- One or two sealings at the power-valve?
- 68 Wiper Door Opens by Itself..??
- A few questions 79 Corvette
- Power window issues on my 82 help
- Jeep Steering Install
- Who can I sell my old Power Steering Ram to?
- Brake issues
- Willcox fuel gauge procedure question
- Radiator petcock
- How do I remove locking lug nut?
- did I kill the cam?
- 69 starting problem
- 1974 Driver side mirror bolts stripped - please help!
- About to pull the trigger on an Edelbrock
- Brake caliper colour?
- battery drain????
- Add AC?
- Radiator out when doing body off...Should I flush it?
- Holley EFI install-555"- Auto Enthusiast Magazine
- what gear do i have
- Need a measurement on an assembled car.
- little help please
- HD alternator & transmission cooler
- Flush water system?
- 71 LT-1 Won't Start?????
- xs-power pipes headers
- Wheel well caulk?
- Sealing Compound, Cement, Adhesive Help
- Troubleshooting 82 Cross-fire issues
- 1974 specific L82 Carb Question
- Please help with squeaking suspension.....!
- Trans coolant lines. Tips ?
- Front suspension rebuild question
- C3 Corvette Rear Side Glass Weatherstrip Replacement
- Brake Pads/Constant Contact/Generate Heat?
- SS brake line issue
- Big block performer 2.0 vs RPM dual plane?
- steering wheel locking plate re-install?
- Identify Holley carb
- no 'slow' speed in windshield wipers.
- LSx vs. Carb Engines
- Radio questions 68
- Replacement Seats for an '81
- Oil Pressure Gauge '81
- Overheating Mystery 77
- Please help, Bypass radiator trans cooler threads busted is it ok go just external?
- '71 350: Rebuild or Crate?
- Not enough travel in rod for ing. Switch 76 vette
- Got my heads ported - but I have popping at WOT
- service manuals
- Under dash wiring, what is it????
- Battery properly installed
- 74' Vert - tach light out, right blinker (almost) always on
- Contaminated brake fluid
- Speed Direct 15% off summer sale
- rear (differential) crossmember bushing
- Little off-topic on 67 chevelle
- 1982 Corvette crossfire flooding.
- 1982 vapor line.
- Quick master cylinder question
- battery not charging on my 78
- Have you tried a Denso mini alternator?
- how to pick a clutch and pressure plate?
- Tall bigblock valve covers?
- power door locks
- 79' horn blows with turn signals!
- new carb
- 72 LT1 head numbers help
- How much coil to cut - with pic!
- 69 Headlamp Washer Nozzles
- Steering stops, tie rods
- Is this a good cam?
- Parking Brake stuck?
- 427 BB piston ID help
- Distributor alignment
- Rims
- Nose Installation
- mounting bumpers on a 1976
- What size speedometer cable gear ?
- '81 speedo switch
- Will 13 inch rotors fit with the splash shield on?
- Concept One serpentine install....pics
- Getting the fan shroud out
- Holley bowl vent
- Timing question again!!
- Driving 350 with only headers on?
- X or H Pipe on dual exhaust -Vette 81
- 993 heads on 72 LT1
- What are the largest size tires I can run?
- Starter in my 87 has been failing to engage at all when I turn the key.
- 82 tbi connector
- [poll] help me choose an intake, please
- Trouble in River City
- Which cam to get for a crossfire with a renegade?
- Won't stop running
- Hole in piston. Advice needed.
- New engine in 76, high temperatures
- Autocross last weekend
- Flow Numbers - Dart Race Pro-1's before and after mild porting.
- Radiator experts ??
- steel caliper piston or aluminum?
- 1973 engine vacuum question ... PCV delete ?
- Big Block Overheating Issues
- Speedometer gear question
- Temperature Sending Unit
- A little t top help please
- alum rad upgrade
- Which Carb for 81
- Hood sits lower than body
- C3 Fiber Optics
- 68 427 under hood questions
- Caliper Rebuild Questions
- 77 Thermostat Question
- How much torque on clutch pressure plate bolts?
- tune up
- Replacing calipers...how long should it take?
- L88 Road Race wiring and fuel changes
- Those w/ Vintage Air - What Would You Do Different?
- Check Valve vacuum
- Vacuum canister ? I give up !
- Intake manifold
- 71 LT-1 350 with a Holley 670 SA ?
- First Oil Change
- 69 shifter troubles.
- The Speed Demon troubles continue on the 78...Anyone else?
- Can a Rear Spring Have a (-) Arch...
- How much moves the side-yoke of the diff?
- where to start on an 81 Vette?
- Q Jet
- ventilation question
- leaking trans at speedo cable
- Distributor Options Question
- Starter motor cables
- 73 coupe rear window trim...
- CA spray dye.....
- Flywheel/clutch install help
- 68 rear suspension
- ZL-1 stripes
- HVAC controls 74
- Alarm 74
- Power Window Quit
- 76 vet won't start with key switch
- Paint removal from Console
- brake bleeding
- 69 350 vacuum hose to carb and manifold
- Interior lights question
- THIS is why you mock up b4 you coat aftermarket headers
- 76 L48 Vacuum help. Please, I'm learning!
- bladder in motive power bleeder
- Passenger window won't go down?
- shifter installation
- Got The Oil Changed – Now My Blood Pressure Needs Checked!
- Odd electrical
- Heartbreak @ 4:12 PM CST 07/23/11
- anyone running Firehawks Indy 500's?
- Fuel problems - Vapor Lock ??
- Offset trailing arms installed
- 81 hp gain
- Rack and Pinion
- Power Steering Cylinder Seal ??
- '75 L48 Timing Questions
- Fuel line installation question
- msd distributor and tach connecion
- Need a cam recommendation
- Weird turn signal problem.
- 69 brake problem, please help.
- Fuse panel
- SI to CS Alternator Conversion
- New Body Mounts... Now Doors Won't Open/Close.
- Starting Issue
- Is the non-powered antenna flexible ?
- heater shut off valve.
- What is the best oil and weight for a 454?
- Mini Starter fitment issues? Pinion gear to flywheel
- Help me id these el. parts/wires.
- LS1/Mechanical Clutch
- Oil dip stick correct length ??
- Adding a resonator to my 75's exhaust...
- 383 stroker for sale ???????
- prepping heads for por15?
- 78 L48 with a spun rod bearing
- 73 350 with holley fuel line part ?
- What could be causing Lean to one side.
- Ncrs..ls1..1969 !!!!
- Control arms bushings
- EGR - Non-EGR, Does It Make Any Difference
- c3 geometry set up
- 73 a/c not blowing cold
- Big block header issue
- recomended rebuild books?
- head question
- ecklers ball joints
- Outside Door Handle Replacement
- Converting Auto to Manual
- Engine surging then flat at higher RPM's
- Power Steering blowout
- Bid block spark plugs
- Grinding noise in rear end
- Vert cowl under dash braces how could they be fabricated?
- Question on heater bypass
- C3 Brake Help
- Can i get rid of the anoying seatbelt buzzer ? Lube rear new bushings ??
- 73 a/c electrical diagram
- Front End Air Dam Function
- why is the cabin temp so friggin hot on c3s
- Replace rear spring on 73
- 72 p.s. control valve
- Local Phoenix mechanic
- Vacuum reserve tank direction 1982 Corvette
- AFR heads w/ Hooker side exhaust?
- Will this intake manifold fit?
- Need help finding a Jim Shea document
- New Steering Box and Flange replacement
- Now THIS is a freakin' crossmember!!
- Frustrated with '81 (long post)
- Car almost stalls/stalls when turning left.
- Demon Carbs - Coming Back Again!
- Running when in park then wants to die when I put in gear
- 78 oil pressure sending unit fitting doesnt fit
- 10% discount to forum members
- fuel pump 1982- drop tank?
- Jersey Bubba strikes again
- Which heads for '81
- Upper 2 Booster Bolts... Help...
- Strut bushings
- Thanks alot Drawmain
- Someone must have done this
- 1968 driver rear view mirror correct
- 68 BigBlock full header options?
- fuel pump on an 82
- Spindle bolt hole pattern?
- where does this post
- fuel pump on 1982
- Lifting body on a 79, where is the oil gauge pickup tube? a few other ?s as well
- Hooker Header/Sidepipe Paint Options?
- 78 Frame-off restoration/upgrade
- 1973 corvette big block
- HEI Rev Limiter ???
- 4-speed conversion
- Torker II cam?
- Roller Rocker/Push Rod Failure
- LS1 Conversion in a 73 Shark
- 1982 fuel pump
- Steel lug inserts for magnesium wheels
- What Time Is It??
- 4 speed shifter
- Headlight relay question
- C6 suspension kit for c3?
- A/C Job - unusual pressures
- Replace the rear view day nite mirror
