- How to hang needle on float-rochester quad.
- Anyone ever used (or heard of) 4X2 intake?
- 71 LT1 Dipstick Length
- 1980 Power Antenae
- How to replace flex plate on turbo 400
- Shift without key in
- power steering pulley help
- Reverse shifter
- Questions about throttle cable, carb and EFI.
- guages eratic
- Neutral Safety Switch and Backup lights adjustment.....how?
- Carb cleaning
- Edelbrock Carb problem
- Secondaries flooding on holley
- Manual to automatic in a C3
- What is the biggest wheel & tire combo
- 1971 LT1 > Fumes Smell?
- crate engine ID
- Power window question
- rear wheels different height?
- Side Window Glass (non-op Doors) DOWN!
- Problem with actuator hose
- Electric fans and A/C
- Aluminum Radiator
- Super T10, how many needle bearings?
- Normal 77 headlight behavior
- Quadra carb
- New member with wiring issues
- Ignition Problem
- Signs of vacum leak
- Changing Engine
- 355 combo intake question
- How to change my tail light on my C3
- Tach
- Steering Box
- SBC Piston ID?
- Rear Bumper Mounting Question
- hot water shut off valve
- Kudo's to Trackdogg2
- Lazy #8 cylinder WTF ?
- 82 ECM use on a carbureted engine
- tire size with steroid steering?
- Best way to get to headlight switch
- Is it feasible to put C5 drive train in an 81 Vette?
- Intake swap = more jet ?
- anyway to bench test a c3's headlight
- filling heat x-over passage in intake manifold
- Suspension improvements "for now"?
- Custom electric headlights + headlight relays
- 71 horn repair = non-stop honking
- Carlisle, good deals to be had for all budgets.
- Which cam?
- Brake Light/Proportioning Valve
- Hot air getting in cabin
- Fusible Link A 1979 C3
- 1973 Tach stopped working...cable broke?
- Wilwood Brakes- 60-0 testing- Auto Enthusiast Magazine
- Future LS swap questions!
- Help Overheating with new engine ALSO
- Some pics of work in progress!
- McJack Headers
- Power steering cylinder
- 82 Vette-Muffler Replacement
- 82 vette-Front Grills Replacement
- New Autofab at work
- TBI spacers
- vacaum hose 1970 corvette
- Heater hose size
- Upgrade drive train to match new motor
- heater vacaum line
- Bpg?
- VanSteel Coilover System - Who has it?
- 1980-1982 Corvette Dyno chart
- mini starter wiring?
- Headlights and wiper door stay up
- Droopy Visors
- Need advice on selecting a carb
- How can I convert to a long water pump (SBC)?
- How do i change cam?
- 1982 crossfire
- 77 vette sounds like a tractor at an idle
- 1969 Corvette Tri Power Stiff Accelerator Pedal-Engine Running
- 1980 new headers and sidepipes-what new wires and plugs should i get
- How to scrap vaccum system 77
- Mirror spacers
- Quick question about o-rings
- Please confirm alternator diagnosis
- 1977 Corvette overheating
- horsepower difference stock intake to lt1
- 1969 L36 with 280H Magnum cam?
- How do I upgrade my rear end 1981 vette
- 78 Pace Car L48 Carburation
- Largest tires with standard trailing arms
- Any one running a Gen Type II power steering pump?
- QUICK DASH QUESTION (working on it this morning)
- Speed--rpm--rear gear
- Interesting Virginia Craigslist items (not mine)
- Yellow paint
- Power steering problem hard right turn
- Help Me Identify This Plug
- yet another start up question
- carb to intake manifold specs
- No Power to car
- Gauge Lights Electrical Problem
- how long will oil pump stay primed
- Racing Oil lab tests - and others
- Richmond super T-10 noise.... its changed.. any ideas before i start trouble shooting
- Spark Issue
- gauge help please
- Cheapest fiberglass bumpers?
- Valve cover question with pics
- Engine hesitation under lite acceleration
- Tranny cooler how big?
- intake manifold restoration
- Interior Door Handle Replacement - HELP!!!
- distributor factory stake marks
- Blockman I need some advice.
- 76 BB blowing oil
- oil pan
- fuel tank 79 corvette
- BB 454 Rebuild
- how to identify motor and tranny...
- C3 Coefficient of drag, frontal area, drive train loss
- Manual transmission linkage
- ??? on the best way to titen up my hanling on my 81 ! ??
- power windows dont work
- Can this be adjusted? [pic]
- 1970 speedometer
- 1968 327/ 350hp engine rebuild
- '81 Windshield Wiper Problems
- Who has 500 horsepower with an electric fan?
- 1973 L82 Stingray
- How many miles this summer ?
- Blower motor replacement
- Comps red break-in lube dripped off
- Performer air gap question.
- 82 Vette-Location of Fuel Pump Relay
- Trailing arms & thrust
- EGR switch
- 76 Won't go into Park
- aircon clutch
- 68 DASH light socket help
- 1969 Corvette 427 400HP or 435hp?
- power brakes question.
- Holley Hi-Tek Air filter....will it fit??
- First Corvette!
- Electrical Problems
- My fire extinguisher mount.
- dove in and removed trailing arm on my 68 today
- What kind of mileage do you get on the highway with your motor/trans/gear combo?
- Wiring issues Electric fan N Water pump
- Are the C3 Gauges accurate
- Q-Jet Question
- Bad Lifter? 82 Corvette
- passing gear linkage?
- U joint greasing
- Interchangeable years for 4 speed equipment in an 80 model
- stahl headers
- 69 Lwr Frt Control Arm Mount Specs
- Sudden Q-Jet cold start problem, 1972
- Where to mount a fire extuingisher
- 1981 Computer
- Will 492 heads work with what I have?
- 3 core to 4 core rad
- auto trans shifting problems
- Help me make the right decission for my fuel line pump to carb
- Temp Sending Unit Removal???
- Trim Ring Repair
- Vanity mirror
- 73 Coolant Tank...creative fix for the aftermarket tank???
- Transmission Leak Confusion
- 68 Headlight Clunk
- Battery Drain issue
- Headers melting plug wires
- wooho new carb or my '69
- help needed with electrical issues in dash!
- What suspension should I go with?
- Split radiator open this afternoon
- Fiberglas crack repairs
- New hood release cable broke
- Aluminum wheel restore.
- Shifter boot question
- Another 81 Timing issue
- performer intake leaking from the block off plate
- Neutral Safety Switch....where is it located??
- Smog Pump Pulley Removal?
- running out of options
- rear wheels freezing
- EGR and vacum hose
- Vintage roadrace wheel questions
- Stripped TH350 transmission bolt
- Vaccum Advance hose?
- Setting timing without timing light
- C3 power window switch troubleshooting
- 1972 corvette Paint
- tuning for my smallblock Vette project
- 68 Parking Brake Consol
- Washer fluid bottle
- tires?
- What heads for 76 L82?
- Electrical gone bad?
- 1978 Rear end ratio
- Seat Belts
- Mcleod 5 speed transmission
- McLeod Twin Plate clutch help
- Factory styled side exhaust fiberglass VS metal covers.
- C3 Roll cage kit?
- Help! What is this thang?
- Damaged Fender
- automatic to manual conversion.
- Location of voltage regulator?
- dipstick tube
- Its amazing what a little work can do
- Altinator is good but wont charge battery
- BBC MSD help
- Air conditioner unit
- Would like a couple pages from the 1981 GM Chassis service manual...
- 1981 Tachometer
- Strut Rod Setting
- Miss at engine operating temperature
- What are these for?
- Is it that easy to get a wiped cam?
- My car keeps shutting off
- Aftermarket Automatic Shifter
- Caliper Recommendations
- Dumb bearing question
- Broken clutch pedal and clutch fork rod
- Low Manifold Vacuum
- rear strut difference? 63-79 and 80-82
- Water leaking from top of exhaust manifold
- Wheel oxidation?
- AC Air Valve
- TH400 converter pump engagement to trans.
- 73 Vapor Canister
- Timing... at 2500 RPM
- The Previous Owners been in here Too!!
- Can't install alternator bracket with new stainless headers
- s it possible to straighten a smog pump pulley?
- 81 Master Cylinder
- HELI COIL help !
- Paging Willcox - tach issue
- Tauk-tauk-tauk valve noise
- Do I need a MSD 6A Box?
- quick ls swap question
- Exhaust Advice
- Instrumentation light bulbs
- 68 wiper motor install followup question
- Hood support question
- Need carb rebuilder contact info
- 82 Collector Hood Decal Removal
