- Can anyone in Indianapolis area help me? 81
- Erson cam, Which one is this?
- Cam change, Now Gears?
- kicking myself..hood liner install
- What gears am I running?
- Distributer advance recomendations
- My Corvette project (The Wounded Warrior)
- The Quest
- NGK Spark Plug Gap - 427 w/Brodix Heads
- Got a nice 200r4 core today for $40....
- 1975 Center Gauge Cluster Installation
- New rag top install. Confidence shattered.
- 68 vent balls - only outside air?
- Pressure Brake Bleeder My Way
- Carb Question?
- Wiper wiring problem
- Borgenson install
- how do you remove the lock cover?
- side yokes
- Moog parts
- Minor electrical issues
- Should i be widening these holes in the gasket for my Head to block?
- What are we using to seal diffs these days?
- Tach Filter
- Another Brake Thread (Long)
- HELP Rough idle / Hesitation when starting out
- #5 Cylinder Rocker arm hitting Valve Cover...
- Spark Plug Wire Question
- 90 Coupe, weird issue with the O2 sensor
- 79 Anti Theft Door Lock
- the dreaded rear CLUNK !
- Rear Wheel Bearing Question
- 1979 Resto-Mod HVAC Gremlins
- Exhaust Wrap Feedback ?
- Source for stainless headers/sidepipes
- March UD pulleys
- annular booster is loose?
- 79 Antenna
- 70 454 Broken Piston
- T56 swap need a bracket.....
- Holley Adjust-a-jet thoughts
- What in the world is this thing?
- trailing arm shims
- Q for those with dedicated fuel tank for nitrous
- Replacement radiator options
- Camber adjusting bolts won't stay tight
- M21 Rear Bushing Replacement
- Transmission Rebuild Advice
- 1974 Intermittent Starting Issue
- 82 corvett lowering suspension
- Wiring help needed, going crazy!
- Best Battery Disconnect
- 81 help
- what bolt?
- 70 thru 72 LT-1 Carb. insulator ?
- Rear Bearing Failure
- Vbp's "spring" into summer sale
- Carb repair help
- MSD 6AL Power line fused?
- 1982 Centre bezel removal
- New Distributor Install
- Willcox New Sale.. You asked for it... Details Inside!
- ground locations on a 1979
- 1975 L48 Corvette Tune-up?
- will be looking ar 78 vette in two days advices needed
- 69 stingray
- control arm removal pass side?
- Front End Rebuild
- 78 No heater, wipers or windows!
- O2 sensor carb tuning
- 454 into a 1968 SBC Coupe
- Figuring Intake Valve Closing Point for Cam selection and DCR calculation.
- Need help to troubleshoot 69 magnetic pulse ignition.
- Spreader Bar help?
- Brake information
- is there a header gasket that wont leak?
- Brake overhaul questions for my 78' Silver Anniversary
- Engine help
- Universal radiator hoses question
- Saginaw 4 speed in a 76
- fixture plate for u-joints, where to buy?
- 79 Tilt/Telescoping Steering Column
- Gasket for Aluminum Heads?
- anyone use sealant on a 1pc oil pan gasket?
- Battery Warning Light 82 CE
- Master Cylinder Bleed Procedure
- Engine Run-on
- repairing fiberglass cracks
- Corvette Central carpet heat barrier kit - front and rear 7 pieces
- BB valve cover gaskets leak.........
- Can clip and firewall be removed together?
- BRAKES -- What to check next?
- Engine Compartment Paint
- Buy 383 crate engine
- TH350 wont shift at WOT
- Need good A/C shop in Winston Salem NC area
- 79 Vette Air Conditioning Troubleshooting
- dip stick question
- Holley Carb Jet Size
- Help with carb/intake/dizzy swap
- Trouble replacing body mounts on 82ce
- Headlights
- 1 Side Marker Light Out
- Lowering Differential: What Am I Missing?
- C3 wheel track widths?
- Tunnel Modifications to Accommodate Transmission
- pushrods worn at top?
- 77 power boost. Rebuild or new motor?
- Dewitts Doesn't Fit
- Is this new one for you??
- electrical wire mistery
- 73 dash, side marker and tail lights out
- C3 wheels
- Need steering help
- 72 BB alternator bracket
- Anybody installed a Retro-electro headlight kit...?
- 700r4 & 4k stall going into '74 vette
- Rear wheel bearing \ small wheel play
- Could a dana44 from a 82 be mated to a 84-96 dana44 batwing?
- Proper tightening for front bearings?
- 427 BB purchase
- I think I might have done something wrong...
- Clock circuit board toast
- Centerforce DF clutch mods
- Power Steering Control Valve has me stumped
- Aftermarket Parts for Removable Rear Window?
- Th 350 autobox - workings?
- Where to buy the short fuse for the inst. and dash lights?
- Distributor installation in correct angle
- corvette college??
- 73 Vette LT1 Swap Question?
- I.D.'ing an Edelbrock carburetor
- Can you recommend offset upper A-arms?
- Spark plug question Iridium? Platinum?
- Aftermarket throttle pedal needed
- Engine stumbles around 3500 rpm... sometimes
- Transistor Ignition Amplifier
- how to get back on track with cam install
- stress cracks at hood hinges
- Will an LS truck oil pan work in the C3 swap?
- oil filter
- Transmission fluid cooler
- Wanting to get my 73 in the 11s
- One side of my engine runs hotter than the other???
- windshield change
- Auto radiator in manual car???
- Caliper Suppliers?
- HELP!!! Hood cable broke and cant open it !!!
- rotors
- Brake Caliper Mount Bolts Hex Head Size
- solid lifters or hydraulic, how to know?
- Clicking Noise from rear end under any acceleration
- does this look like an old repair in my head?
- Dyno results for Comp XE268H
- Need help changing air filter
- Dumb autoX question
- Another rear spring upgrade question
- Strange Oil Pressure Readings
- proportioning valve
- Fabricating Wider Steel Wheels?
- gen light on in dash ???
- Wiring, can someone identify these? (pics)
- 555" Dyno testing-Auto Enthusiast Magazine
- Stall converter?
- Do I have low oil pressure?
- Side Yoke Bearings
- Stress Cracks
- Block Core-Shift Question
- Ignition Cylinder removal - again...
- Calling all differential gurus: Video
- 1980 Vette turns over but won't start
- *Which Headers Are You Using With Your Angled Plug Heads?*
- Gas gauge not working.
- compression
- lowering kit corvette for 1980
- Another head, gasket, and Compression Q
- Need help from '82 owner
- Timing question 76 350
- Shark Bar for a '79.....
- Seat back release strap
- Air gap intake in a 73 ?
- pusher or puller?
- Mystery fan
- 71 wiper door technical assistance needed
- Front Suspension Mod
- Installing LS3/4L65E in 79 and needs help.
- Vintage Air..after a few +years???
- engine questions
- What do you guys think?
- Does anybody use an exhaust gas reader to performance tune their engine?
- Hydraulic or Roller?
- How to tell matching number
- interior "to paint or not to paint".
- removing a/c condenser
- 1970 LS5 454 ignition?
- Engine Guru's, I need your help...still can't figure out this tapping noise…
- Help with engine id
- Valve Train Noise
- Exhaust Questions
- Front End/Steering Problems
- Shift kit needed?
- Would rather have an Oil Temp. Gauge instead of a clock ; is this possible on a 1970
- How do you test for which is defective between the water temp. sensor and the guage ?
- Platinum Ir Fusion 3/4 reach Plug?
- exhaust manifold leak help
- Head Warpage
- clock
- 1985 700r4 in a 75 Vette.......
- Will this Edelbrock Air cleaner fitmy L48 1975
- 1980 fuse question
- Bee Jay's Fatass ignition wires
- 82 Emblems in Decal form ??
- engine vacuum
- brake pedal to MC push rod help
- Heater Core rebuild - missing part. Help needed!!
- Rebuilt engine leaking like crazy... need quick help
- Where is the water coming from?
- Wilcox
- 1971 Sill Plate Removal
- Engine Knock on hard acceleration
- Stalling when cruising up hills...
- online maintenance log
- 9.5 fuel pressure
- How the heck do you change the blower motor in an '82?
- 78 L-82 Spreader Bar with Stock Mechanical Fan
- Power Steering Pump Rebuild-78
- Where to buy a lightweight hood?
- Recurved distributor today
- No brake/blink at drivers rear, but others all work
- Do I need to trim my speedo cable?
- New member 82 CE
- Correct Woodruff Key Fluidampr 400sbc ext
- Odd Holley Occurence
- C3 Short Circuit
- C3 differential strength
- What should a gear change cost?
- Need Help w/ID of PS PUMP
- What size Gears?
- 1979 Power Steering hose...
- Old differential side yokes: What to do with them?
- cARB SPACER 1972 LT1
- Wiper Door Hinge removal 71 Model
- Repairing 73 Heater Box
- Is this a test pipe?
- What is the bolt size for securing the seat belt recepticle?
- 1968 front control arm studs?
- Clutchless manuals
- 1971 CORVETTE LIFT and CONDITION ISSUES
- Wipers don't rest
- Heater fan doesn't turn on
