch doesn't reach the door
- Wheel Bounce??
- Vibration when RPM's climb
- 383 Combo experience needed for Cam select
- headers hookup
- Spare Tire and Jack 69
- Corvette Geneology and History Service's
- Which wires are sending unit wires?
- Blockman ? worried friends pro comp BBC heads
- What's the best easy out?
- 350 plan out 383 plan in
- 1979 differential swap
- GM TBI conversion questions.
- 1975 Coupe Rear End Too High
- Witnesses say the entertainment value was priceless!
- 1972 LT1 rear rotors
- ZZ430 - need more HP!
- flywheel question.
- Neutral Safety & back up lamp switch(connectors)
- Wanted Corvette body lift kit
- glass removal 70's side mirror?
- Electrical ?
- Factory sidepipes, whats inside??
- Eliminate heater core & hoses
- seat belt question
- Console light not working?
- Factory side pipes performance
- Decisions: Edelbrock Pro Flo XT or Holley Stealth Ram
- High idle
- Block protecter,thrust plate with roller bearings
- Is it possible to reuse heads gasket ?
- 69 body on a 78 frame
- Electrical question 74 Corvette
- Crossmember Cushion Top Brkt
- steeroids tie-rod rubbing lower A-arm's
- Tranny decode
- Fiber optic cable cleaning the end
- Power Steering valve internal wiev
- clutch inspection
- will pulling rear spindal trash bearings
- differential cross member question
- Picts of Plug Wires. Big Block with Headers
- Solid FT Camshaft recommendation BBC
- suspension help
- No power steering 79 corvette
- My New Springs Are Short
- aluminum flywheel & weight?
- Master Cylinder Brake Lines
- Spark plug heat range??
- Corvette rack and pinion coversion "Rack Attack"
- How should an engine be started that has not run for 7 years?
- 700r4 Lock Up ?
- 1972 blower motor relay location
- help with 425hp stroker carb
- Brake Fluid Fiasco
- Can someone help me determine if these switches are what I need?
- Developed a brake fluid leak.....
- 1982 and ZZ383 with stock hood
- Universals binding at full droop
- My modified LS1 water pump
- Would a pair of 4 ohm resistors protect my radio and allow me to use 4 ohm speakers.
- Would a pair of 4ohm resistors protect my radio and allow me to use 4 ohm speakers.
- Side exhaust rant
- What/where does the dash volt gauge measure?
- Results from my headlight vacuum tests...
- Engine rebuild question
- What size fusible links on starter?
- Power Steering belt question.
- Solid roller lifters ISKY 1241LSH or Comp Cams 818-16?
- L88 hood: functional fresh air chamber or not?
- Frame off?
- Steeroids question.
- Will these rims fit?
- Head gasket for 383ci with AL. Heads
- what do you think about these L48 mods
- l48 vs 290 hp GM crate engine?
- Blower no low speed, high and med are OK (non AC, 69)
- Where to source 'stock' oil pan for 74' L48?
- Turn signal switch
- Brake Line Distribution Block Wire
- Muncie Rebuild Kit....Needed
- 70 dash pad in a 69?
- Leaking headers
- power steering control valve
- Phoenix, AZ Engine Machine Shops???
- headlights not moving
- speedometer not working
- Help, Borgeson PS Pully alignment woes
- Bolt Specs, Rear strut Bracket
- ZZ 383 oil pan..does it fit a 1980 C3?
- Steeroids and Headman headers
- Power Steering Fluid
- Another Muncie ID Thread
- brake light wiring
- Need picture can anyone help
- Welded of Bolted Tranny Crossmember for 1971
- heater by pass valve
- T-Top Hardware Question
- Corvette 72 steering column disassembly
- Rear wiring harness-lights
- performer vs rpm air gap, pII track results
- tranny Plastic speedo gear
- Why vacuum canister
- LR Caliper won't line up??
- Got bored-Again
- balancer bolt question
- Shifter Plate and Center Gauge Bezel
- Leaks
- New C3 Owner Needs Help
- Is this differential a posi?
- 80 Interior Overhead (T-Bar) Lamp: Bulb Type?
- rear wheels..ready to fall off......
- engine guy and parts guy flywheel throw-down
- Hood stuck shut!!! Advice!!
- Desktop dyno run please
- tire and rim weight.... what is yours?
- build or buy
- Rear end shuttering
- Radio and headlight issues
- Q-jet seting question
- Temp Gauge
- Nasty Grinding Sound from Rear End
- Birdcage Swap
- Evapo-Rust Before and After
- Zink Additives
- Window rattle
- A Bunch of different tranny problems...If in RTP, please refer me somewhere
- Coil Wiring
- Talke to me about fuel injection
- Making stock 82 Power steering work with LS1
- engine removal, 69 with m21
- Aftermarket Seats?
- wiper arms for '78
- Headlamp bushing '75
- Power window - cleaning and lubricating
- brake pad replace
- 1972 LT1 Vacuum
- D36 batwing on iron differential case?
- 69 upper suround to pass NCRS
- shocks
- Best Interior Floor Products?
- Unbolted my odometer cable and the entire littel fitting came out of the gage!
- Insurance company, motor swap, and my 80.
- 79 Block hugger headers
- how many cars are left of.....
- Door latch and lock assembly lubricant?
- Shift kit B&M Mid America
- Please Share Your Thoughts For the Perfect Exhaust
- HEI IGNITION & TIMING question.
- Anyone running the vpb grand touring plus?
- strange electrical part
- 78 corvette Battery Problems
- Quick question for'80, what size is stock front sway bar
- 1976 stock radio
- More 68 brake woes..........?
- '79 Suspension overhaul
- Difficult getting in gear
- Center Console Gauges won't light; 82
- Help with Door Locks
- 79 gauge circuit board help needed
- Side pipe mufflers
- 1980 Corvette LSX 454 Project
- Body moulding question
- Removed the A/C. Who has the plate to cover the hole in firewall?
- Fuel Injection Conversion
- oil for my '74
- rear quarter panel interior trim threaded inserts
- L-48 cam numbers?
- Need picture
- Problem: Rotors returned by shop with Runout
- Trailing arm shims, other options
- ZZ 502 HR cam
- Removing 78 dimmer switch (with Tilt/Tele)
- 68 master cylinder woes.......?
- Seats
- Gear Patern Pics
- oil Blow-by seems to be gone....
- lower radiator hose help
- headlight canister positioning
- Pittman arm install.
- Power steering pump that DOESN'T leak?
- one piece rear main leak/fix
- Need Help NO Parking Lights on My 72
- Cool article SC did a while back...drag test 67' 427 Tri power
- Piston position to install the heads
- 1982-Fuel Pump Cut-Off Switch
- Willcox Winter Sale: Includes Free Seat Cover Installation Offer!
- HELP, 81 Climate control problem
- Radio installation
- Can anyone comment on these coilovers ?
- Upholstry Help
- 1982 Rear brake caliper mating
- transmission???
- Storage/Cargo area...ok to mount amp?
- Exhaust 77 duals question.
- Rear coil overs
- Does anyone have a 69 AIM and can
- New Member of Club 383
- 1978 Clutch Question
- couple quick questions about the performer/rpm air gap.
- Wheel alignment required?
- Torq Thrust II Wheels with 1/2" wheel studs ?
- 1979 L82 Aluminum intake
- 1982 Collector addition doors won't unlock
- which 73 454 intake manifold to get
- Removing Power Steering?
- Grant Steering Wheel
- Yes...another widest tire/rim combo question!
- Power Antenna Help?!!
- LT-1 Question
- Quadrajet oddity
- Steeroids Sale
- Starting Engine.....how should this be?
- 72 rear suspension ???
- 70 Lt1 Choke Coil question?
- Reading the 1969 Chassis Service Manual
- camshaft help?!?!
- TH 400 help
- Carb Height Question
- Differential Oil
- 74 Power Antenna
- Question for 68 BB Owners
- front and rear tail light holders for a '76
- Rear Leaf Help
- heater core repair
- Static from stock stereo with dial movement otherwise no stations play. Please help!
- best bang/buck topend upgrades for a 69 350/300?
- heater fan blower motor - 1971
- Wipers and wiper door - 1971
- Stripped Air Cleaner Stud Threads?
- trailing arms
- '77 L48 Cam recommendation
- problem with gm zz427
- Looking for Dash Ideas
- HELP - No TDC marks
- Interior coming together...
- Trick Flow Head Packages
- vacuum from carburator ok ?
- Update of Keiths 77 widebody
- Temp Needle Jumping
- Wiper door question
- a/c to non a/c heater box
- headers
- Engine bay pic request 69 350/350
- zz4 serpentine system
- LS1 in a C3
- Good idea I took the intake manifold off
