- HELP... Installalling Trans Adapt chrome brackets and not sure how..
- Fast Idol Selonoid Broken??
- '81 Stock, Manual Seats too low
- L-82 Rebuild Advice (1977)
- Squeaky belts
- How to get the seals off the end of the PS cylinder??
- My latest bonehead move...
- Fuses - 1973 vette
- Speedometer cable lubing
- NEED bearing caps for dana 36
- Instead of header wrap...
- Wheel Size?
- Power Steering Control Valve O ring needed
- Anyone FIX a broken 79 seat bottom ?
- New owner 68 Vert - Need interior parts
- Help identtifying a engine
- How to correct over steering?
- install your rear alone, with no heavy lifting
- Year One crate motors - 500hp?
- 68 Ammeter flapping
- 74 350 running hot
- head gasket life
- Mannuel master cylinder for road racing?
- Noise in rear
- Rotor rivet removal
- Need help putting together a top end kit.
- What did I do lol
- How to vent fuel tank?
- just a test......
- New Exhaust Alignment/or Not!!!
- Distributor Rebuilds
- Do ANY parking brakes work well on a C3????
- Electric fuel pump & line mounting
- I need a new floor jack
- C3 Gravity Bleed
- Spreader bar for you BigBlock guys!
- Front Bumper Cover Problems
- got my new aluminum radiator installed!
- $10 ls1 swap gauges speedo and tach
- Interior Paint Match
- 76 auto trans th400 not shifting
- Another "Guess this connector/part" (aka I am old and forget where it goes)
- Gear Drive Question
- Alignment / Caster Question w/pic
- OK, engine guys...what am I doing wrong?
- 1972 454 AC compressor rear mount
- 73 corvette power cuts out to the radio when floored
- Original Valve Covers - 1977? - Easy question for a Vette expert...
- Exhaust Pipe Measurement - ID or OD?
- Head Porting 041 Casting
- RIGHT turn signal won't work?
- 76 won't shift into reverse
- 76 brake console removal help
- rear coupe seat bolts
- Squeaking sound from rear of car @ slower speeds/turns
- About to order a package would like input.
- My tranny lost its home after 40 years!!
- valvoline racing synthetic
- 1963-79 Halfshaft
- 68 positraction
- Rocker arm nuts
- Automatic to 4 or 5 speed??
- 78 ticking sound when steering wheel turned
- OK throw me a bone here
- Short vs Long Water Pump
- Door hinge bushings
- 1979 t-top weather strip
- Should idle speed change when distributor vacum disconnected/connected?
- Heads, oh my!
- Good San Diego paint shop
- Horn relay
- 68 turn flasher question
- reverse light hook up
- What is that switch?
- Pop rivets or SS bolts for Body brackets?
- Installing Kiesler transmission update question
- Power steering control valve balance?
- Question for the Suspension Gurus
- Holley Power Shot Air Filters...installation????
- Axle Code LRW 070E
- rear defrost
- alinment recomendations in NJ
- Edelbrock performer manifold any good
- U-Joint thoughts?
- What are the causes of a too much pressure in upper rad. hose?
- 1972 driveshaft question
- Who is the Quadrajet guru here?
- Another computer tech guy question ???
- Vented or Non-Vented Cap; that is the question...
- Installing shocks
- Second Opinion on a 383 Engine Build Sheet??
- Are these cheap headers any good.
- sounds in reverse
- rear dif help please
- Is it possible to do this?
- Numbers Matching???
- Will the rear spring from an 81 work in a 78?
- felpro 1094 head gasket ?
- Would a bad TPS and/or Ignition Module cause a code 42
- Patriot Side Pipe Heat Shields
- Ammeter/Voltmeter Discharge
- Anyone ever take any material off the brake calipers?
- 74 Coupe rear window seal question
- How do I use a spring compressor
- Idle problem, please help
- Power Steering leak...PLEASE help.
- Stewart Warner 280ED-F temp sending unit
- Radiator & Cooling system - capacity?
- Strange things
- Foose nitrous chrome wheels anyone ?
- L-48 Summit Racing Cylinder Head Combo Advice
- replacing the heater core
- Highly polished caliper... normal?
- heater core
- '75 Vacuum port sizes
- 700R4 code numbers
- Dewitt radiator for '74 454
- Harmonic Balancer for 1975 L48
- Date code for 1970 power steering cylinder
- E-brake handle - Oh no!
- 5 quarts too many for my 76 L-48?
- '76 Alarm Problem
- New Steering Wheel for my 76
- Need help and advice on wheel selection for a C3
- looking for C3 pictures of this rim/tire combo. Will they fit my 76?
- 82 with 81 parts
- 6 Speed Trans upgrade for 74?
- Flushing transmission in 74
- Which Gas Tank?
- If you were going to change the rear springs tomorrow
- 71 Vaccume Tank
- Which flashers were originally on my late 69
- Front bumper brackets
- 4L60 to Replace TH350?
- Parking brake button popped off-how to repair?
- Still overheating about to take heads off.
- Need help with installation of 69 factory sidepipes on a 68 vette
- flashers on 1970
- 82 Fuel pump/relay/pressure problems??
- Summit starter sounds questionable (video)
- Heat sensor installation
- 1970 C3 in Germany
- Help with a 1978
- A/C makes my '75 Coupe Run Hot
- Question about the Borgeson drag link adapter
- Dragging Brake Question
- Holley 4175 guys - quick, easy question
- Drivers side front *thunk*
- any issue with c3 IRS holding up to high HP/ TQ?
- SBC engine setup looking for 350 to 400 hp
- How to get pointed to the #8 plug
- GM Steering Coupler - Rant about grounding
- A/C Blower Motor
- Do I have 75 or 77 Steering Wheel on my 76?
- Clearing the electric choke
- Another Q-jet ??????
- '77 - Exploded view
- 383 stroker with holly carb
- custom headlights
- th350 Trans.
- Difference between gross and net hp
- converting manual brakes to power
- Ignition switch black connector Q
- Brake help
- In need of heads
- 1968 brake problem
- 1969 Seat Track
- Magnaflow XL vs Perfomer Mufflers
- Brake rotor questions
- 1968 427 (3x2) brake problem
- Parking Brake cable replacement
- Vibration at around 50...
- 1972 Backup Light Switch
- timing, bog, no response, help please
- 1972 Rear bearing
- Found a pic of my '70
- Witch bulb will fit my 1968 center console?
- Why this love/hate attitude with a 700R4
- How to pick a torque converter using HP/TQ/Gear ratio
- mystery wires
- overheating
- '75 - How much power?
- '75 e-brake back cables
- Anyone convert from bubble back (78+) to sugar scoop rear deck?
- Looking for new spindle/dust shield gaskets
- Ignition cylinder lock replacement, missing original key
- Looking for a good high performance ignition system
- Headlamp Gnd. physical location ?
- M21 overdrive tranny
- 1970 signal lights
- 69 coupe, Ignition ideas
- Replacing T Top seals, thoughts or tips?
- Thermo Clutch Fan vs a Non-clutch fan
- Third year third engine
- loose wire...
- Sagging Shifter Console?
- Anyone running a T56 - VSS question
- Where to find a PS pump for 79?
- Net HP for 78 vette
- Carb: Not enough fuel?
- Another a/c question
- Radiator flush
- 1969 corvette six pack set up
- Water pump grenade!
- '77 Brakes locking up
- 78 outside door handle difficulty
- Bought a new luggage rack
- How To Test Trailing Arm Bushings?
- codes, codes codes lots of codes
- 71 Fuel tank won't hold 20 gallons
- 1980 brake problems,please help
- Defective Temp sender?
- Non Corvette question about a 440 Chrysler
- Idler Arm and Exhaust Pipe
- My 81 wants to overheat
- How to start a 1976 that has not ran for 15yrs
- side pipes from the catalytic converter
- Heat damage to fiberglass rear spring.
- prothane bushings for my c3 rear controll arms
- q jet
- engine seals
- price of full rebuild 350 ci
- '76 Automatic Park/Neutral Switch
- Pictures of actuator repair
- Best method of cleaning leather seats?
- Charging Issue- 1978
- Door light switches
- Having trouble finding a GOOD thermostat...
- Does the number really matter on a Q-jet?
- Power windows on '76
- strut rod bolts
- 1976 L48 Running Rich
- Best gasketing material between McJacks full length headers and cast iron heads???
- Figure the Odds....
- Engine Identification
- Manual transmission rebuild - BW '79
- Help With A Arm Bush Question Please
- vibration after a restoration
- Ecm 1981
- Fuel line leak..replacement help
- Headlight Warning Indicator ?
- Royal Purple CHEAP!!
- Another Parking Brake Issue - SOOO frusterated
- Replacing the top dash on '73
- Q on door mirror glass replacement
- A.I.R. System
- ???? ss anyone on the edelbrock ias performer shock !
- Pro-systems carb arrived!
- TRANSPAK shift kit......
- 74 Coupe Front Carpet Install
