- 78 only runs with butterfly partially closed
- Body mount spacer issue?
- Correct Oil Weight?
- Licensed AR rims will fit?
- Quadrajet 17054923 vs. 7041213 for 71 4-speed
- Exhaust manafold
- 88 alternator in 73 ll82
- Most HP with crossfire?
- 82 diff front mount bushing/cushion/snubber??
- Normal "trickle" amps when vehicle off?
- 79' gauge cluster flakey
- Rocker Channel/Door Jamb
- Gas smell on oil dipstick
- Thinking about fuel injection TPI guys come in
- wiper door actuator
- Need help bad
- Carbeurator hose
- who's best for building a really strong diff??
- Trying to learn how to post pictures....test
- Tech Help: 72 lost all power while in Reverse?
- 1975 with power issues
- replaced the oil pan gasket and rear main seal 3 times, still leaking!
- super t-10 speedo drive gear
- Headlight test
- Post a picture of your aftermarket gauge installations. How well do they read?
- Back Fire
- Exhaust manafolds
- is a 77 original block safe to build up?
- 68 proportioning valve...
- 79' center console replace or paint?
- Electrical question - need 12v @ run & start
- 1975 ignition starter switch
- Holley carb experts, a quick question, please
- think i have a bad oil pressure gauge
- New Autometer Gauges
- domed pistons?
- Auto Enthusiast Magazine- 427Hotrod's 2500 Mile road trip saga....
- Auto Enthusiast-Shouldn't Be Here-Traccdog-VortecPro-Dewitt's
- [quadrajet] no gas for secondaries?
- Heat Soak or what?
- 1978 Car bogging down - carb issue?
- Battery Cables the Problem?
- OEM Side Exhaust Cover Vibration
- Choke stuck?
- A new high zinc/phos motor oil for flat tappet motors
- 69 427 wS....what would cause a brand new alternator belt to shred?
- "76 Neutral Safety Switch
- T56
- Fiberglas bumpers - how to seal the gap
- Ls engine tranny combo
- Big Block pan and windage tray.....
- Edelbrock carb/air cleaner question?
- Transmission shift lever seal leaking
- Door Latch Spring
- Pegged the temp gauge, damage ?
- T top trim removal
- 2 questions --- warm starting and temperature gauge
- radiator overflow hose connection?
- 1974 temperature senders
- Neutral Safety Switch Wiring Oddity
- going from dot5 to dot 4
- How much voltage from an alternator?
- Hooker Maxflo Sidepipe Muffler performance update
- Starter Heat Shield
- 78' fuel gauge fluxuates
- blown fuseable link?
- Coil voltage
- shifter vibration
- Corvette 1968 rear suspension problem
- tach drive gear bottoming out
- Radiator Help with Advice and Tips....
- Van Steel Rear Coilover Questions
- Pulling engine on 1980 L82
- Rear Wheel Movement
- a few 7'9 questions for a new guy
- Forum Vendors.....Help
- steering coupler not available? options?
- couple questions before i close up the bottom
- 1971 Stalling when Idle
- horn relay
- Quadrajet Idle Stop Bracket
- Oil leak at the distributor to manifold gasket
- ID Quadrajet Carb?
- T-top seals screws stuck
- Fuseable link wire problem
- Jet Carb idle problem
- Window Regulator
- AN Fitting sanity Check
- Still having problems getting this thing to idle
- 79 L82 Engine prices
- Frame Filler / Funky Welds?
- Head Lights Don't Close
- Fog in Window
- Help!! 1969 hood latch problem
- Vented Gas Cap for 1979?
- Gear Ratio question
- 68 Steering Questions
- Carburetor recomendations
- 1974 aim p344?
- Convert from manual to power brakes
- 79 l82
- Distributor cap & rotor install
- Valve Cover Change: need help identifying hoses
- 383 Dyno #s, stock intake & carb?
- Sticky tach (1977)
- Paint or PowderCoat Frame??
- Oil pressure to high??
- Ignition Switch Problem
- Reverse Brake Bleeder?
- Trouble setting timing
- Electrical Problem 1979 Corvette
- 454 front pulley
- Has anyone installed one of these?
- Fuel Tank verification vs guage????
- Max lift on stock Vortecs?
- Does rebuilt 350 need ZDDP?
- 93 Chevy S/10 T5 work in a sb350?
- AutoX Tires
- VBP is now on Facebook!
- 12-bolt Tom's Differential Conversion
- How to change out the A/C Condenser?
- Curious minds..would a 2005 Corvette T56 fit in a '79 C3
- Who makes this hood?
- Sticky for wheel and tires?
- Installing TKO-600 5speed kit into my 71
- timing
- Electric choke Hookup
- Corvette Specialist - Northern VA
- Need tires and have question
- Strange thing happened a few days ago.
- venting gas tank.advise needed
- 69-72 guys with BB, refresh my memory
- 78 SA Turn Signal Lever
- Differential and Trailing Arm Rebuilders in Houston?
- Q-jet starving at 70mph, runs fine at 60mph
- Anyone know where to geta quality parking brake console for a 72?
- potential water leak
- Would a 3000 stall convertor too much for my cam choice
- 82 Vette idling troubles
- Help finding ring & pinion part #'s
- Half Shaft Question??
- power bleeder
- Front brake disc rivets?
- 77- alternator to battery
- 78 steering column
- AC Control Max versus Norm Air Flow
- shift points turbo 400
- Rewired and grounded
- Smog guys really not smart or what?
- Help! my 74 is Overheating
- Tilt/Tel nice and tight.. thx jim shea
- 80/Glass Tops/Windshield Replacement
- Speed Direct light kit
- 77 c3 paint stripping question
- vacum advance can removal on '74 SBC question...
- Too much invested....or destroyed
- speaking of loping...
- AC diversion issue
- Push Button Starter anyone?
- ZZ427 Crate Motor into early C3 ??
- 79 Headlights
- ooops, no brake lights !!!!
- 880 motor questions
- Taillight fuse blowing - oddball fix
- Tires and wheels
- 383 flexplate question with picture
- Can Someone Explain....
- Upgrading to HEI - Firing Order
- Full Length Braided Stainless / AN Fuel Line?
- Tail Lamp Problem
- Rochester Q-Jet Back Barrels Question
- Electrical again, wrenching on road
- Starter/Flywheel questions. 69 coupe(long)
- 5 speed Richmond install
- 1981 has me puzzled
- 1982 crossfire GM reman ECM with hypertech chip
- Torque Converter Bolts
- Rack Attack(ed) - lessons learned
- Lost My Lope
- Blue Light On Console
- fuel pressure after shutdown
- trackday report
- Starting the T-5 WC swap-Camaro hydraulics?
- Looking for 383 Engine Build Suggestions for 71 Vette
- Another brake question
- First Ride after 17 years
- 1972 L48 Piston Dish
- '79 TH350 Auto Fluid Type?
- Oil in # 7 cylinder
- No electrical power help
- 1975 Water Pump
- '71 LT-1 front crossmember replacment teqnique?
- Timing marks
- 1980 Spoiler Part Not in Assy Manual
- STILL will not start...utterly lost
- Slip yoke question
- What Am I Missing? (Cooling system q's)
- Adjustable strut rods.. angled?
- How do I remove this? (picture included)
- starter/battery question -74 454
- 1980 manual trans.-need advise on sidepipes
- New radiator installed
- Brake Caliper Question
- chronic brake SQUEAK... squeak... squeak...
- SB top end noise?
- Q. re Fuel Pump R&R
- Trans. tunnel seal install ?
- Crane cam
- Whale snot?
- did i ever mention how much i hate timing????
- Trailing arm bushing question
- Let's talk about gearing...
- 82 fuel pump
- 1980 hood stuck
- Rear Main Seal options?
- FYI New 6 speed QUAIFE transmission
- I just thought I'd share this Corvette build with everyone
- Wipers not working on 1970.
- 1976 alarm key hole location
- New Calipers question
- Are turbo400 and turbo350 govornors the same?
- Corvette ID Question(mystery numbers)
- rear rotor forzen to spindle
- Leaking Transmission
- Thermo Wrap
- Removing door glass question.
- 81 Corvette A/C Diagram
- Can you 'stroker' a 327???
- T5 guru's needed V6 or V8 URGENT (somewhat)
- '72 4Speed Shifter Linkage Adjustment
- Front Brakes
- My "Zero Loss" air induction project....
- Trans cooler mounting help
- motor misses under load after warm up
- Best Header Gasket?
- problems with new msd 6aL digital with 2 step?
- Q-jet issue
- a strange overheating problem!
- 71 Cranks long time before starting
- 1976 Corvette large rocker switch on center console next to the accelerator pedal.'
- 76 ignition lock cylinder/tach does not work
- options for Krylon 1613 yet?
- Air Filter
- 1976 fuel starvation on full acceleration
- Blower motor
- Shifter handle
- replacement ac for a 1979
- 350 with no leaks
- Oil Sending Unit Wire
- location of holes for sway bar in rear on a 79
