- Shimming my starter?
- This is killing me and my battery
- A few more questions from a C3 Newbie.
- windsheild wiper/washer control module/relay
- Compressor Bad?
- how much hp gain with roots sc on stock 81?
- What is this? How do you connect it?
- I didn't know my motor oil could be wrecking my engine
- steering and A/C compressor questions
- Open or Closed Breathers?
- Anyone from Maine ?
- More performance in engine
- Should I use Slick 50 in my vehicle?
- Break issues on a '73
- Cutouts
- Seat belt override relay
- Flywheel Question
- Modding on 98 Octane
- 77 C3 Possible NSS dead
- corvette central center exhaust hangers for duals
- Motor oil lab tests – the new Royal Purple HPS and others
- Windshield trim removal
- Stalls at Idle
- Engine setup question
- I think my 700r4 Transmission is Dying
- Rear End Leaking
- "are you kidding me?!!!!!"
- Spark plug:
- 75 Muffler Hangers ?!?!?
- Engine removal
- divertor valve vacuum hose
- C3 Brake Question
- 1975 L48 running rough causes?
- adapter vs. spacer
- plug wires part number ?
- High Volume Oil Pump Observation
- Speedo Gear Question - 79 reads too slow
- documentation
- Interior help on Long Island
- Mentor
- just wanted to show off. my little project is almost done.
- What's a good connector for the distributor wires?
- carb bog then whoo hoo
- Changing spark plugs
- Rear Spring Adjustment
- 82 Vette-Location of Ignition Coil
- Changing TKO speedo gear for 140mph face
- Quick Electronic Question
- Turbo 350 or 700r4 that is the question
- Tilt Column for a 68
- Front end alignment
- corvette mechanic near 19468 ?
- TH400 Troubles
- Light weight Wilwood front brake kit
- Rebuilding Calipers Question
- 78 restoration
- fan shrould
- Wiring Question?
- 79 Starter Wiring... I'm a dummy
- Aftermarket gauges in C-3
- How Not To Install A Throw Out Bearing
- Muncie Front Shaft Leak
- Will this 75 oil gauge work for a conversion?
- electrolysis rust removal question
- Engine running on [not dieseling]
- Rear Suspension Upgrade advice/experience
- 1973 LS-4 ..... I have a few technical questions.
- TKO 600 fluid leak,,,
- Lucas Oil Additives ????
- 1977 Corvette wiring Basketcase!
- 76 l82
- Help!
- Need advice with headlight vacuum relays - bolts broke
- Under body seat belt reinforcement- 1974
- Grease for front spindles/bearings?
- Need Help with Radiator Clearance from Steel Bumpers & Big Block owner
- 82 vette
- Electric Fan & Alternator
- Need help with engine numbers (1973 454 LS-4)
- turn signal failure
- 71 big block ignition problem?
- 81 Vacuum Problem
- MSD 8362 Street Fire in a '77?
- 1978 radio volume issue
- Cockpit Heat
- Need some C3 Brake Advise!!!
- Cooling a big block in a 1978 Corvette
- speed-o-meter
- Reverse light switch issue with video
- Sorry another wheel question see picture
- What Are The "Must Have" Tools To Work On C3's?
- 330545 Cylinder Heads
- 79' running hot, maybe this is why?
- 81 ignition shield
- Saginaw 4-speed noise
- Starting/electrical problem
- Power antenna fail
- Ready to wrench on the C3 once again
- 79 Corvette just died... Need help
- Hamburger oilpan install: pickup to pan distance?
- 1971 Drain Plug Tricks
- Shift Kits?
- 350 Chevy oil pump shaft slop.
- 82 fuel injectors
- Got's to show off a little
- tracing vacuum leaks..
- C3 '76 Corvette makes scratching/popping sound on back left wheel area
- rear wheel bearing manufacture reference
- Sun Visor
- Anyone have experience with these Halibrand replica wheels?
- new light weight crank shaft
- Antenna wireless switch
- 1969 427 Corvette 4 speed
- Removing AC vs. wiring issues
- what did i do wrong here? headers and alternator mount
- [YAWN]My 383(389) Dyno #s[/YAWN]
- Clutch Release Issue/Feel
- control arm bushings and play in steering wheel
- Holley 4368-1 Carburetor
- Torque value on 1969 rally wheels
- blower works...
- Is It Possible To Change Cam Bearings With Engine In?
- High Quality Clamps - radiator, heater, fuel hoses etc
- Help
- Door
- Help me with my 6.0 T56 build for the 81
- "69 350/350
- need some wiring help
- Transmission Question on Cavalier not Corvette
- how do i replace rear spring cushions
- HELP!! Manual Override Switch
- Muncie Or Saginaw Oil Seal
- wiring diagram
- '81 350 Cam Change
- Holley carb experts needed!!
- 81 Speedo Gears
- Jet Q-Jet Stage 2 - any experience?
- 435 1969 vette vapour lock
- question about setting hydraulic valves
- keisler 5 speed ??
- Electric brakebooster/brakeassist
- New Starter Reinstall - Where does the Ground Cable Go?
- Know of a good speed shop in Westchester NY?
- Odd Coolant Leak
- 82 fuel pump replacement
- New Corvette Owner With A Bunch Of Questions!
- '81 vette throwing codes (or not)
- wiring question
- Specs on a 350 converted to 383
- Help!!!..ticking noise in motor....and...vibration between 40-55
- Pulley Question
- Help with engine miss
- Bubba Tip of the day - Quick heater mod
- LS engine build?
- Squeaky Belt
- Erratic oil gauge
- Another vette bogging under load/accell and running rough
- Why DeWitts?
- Installing Oil Temp Gauge in a ´76
- Synthetic Motor Oil
- replacing rochester to edelbrock on 350
- Please help troubleshooting heater blower
- Horsepower gains
- Power steering pulley alignment
- Pilot bearing grease????
- Tach cable suddenly seems to short?
- Red Fluid Mystery
- MSD Street Fire vs Taylor Street Thunder
- Noise on acceleration
- 1982 Crossfire Injection
- '72 Hood release cable replacement
- carb flooding
- AFR Heads and Edelbrock Air-Gap????
- whats with this state farm pop up
- '72 mystery wire, washer pump?
- Spark Plug
- Line Lock Install in my '77
- T-5 from a Firebird in my C3?
- HEI ticking noise in cap
- Richmond 6 spd & cam change
- flat tappit oil
- 76 wiper motor mechanical operation
- where can i buy?
- Power steering Pulley Install
- New engine time
- please help with Half shaft problem
- tick,tick and faster tick
- 1968 C3 Manual Transmission - Won't Go Into Gear
- Tach problems with my 79
- Advice on buying a '69
- borg warner 4 speed
- Which hood support?
- [IMG]http://i5.photobucket.com/albums/y154/Petes81z/002center cluster bulb won't work
- 75 Speedometer
- 69 SB Harrison Radiator
- 1977 Vette turn signal problem
- alternator
- 78 Climate Control Fan / Blower
- '76 Stingray would not go in reverse...
- Changing Tranny Yoke Seal - 1971
- Headlight Actuator Relays ?
- Looking for 49 state emissions legal exhaust recommendations for 1977 350/350
- First timer Head Gasket replacement
- Can i use a auto frame vs a manual
- Distributor not sitting right on manifold
- New soft top... Care input ?
- Aftermarket AC advice
- Head porting worked - 12.63 in the heat
- slow lights?
- What engine do I have?
- 1970 tachometer conversion
- What operates the 73/74 cowl induction flap?
- Metal Shavings in my SA 670
- trouble installing my first set of headers
- You guys are going to wet your pants.
- HEI distributer module failures
- One Hot 77
- 82 diff Pinion Yoke flange needed
- i want to no everything about my 1980 corvette any help????
- Cooling question
- Headlights pop up
- Is this cause for alarm?
- Diagnose water leak by the headers
- Dart shp
- Throttle cable falling out of pedal - Bubba ftw!
- Yet another power window thread (Yay!)
- 1971 Front Headlight Change
- Amount of Oil in 1971 4 Speed Transmission
- auto trans concern..77
- Does GL5 Already Have Positrac Additive?
- Repairing My Poor Vettes broken nose!
- Hot start issue- minor
- correct fuel delivery components for 350 HO
- what carb for a 1970 454 LS5?
- Which Plug Boots for the Angled Plug Heads
- Ballpark cost to prep small block for ~550hp (& SF Bay shop rec)
- Steering wheel
- window alignment / wrong glass????
- Manual Swap
- [Electrical] Only the brave may enter!
- Heater fan question on an '80
- another vett that wont start
- LS Engine Conversions
- Hot engine - won't start 82 crossfire injection
- Brake Light questions
- Can someone help me identify this part?
- Corvette is not level
- 1977 corvette Tach reading
- Block huggers or Full length headers????
- Teach me about 5pt harnesses
