- Help! Replacing Body Mounts...
- Need Help - Differential Removal
- QuadraJet DialIn/Tune
- HELP! my engine is surging at idel. why?
- Ignition lock
- Torque Thrust wheel cap thread size
- Any OEM radio repair shops in San diego?
- Cam replace
- Timing mark location on 1970 454
- looking for a mechanic on Long Island
- wiper solenoid wires
- Engine break in with body off
- watch my motor come together.A seven day thread.
- C3 Rear Spring Rubber Donuts
- One more thing about stuck C3 hoods...
- Differential Spindle Question.
- 72 vette with proble3ms
- 1982 turn signal Dash bulb
- intake manifold question?
- Need help installing power door lock switch 79
- No Spark
- Antifreeze
- Gear Patterns- Experts in here, please!
- Wiper override switch puzzle
- TH-350 vs TH-400
- '77 build (pic heavy)
- Engine dies round bends and under hard braking
- 10% Off Select Brands & Free Shipping this weekend only!
- Ignition Module
- Radiator for a 1974
- rebuild kit
- worm air
- matching new paint job
- stud girdles
- who has seen this carb?
- spongy brakes after sitting awhile
- Proline brand oil
- L-88 or hi rise hood hight help please.
- 76 heater core replacement
- Rebuilt Small block-zero compression??!!!
- Half Shaft Installation Concern.
- stuck in reverse
- Removing the 82 fuel pump and sender ? Help
- 68 Vette
- ZZ4 owner valva trane question
- Brake Fluid
- '76 Purchase advise - ride quality?
- wheels??
- Carb/Dist vacuum diagram?
- Power strg pulley
- Question concerning brakes
- Does anyone know where to get the black, cloth core tape
- Tall deck big block with hooker sidepipe headers?
- '79 Window "Blow-Out" Clip Replacement
- Double pump or vacuum secondary??
- cam install question....????
- Interior paint questions
- Need Advice on Bushings
- Vacuum Secondaries
- 1977 Corvette Service Manual Advice
- power antenna
- Memorial Day suspesion sale from Speed Direct
- Cooling system experts
- spark plug gap question
- I want to install a 6 speed trans to a 350
- Inspection Warning!!!!!
- Opinions Needed! Keyless entry/Remote start
- '75 'Vette power window is slow
- All you vets with Vettes
- Paint problems.....
- pulling cam questsion
- Light Pictures as Requested
- Adjustable Proportioning Valve?
- MSD 6AL malfunctioning - again??
- dual fan
- New vs rebuilt control valves
- Using stainless nuts on exhaust manifold studs
- Wiper Compartment cover and windshield question?
- Tick
- 750 Mighty Demon Question
- tcs
- 8.1 Vortec Conversion...Anybody??????
- I need help! Transmission problem...
- 78 vs. Mustang
- Vacuum ?'s inside
- wheels leaning
- Huge Roller Cam NO vaccum
- Hood clearance fo Holly and RPM air gap
- Disasembinling Rear Control Arms HELP
- Top End Kits for an L82
- Suspension help...please
- Darn Bubba's
- New Vortec Valve Covers, question about PVC and breather
- Replacement Radiator.... PROLIANCE 433717
- Hydraulic Lock up for 700r4 ?
- Diff between 4speed/automatic dual exhaust
- Starter or safety neutral switch???
- Speedo cable leak on Tremec
- Help putting shield & vacume assembly for heat riser on 1979 L82
- Where is the power?? Vortec question
- Fast Idle After driving
- open sidepipes?
- Temp Gauge...Here's a wierd one....
- Dyno test
- Need some electrical help!
- Trying to find info on 2 old holley carbs...
- Tach cable & w/shield squirters
- Cold air on a S/B
- what's better, Fluidampr or rattler HB?
- Rocker panel question
- Vibration under accleration - 68 L79
- intake vs. head coolant paths
- Altering battery/storage bins
- Not just another oil for flat tappet cam question. Rottela = slug? Royal Purple?
- Help with '69 TI auxiliary harness routing
- "Edelbrock" 2116 && Q-jet 4 hole gasket / Wrong gasket?
- Adelbrock 2116 & 4 hole base gasket for Q-jet
- Anyone Remove Their Air Cond?
- Fuel Gauge Check
- decode engine
- Windshield molding replacement - need to remove windshield??
- anyone use a unversal whindshield washer pump
- TH350 Problems when Hot
- Ram Jet EFI into 76 stingray
- Headers and angle plug heads
- Interior Data Plates........
- BB exhaust options
- Big Block swap-AC, PS, Alt brakets??
- Back up lights
- 77 Vette Rear Swaying
- My 77's First Day On The Road Today For Me
- dash pad speakers
- torque specs for halfshaft to rear end
- Transmission fluid
- In car cam swap
- FB 385, ZZ383, CT350pc1
- Engine swap question
- quick trans filter question, 76 c3
- Back to square one, just CANT decide! Help?
- What should I replace while the dash is out?
- Poly Differential Front Snubber Bushings-Problems?
- when i shift into gear; *CLANK*
- Frame Numbers
- Choke problem
- Blown Stroker
- Convert a Felpro part number
- 1978-1982 Tach Rebuild Video from Willcox
- 1977 Vette Key Problem
- 77 Vette Weather Stripping
- 77 Vette Seat Back Angle
- 700r4
- Hot rod air pics???
- I need some help here
- Carburator problems!!!
- Camshaft Choice
- please please help
- Camshaft Choice
- Strange Stereo Interference w/HEI
- LSX Swap
- Need oil pan recommendation for 496
- Leaf Spring Liner Question.
- burned the clucht
- Brake Booster grommet
- Suspension Rebuild
- Over Heating After Sidepipes
- Coolant from under dash
- anyone ever seen this before?
- 78 Seat Recovering Help
- 1970 454 Fan Shroud Mounting Question
- 1970 wiper motor power
- Starting Problems What Do You Think?
- Had the dash in my 63 race car airbrushed to look real...
- '69 shift boot
- Turnsignals are dead!!!!!!
- MSD distributor with 454 shielded plug wires - will it work OK?
- I need some advice on a 69 Iam looking at HELP!!!
- 1968 Windshield Wiper Arm Cover
- speedo help
- 1979 Vette and Fuel Injection
- Help with torque spec for motor mount
- EFI on big block with sidemounts
- Carb. opinions needed!!!!
- Brake Light Switch Wiring
- Extending Steering Column
- Fuel pump help needed asap.
- Rearend noise.. need opinions
- Who sells (QUALITY) L88 hoods (With Cold Air Box) ?
- Fan Clutch Question......
- ZZ4 Heads & Hooker Header Sidepipes
- rotelle oil in older motors?
- re 72 egg crate painting
- More stearing column woes...
- Help!!! Wiring F
- 30 over?
- Need torque specs for the halfshaft to the spindle flange
- Carburator base gasket
- New heads and cam. Suggestions/instructions?
- Rivet tool?
- can't reattach spreedo cable-help
- Roller cam setup questions
- Lock removal / steering column disassembly
- Denso Iridium vs. NGK Iridium vs. Pulstar Pulse? Which Way???
- Installing Cam
- Anybody use the Speed Direct hood strut?
- Cheap rotors????
- supercharger pics wanted
- Engine vacuum
- Rotating assembly question
- Interior lights won't shut off.
- New top end
- Tach Needle
- Evap canister ??????
- No clutch pivot hole in a 400 block?
- Question on changing to an electronic distributor & keeping original tach.
- Fiberglass front end replacement
- performer intake and distributor shaft
- unilite distributor tachometer hookup
- Stroker kit.
- In the process of swapping brake lines
- Door handle adjustment
- Torque specs for Main and Rod Bearings SBC 400
- How do I remove a hooker side pipe?
- R43 vs r43s
- 1979 corvette. Does anyone know?
- BBC roller rocker
- Vacuum '78 L-82
- What else to boost performance???
- Performer Air Gap
- Is the fan clutch necessary? (327-350)
- installing a circuit breaker to vette for security??
- Tires and wheels 16 inches
- For how long time can the engine sit?
- Head lights
- Finishing Up Front Suspension, Quick Question
- Side yokes play found yesterday - what to do?
- what have you smoked?
- Overheating problem or sensing problem?
- 77 Vette Brake Pedal Low
- 77 Vette No ACC on Ign Key Just Power on & Start
- No warning lights before start
- 82 C3 Intermittent starting trouble
- Crate Motor
- Autofab 4-link solid axle kit for a Dana 60? Need advice.
- Window Regulator Gear Rivet
- ECPB Electric Headlight KIt
- Ford 9"Axle
- Need suggestions for removing t-nuts from 69 side exhaust car
- Is it possible my rings have not seated yet?
- Does a 1972SB AC box fit a 1969BB no AC?
