- BB Chevy valve cover drippers
- Weiand 7513
- Uh-oh
- Squeak from transmission output?
- oil pan
- Need help with issues with 68 wiper motor wiring
- Flowtech Headers
- What give more droning noise? Flowmaster of Dynomax?
- "S" wire for starter ends up under consol???
- Hood Insulator (Need Or Not)
- Steering hydraulic line repair?
- Electric Choke on a Holly 600CFM carb
- LOUD POP!, FLASH and SMOKE up through the CARB! WHAT THE HECK???
- engine oil additives (stop leak)
- Oil Pressure Sender hole in block - what should the size be?
- clutch geometry/linkage messed up
- Bellhousing ?'s for TKO 600...
- What oil to use!!
- Proper way to install door panel skins.
- excessive oil on valve stems?
- County Now Testing Emissions - Failed Because Air Pump Missing.
- Wiring Question #1 68 Heater
- Steel braided fuel line help for Q-jet
- Install headers to crate before or after motor install?
- Exhaust Tech Questions: pipes, bends, etc.
- Question re: TCS wires and HEI
- Vbp's "spring" into summer sale
- Road racing oil pan design
- Engine floating / rebuild for $3,000
- Hood Open Warning Switch
- Help me pick a Carb.
- Front Suspension Refresh project
- wiring diagram
- Anyone with Hooker Sidepipes on their C3, PLEASE HELP!!!!
- bleeding problem
- Wiper motor wiring switch question
- 454 head gaskets
- electrical short...maybe? who knows
- It started out as a simple job
- 1977 Power Window Problems
- 1968-427 Convertible Tail Light Issue?
- Drive shaft safety loops.... with pictures
- Bent-warped Driveshaft on my lil '68
- Finally got rid of my check engine light
- Differences in '68 and '69-'79 Hurst Shifter?
- Anybody make a kit to convert rear window to 'removable'?
- What dia. exhaust pipes work best,and a good sounding performance muffler.
- Power steering leak
- Power steering pump pulley reinstall screwup...
- Installing catalytic converter
- Need help with an Ecklers Twin Turbo hood
- Best valve covers gaskets
- New shocks, new problem
- Newbie rear wheel play question
- My window regulator roller replacement quest for my 71
- front end setteling after motor install
- 2004-R Swap
- Help! Pushrods not staying adjusted?
- Correct tailhousing for my Muncie M20?
- What electric fuel pump to use?
- Koni Shox
- Questions on changing body mounts
- EdelBrock Carb
- USA made brake rotors?
- whos running PerTronix 2 91181 Ignitor
- Spectre Intake Systems
- Universal Sway Bar Bushings - 1 inch (25mm)
- 79 Tach Printed Circuit
- 82 EGR valvle replacement
- sidepipes
- 1979 Corvette Backfiring
- Front Sway bar bushing
- want redline tires, diamond back or coker?
- C 3 cruise control - how to?
- Rack and Pinion u-joint problem
- rebuild
- Non return valve in fuel lline question
- corvette blues
- C3 '81 with wrong clutch fork pivot ball
- Caps, Straps, or U-Bolts?
- New U-Joints not fitting
- jacobs electronics stop action anti-carjack - help!
- how thick should a healthy clutch be?
- Lets see your add-on fuel filter ! w/crate pics..
- A/C belt vibration....? why
- WTF!! How do I shut this thing off correctly?!
- No electrical power.
- brake fluid change
- For those who have converted to F-body serpentine
- Installing Th-400 shift kit VIRGIN
- Valvoline Syn Power, my choice
- Torque for Crankshaft Oil pan cover?
- headlights one functions the other doesnt
- starting problems
- Manual Hot Water shut off
- Vette Brakes TOP in Customer service
- Starter (and misery loves company)
- Front Spoiler (air dam) - quick question
- 74 Gauge Bezel question
- Intake
- Murphy's Law strikes again
- >>>> St Jude Auction #31 FORCE-CDI-IGNITION-BOX-2-STAGE-MULTI-SPARK-RL-2 <<<<
- Wiper arms+blade pictures wanted
- Advice on Steering Box Rebuild
- My PWM went out again... any one else have trouble with these things?
- missing O2 sensor plug
- New 12 Bolt, Off Set T/As, & Suspension Upgrades
- Speed Bleaders - What size for a 1975?
- Opinions on Holley Street Aluminum Avenger (083770) 770 cfm?
- Found My Battery Drain - Now How Do I Fix It?
- speedo cable change - transmission fluid
- Which exhaust system 69 tripower
- How did I screw this up? Ignition Cylinder When Replacing Steering Gear Box
- Heat Riser Question
- Cooler Footwells
- Help !! Brake Booster removal question
- Pro6Ten A/C compressor
- T-Top, T-Bar molding question, with pics
- Trans shifting properly now - Airgap, no help
- Replace heater/AC blower motor/fan
- Potential for Spark Plug Wire Damage with Loom?
- Anti Freeze
- Drive shaft installation
- a better way?
- Help please with a flat tappet cam shaft choice
- noisy speedo cable
- LS1 exhaust on ZZ4 heads on a 75 Vette
- Assembly issues on 1969
- Clutch Disc/Pressure Plate Warped? How To Tell?
- brake bleeding success
- Removing A/C - questions
- Vacuum canister help...do I need?
- transmission numbers?
- Well, I Didn't Trash My Adjustable Strut Rods.....
- Need vapor lock help please.
- Flat-Tappet Camshafts: Semi-Syn Oil from Summit
- thermostat
- One Issue One Request 1974 Stingray L48
- Project help
- Help, Can I use this Mini Starter with my new engine combo, please?
- Head Gasket
- Cut-pile or nylon loop.
- any trick to removing the oil pressure line from the back of the block?
- 1978 Pacecar Vette with Electrical Issues
- Big Block Help
- Spark plug choice
- Help - 2nd oil pan wont fit (hits oil pick-up filter)?
- Need Help My Car Won't Start
- Changes needed to run a 1 Piece Main Block in 79?
- 77 and later AC Control Lighting... anyone done any modifications?
- cs-144 Alternator install
- Losing my rearend
- C3 hood pins
- C3 front mono spring upgrade
- C-3 front hub interchange
- I lost close to 400 lbs. Here's how:
- 1980 Stock Corvette: Carb & Intake Manifold Suggestions
- Side pipes - transmission spacer plate
- making a accurate jig to center C4 suspension on a C3 frame ????
- Tri power tuners in DFW area???
- Trouble Shooting LSX engines
- 81 Trailing arm, spindle
- Front Running Light Bulb Replacement
- Temperature sensing - 2 wire or 1 wire ?
- Paint chipped off front bumper
- Is this gunk OK in my filter?
- will these later model corvette wheels fit my 75?
- Lifter wear issue on newly rebuilt 408...pics.
- Calling all Motor Guys!!! LT-1 help!!!
- JUst got an 81', need some help, pics included..
- New Distributor?
- tune is backward!
- Engine Rebuilding ideas
- Too Loud!!!
- '72 coupe rear window gasket replacement?
- Header installation 75L48
- Careful way to remove AC Compressor/hoses?
- Side Pipes or Not. That is the Question?
- 1971 454 Valve Covers
- Question about - American Racing 18" Phantom Wheels
- Total newbie eeek!
- fuel pump
- BRAKES..who needs um?
- Parking brake shoes
- '76 Heater Core
- New rear spring, car sitting uneven
- oh oh..something has gone wrong with my steering,suspension.
- Engine ID
- NEW TO THE C3!!! newbie in need of help
- 1978 Corvette Side Exhaust Dilemma...Any C3's Owner's with Hooker Side Exhaust? HELP!
- Vintage auto transport cross country
- stock crossmember 200-4r installed pics
- Who sells good, sturdy t-top locks?
- Left fender is 1" lower than the right over the wheel.
- Rocker arm geometry
- Header gasket
- Fill in aluminum and rethread?
- 700 in 81 vette ???
- sport racing seats???
- Wheel Stud Replacement
- 1976 Rochester problems
- 80 model radiator- what are my options?
- 4 sp support
- AC spinning out refrigerant oil
- Power Steering Problem After Rebuild
- Power brake booster clearance
- holes in calipers?
- Hooker side pipe mufflers
- Holley Avenger MPFI Manifold doesn't match heads
- C-3 front hub
- Removing the shifter
- best way to clean a motor for painting?
- New engine valve lash setting
- no oil pressure?
- Bleeding P/S System
- 72 454 carb burns too rich
- matching # motor rebuild
- Holley boosters pouring fuel @ 2500 RPM
- Body mounts
- switched power problem
- moroso ext. battery switch location ideas
- Nose Emblem Placement
- broken rear short Axle
- Factory Tripower
- engine swap/accessories
- Transmission options for 76
- RTV or Teflon Tape on Oil Drain Plug
- DD VHX VS Autometer - Opinions Appreciated!
- Brake rotors hats offset
- Tire & rim fitment 1968 corvette
- 1975 L-48 ZZ4 heads and building
- can anyone please help with this distributor wire
- My LS swap to date
- ISIS Electrical system
- Are my pistons ok?
- power steering fluid
- Hesitation kills.....performance issue need help
- 78 rear carpet @ the cargo cover
- need advise on heater fan
- power steering pump overhaul
- 1974 power steering cylinder and other ?s
- Which shift linkages to buy for stock Saginaw 4 speed?
- Whining/squeaking Sound
- The Dreaded Wink
- Carb setup help
- Voltage at Power Window motor too high?
- Rag Joint Installed - Have a question
- Hi-Torque Starter at great price = Too good to be true??
- Timing light not working on GM HEI Dizzy
- Just broke my replacement power steering pump and I'm pissed..
