- Best cam with stock unmodified Vortec Heads?
- Need some help on BB belt squealing issue....(pics)
- Winter Starting Help!
- Fuel Pump Plug Tool
- Intake manifold question...
- Going from 727' to 236' in Elevation. Effect on Carb ???
- suspension set up
- 1981: electronic unit & TH350C
- Brake/ Tail Light Problems
- test pipe
- C 3 cold ac, how to achieve
- 1981 corvette repair shop
- Help-Im stuck-1980 power window motor replacement-pics
- Rims, will these fit
- Horn Connector Brush For My 1977
- poor choice on rear
- A quick water pump question, please.
- '75 Won't Start...not getting fire I believe
- Question about changing windshield
- Measurement between cam gear and timing cover
- Frozen Rear Wheel
- Gas Tank Removal.
- Numbers matching 350 or 406 vs car value
- remote starter switch
- Power Window Motor - Is that the problem??
- Rear Bumper
- wipers stuck ON!
- •► ► MERRY CHRISTMAS & HAPPY HOLIDAYS from CHUCK CoW & CORVETTES of WESTCHESTER ◄ ◄•
- Exhaust questions, X-pipe / dual mufflers
- Muncie Experts PLEASE Help! Trans blowing gear oil out of everywhere
- 1979 Door Latch Mechanism Lubrication
- p/s pump interchangeable?
- holley tbi tuning help
- Questions about my rearend :)
- 406 SB Carb & Cam Selection
- mechanical secondaries vs vacuum secondaries
- Sorry - one more ?? about Windows
- Newbie here... 81 vette- removing the smog pump
- Tilt and Telescopic Column Rebuild Video
- Battery charger question
- 383 stroker motor
- 1974 Brake booster vacuum line & Acelerator cable bracket
- 1972 rear vibration
- Tail/Stop Light Issues
- Gas Pedal Assembly Differences
- 4sp to auto swap question
- Rear Spindle Support
- Steering issues
- HELP in time for the Holidays!!!
- Accelerator Cable Install
- Fuel pump relay
- Muncie Input Shaft Bearing
- 81 w/computer, 268H cam...head choices?
- Help design my suspension - street/track
- intake and carb question
- AC compressor bracket question
- Weiand 8024/8004 Intake
- junkyard scrounging
- What are these??
- 4-5 6 speed auto transmissions?
- Can't get her started
- Harmonic Balancer for 72 LT-1
- Should I replace front springs
- Q? recommend replacement rubber bumpers ?
- Fuel tank pick up pipe?
- working out the buitd date and options on my 69
- Modify lower control arms?
- 2 Weeks Vacation
- Selling dealer info help
- Parking Brake
- Getting to the temperature sending unit
- Head gasket bore question?
- Torque converter questions
- E-Brake Not Engaging
- all in one style gauges?
- Chain Hoist Experiences?
- Diff crossmember bushings
- Side Yoke Help
- under drive pulley and rack & pinion / HydorBoost issues ..... input plz
- question for the winter
- Unusually High Clutch Pedal
- Need advice/help with Park brake
- New '78 owner, couple of questions
- fiberglass sub box
- Just bought my first corvette! And I've got wiring issues!!
- What are these hooks for???
- Can you get to these?
- Are offset HD trailing arms worth the $$?
- Correct Radiator Cap for L-89
- engine knocking...HELP
- Electical tape on harness is a gummy mess.
- head light problem
- Brake Light Wire
- Setting the stock radio stations and clock
- Alan & Roger Appreciation Thread
- Seat Belt Reinforcement rivets?
- Can I get a replacement key from the dealership
- ?? about interior lights switches
- C3 Spark Plug and Ignition advice/support?
- New Fuel Pump??
- Coil Spring Install
- Questions
- 1968 327 replacement & removal
- power steering pressure port for hydroboost setup
- Custom TA Bushing tool
- Headlight locking mechanism help...
- Rattles in Door Drivers 1971
- Car broke down, Diff experts needed
- Cam Information Needed
- TPI in-tank fuel pump for C-3 tank
- Wind Tunnel Tests C1-6
- Cracked mirror t-top worth anything for frame?
- Edelbrock Performer Air-Gap under 1980/81 hood
- C3 Long Tube 1 7/8" Headers, Stainless Steel!
- PCV question of the day?
- Bolts missing from half shaft
- emissions help
- BB Water Pump Bolts for 66-72?:
- 68 early quantity vs later made quantity cars
- No A/C, No Cooling Fan - No Idea?!
- firing order?
- anyone want to help this guy out?
- Flex fans, pluses and minuses????
- Oil leak after engine rebuild!!
- High Crankcase pressure after complete rebuild ; what went wrong ???
- Do i have a bad brake booster????
- new rear window problems
- A-Frame bushing /ball joint r/r?
- Headers removal?
- Power lock install on early C3 (pics)
- T top fitment
- Is there a Billet Aluminum Rear Spindle Support available?
- Carb bolt pattern
- tranny
- Window Roller ??s 1971
- Pro charger setup info
- Retrofit Camshafts
- new intake ?
- torque converter
- 82 CE fuse block problem
- What is the Wheel Bolt Pattern for a 1979 Corvette??
- Patriot Headers, other Aftmkt Headers and A/C and Alternator Support Issues !!!!
- new carb
- Metal Piece Holder
- Any experiences with one-piece oil pan gasket for 74' or so SBC???
- Max HP for a Q Jet
- '76 window switch orientation
- 70 verse 60
- Wiring ID, Astro Vent System, Performance and Window mech help wanted please!
- ignition switch 69
- starter keeps going with igniton off
- Weatherstripping Suggestions
- Billy Boat Performance Exhaust is looking for a 63-82 small block car for testing
- Hardened Push Rods?
- looking for info on a 5 speed
- Is it time to replace my composite spring?
- Batwing Bushings for 81
- Nose transplant
- trans gear
- New 76 owner with questions please!
- *** 9th Annual Corvetteforum Fundraiser for the children of St. Jude ***
- 71 Temperature Gauge issue
- Quadrajet or a holley for my rebuilt 1980 4/speed
- New Camshaft Recommendation 372
- Ignition or fuel?
- key/ column problem
- MaxJax Group Buy
- Looking to replace the wiring on my 73 stingray
- body mount ?
- lower A-arm shafts
- How do you find cc volume for heads?
- simple carb/ intake question
- Door Lock Question
- Anyone got a good picture of a 69 wiper motor?
- Stripped bolt hole on Muncie transmission
- Sand blasting stripped down under carriage
- Wiring a Mallory Hyfire VI Help!
- Oil Leak Assistance
- New style corvette heads
- rear wiring harness
- What is THE absolute best way to seal an Oil Pan on a 1970 BB ?
- Need help on C3 manual/5speed transmission.
- motor issues
- 4l80e
- No More Cloth Seat Covers For 78
- 79 Glove Box Knob Removal
- Rear rubber snubber...??
- has anyone used summits headers?
- Speedometer issues
- Transmission overhaul
- 1972 Lt1 aluminum radiator
- 72 brake/master cyl help
- Steering stiffer
- What is the true horse power difference between a 70 and 71 big block?
- Cross Fire To Carb Help
- headlight stuck open
- Lars
- Holley 80555C
- 68 wont start after a day
- Exhaust manifold
- Fuel Supply (pump ?) problem
- Has anyone ever tried Leaded Gas?
- radiator
- Head questions?
- Offset trailing arms '72
- RPM at speed
- New tune-up procedure
- AC Help
- making C3's run 0-60 in less than 5 sec's?
- Dash Bezel Center Printed Circuit
- HELP, Tires
- Fixing floorboard to firewall joint damage
- RetroSound USB mounting location
- F1 Lemans headlights
- GM specs - downloadable
- Hot Start
- Need some help with dynamic compression ratio
- Transmission trouble???
- what head and header gaskets do i need for my 69 350?
- Door Poppers 1976 Stingray
- driver side window
- '77 rear wheel bearing removal tool....
- Quadrajet rebuilder
- 1973 fuse block
- 10:1 compression ratio
- need a little help identifying this piston
- New Exhaust 2" or 2,5".
- for road racers: is there a sporty 15" steering wheel somewhere?
- Can engine & transmission be pulled as a unit?
- Anyone Jet-Hot coat BB exh. manifolds?
- heads
- Does anybody run a tranny out of a C4 in his C3?
- C3 1969 Spare Tire Question
- how to remove the body from my 69 roadster
- tires and wheels
- vacuum hose routing
- Brake Lights not coming on - 71
- Grinding, knocking while rolling, rear right hub is hot
- alternator/gauge question
- Zora Duntov Signature on Brochure
- Original Temp on 72 SB
- L82 valve covers question?
- Starts good,idles good,but when you put it in gear
- HELP - NEED pictures of the muffler system on a 69 or similar C3
- Headlights Rise when Started?
- 72 Header Bar Question
- BB header question
- G-force t56 for sale
- Drivers side window adjustment
- fresh air intake
