- Identify Quadrajet
- What is the best engine oil for an old stock 350
- Motive brake bleeding question
- engine idle low after valve cover gasket replacement
- Does a ZZ383 fit under a stock hood?
- distributor rebuilding
- going from a gm eliminator to an airgap opinions please.....
- Emblem
- fuel gauge woes
- 302 chevy
- How to rotate engine to check bellhousing runout?
- steering box bolts
- Question about turn signals
- measurment needed
- Cruise control transducer, 1982
- Engine swap
- Reverse Light Switch Rod
- Dish piston volume for 350 V8 ?
- Another outside door handle question....
- 81 rocker arm adjustment
- fuel gage needle swaying
- 79' fan relay or resistor?
- EXACT location of P/W circuit breaker ... PICS ?
- Shocks for a 77
- 1968 427/390 eating voltage regulators
- Neutral/Safety Switch....
- Small Cracks Appearing in Paint at Rear End
- Help with part name
- Removing 1971 Differential and Replacing Seals
- Timing light "scatter" and other timing neophyte issues
- need help 80 vette ac/heat vac diagrams
- Leaking rearend
- Hard Brake Line--what kind?
- What size pushrods???
- Please help identify vacuum switches!
- C3 under-body insulation
- Help identifying vacuum hose
- Spark plug wire dilemma
- wiring diagram for 82 vette heater/ac blower circuit
- window adjustments/etc
- radiator question
- Changing Differential Cover Vent
- Looking For Ground
- 1977 - Radiator Removal
- Castor??
- Delco Cassette problem
- 77 Vette heat/vacuum switch leaking
- Battery drain solved....
- Spun Rear Drive Shaft
- Willwood aluminum calipers
- Electrical Draw
- Power Steering Control Valve - how to?!
- 200 4R Trans
- 1980 Radio wiring issues...
- Failure to start after body off.
- 79 A/C stopped working and my fault...
- Question about lights.
- arp pump bolts
- Power steering control valve, leak
- A little off topic, but........
- HL Relay and Wiper Door Safety Valve testing with New O-ring style Piston
- where does this ground go to again?
- Repeated alternator failure
- front camber maxed
- Ram Horn Identification
- Starter issue
- headers to stock manifold
- Water pump removal
- Boyd Wheels question
- Hey where's that fuel pump install thread ?
- can POR15 engine enamel be sprayed in high humidity?
- 1979 fan clutch
- Parking brake retaining spring tool
- Help! installing chrome alternator in factory location...
- Dewitts Direct Fit Radiator/1979 L82 4 spd
- Dash crack - help
- 70 LT1 Piston Ring Side Clearance
- Hyd roller cam retro fit
- Heater Core Bypass
- A/C and marbles
- Glackore 71 Chassis Dyno- Videos
- Temp gauge gone wild.
- Coasting in drive ?
- Where can I get extra GM key
- Please help to jetting my carb properly
- What do u think this rotational noise is on my 1970 BB ?
- Is there a blower motor in the rear of our cars?
- ZZ3 1995 engine
- Using an adapter for spreadbore carb on a squarebore intake.
- pulling out the engine today!
- carburetor adjustments
- 68 rear wheel bearing!!! SIMPLE!!!
- Does a 1972 sb need a smog pump?
- '81 radio question, serv#20FBCT1
- C4 blower motor info?
- IR temp reading.
- Torque Converter Install and Expectations
- Speedo and tach lights dead
- Front Suspension rebuild complete!!
- Buying a 69 Convertible
- Frustrating Starter issues
- 72 vs 73 radiator
- Brake Bleeding
- Barry Grant 6 Shooter
- Quality brake rotors?
- Tach Problem
- Differential Removal
- Willcox Summer Sale Inclds: Interiors, Weatherstrips, Carpet and 10% off Still On!
- help with power steering on 76
- Can't open hood anymore
- Engine sputter / ping, funny smell and lots of smoke
- New radiator or fix original 69 radiator???
- Leaking heater core??
- Professional Products, Pro Comp and plain old copies...
- Fuel hard line install and mini tool review
- oil filter whoes
- 1974 Fan Shroud Extension question
- rear tires on a 1974
- A/C high pressure side
- Dropping the oil pan in a 69 stingray
- Anyone use Aeroquip StartLite hose?
- DIY side exhaust
- speed-o-meter
- Ok, let's talk about.. Vintage Air on 77+ cars
- my car with hoosier slicks
- 454 starter question...
- ordering my clutch soon, which one? Ram or Mcleod?
- 8 Cam Recommendations From 6 Venders
- Gasoline smell when tank is full..
- squeaky brake
- do we have a LSX swap thread??
- Bad front brake caliper?
- LSX people help. 80 with a 2009 6.0 swap.
- Help.....transmission!
- 75 running issue
- Crate motor
- Breather plus pcv?
- Heater and A/c System Help
- 81 ecm
- Thanks
- Electrical/Wiring Help Needed - Starter
- new paint pic
- 2" air filter element or 3" element?
- trying to start my 383 after rebuild...problems
- ZZ502 Oil Pump Drive Clearance
- Why would someone block the vacuum advance hose?!
- 1974 interior light fuse keeps blowing
- Amsoil Question
- Help!! Brake line leak
- Roger called it - cracked spark plug was my problem
- Exhaust Heat Valve
- brake caliper bleed screw
- b/w super t-10
- electrolyses of alu heads.
- where did you guys put your remote oil filter
- Big Block Heads for 427cu
- Propane??
- Coolant leak, new thermostat house gasket
- Thread lock and sealer on screw in rocker studs
- Glue the front clip back on
- how to properly charge my R12 A/C system?
- Edelbrock Performer Heads Spark Plug
- Correct alternator for 1968 427/390
- How can I tell if I have a flat tappet cam or not?
- Weld repair of '69 posi case
- disconnected yellow wire from console?
- Holley Blue Electric Pump Installed
- R134 pressure
- noise through speakers
- t top weather strips
- B&M (BMM-70244)transmission Lock-up control box?
- 1977 Small Block: Engine block antifreeze drain plugs location
- Pls Help 77 AC VIR Eliminator
- Power Steering Cylinder Rebuild Question
- 1977 AC VIR Eliminator Pls Help
- A/C Questions
- Paint Ideas For A L88 Hood
- Anyone Make a Repro 15x8 Rally Rim, in Aluminum?
- '72 side vent eggcrate replacements
- Correct numbers?
- Question on Carb, #'s
- Header Bar Installation File Now Available
- Muncie Transmission Seals
- Going from carbureted to TPI. Need tips and help please. :)
- block casting # FOR 1972 LT1
- What Axle Ratio Are You LSx Guys Running with a OD Auto?
- L48 Top End Upgrades vs. 383 Stroker
- Installing Edlebrock Performer intake manifold - Do I use rubber end seals or not?
- Bosch Platinum Plus...?
- C3 Coil Springs are easy....now!!!
- 79' pillar interior trim removal?
- wideband O2 sensor location
- Ultimate Air Conditioning Thread AC
- Final Engine thought
- bouncing timing line
- Question for those running Coys wheels
- 200R4 shifter shaft problem
- 400 short block rebuild question
- Hood Release cable and Seat Belt Light Button
- L88 hood suggestions...Got the approval from the boss!
- What is this coffee can looking thing behind my 82's bumper?
- You have to LOVE! mordern era quality control.
- '81 RPM at Speed
- Headlight Problem
- North Dallas Chassis Dyno Recommendation
- Serpentine System - P/S Return line issue
- Exhaust
- bumps across front nose
- Heater core shutoff causing overheating
- mechanical tach cable install
- Wheel bearings.
- Mysterious engine misfire, no solution in sight...
- '78 Headlight Issue
- Brake Lines
- Parking brake question
- How to identify 502 cam
- Hooker Header fitment question
- 1969 Fuel Filter
- Does anybody use this A/F ratio gauge?
- Stereo wiring question
- Parking Brake Light
- `76 C3 with front left calipers locked up
- Help identifying engine and stalling-issue
- rpm drop when ac engaged.
- Major hesistation when pressed
- 68,,,one headlight door won't close,,,
- Starter Solenoid need the big spring? Also wiring pictures anyone?
- Fuel Line Leak
- 1980 HP gain?
- HP gain?
- 1970 SB LT-1 Radiator/shroud problems
- A/C Compressor Clutch
- Something out of wack??????
- Boxing control arms and mounts
- Control valve
- over caulcked back glass
- Water Temp Sending unit.
- 200-4R help please....
- Curious about HP gain when increasing advance
- One or two sealings at the power-valve?
- 68 Wiper Door Opens by Itself..??
- A few questions 79 Corvette
- Power window issues on my 82 help
- Jeep Steering Install
- Who can I sell my old Power Steering Ram to?
- Brake issues
- Willcox fuel gauge procedure question
- Radiator petcock
- How do I remove locking lug nut?
- did I kill the cam?
