View Full Version : Autocrossing & Roadracing
  1. 305 tires too big for front tires on c6
  2. Oil Cooler Lines
  3. Conversion of Early Dry Sump (8qt) to the Late model (10½qt)
  4. Anybody have a set of Diff mounts laying around???
  5. 18/18 or 18/19 for base C6
  6. GT Track days at Road America June 11 & 12, 2012!
  7. Koni 3013 Questions
  8. May be in Sandiago area - What tracks r around
  9. ACP front splitter overlay...pics please
  10. Halfshaft install...
  11. going to VIR for some r&r
  12. 10/10ths Motorsports Corvette / Viper / Porsche SHOOTOUT :) May 4th
  13. >>>>> St Jude Auction #11 Set of Chrome Grandsport Wheels<<<<<
  14. Corvette Racing Completes Successful Two-Day Test in Sebring
  15. -- [EVENT REMINDER] - Sat, Mar 3rd 10am - MTI Racing's Annual DYNO DAY & OPEN HOUSE
  16. A different race seat question
  17. Hoosier A and R tire heat cycles and performance expectations.
  18. sebring 1st time attendee info ALMS 12 hours race
  19. Anyone going to Sebring this weekend?
  20. F/S - Double Roller Timing Chain
  21. If you drilled the rear backing plate please post.
  22. New at LG Motorsports, race quality filter for your stock LS engine
  23. Harness bars: which gives a good belt mounting angle? Many seem high
  24. Quick Simple Question........
  25. 3 Balls Racing Season Opener at Gingerman
  26. What's the status of Atlanta Motorsports Park?
  27. whats so hard about getting a c4 race ready?
  28. Special deal on Ferodo Racing brake fluid!
  29. Running Sebring in a Stock C5 Z06
  30. C4 abs
  31. Camaro Lost Brakes
  32. 2012 c6r livery
  33. Harnesses and floor mounting
  34. Thinking about coming back to a Corvette for track day fun...
  35. ALMS Sebring Test
  36. Cool thing to have if your Auto Crossing, tracking or dynoing your C5!
  37. Anyone run a wideband? Brand? Pics of install?
  38. How to haul to track day, opinions?
  39. FS: APR Front Splitter for C6 Z06
  40. Best Track tires (non-slicks)
  41. PTA C4 Turn key race car for sale
  42. FS: Recaro PROFI XL
  43. Measure brake pressure (psi)? Which sensor?
  44. Tall Racers, Chime In
  45. Hoosier H WETS for sale..
  46. New Transmission lowers laptimes. Shifts with or without clutch.
  47. Toyo R888's
  48. Chuckwalla Valley Raceway
  49. This is what happens when you get bored on a Sunday............
  50. ***** St Jude Auction #9 "Support Our Troops NASCAR Tire*****
  51. Corner Weighed my FRC...I was surprised.
  52. T1 sways too much??
  53. HPDE Guys who don't run R-Comps... What tires are you running?
  54. Rock auto code needed
  55. F/S - Carbotech Rear Brake Pads
  56. Warning, do not put this brake fluid in your car
  57. Cost of changing race tires?
  58. Best Data Logger for autocross
  59. Burning oil on high G left hand sweepers: solution?
  60. How to instal Corbeau seats, new brackets but keep stock belts for the street ?
  61. Door panel Replacements?
  62. A6 leaks air at bead, no visible problem
  63. FS: Ron Davis Rad - Lap Timer - Canton EPC Valve
  64. Why is my car running rich on the dyno? What temps cause the car to fatten up?
  65. FS: Hawk Pads
  66. German DTM vs ALMS GT
  67. FS: Sparco Wheel etc
  68. C5 (not Z06) in NASA TTA Questions.
  69. Chuckwalla track day 2/25 - $180 (or less) incl. transponder
  70. Z06 oil cooler on a base C6 w/Z51?
  71. HANS for sale
  72. Looking for Discount Drivers School
  73. I got the HPDE BUG.
  74. Big Pine Key made it home....
  75. Slow air pressure leak around rim?
  76. FS Caravaggio Race Seat
  77. NCM announces 2012 VIR HPDE Registration
  78. Do the GM T1 swaybar bushings need any lube?
  79. WTB: Set of Hardbar Seat Mount Brackets
  80. FS: APR GTC 500 Wing for C6
  81. WTB. CCW Corsair(any) 18x11-18x13 with C6Z06/ZR1 offets
  82. No tpms at track question
  83. custom seats used by pros, creafoam
  84. looking for wheels and tire set up
  85. Bolt size - wheel bearings & caliper bracket?
  86. Remote damper reservoir mounting locations -- advice sought
  87. FS: Phoenix C6 Rear Tow Hook
  88. FS: 85 C4 Road Race -Auto X- Land Speed Racer
  89. WTB Used 315/30 18 R6 or A6
  90. Stock leafs and weather
  91. Couple of C5 Corvette road race goodie blogs..
  92. WTB: Borla XR-1 Offroad cat back system
  93. C6 Aluminum Lower Radiator Supports NEW!
  94. Fat Guy needs help.
  95. 10/10ths season starts soon
  96. Tire skipping, steering rack, loose shock, worn tie rod, or balljoints?
  97. ZR-One
  98. F/S: Hoosier A6 315, 18s and 17s. Like New
  99. Shocks - where do I go from here?
  100. Wheel spacers
  101. In Car Video: Cameron Lawrence TA2 car at Petit Lemans Trans Am event
  102. Anyone scuff wheel beads prior to tire install?
  103. Old Autocross Videos
  104. Want To Buy Rotors
  105. WTB rotors
  106. Looking for feedback on Piper Motorsports
  107. T1 Control Arms
  108. 275/35/18 all around on Z06 wheels
  109. 345/30/19 runflats?
  110. WTB: Oil Cooler Kit, OEC for C5 Corvette
  111. ForgeLine GA1R at LG Motorsports
  112. Recaro SPG XL in a C5 Z?
  113. Stock take off C6 Z06 oil cooler with lines
  114. CCW Corvette C6 Z06 Track Corsair C10 18” wheels
  115. Looking to buy some of your leftover stock parts!
  116. How bad did I screw my motor up?
  117. Nordlock washers for wheel bearing size?
  118. LS 7 maintenance question
  119. Corvettes in NASA ST1 Question
  120. What's up with John B Tires?
  121. Rear LCA poly bushing install solution
  122. Alignment question with poly control arm bushings
  123. Anyone make a good Car cover for a C6 w/wing?
  124. race seat mounts...?
  125. And you only thought you were fast...
  126. FS - C5 Hardbar harness bar
  127. 2 seat DP car at Daytona..to awesome not to share
  128. quick disconnect brake lines
  129. F/S: Brand New Wilwood PolyMatrix Front Brake Pads, C5 Z06
  130. F/S: Brand New Wilwood PolyMatrix Front Brake Pads, C4 Corvette
  131. What happended to the DP Corvettes?
  132. Johnny O'Connell VP at Bondurant
  133. FS - C6Z Brake Parts
  134. f/s Spring Mountain Driving school gift card
  135. European Camaro Cup at Sebring and PBIR
  136. Why Corvette and not Chevrolet or GM?
  137. Rolex 24 better than i ever imagined...
  138. Corner Weighting
  139. TTA to PTA build
  140. C7 Z06 frame ??
  141. New undertray and transponder location
  142. DP(Dayton Prototype) Corvettes......why? who builds them? ...........................
  143. GM Track Car?
  144. Rolex Daytona 24 SPOILER alert.....don't look
  145. Race Technology DL1 MK3 ??
  146. What are the optimal alignment/susp specs for my c6?
  147. Exhaust Wrap On a Race Car?
  148. Tire size question
  149. Tie Rod End Dust Boots
  150. Aero question
  151. Pictures from Daytona Tonight
  152. Tunnel Plate. Worth the investment?
  153. Pictures from Daytona today
  154. Wanted to buy
  155. Will C6 Z06 oil cooler work on C5 LS1/LS6?
  156. anybody get a ftd in a c5 autocrossing with a a-4
  157. Any Streaming Links for Daytona?
  158. Selective ride Yes or No?
  159. C6 Camera bar?
  160. Hankook RS3 guys.... whats your PSI?
  161. Corvette DP car at Rolex 24 practice 1/26
  162. NASA Road Atlanta - March 9-11: who's going?
  163. C6 Z51 Front Spring Question
  164. WTB front splitter
  165. C5Z rear wheel stud replacement
  166. Have you tracked/raced on a repaired rim?
  167. FS:4 New Kumho V710 0n speedlines
  168. Daytona 24 - 1 Corvette in GT
  169. where to plasti-dip for autox races
  170. F/S: Hoosier A6 295 35 17 (pair)
  171. FS: 1967 Vintage RR Autocrosser
  172. sequential gearbox for ls7
  173. 1962 Daytona Continental
  174. 2009 Z51 smooth rotors for track?
  175. Northwoods Shelby Club at Road America, July 27-29
  176. Evo school Phase 1 and 2 on the same weekend?
  177. 2012 Trackday Schedule - MTI Racing
  178. Bilstein Xtreme Valved Shocks For an 88
  179. did every body get the datona email???
  180. Rolex live timing
  181. I need your vote!!! Vote for Corvette
  182. How About the Ultimate Racing Simulator Cockpit?
  183. how often do you change your valve springs?
  184. Race seat drivers, stock passenger for track days - opinions?
  185. Tow Hooks. Any easy way to install on front of my C6
  186. everybody going to Datona Needs to email me
  187. LG Billet Spindles for Street, Road Race, or Drag racing.
  188. FS Hoosier A6 315 30 18 and 335 30 18
  189. Chevy Press Release for Rolex 24
  190. FS Hoosier NARRA 335 30 18 slicks with 6 laps on them
  191. A Great Guy and Fellow Racer Lost Yesterday
  192. Need rollbar/cage pictures/help
  193. 24 Hour Rolex , tickets selling out
  194. When will it end..... Areo mods
  195. FS Stainless Works 1-7/8" Headers for LS3
  196. A&A Corvette autocross videos. 1/22/2012.
  197. wtb C5 front brake cooling kit.
  198. Oli's Crazy "Flying Hood" Incident
  199. FS: GTC-500 APR Wing
  200. Annual radiator maintenance - what to do?
  201. Daytona 2012, Friday Continental race.
  202. Your thoughts on cargo carrier vs trailer.
  203. Does the Louver Hoods really help with the heat?
  204. FS: R&D Racing Cross-bar w/camera mount
  205. lingenfelter mini tubs
  206. Autox. Passenger with a bad back?
  207. T1 Corvettes at Cal Speedway for Season Opener (Vids)
  208. Trade for Hoosiers... HP elite 8100 i5 3.33Ghz, 8gb ram, 500gb hd.
  209. F/S - Everything...no more racing for awhile
  210. FS: Carbotech XP12/10 for C6Z/GS - padlets
  211. 17" AR wheels and Hoosier R6's
  212. crap got to go to Rolex 24 for work!!!
  213. Katech track attack 2012
  214. Delrin A-Arm Maintenance and Reliability?
  215. Do you guys re-use ARP studs when swapping hubs?
  216. Single Wiper Conversion
  217. Oli Needs a New Hood for his C5 T1 race car... video to follow!
  218. FS: APR GTC-300 Wing w/ Gurney Flap
  219. Should I go lower than 27"/28" ride height
  220. Track day in my c6, should i add oil?
  221. Anyone replace the snap ring on the shock shaft?
  222. Energy Suspension upper balljoint boot... smush it in there or trim it?
  223. Please help me win a new set of track wheels
  224. Front lower balljoints so tight even the OEM Kent Moore tool won't pop them???
  225. GoPro released a new camera.
  226. 2 Quart Accusump
  227. Fuel Tank Crossover install
  228. Noise from the rear
  229. WTB 295/35/18 or 305/18
  230. FS: C5 harness bar and harnesses
  231. Corner weight compromise?
  232. Is anyone doing the Track day Feb 11th at Thunderhill
  233. Finspeed: Oil Cooler Insert and Mesh Grill !!
  234. New AIM Solo lap timer
  235. Anybody Have Any Experience With Borla XR-1 Racing Mufflers?
  236. New Orleans track event March 24-25 on brand new track!!
  237. Cobra Suzuka Pro GT Racing Bucket Seat manufactured 03/2009
  238. C6Z06 Street/Road Race from LG Motorsports 570 rwhp package
  239. Corvette Racing Announces 2012 Driver Pairings
  240. Club Racing entry fees?
  241. Turn One pump c5 z06 users
  242. Cobra Crash at Willow Springs
  243. Star Car Sports and Chuckwalla Valley Raceway
  244. Corvette Corral at Rolex
  245. BlingMaster Aluminator Polish Now Available at VetteNuts!
  246. Stock C6 (or Z) vs C5 (or z) with Tires and Brakes
  247. Kumho XS
  248. SBC Oil Pump for a Race Car? Opinions?
  249. [POLL] NASCAR and St. Jude Auction
  250. 2012 KY Region schedule
