- Air Conditioning - blower fan
- Testing instruments
- heater... arrghh...
- 1976 Trual Dual Exhaust and Headers
- Strange noise after suspension rebuild
- Mallory Distributor Question
- Fuel Pump Question
- i want a 4th gear on 81 c3, but how to do it?
- Drivers door spring replacement
- 1979 electrical issue
- 1976 C3 - does my gas tank has a hole?
- Where to buy top O-Ring for VIR?
- Strut Rod Question
- It's ALWAYS somethin'........
- LS3 into my 72
- Engine died last night
- Any one here use dyno2000?
- New balancer and timing chain set
- L-81 Smog Pump Repair
- A/C not putting out cold air
- Brake Bleeding Newbie
- C3 Corvette Wanted for Test Fitting New Racing Seats
- My corvette is a victim of "While I'm at it"!
- Opinion? Black carpet in a red interior?
- 79 fuse box question
- The last detail vette parts inc
- sidepipes.. why stop in 74?
- What size offset dowels do you recommend?
- C3 hood support question
- Passenger Side Alternator Mount
- passing gear linkage?
- 82 Vette-Stuttering Wipers
- 82 fan Clutch
- Another stalling issue
- Rear Suspension-Last Refurb of 2011
- 1969 brake master cylinder color
- 100 Degree heat and timing
- Holley transfer slots
- Wrong rear caliper ?
- Stalling Problem
- hydraulic clutch
- Shift Boot
- Where to buy Wiring Harness for 75
- Custom Hoods
- 82 Vette-Exterior Door Handle
- What size exhaust manifold stud lengths for SB?
- Interior repaint
- Starting Electrical Problems UGHHHH
- Power steering weaker after rebuild
- 82 Vette-Starter Problem?
- serpentine question
- Radio Dial Overlay
- '69 Late w/ Behind Wheel Flares Like a '70??
- Where to install cutouts
- ~~~ St Jude Auction #93 Ladies Pink C3 Shirt (Lg) BUY IT NOW PRICE
- '76 clutch fork
- Bad caliper ?
- Composite rear spring heat shield.
- What is a neutral safety switch?
- STP is now constipated
- Painting intake
- Fan= electric or clutch?
- wiper motor wiring?
- Installing screw in studs in Vortec heads.
- Another radiator thread
- Tansmission/engine alignment problem.
- New Corvette Owner
- Longtime C3 owner-Now C2-1963 Grand Sport LS2/T56
- 74 Wiring Issues
- 1968 wiper motor question
- Why is it so hard to find a good machineshop
- Took Motor to the Machine Shop today...
- 81 Rattling/Noise
- What kind of hp gains will I see with these parts?
- Anybody have a 3963569 BB manifold they can measure for me?
- 79 windshield wiper question.
- T-Top Question
- 1981 Door Spring
- T-top trim install
- cant get oil up through my pushrods
- Diff question
- Dust shield installation
- 71 C3 electrical question
- Power Steering pulley rubbing frame
- Where to buy floorpans?
- Hedman Header fitting problems
- A/c and alternator bracket installation help
- Runs rough, sounds "flat"
- Just bought this what kind of return should I expect?
- rear defroster wire location
- 1970 A/C Evaporator Core
- Difference between 1982 fuel pump and 1985 fuel pump
- Rear wheels rocking
- Stuck manifold plug, HELP
- has anybody tried the obx sidepipes?
- Spring plate came off Distibutor shaft...
- 76 header install pics
- Cam Analysis Paralysis
- Longer spring bolts didn't lower my rear ride height
- Trans modulator replace.
- Charging question.
- Electrical thingy - What is this?
- how much more $$$ would you spend for a radiator that is 20% more effecent ?
- Summit header port size
- Interior cockpit lighting
- rear end ratio?
- Engine Temp Gauge not working (1982)
- Here's an idea,battery disconnect with clock power.
- difference 350 vs 400 auto
- Rock guard?
- l82 performance parts
- Proform Heads - Any Experience?
- New CD player for my 82
- Custom 81 Ccrvette w/454BB
- Thermo Housing Gasket
- 1969 corvette 427 3x2 435 vapour lock
- 69 rocker panels
- c2 sidepipe covers on a c3
- paint stripper or sanding???
- concern with my rebuilt motors initial start up
- What does a Charcoal Cannister Do?
- Another Master Cylinder Question
- 82 fuel sock replacement
- Water Injection
- Starter Problems
- v-6 t-5 wc trans
- Any reason not to put on 492 heads
- Can anyone help me out with a part #
- Starter for 69 SB manual w/ AC
- Why would my brakes get "mushy" after a few months
- Engine just quit
- not a corvette clutch problem
- GM385FB, DeWitts Radiator... Will Factory Radiator Hoses work?
- wrong size half shaft strap? Need help.
- 69 hood clearance
- 1980 heat and ac dont work.. Please help
- Spark Plug Wires keep burning out by manifold
- Steering Wheel removal on 1978
- AC question and door handle question
- engine question about egr and efe
- Tail light help!
- Another '71 wiper issue
- Power Steering - Delayed response
- measurment needed
- Anyone have a 1982 vette GM wiring diagram? Horn wiring question
- Rear Wiring Harness - Where do these wires go ? Red plug and yellow wire
- New shocks needed?
- Rear Wheel Wobble (with video)...Please Help Diagnose!
- a little suspension work done
- Gas for a 1969 Corvette
- Brake Hose
- 82 vette-Power Door Lock
- Looking for recommendations on 700r4 kit
- what's this crap in my float bowl?
- 73 350 won't start
- Quadrajet Secondaries
- T56 viper trans for the 81, Strap yoke??
- Rear Script replacement on a 78
- 1979 383 stroker intake?
- How tight on the lug nuts?
- Fender flare protection
- Setting belt tension
- has anyone tried the 2 stage paint from summit?
- 72 ls5 Stock Swaybar Sizes
- new radiator advice
- Spindle bearing rebuild Q
- wilcox sidepipes...
- Question on Coil (+) wiring and no start (long)
- Brake lite Just Came on on my 76
- Back from the dyno with questions
- coutesy light rear compartment
- Holley Carburetor Heat shield
- Good/Bad Corvette Repair Shop in Houston
- 74 Emergency Brake Advice
- TH350 / Radiator Cooler Line fittings
- Electric Fan - "Always On" or "Thermostatic"
- Help with IDing engine
- Rear Caliper Bleeder Problem
- center cluster gauges are pegged all the way to the right?
- 82 fuel pressure guage install
- Exhaust leak
- Torque specs fpr everthing on a C3
- Intake port size
- Engine guys: 383 from a large-journal 327?
- tail light wire color
- 1971 Wiper issues
- Sport Mirror Disassembly?
- mystery engine tuning tips
- Panel Bonding
- 1970 Wiper door closes too soon
- heater blower
- Changing X fire injection into carburator
- belts screaching
- Which Tranny would you go with?
- Who Makes New 4.56 Ring & Pinion???
- wiper motor test?
- ** wtb a supercharger or supercharger kit***
- ZDDP ppm vs Zinc/Phos elemental ppm
- Pulls to the left when braking
- Edelbrock Carb Problems
- Tail light issue... please help!
- a/m f/m c/b
- Oil pump bolt torque on a big block?
- Need Holley 850 Idle Help
- need an alignment in south houston area?
- 1982 Vette-Throttle Bodies
- VB and P customer service??
- 2 bad Edel 1706's in a row or heat soak??
- Exhaust
- Photo/poster contest: submit your entry
- 77 Driver side rear caliper. No fluid on inside bleeder question.
- Who's Selling MOOG frontend Kits and how good is a Fiberglass airdam???
- Power window switch removal
- Advice on this 69 (with pics)
- Changing transmission oil and filter
- Head Light Stuck
- How do I...???
- did i just screw something up in my wiring?
- Auto to Manual trans swap, nss intermittent
- HELP - C3 Big Block Side Pipes... Will these fit ?
- advise
- C-3 race car console pics
- Brakes again
- Brakes again
- Some help with these numbers please!
- How to rebuild L82? Looking for guides
- 1972 lt-1
- Technology challenged
- Slight engine whine after cam swap?
- Headlight vacuum canister patch
- Carpet
- Power brake bleeding tool... S.O.S !
- Trailing arm question
- Weird Distributor/Idle Problem
- Does CTS-V accessory drive fit in C3 frame??
- Technical seat belt installation question
- Are C-3 valve covers aluminum or magnesium????
- Can the flywheel be changed without pulling motor?
- Shimming my starter?
- This is killing me and my battery
- A few more questions from a C3 Newbie.
- windsheild wiper/washer control module/relay
- Compressor Bad?
- how much hp gain with roots sc on stock 81?
- What is this? How do you connect it?
- I didn't know my motor oil could be wrecking my engine
- steering and A/C compressor questions
- Open or Closed Breathers?
- Anyone from Maine ?
- More performance in engine
